Return-Path: <ovmsdev-bounces@lists.openvehicles.com>
Received: from network-box.com ([unix socket])
	 by nbmailhq5.network-box.com with LMTPA;
	 Thu, 17 May 2018 10:22:58 +0800
X-Sieve: CMU Sieve 2.4
Received: from nbmailscanhq5.network-box.com (unknown [10.12.18.182])
	by network-box.com (Postfix) with ESMTP id C9515403A18B
	for <mark.johnson@network-box.com>; Thu, 17 May 2018 10:22:58 +0800 (HKT)
Received: from nbmailhk1.network-box.com (localhost [127.0.0.1])
	by nbmailscanhq5.network-box.com (Postfix) with ESMTP id 9AE17A15EA
	for <mark.johnson@network-box.com>; Thu, 17 May 2018 10:22:56 +0800 (HKT)
Received: from unknown (EHLO nbmailhk1.network-box.com) (10.8.12.9)
  by 127.0.0.1 (Network Box) with SMTP id
 '35da105a-5979-11e8-8728-7e2b5a688fa9'; 17 May 2018 02:22:58 -0000
X-Scanned-By-nbmailscanhq5: eMail scan performed by network-box
X-Scanned-By-nbmailscanhq5: Network Box scan job
 35fe948e-5979-11e8-8728-7e2b5a688fa9
X-Scanned-By-nbmailscanhq5: Network Box message id
	by nbmailhk1.network-box.com (Postfix) with ESMTP id 54EAC9004B
	for <mark@webb-johnson.net>; Thu, 17 May 2018 10:22:56 +0800 (HKT)
Received: from charged.hk (localhost [127.0.0.1])
	by nbmailscanhq5.network-box.com (Postfix) with ESMTP id 29FBEA148D
	for <mark@webb-johnson.net>; Thu, 17 May 2018 10:22:54 +0800 (HKT)
Received: from unknown (EHLO charged.hk) (10.12.12.188)
 '34581966-5979-11e8-8728-7e2b5a688fa9'; 17 May 2018 02:22:56 -0000
 3483e370-5979-11e8-8728-7e2b5a688fa9
Received: from [10.12.12.188] (localhost [IPv6:::1])
	by charged.hk (Postfix) with ESMTP id CD96080C3209;
	Thu, 17 May 2018 10:22:53 +0800 (HKT)
X-Original-To: ovmsdev@lists.openvehicles.com
Delivered-To: ovmsdev@lists.openvehicles.com
 by charged.hk (Postfix) with ESMTP id F2EEF80C3206
 for <ovmsdev@lists.openvehicles.com>; Thu, 17 May 2018 10:22:52 +0800 (HKT)
Received: from [10.8.2.100] (localhost [127.0.0.1])
 by nbmailscanhq5.network-box.com (Postfix) with ESMTP id CDD23A148D
 for <ovmsdev@lists.openvehicles.com>; Thu, 17 May 2018 10:22:50 +0800 (HKT)
Received: from unknown (EHLO [10.8.2.100]) (10.8.2.100)
 '3260165e-5979-11e8-bc2d-7e2b5a688fa9';
 17 May 2018 02:22:52 -0000
X-NetworkBox-Signature-Group-NBHQ: 0501; GROUP; NBHQ; nbmailscanhq5;
 5f807f87e3ee1abc656824757c2e72b78c10b3a3d4e7fe436f9d8a276ab99468
 3289eab0-5979-11e8-bc2d-7e2b5a688fa9
Mime-Version: 1.0 (Mac OS X Mail 11.3 \(3445.6.18\))
Message-Id: <56C111E5-AC24-4BE2-8800-61616261D757@webb-johnson.net>
Date: Thu, 17 May 2018 10:22:49 +0800
To: OVMS Developers <ovmsdev@lists.openvehicles.com>
X-Mailer: Apple Mail (2.3445.6.18)
Subject: [Ovmsdev] SD CARD speed vs cp2102
X-BeenThere: ovmsdev@lists.openvehicles.com
X-Mailman-Version: 2.1.15
Precedence: list
List-Id: OVMS Developers <ovmsdev.lists.openvehicles.com>
List-Unsubscribe: <http://lists.openvehicles.com/mailman/options/ovmsdev>,
 <mailto:ovmsdev-request@lists.openvehicles.com?subject=unsubscribe>
List-Archive: <http://lists.openvehicles.com/pipermail/ovmsdev/>
List-Post: <mailto:ovmsdev@lists.openvehicles.com>
List-Help: <mailto:ovmsdev-request@lists.openvehicles.com?subject=help>
List-Subscribe: <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>,
 <mailto:ovmsdev-request@lists.openvehicles.com?subject=subscribe>
Reply-To: OVMS Developers <ovmsdev@lists.openvehicles.com>
Content-Type: multipart/mixed; boundary="===============3083041437029062667=="
Errors-To: ovmsdev-bounces@lists.openvehicles.com
Sender: "OvmsDev" <ovmsdev-bounces@lists.openvehicles.com>
--===============3083041437029062667==
Content-Type: multipart/alternative;
	boundary="Apple-Mail=_EB7CB4E2-AA24-4719-B238-F6D6B040E0EA"
--Apple-Mail=_EB7CB4E2-AA24-4719-B238-F6D6B040E0EA
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
	charset=utf-8
Good grief. A year into this, and still writing about SD CARD issues =
with ESP32. If I could get into a room with the engineer who decided to =
share boot strapping pins with SDCARD pins, and to hard wire the SDIO =
controller to specific pins, I would literally try to slap some sense =
into him.
The China guys and I have been struggling for the past couple of months =
trying to work out why we can=E2=80=99t get as much speed out of the SD =
CARD as we wanted. If we raise the speed to the normal 20MHz, we =
randomly get errors (timeouts, checksums, etc). It looked like =
interference on the bus lines, but scoping those we can=E2=80=99t find =
any. Dropping the speed to 16MHz works around the issue, but SD CARD =
accesses are slow.
Then, we worked out it wasn=E2=80=99t random. It was based on whether we =
were powering from USB or external 12V. On the bench it works fine. In =
the car the problem appears. Simply put, if the USB was plugged in the =
=E2=80=98interference=E2=80=99 disappeared. If USB was unplugged, it =
came back. USB + external 12V combination also didn=E2=80=99t suffer =
from the issue, so the problem is not coming from the 12v side. The =
issue often appeared on only the second test of SD CARD, not the first. =
We didn=E2=80=99t see this problem on either the v3.0 developer modules, =
or v3.1 prototypes.
We looked at the capacitors and pull-up resistors on that side of the =
circuit, without success. Whatever we did made little difference (or =
randomly changed things for the better/worse). We thought maybe =
ground-line interference, but nope. We spent some time looking at C20, =
C22, C23 to see if the manufacturers had messed up the component values =
- they hadn=E2=80=99t.
Anyway, to cut a long story short, we finally found the culprit. The =
CP2102 chip itself.
We=E2=80=99d already had to change the power supply design early on in =
the project to cope with a bug in CP2102 not correctly handling USB host =
disconnect and not properly going into suspend mode (to reduce power =
consumption of cp2101 circuit when usb was disconnected) - our current =
design completely powers down the cp2102 chip when the USB cable is =
disconnected. Michael Stegen had previously warned me about clones of =
this chip (see https://wiki.sha2017.org/w/Projects:Badge and what they =
went through), and we had added the extra resistor already to cope with =
that eventuality. But, from what we can tell this is not a clone part =
issue. Here is what we found:
OVMS v3.0 and early v3.1 prototypes use CP2102 v1412+. For that chip, =
when the USB cable is disconnected, CSL-TXD is 3.3v.
OVMS v3.1 first production batch use a newer CP2102 v1708+. For that =
chip, when the USB cable is disconnected, CSL-TXD is pulled down to =
0.78v.
We have replaced the cp2102 on a v3.1 first production module with =
v1412+, and SD CARD resumes normal operation (even with usb =
disconnected).
The version number seems to be a date code. YYWW (year, week), I guess.
We have absolutely no idea why this would be affecting the SD CARD =
performance or interference. Somehow, that CSL-TXD line is going through =
the ESP32 chip and affecting the  SDIO controller (perhaps related to =
the bootstrapping pins dual use). The interference we see is inside the =
ESP32, not on the lines going from ESP32 to the SDCARD (which is why we =
couldn=E2=80=99t see it on the scope).
I tried shutting down the pins on the ESP32 for CSL-TXD and CSL-RXD, to =
see if I could work around the problem in firmware, but couldn=E2=80=99t =
get it to work. There is no way of knowing whether the USB is connected, =
and even if we did know, setting CSL-TXD and CSL-RXD pins to output =
mode, or float, doesn=E2=80=99t seem to make any difference.
The good news is that we=E2=80=99ve at least identified the problem. We =
are (a) checking the revision of cp2102 chip in the upcoming production =
batch, and (b) changing QC procedures to set SD CARD bus speed to =
default (20MHz) and randomly test modules twice on 12V power. Latest =
production batch is now using v1742+, and that has been tested as =
working. Going forward, we can resolve this.
As for the first production batch units, they are what they are. For =
normal SD CARD operation (copying files, flashing firmware, etc), it =
makes little difference. I guess most users don=E2=80=99t even have an =
SD CARD inserted. The speed limitation really only becomes an issue if =
you are trying to log lots of data to SD CARD (such as CAN bus dumps). =
If the USB is connected, you can 'config set sdcard maxfreq.khz 20000=E2=80=
=99 and it will work faster. The CP2102 chip can be changed, and I=E2=80=99=
ll do that for anyone that needs it. I=E2=80=99m asking China to send me =
some from the latest production batch that we know works. Replacement is =
relatively straightforward, but involves micro-soldering (the cp2102 is =
a surface mount chip, very small footprint, with lots of other =
components near it on the board).
Content-Type: text/html;
	charset=utf-8
<html><head><meta http-equiv=3D"Content-Type" content=3D"text/html; =
charset=3Dutf-8"></head><body style=3D"word-wrap: break-word; =
-webkit-nbsp-mode: space; line-break: after-white-space;" class=3D""><div =
dir=3D"auto" style=3D"word-wrap: break-word; -webkit-nbsp-mode: space; =
line-break: after-white-space;" class=3D""><div class=3D""><br =
class=3D""></div><div class=3D"">Good grief. A year into this, and still =
writing about SD CARD issues with ESP32. If I could get into a room with =
the engineer who decided to share boot strapping pins with SDCARD pins, =
and to hard wire the SDIO controller to specific pins, I would literally =
try to slap some sense into him.</div><div class=3D""><br =
class=3D""></div><div class=3D"">The China guys and I have been =
struggling for the past couple of months trying to work out why we =
can=E2=80=99t get as much speed out of the SD CARD as we wanted. If we =
raise the speed to the normal 20MHz, we randomly get errors (timeouts, =
checksums, etc). It looked like interference on the bus lines, but =
scoping those we can=E2=80=99t find any. Dropping the speed to 16MHz =
works around the issue, but SD CARD accesses are slow.</div><div =
class=3D""><br class=3D""></div><div class=3D"">Then, we worked out it =
wasn=E2=80=99t random. It was based on whether we were powering from USB =
or external 12V. On the bench it works fine. In the car the problem =
appears. Simply put, if the USB was plugged in the =E2=80=98interference=E2=
=80=99 disappeared. If USB was unplugged, it came back. USB + external =
12V combination also didn=E2=80=99t suffer from the issue, so the =
problem is not coming from the 12v side. The issue often appeared on =
only the second test of SD CARD, not the first. We didn=E2=80=99t see =
this problem on either the v3.0 developer modules, or v3.1 =
prototypes.</div><div class=3D""><br class=3D""></div><div class=3D"">We =
- they hadn=E2=80=99t.</div><div class=3D""><br class=3D""></div><div =
class=3D"">Anyway, to cut a long story short, we finally found the =
culprit. The CP2102 chip itself.</div><div class=3D""><br =
class=3D""></div><div class=3D"">We=E2=80=99d already had to change the =
power supply design early on in the project to cope with a bug in CP2102 =
not correctly handling USB host disconnect and not properly going into =
suspend mode (to reduce power consumption of cp2101 circuit when usb was =
disconnected) - our current design completely powers down the cp2102 =
chip when the USB cable is disconnected. Michael Stegen had previously =
warned me about clones of this chip (see&nbsp;<a =
href=3D"https://wiki.sha2017.org/w/Projects:Badge" =
class=3D"">https://wiki.sha2017.org/w/Projects:Badge</a> and what they =
issue. Here is what we found:</div><div class=3D""><br =
class=3D""></div><div class=3D""><ol class=3D"MailOutline"><li =
class=3D"">OVMS v3.0 and early v3.1 prototypes use CP2102 v1412+. For =
that chip, when the USB cable is disconnected, CSL-TXD is 3.3v.</li><li =
class=3D"">OVMS v3.1 first production batch use a newer&nbsp;CP2102 =
v1708+. For that chip, when the USB cable is disconnected, CSL-TXD is =
pulled down to 0.78v.</li><li class=3D"">We have replaced the cp2102 on =
a v3.1 first production module with v1412+, and SD CARD resumes normal =
operation (even with usb disconnected).</li><li class=3D"">The version =
number seems to be a date code. YYWW (year, week), I guess.</li><li =
class=3D"">We have absolutely no idea why this would be affecting the SD =
CARD performance or interference. Somehow, that CSL-TXD line is going =
through the ESP32 chip and affecting the &nbsp;SDIO controller (perhaps =
related to the bootstrapping pins dual use). The interference we see is =
inside the ESP32, not on the lines going from ESP32 to the SDCARD (which =
is why we couldn=E2=80=99t see it on the scope).</li></ol></div><div =
class=3D""><br class=3D""></div><div class=3D"">I tried shutting down =
the pins on the ESP32 for CSL-TXD and CSL-RXD, to see if I could work =
around the problem in firmware, but couldn=E2=80=99t get it to work. =
There is no way of knowing whether the USB is connected, and even if we =
did know, setting CSL-TXD and CSL-RXD pins to output mode, or float, =
doesn=E2=80=99t seem to make any difference.</div><div class=3D""><br =
class=3D""></div><div class=3D"">The good news is that we=E2=80=99ve at =
least identified the problem. We are (a) checking the revision of cp2102 =
chip in the upcoming production batch, and (b) changing QC procedures to =
set SD CARD bus speed to default (20MHz) and randomly test modules twice =
on 12V power. Latest production batch is now using v1742+, and that has =
been tested as working. Going forward, we can resolve this.</div><div =
class=3D""><br class=3D""></div><div class=3D"">As for the first =
production batch units, they are what they are. For normal SD CARD =
operation (copying files, flashing firmware, etc), it makes little =
difference. I guess most users don=E2=80=99t even have an SD CARD =
inserted. The speed limitation really only becomes an issue if you are =
trying to log lots of data to SD CARD (such as CAN bus dumps). If the =
USB is connected, you can 'config set sdcard maxfreq.khz 20000=E2=80=99 =
and it will work faster. The CP2102 chip can be changed, and I=E2=80=99ll =
components near it on the board).</div><div class=3D""><br =
class=3D""></div><div class=3D"">Regards, Mark.</div><div class=3D""><br =
class=3D""></div></div></body></html>=
--Apple-Mail=_EB7CB4E2-AA24-4719-B238-F6D6B040E0EA--
Content-Type: text/plain; charset="us-ascii"
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
OvmsDev mailing list
OvmsDev@lists.openvehicles.com
--===============3083041437029062667==--
