[Ovmsdev] little problem/feature needed/debug
    William Petefish
    william.petefish at gmail.com
    Fri Feb 17 22:34:45 HKT 2012
Mark,
Will Do.
Waiting on it now.
I'll run a test after I get out of my first class.
William
On Fri, Feb 17, 2012 at 8:25 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> Michael,
> I just tried from the iPhone App I'm working on, and all seems ok.
>    - Car was not charging, standard mode with limit 13A on a 70A HPC.
>    - I sent a charge mode command to RANGE mode, and car switched to
>    range mode, started charging at 13A and reported charging,range.
>    - I sent a charge mode command to STANDARD mode, and car switched to
>    standard mode, while charge continued at 13A and reported as
>    charging,standard.
>    - I sent a charge limit command to 32A, then car sent back limit 32A
>    and within a few seconds increased the current at the car to 32amp.
>    - I sent a charge limit command to 70A, then car sent back limit 70amp
>    and within a few seconds increased the current at the car to 70amp.
> Sonny says he has fixed the Android App charge mode and the version in the
> market should be ok now. Can you try that?
> If the new version has not yet been released, perhaps selecting
> performance mode will enter range mode (assuming 3=2 and 4=3)?
> On 17 Feb, 2012, at 9:35 PM, Mark Webb-Johnson wrote:
> Michael,
> I tried issuing the commands manually on the can bus and can switch modes
> shown on the VDS.
> N.B. There is a bug in the Android App on the marketplace - it gets the
> mode numbers wrong (I guess 0..3 not 0,1,3,4).
> I'm implementing this in the iPhone App tonight, so should be able to test
> later.
> On 17 Feb, 2012, at 9:11 PM, Michael Stegen wrote:
>  I can confirm that switching between charge modes does not work 100%.
> I tried switching to range mode, and then start charging from the app.
> The battery indicator in the car changes, i.e. the top of the battery is
> visible.
> Range does not change, also charge mode visible on the VDS does not change
> (still standard charging)
> On the (Android) app , it's shows the same. After i stopped the charging,
> i received a SMS that does not start with Range - or Standard -
> just "Charging Stopped, ideal range ..etc"
> Tonight i'll try to send the commands manually on the CAN bus, to see if i
> see any difference in behaviour.
> Btw, i do receive a "Hello World" push message on my android phone, but
> not on the Ipad.
> I'm not using any testflight version anymore, but the one from the
> appstore.
> Btw2, when a charge is stopped, i used to receive a push message + SMS,
> this somehow does not work anymore for me. I only receive the SMS
> Btw3, the car powers up fine, and starts charging, even if left unused
> (but connected) for over a day.
> -Michael
> Op 17-2-2012 8:06, Mark Webb-Johnson schreef:
>   P.S. Could someone fix the display so it reads Range Mode instead of
> Standard Mode when switched from standard to range? (Much appreciated.)
>  Is this Android App?
>  If so, Sonny (again): modes are 0=standard,
> 1=storage,3=range,4=performance
>  P.S. What happened to mode 2? Did there used to be a mystery fifth mode?
>  On 17 Feb 2012, at 2:59 PM, William Petefish wrote:
>  Mark,
>  Yes, fully repeatable, reproducible, and verifiable.
>  When not woken up first, none of the commands work.
>  I will restart the module and try further.
>  It will disarm the alarm and allow it to be driven.
>  William
> On Fri, Feb 17, 2012 at 12:51 AM, Mark Webb-Johnson <mark at webb-johnson.net
> > wrote:
>> William,
>>  Is it repeatable?
>>  ie; plug in, stop charge. wait 5 minutes until coolant pump turns off,
>> then try start charge from the app.
>>  Also, are other commands working (like lock/unlock)?
>>  After setting the feature for write-enabled CAN bus, you need to
>> restart the module. If not, none of the commands will work. If at least one
>> of the commands is working, then that is fine.
>>  Regards, Mark.
>>  P.S. Not wishing to hijack this thread, but since you are in the USA -
>> could you test the lock/unlock commands for us on your US car? Supposedly,
>> the US cars don't have an immobiliser so that the UNLOCK command will
>> disable the alarm and allow the car to be driven. Please try and let us
>> know.
>>   On 17 Feb 2012, at 2:35 PM, William Petefish wrote:
>>  Mark,
>>  Yes, I did and to no avail. I had purposefully let the car sit until it
>> went into power save mode and tried again, no joy.
>>  Might it have something to do with the new FW on the roadster? (4.6.4 I
>> think is the FW that is on mine.) My roadster is a 2.5.
>>  William
>> On Fri, Feb 17, 2012 at 12:29 AM, Mark Webb-Johnson <
>> mark at webb-johnson.net> wrote:
>>> William:
>>>  Current (1.2.0-rc3) code is:
>>>   void can_tx_setchargecurrent(unsigned char current)
>>>   while (TXB0CONbits.TXREQ) {} // Loop until TX is done
>>>   TXB0CON = 0;
>>>   TXB0SIDL = 0b01000000; // Setup 0x102
>>>   TXB0SIDH = 0b00100000; // Setup 0x102
>>>   TXB0D0 = 0x05;
>>>   TXB0D1 = 0x02;
>>>   TXB0D2 = 0x00;
>>>   TXB0D3 = 0x00;
>>>   TXB0D4 = current;
>>>   TXB0D5 = 0x00;
>>>    TXB0D6 = 0x00;
>>>   TXB0D7 = 0x00;
>>>   TXB0DLC = 0b00001000; // data length (8)
>>>   TXB0CON = 0b00001000; // mark for transmission
>>>    can_tx_wakeup(); // Also, wakeup the car if necessary
>>>  void can_tx_wakeup(void)
>>>    TXB0CON = 0;
>>>   TXB0D0 = 0x0a;
>>>   TXB0DLC = 0b00000001; // data length (8)
>>>  That should work. Pre-rc3, I used to see this, but since rc3 it has
>>> been ok for me.
>>>  Maybe the bus was busy and lost the wakeup message? Did you try
>>> sending any other commands, or repeating the start charge command?
>>>  What is the version of your car (2.x or 1.5?).
>>>  Regards, Mark.
>>>  P.S. There is also a specific command C,18 that calls the CAN wakeup
>>> function. Not sure if the Android App supports it or not.
>>>   On 17 Feb 2012, at 2:22 PM, William Petefish wrote:
>>> Mark,
>>>  Feature Needed: Wake Up command.
>>>  I tried to send the start charge command from my android phone and it
>>> wouldn't start to charge or change charging mode, etc. without being woken
>>> up by opening/closing the doors/trunk/remote/etc.
>>>  I am using the latest release (1.20) and the Android app.
>>>  William
> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
> Stegen Electronics
> Kwartslaan 95
> 3162 RD Rhoon
> The Netherlands
> Tel: +31 10-5016960www.stegen.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120217/643ba5af/attachment.htm>
