[Ovmsdev] OVMS OBDII Cables now available
    Sun Dec 30 00:01:32 HKT 2012
I like it. Looks neat.
Really glad I found that right-angled OBDII connector - although a little bit more money, I think it makes a big difference given where the OBDII ports are in most vehicles.
On 29 Dec, 2012, at 8:40 PM, mikeljo at me.com wrote:
> Hi mark,
> nothing with customs. ;-)
> I think the quality is ok.
> The length is for normal use ok, but for my development is a little bit short. My module is in the moment behind the Driver seat. This is NO Problem!!
> When the module is installed in the dashbord the length is ok.
> Here is a Pic:
> <IMG_1087.jpeg>
> With the cable to the side, it is out of the way. Secure from my feet.
> Bye
> michael
> Am 28.12.2012 um 17:40 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>> Michael,
>> Thanks for testing this. I hope you didn't get too much hassle at customs.
>> What do you think of the cable? Good enough for the job?
>> On 28 Dec, 2012, at 8:14 PM, mikeljo at me.com wrote:
>>> Hi all,
>>> Cable received.
>>> Tested and it Works.
>>> Bye
>>> Am 19.12.2012 um 09:20 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>>>> We received the cables yesterday, and they look good. The factory seems to have done a good job. I tested 5 - all ok - and even put one in my wife's Nissan to power up an OVMS module. Now, if only her car had a can bus :-(
>>>> OVMS vehicle cables for connection to can-bus equipped OBDII vehicles are now available from our FastTech logistics partner. You can find them here:
>>>>     OVMS OBDII Cable @FastTech
>>>> This cable connects the OVMS module to the vehicle CAN bus, via the industry standard OBDII socket. It is 1 metre in length, and uses a right-angle OBDII plug (J1962-M) to help with cable management and routing.
>>>> The cable is intended to be used in Renault Twizy, Chevy Volt, Opel/Vauxhall Ampera, and other cars using OBDII connectors.
>>>> OVMS OBDII Cable Pinout
>>>> J1962-M   DB9-F   Signal
>>>> 4         3       Chassis/Power GND
>>>> 6         7       CAN-H
>>>> 14        2       CAN-L
>>>> 16        9       +12V Vehicle Power
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121230/75b62e8b/attachment.htm>
