[Ovmsdev] 1.2.0-rc3
Tue Feb 14 21:09:54 HKT 2012
Michael,
I'll check the PUSH on 202.52.42.80.
The iOS Simulator doesn't work with PUSH notifications. It is an Apple restriction. The PUSH notifications only work with physical devices.
P.S. Yes, the new GUI looks amazing - thanks to Felix B, not me ;-)
> From: "Michael Gerber gerber energie systeme" <michael.gerber at gerber.tv>
> Subject: AW: [Ovmsdev] 1.2.0-rc3 tire pressure monitoring system
> Date: 14 February, 2012 3:49:07 PM GMT+08:00
> To: <ovmsdev-bounces at lists.teslaclub.hk>
> Mark,
> Thanks - moved yesterday evening to dev (202.52.42.80) server – works fine – but sill no push messages
> I also tried the iOS Code released on Github with the Xcode iOS simulator – also no push
> The new GUI looks fantastic!!!
> All the best
> Von: ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
> Gesendet: Dienstag, 14. Februar 2012 03:44
> An: OVMS Developers
> Betreff: Re: [Ovmsdev] 1.2.0-rc3 tire pressure monitoring system
> Michael,
> Thanks for the feedback.
>> -         my EU 2.5 Roadster Sport have no tire pressure monitoring system installed, the iOS App shows invalid temp an pressure values
> Seems to be an invalid tpms record (dating back to  2012-02-08 15:35:58). I have cleared it.
> -         Not able to receive any PUSH Messages via the iOS App, maybe a configuration or server (64.111.70.40) issue …
> Yes, that server has not been provisioned for PUSH yet. The main 202.52.42.80 server should be ok (and I think you've switched to that one).
> -         I enabled the CAN write Feature by sending “FEATURE 15 1” SMS command – but how to check if it’s enabled?
> The Android App on the store supports this today. The iOS App is a little behind (but will look better when done) - I should have a testflight release later this week.
> On 14 Feb 2012, at 12:39 AM, Michael Gerber gerber energie systeme wrote:
> Hi all,
> yesterday I flashed the new 1.2.0-rc3 firmware, while testing I found some issues:
> <image001.jpg>
> But hey – great work!
> mit sonnigen grüßen vom kaiserstuhl, with sunny regards
> Michael Gerber
> Geschäftsführer
> <image003.jpg>
> gerber energie systeme gmbh
> Coulonger str. 8
> 79346 Endingen, Germany
> Telefon: +49 (0) 7642 92118-22
> Telefax: +49 (0) 7642 92118-18
> Mail michael.gerber at gerber.tv
> http://www.gerber.tv/
>  This message may contain confidential or privileged
>  information and is intended only for the use of the
>  addressee named above.  If you are not the intended
>  recipient of this message,  you are hereby notified
>  that you must not use, copy, disclose  or take any
>  action based on this message or information herein.
>  If you have received this message by error, please
>  advise the sender immediately and delete this message.
>  Thank you for your cooperation.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120214/d58cb0bb/attachment-0001.html>
