[Ovmsdev] Wrong Roadster Data
    Tom Saxton
    tom at idleloop.com
    Mon Dec 17 00:07:41 HKT 2012
Opening the door didn't help.
I was wondering if I was getting data from another Roadster, so I checked
the Location view. It's showing the spot where the car was parked yesterday
afternoon, and in fact all of the data is consistent with that: SOC and
locked status. Since then, the car has been driven twice and charged, so
plenty of opportunity to get current CAN bus readings.
The other odd thing is that it shows it's been parked for 5 minutes every
time I update it.
The only thing unusual yesterday was that I realized I hadn't locked the car
a couple of minutes after we parked, so I used OVMS to lock the car, and
checked the Car view to confirm it was locked.
Could that have frozen things for some reason?
I'll try rebooting the car module before I drive it this morning.
    Tom
on 12/16/12 6:29 AM, Mark Webb-Johnson wrote:
> Tom,
> I just checked the server logs, and the car seems to be online.
> 2012-12-16 09:22:12.710176 -0500 info  main: #65 C SAX217 msg handle S
> 73,M,-1,0,stopped,standard,135,105,32,254,100,29,7,14,0,1,200,1
> It is reporting 73%.
> Maybe some issue with the message reception on the can bus? Can you try
> opening a door with the app running, and see if it registers?
> [Michael, working on the Twizy, found an issue where the can bus buffers could
> overflow, causing no more can messages to be received - I haven't seen it on
> the Roadster before, but it is possible this is what you are seeing]
> On 16 Dec, 2012, at 10:23 PM, Tom Saxton <tom at idleloop.com> wrote:
>> There's something odd going on with OVMS and my Roadster this morning. I'm
>> seeing data that claims to be live, but which is totally wrong.
>> I got home last night with a 50% charge and set the Roadster to charge at 2
>> am. When I checked it this morning at 6:20, OVMS said the car was at 73%,
>> live, parked for 5 minutes, and locked. When I checked the car, none of
>> those were true. The car's at 97%, has been parked 9.5 hours, and is
>> unlocked.
>> I've never seen OVMS be wrong and claim to be "live".
>>    Tom
