[Ovmsdev] Twizy module 2.1
Mon Dec 10 08:50:09 HKT 2012
Looks good. I'll try to merge it in.
What is the status of Twizy support now, in your opinion? Is it stable and usable?
I put up a page at:
http://www.openvehicles.com/vehiclesupport
Here's a summary of the vehicle support we have in OVMS at the moment. Functionality for the Tesla Roadster v1.x and v2.x is pretty much complete (although we have lots of ideas for add-on functionality) and support for other vehicles is in progress.
Note that functions marked "experimental" and "development" may not be in the main code repository yet - we recommend you check with the developers mailing list for up-to-date status and code location for these.
Function Tesla Roadster v1.x Tesla Roadster v2.x Volt/Ampera Renault Twizy
Status Released Released Development Development
Firmware 1.2.2 or later 1.0.0 or later VA experimental RT experimental
Hardware v1 or v2 v2 or v2 v2 v2
Module OVMS Module v2 OVMS Module v2 OVMS Module v2 OVMS Module v2
Vehicle Cable OVMS Data Cable OVMS Data Cable Not available (yet) Not available (yet)
GSM Antenna OVMS GSM Antenna OVMS GSM Antenna OVMS GSM Antenna OVMS GSM Antenna
GPS Antenna Not Required Not Required OVMS GPS Antenna OVMS GPS Antenna
Firmware Tool PICKIT 2 PICKIT 2 PICKIT 2 PICKIT 2
SOC Display Yes Yes Yes Yes
Range Display Yes Yes Not yet Yes
GPS Location Display Yes (car gps) Yes (car gps) Yes (OVMS gps) Yes (OVMS gps)
Speed Display Yes Yes Not yet Not yet
Charge Status Display Yes Yes Not yet Yes
Charge Interruption Alerts Yes Yes Not yet Yes
Charge Control Yes Yes Not yet Not yet
Lock/Unlock Control Yes Yes Not yet Not yet
Charge Mode Control Yes Yes Not yet Not yet
Cabin Pre-heat/cool Not possible Not possible Not yet Seriously? No
Digital Speedo Yes Not yet n/a n/a
Does that seem accurate? Anything to add/remove.
I think the v2 branch is stable now, and what we are working from, so perhaps it is time to merge it back into mainline head...
On 9 Dec, 2012, at 8:39 PM, Michael Balzer wrote:
> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/e527b90883353f32da0f60d09c871333dc2c4646
> - temperature function updated to new formula (A - 40)
> - cell alert thresholds changed to fixed absolute deviations
> 3 °C temperature / 100 mV (watch thresholds = stddev as before)
> - battery monitor reset now bound to "key on" event
> instead of full charge cycle
> - cell mean value / deviation calculations now done with rounding
> - battery text alert now also sent by MSG protocol ("PA")
> and triggered immediately after every alert status change
> - Twizy battery monitor compiler switch: OVMS_TWIZY_BATTMON
> current ressource usage: 6% RAM (193 byte) + 10% ROM
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121210/9f2fa94b/attachment.html>
