[Ovmsdev] PUSH notifications
Fri Feb 17 08:52:18 HKT 2012
I found an issue with the developer build of push notifications under iOS. It was not a code problem - just the wrong certificate specified for code signing. I also found that the PUSH certificates were not installed on the production tmc.openvehicles.com server (64.111.70.40).
So, two questions:
For those of you using the iOS TestFlight release against www.openvehicles.com server, do PUSH notifications work for you? Do you get a notification of charge complete/done when you are not running the App? A simple way to test is to send an SMS to your car "HELLO WORLD" - you should get a PUSH notification back with the content of the unrecognised SMS. Can you test this, and let me know if it is ok?
For those you using the iOS TestFlight release against tmc.openvehicles.com, can you test PUSH notifications now, to see if they work? A simple way to test is to send an SMS to your car "HELLO WORLD" - you should get a PUSH notification back with the content of the unrecognised SMS. Can you test this, and let me know if it is ok?
We're getting ready for production now, and need to cross the T's and dot the I's.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120217/3d08ea5d/attachment.htm>
