[Ovmsdev] Twizy module 2.1
Tue Dec 11 02:23:53 HKT 2012
Mark,
stable & usable, with battery monitor enabled as well.
For the vehicle support table: speed display is also working -- if you
mean feeding "car_speed". The old App shows this on the second tab.
Also "charge mode control" and "lock/unlock control" would be "n/a" for
the Twizy. LOL on "seriously?" btw :-)
How about adding a row "special features"? For the Twizy that would now
contain:
- Individual max range config
- Charge alerts on SOC/range
- Battery health monitoring
I also vote for merging v2 into the master, I have been using only v2
lately.
Am 10.12.2012 01:50, schrieb Mark Webb-Johnson:
> Looks good. I'll try to merge it in.
> What is the status of Twizy support now, in your opinion? Is it stable
> and usable?
> I put up a page at:
> http://www.openvehicles.com/vehiclesupport
> Here's a summary of the vehicle support we have in OVMS at the
> moment. Functionality for the Tesla Roadster v1.x and v2.x is
> pretty much complete (although we have lots of ideas for add-on
> functionality) and support for other vehicles is in progress.
> Note that functions marked "experimental" and "development" may
> not be in the main code repository yet - we recommend you check
> with the developers mailing list for up-to-date status and code
> location for these.
> Function Tesla Roadster v1.x Tesla Roadster v2.x Volt/Ampera
> Renault Twizy
> Status Released Released Development Development
> Firmware 1.2.2 or later 1.0.0 or later VA experimental RT
> experimental
> Hardware v1 or v2 v2 or v2 v2 v2
> Module OVMS Module v2
> <http://www.fasttech.com/products/1099/10000001/1000300-ovms-car-module-v2>
> OVMS Module v2
> OVMS Module v2
> OVMS Module v2
> Vehicle Cable OVMS Data Cable
> <http://www.fasttech.com/products/1099/10000001/1000400> OVMS
> Data Cable
> <http://www.fasttech.com/products/1099/10000001/1000400> Not
> available (yet) Not available (yet)
> GSM Antenna OVMS GSM Antenna
> <http://www.fasttech.com/products/1099/10000001/1000500> OVMS GSM
> Antenna <http://www.fasttech.com/products/1099/10000001/1000500>
> OVMS GSM Antenna
> GPS Antenna Not Required Not Required OVMS GPS Antenna
> <http://www.fasttech.com/products/1099/10000001/1020200> OVMS GPS
> Antenna <http://www.fasttech.com/products/1099/10000001/1020200>
> Firmware Tool PICKIT 2
> <http://www.fasttech.com/products/1099/10000001/1002200> PICKIT 2
> SOC Display Yes Yes Yes Yes
> Range Display Yes Yes Not yet Yes
> GPS Location Display Yes (car gps) Yes (car gps) Yes (OVMS
> gps) Yes (OVMS gps)
> Speed Display Yes Yes Not yet Not yet
> Charge Status Display Yes Yes Not yet Yes
> Charge Interruption Alerts Yes Yes Not yet Yes
> Charge Control Yes Yes Not yet Not yet
> Lock/Unlock Control Yes Yes Not yet Not yet
> Charge Mode Control Yes Yes Not yet Not yet
> Cabin Pre-heat/cool Not possible Not possible Not yet
> Seriously? No
> Digital Speedo Yes Not yet n/a n/a
> Does that seem accurate? Anything to add/remove.
> I think the v2 branch is stable now, and what we are working from, so
> perhaps it is time to merge it back into mainline head...
> On 9 Dec, 2012, at 8:39 PM, Michael Balzer wrote:
>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/e527b90883353f32da0f60d09c871333dc2c4646
>> - temperature function updated to new formula (A - 40)
>> - cell alert thresholds changed to fixed absolute deviations
>> 3 °C temperature / 100 mV (watch thresholds = stddev as before)
>> - battery monitor reset now bound to "key on" event
>> instead of full charge cycle
>> - cell mean value / deviation calculations now done with rounding
>> - battery text alert now also sent by MSG protocol ("PA")
>> and triggered immediately after every alert status change
>> - Twizy battery monitor compiler switch: OVMS_TWIZY_BATTMON
>> current ressource usage: 6% RAM (193 byte) + 10% ROM
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121210/0cefbc6e/attachment-0001.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121210/0cefbc6e/attachment-0001.vcf>
