I (1290) cpu_start: ELF file SHA256: 96d26c67fedbd772... I (1296) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (0) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2181) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2187) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (45) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Power cycle reset detected I (71) events: Initialising EVENTS (1200) I (75) config: Initialising CONFIG (1400) I (81) time: Initialising TIME (1500) I (84) script: Initialising SCRIPTS (1600) I (89) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (94) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (100) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (106) metrics: Initialising METRICS (1810) I (112) metrics: Expanding DUKTAPE javascript engine I (117) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used I (139) notify: Initialising NOTIFICATIONS (1820) I (141) notify: Registered notification type info I (141) notify: Registered notification type error I (145) notify: Registered notification type alert I (150) notify: Registered notification type data I (156) notify: Registered notification type stream I (161) notify: Expanding DUKTAPE javascript engine I (167) location: Initialising LOCATIONS (1900) I (175) location: Expanding DUKTAPE javascript engine I (178) vehicle: Initialising VEHICLE Factory (2000) I (189) tls: Initialising TLS (3000) I (190) pcp: Initialising POWER (4000) I (192) max7317: Initialising MAX7317 EGPIO (4200) I (198) sdcard: Initialising SD CARD (4400) I (203) ota: Initialising OTA (4400) I (209) canformat: Initialising CAN Format Factory (4500) I (213) canformat-cs11: Registering CAN Format: CS11 (4505) I (219) canformat-crtd: Registering CAN Format: CRTD (4505) I (225) canformat-gvret: Registering CAN Format: GVRET (4505) I (232) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (238) canformat-panda: Registering CAN Format: PANDA (4505) I (245) canformat-pcap: Registering CAN Format: PCAP (4505) I (251) canformat-raw: Registering CAN Format: RAW (4505) I (257) can: Initialising CAN (4510) I (269) dbc-app: Initialising DBC (4520) I (272) canlog: Initialising CAN logging (4550) I (273) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (279) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (288) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (296) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (301) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (311) canlog-vfs: Initialising CAN logging to VFS (4560) I (314) canplay: Initialising CAN play framework (4570) I (320) canplay-vfs: Initialising CAN playing from VFS (4580) I (327) cellular: Initialising CELLULAR (4600) I (333) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (338) cellular-modem-auto: Registering auto-detect modem driver (4650) I (346) SIM5360: Registering SIM5360 modem driver (4650) I (352) SIM7000: Registering SIM7000 modem driver (4650) I (358) SIM7600: Registering SIM7600 modem driver (4650) I (364) SIM7670: Registering Simcom A7670E modem driver (4660) I (370) tpms: Initialising TPMS (4700) I (375) test: Initialising TEST (5000) I (380) module: Initialising MODULE (5100) I (385) vfs: Initialising VFS (5200) I (389) ovms-server: Initialising OVMS Server (6000) I (394) ovms-server-v2: Initialising OVMS V2 Server (6100) I (401) ovms-server-v3: Initialising OVMS V3 Server (6200) I (407) vehicle-poll: Initialising Poller (7000) I (414) obd2ecu: Initialising OBD2ECU (7000) I (418) canopen: Initialising CANopen (7000) I (426) pluginstore: Initialising PLUGINS (7100) I (428) esp32wifi: Initialising ESP32WIFI (8000) I (433) ovms-mdns: Initialising MDNS (8100) I (437) webserver: Initialising WEBSERVER (8200) I (445) ssh: Initialising SSH (8300) I (447) powermgmt: Initialising POWERMGMT (8500) I (452) re: Initialising RE Tools (8800) I (459) pushover: Initialising Pushover client (8800) I (464) netmanager: Initialising NETMANAGER (8999) I (471) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (474) v-zeva: Registering Vehicle: ZEVA (9000) I (479) v-vweup: Registering Vehicle: VW e-Up (9000) I (485) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (492) v-track: Registering Vehicle: TRACK (9000) I (498) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (505) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (511) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (518) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (525) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (531) v-smarteq: Registering Vehicle: SMART EQ (9000) I (537) v-smarted: Registering Vehicle: SMART ED (9000) I (543) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (550) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (557) v-twizy: Registering Vehicle: Renault Twizy (9000) I (563) v-obdii: Registering Vehicle: OBDII (9000) I (569) v-none: Registering Vehicle: NONE (9000) I (574) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (580) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (590) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (596) v-mgev4: Registering Vehicle: MG4 (9000) I (601) v-mgev: Registering Vehicle: MG5 (9000) I (606) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (613) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (619) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (625) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (631) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (637) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (644) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (650) v-maple60s: Registering Vehicle: Maple 60S (9000) I (656) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (663) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (670) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (677) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (684) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (691) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (697) v-energica: Registering Vehicle: Energica (9000) I (703) v-demo: Registering Vehicle: DEMO (9000) I (709) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (715) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (723) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (730) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (736) v-boltev: Registering Vehicle: Bolt EV (9000) I (742) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (747) version: Initialising Versioning (9900) I (758) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (838) ovms_main: Executing on CPU core 0 I (838) ovms_main: Mounting CONFIG... I (958) ovms_main: Configure logging... W (968) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (968) ovms_main: Registering default configs... I (968) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (968) ovms_main: Starting HOUSEKEEPING... I (988) housekeeping: Initialising HOUSEKEEPING Framework... I (988) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2158) pluginstore: Loading enabled plugins (2) I (2158) pluginstore: Load retools web page /plugins/retools I (2158) pluginstore: Loading enabled plugins (3) D (2168) events: Signal(housekeeping.init) I (2168) housekeeping: Executing on CPU core 1 I (2168) housekeeping: reset_reason: cpu0=1, cpu1=14 I (2178) housekeeping: Starting PERIPHERALS... I (2178) peripherals: Initialising OVMS Peripherals... I (2188) peripherals: TCP/IP Adaptor I (2188) peripherals: ESP32 system I (2198) peripherals: SPI bus I (2198) peripherals: MAX7317 I/O Expander I (2208) peripherals: ESP32 CAN I (2208) peripherals: ESP32 WIFI I (2218) peripherals: ESP32 ADC I (2218) peripherals: MCP2515 CAN 1/2 I (2218) mcp2515: can2: SetPowerMode off I (2308) peripherals: MCP2515 CAN 2/2 I (2308) mcp2515: can3: SetPowerMode off I (2388) peripherals: SD CARD I (2388) peripherals: CELLULAR MODEM I (2388) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2398) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2408) cellular: Starting modem task I (2408) uart: queue free spaces: 50 I (2408) ext12v: Powering off external 12V devices I (2418) housekeeping: Auto init max7317 (free: 160936 bytes) I (2428) housekeeping: Auto init ext12v (free: 160936 bytes) I (2428) housekeeping: Auto init dbc (free: 160936 bytes) I (2438) housekeeping: Auto init wifi (free: 160936 bytes) I (2438) housekeeping: Auto init modem (free: 160936 bytes) I (2448) housekeeping: Auto init Pollers (free: 160936 bytes) I (2448) cellular: Set modem driver to 'auto' I (2458) housekeeping: Auto init vehicle (free: 160936 bytes) I (2458) cellular: State: Enter PowerOffOn state I (2468) v-none: Generic NONE vehicle module I (2468) cellular-modem-auto: Power Cycle I (2478) housekeeping: Auto init obd2ecu (free: 149136 bytes) I (2478) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2488) housekeeping: Auto init server v2 (free: 149136 bytes) I (2498) housekeeping: Auto init server v3 (free: 149136 bytes) I (2508) housekeeping: Auto init javascript (free: 149136 bytes) I (2518) housekeeping: Auto init done (free: 149096 bytes) I (2518) housekeeping: Starting USB console... I (2528) uart: queue free spaces: 100 D (2538) events: Signal(egpio.output.1.low) D (2538) events: Signal(power.cellular.on) D (2538) events: Signal(system.modem.stop) D (2548) events: Signal(vehicle.type.set) D (2548) events: Signal(egpio.output.0.low) D (2548) events: Signal(system.start) I (2558) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-426-g56a6a42b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (2568) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> I (2698) ovms-duktape: Duktape: Initialising module system I (2878) pluginstore: Loading enabled plugins (1) OVMS> D (4178) events: Signal(vehicle.aux.12v.low) OVMS> D (4998) events: Signal(egpio.output.0.high) OVMS> I (7178) sdcard: SD CARD has been inserted OVMS> I (7398) sdcard: mount done D (7398) events: Signal(sd.insert) OVMS> D (9178) events: Signal(sd.mounted) I (9198) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (9998) events: Signal(egpio.output.0.low) D (10198) events: Signal(egpio.output.0.high) D (10198) cellular: State timeout PowerOffOn => PoweringOn I (10198) cellular: State: Enter PoweringOn state I (10198) cellular-modem-auto: Power Cycle I (10198) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10198) events: Signal(system.modem.poweringon) D (10198) events: Signal(egpio.output.0.low) OVMS> D (12698) events: Signal(egpio.output.0.high) OVMS> D (17698) events: Signal(egpio.output.0.low) D (17898) cellular: tx-cmd: AT D (17898) events: Signal(egpio.output.0.high) D (17898) cellular: tx-cmd: AT D (17898) cellular: tx-cmd: AT I (17898) cellular: State: Enter Identify state D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM OVMS> D (18178) cellular: tx-cmd: AT+CGMM I (18188) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (18188) cellular: Remove old 'auto' modem driver I (18188) cellular: Set modem driver to 'SIM7600' I (18188) cellular: State: Enter PoweredOn state D (18188) events: Signal(system.modem.installed) D (18188) events: Signal(system.modem.poweredon) OVMS> D (28178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (28208) cellular: mux-rx-line #0 (2/120): OK D (28208) cellular: mux-rx-line #0 (124/0): AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (28208) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (28208) cellular: mux-rx-line #0 (10/6): +CSQ: 14,0 D (28208) cellular: Signal Quality is: 14 (-85 dBm) D (28208) cellular: mux-rx-line #0 (2/0): OK OVMS> D (29488) cellular: mux-rx-line #0 (10/0): +CSQ: 19,0 D (29488) cellular: Signal Quality is: 19 (-75 dBm) OVMS> D (30178) cellular: tx-cmd: AT+CGMR;+ICCID D (30188) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (30188) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (30198) cellular: mux-rx-line #0 (2/0): OK OVMS> D (38178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (38188) cellular: mux-rx-line #0 (2/0): OK I (38188) cellular: State: Enter MuxStart state V (38188) cellular: Starting MUX D (38188) events: Signal(system.modem.muxstart) OVMS> D (39178) cellular: State transition MuxStart => NetWait I (39178) cellular: State: Enter NetWait state V (39178) cellular: Starting NMEA D (39178) cellular: mux-tx #1: AT+CGPS=0 D (39178) events: Signal(system.modem.netwait) OVMS> D (41178) cellular: mux-tx #1: AT+CGPSNMEA=258 D (41198) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (41218) cellular: mux-tx #1: AT+CGPS=1,1 D (41218) events: Signal(system.modem.gpsstart) D (41218) cellular: mux-rx-line #1 (2/0): OK D (41218) cellular: mux-rx-line #1 (2/0): OK D (41218) cellular: mux-rx-line #1 (2/0): OK D (41228) cellular: mux-rx-line #1 (2/0): OK OVMS> D (49178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (49198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 I (49198) cellular: Network Registration status: RegisteredRoaming D (49198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (49208) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (49208) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:26:15+04" D (49208) cellular: mux-rx-line #3 (10/6): +CSQ: 19,0 D (49208) cellular: mux-rx-line #3 (2/0): OK OVMS> D (49498) cellular: mux-rx-line #3 (10/0): +CSQ: 19,7 OVMS> D (50178) cellular: mux-tx #3: AT+CPSI? D (50178) cellular: State transition NetWait => NetStart I (50178) cellular: State: Enter NetStart state D (50178) events: Signal(system.modem.netstart) D (50188) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-80,0,27-27 I (50188) cellular: Network Mode: GSM,Online D (50188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (51178) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (51228) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (51228) cellular: PPP Connection is ready to start OVMS> D (51498) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 OVMS> D (52178) cellular: State transition NetStart => NetMode I (52178) cellular: State: Enter NetMode state V (52178) cellular: Launching PPP V (52178) cellular: Starting PPP I (52178) gsm-ppp: Initialising... D (52188) events: Signal(system.modem.netmode) I (52308) gsm-ppp: StatusCallBack: None I (52308) gsm-ppp: status_cb: Connected I (52308) gsm-ppp: our_ipaddr = 10.170.195.13 I (52308) gsm-ppp: his_ipaddr = 10.64.64.64 I (52308) gsm-ppp: netmask = 255.255.255.255 I (52308) gsm-ppp: DNS#0 = 8.8.8.8 I (52308) gsm-ppp: DNS#1 = 8.8.4.4 I (52308) gsm-ppp: our6_ipaddr = :: D (52318) events: Signal(network.interface.up) D (52318) events: Signal(system.modem.gotip) D (52318) netmanager: Saved DNS#0 8.8.8.8 D (52318) netmanager: Saved DNS#1 8.8.4.4 D (52318) netmanager: Saved DNS#2 0.0.0.0 I (52318) netmanager: Interface priority is pp1 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (52318) netmanager: Set DNS#2 0.0.0.0 I (52318) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (52318) events: Signal(network.modem.up) D (52328) events: Signal(network.up) D (52328) events: Signal(network.interface.change) D (52338) netmanager: MongooseTask starting D (52338) events: Signal(network.mgr.init) I (52358) ssh: Launching SSH Server OVMS> D (53498) cellular: mux-rx-line #3 (10/0): +CSQ: 19,4 OVMS> D (57308) cellular: mux-rx-line #3 (10/0): +CSQ: 24,4 D (57308) cellular: Signal Quality is: 24 (-65 dBm) D (57508) cellular: mux-rx-line #3 (10/0): +CSQ: 18,4 D (57508) cellular: Signal Quality is: 18 (-77 dBm) OVMS> D (82178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (82198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (82198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (82198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (82198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:26:48+04" D (82198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (82198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (83178) cellular: mux-tx #3: AT+CPSI? D (83198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-98,-1069,-776,10 I (83198) cellular: Network Mode: LTE,Online D (83198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (84178) cellular: mux-tx #3: AT+COPS? D (84188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 I (84198) cellular: Network Provider is: vodafone.de Hologram D (84198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (112178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (112198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (112198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (112198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (112198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:27:18+04" D (112198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (112198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (113178) cellular: mux-tx #3: AT+CPSI? D (113198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-100,-1078,-780,10 D (113198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (114178) cellular: mux-tx #3: AT+COPS? D (114188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (114188) cellular: mux-rx-line #3 (2/0): OK OVMS> I (122188) housekeeping: System considered stable (RAM: 8b=102672-105328 32b=12128 SPI=3274072-3278628) OVMS> D (142178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (142198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (142198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (142198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (142198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:27:48+04" D (142198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (142198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (143178) cellular: mux-tx #3: AT+CPSI? D (143198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-97,-1068,-771,10 D (143198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (144178) cellular: mux-tx #3: AT+COPS? D (144188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (144198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (172178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (172198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (172198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (172198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (172198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:28:18+04" D (172198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (172198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (173178) cellular: mux-tx #3: AT+CPSI? D (173198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-107,-1068,-768,10 D (173198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (174178) cellular: mux-tx #3: AT+COPS? D (174188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (174188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (202178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (202198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (202198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (202198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (202198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:28:48+04" D (202198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (202198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (203178) cellular: mux-tx #3: AT+CPSI? D (203198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-120,-1074,-746,10 D (203198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (204178) cellular: mux-tx #3: AT+COPS? D (204188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (204188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (232178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (232198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (232198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (232198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (232198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:29:18+04" D (232198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (232198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (233178) cellular: mux-tx #3: AT+CPSI? D (233198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-108,-1079,-772,9 D (233198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (234178) cellular: mux-tx #3: AT+COPS? D (234188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (234188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (262178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (262198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (262198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (262198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (262198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:29:48+04" D (262198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (262198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (263178) cellular: mux-tx #3: AT+CPSI? D (263198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-109,-1080,-778,10 D (263198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (264178) cellular: mux-tx #3: AT+COPS? D (264188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (264188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (292178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (292198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (292198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (292198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (292198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:30:18+04" D (292198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (292198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (293178) cellular: mux-tx #3: AT+CPSI? D (293198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-104,-1080,-777,9 D (293198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (294178) cellular: mux-tx #3: AT+COPS? D (294188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (294188) cellular: mux-rx-line #3 (2/0): OK OVMS> I (302198) housekeeping: 2025-03-29 08:30:29 CET (RAM: 8b=102672-105264 32b=12128 SPI=3274072-3278660) OVMS> D (322178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (322198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (322198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (322198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (322198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:30:48+04" D (322198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (322198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (323178) cellular: mux-tx #3: AT+CPSI? D (323198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-115,-1081,-765,9 D (323198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (324178) cellular: mux-tx #3: AT+COPS? D (324188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (324188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (352178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (352198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (352198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (352198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (352198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:31:18+04" D (352198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (352198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (353178) cellular: mux-tx #3: AT+CPSI? D (353198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-117,-1080,-771,10 D (353198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (354178) cellular: mux-tx #3: AT+COPS? D (354188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (354188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (382178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (382198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (382198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (382198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (382198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:31:48+04" D (382198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (382198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (383178) cellular: mux-tx #3: AT+CPSI? D (383198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-130,-1081,-751,10 D (383198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (384178) cellular: mux-tx #3: AT+COPS? D (384188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (384188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (412178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (412198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (412198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (412198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (412198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:32:18+04" D (412198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (412198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (413178) cellular: mux-tx #3: AT+CPSI? D (413198) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-143,-1081,-739,9 D (413198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (414178) cellular: mux-tx #3: AT+COPS? D (414188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (414188) cellular: mux-rx-line #3 (2/0): OK OVMS> D (442178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (442198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (442198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (442198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (442198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:32:48+04" D (442198) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (442198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (443178) cellular: mux-tx #3: AT+CPSI? D (443198) cellular: mux-rx-line #3 (85/0): +CPSI: LTE,Online,262-02,0xB092,13250570,245,EUTRAN-BAND3,1801,5,5,-130,-1091,-755,10 D (443198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (444178) cellular: mux-tx #3: AT+COPS? D (444188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (444188) cellular: mux-rx-line #3 (2/0): OK OVMS> enable Secure mode OVMS# module reset Resetting system... OVMS# I (459308) boot: Shutting down for Restart... D (459308) events: Signal(system.shuttingdown) W (459308) boot: Shutdown: vehicle pending, 1 total I (459308) v-none: Shutdown NONE vehicle module W (459308) boot: Shutdown: vehicle-poll pending, 2 total D (459308) vehicle-poll: Poller Shutdown Sending Shut-Down V (459318) vehicle-poll: Poller Shutdown Powering Down Busses V (459318) vehicle-poll: Poller Shutdown Finished D (459318) vehicle-poll: Pollers: Shutdown null W (459328) boot: Shutdown: sdcard pending, 3 total I (459328) sdcard: Unmounting SDCARD for reset W (459328) boot: Shutdown: cellular pending, 4 total W (459328) boot: Shutdown: ovms-duktape pending, 5 total I (459328) cellular: State: Enter PoweringOff state V (459328) cellular: Stopping PPP W (459328) boot: Shutdown: webserver pending, 6 total I (459328) gsm-ppp: Shutting down (hard)... I (459328) gsm-ppp: StatusCallBack: User Interrupt I (459338) gsm-ppp: PPP is shutdown V (459338) cellular: Stopping NMEA D (459338) cellular: mux-tx #1: AT+CGPSNMEA=0 D (459338) events: Signal(sd.unmounting) I (459338) ovms-duktape: Duktape: Clearing existing context D (459358) cellular: mux-tx #1: AT+CGPSINFOCFG=0 D (459458) cellular: mux-tx #1: AT+CGPS=0 I (459458) Simcom: Power Off - 3000 ms I (459528) command: CloseLogfile: file logging stopped I (459528) sdcard: unmount done D (459528) events: Signal(system.modem.down) I (459528) netmanager: MODEM down (with WIFI client down): network connectivity has been lost D (459528) events: Signal(system.modem.gpsstop) D (459528) events: Signal(system.modem.stop) D (459538) events: Signal(egpio.output.3.low) D (459538) events: Signal(egpio.output.0.low) D (459538) events: Signal(network.modem.down) D (459538) events: Signal(network.down) D (459548) events: Signal(network.interface.change) D (459648) netmanager: MongooseTask stopping D (459648) events: Signal(network.mgr.stop) I (459648) ssh: Stopping SSH Server OVMS# I (460178) boot: Shutdown: vehicle ready, 5 pending I (460178) boot: Shutdown: vehicle-poll ready, 4 pending I (460178) boot: Shutdown: ovms-duktape ready, 3 pending OVMS# I (462178) boot: Shutdown: sdcard ready, 2 pending I (462178) boot: Shutdown: webserver ready, 1 pending D (462178) events: Signal(sd.unmounted) OVMS# D (462468) events: Signal(egpio.output.0.high) OVMS# I (464178) boot: Restart in 65 seconds (1 pending)... OVMS# I (469178) boot: Restart in 60 seconds (1 pending)... OVMS# I (474178) boot: Restart in 55 seconds (1 pending)... OVMS# I (479178) boot: Restart in 50 seconds (1 pending)... D (479178) cellular: State timeout PoweringOff => CheckPowerOff I (479178) cellular: State: Enter CheckPowerOff state OVMS# D (482178) cellular: tx-cmd: AT W (482178) cellular: UART frame error W (482178) cellular: UART frame error I (482178) cellular: State: Enter PoweringOff state V (482178) cellular: Stopping PPP I (482178) gsm-ppp: Shutting down (hard)... I (482178) gsm-ppp: StatusCallBack: User Interrupt I (482178) gsm-ppp: PPP is shutdown I (482178) Simcom: Power Off - 3000 ms D (482178) events: Signal(system.modem.down) D (482188) events: Signal(system.modem.stop) D (482188) events: Signal(egpio.output.0.low) OVMS# I (484178) boot: Restart in 45 seconds (1 pending)... OVMS# D (485178) events: Signal(egpio.output.0.high) OVMS# I (489178) boot: Restart in 40 seconds (1 pending)... OVMS# I (494178) boot: Restart in 35 seconds (1 pending)... OVMS# I (499178) boot: Restart in 30 seconds (1 pending)... OVMS# D (502178) cellular: State timeout PoweringOff => CheckPowerOff I (502178) cellular: State: Enter CheckPowerOff state OVMS# I (504178) boot: Restart in 25 seconds (1 pending)... OVMS# D (505178) cellular: tx-cmd: AT I (505188) cellular: State: Enter PoweringOff state V (505188) cellular: Stopping PPP I (505188) gsm-ppp: Shutting down (hard)... I (505188) gsm-ppp: StatusCallBack: User Interrupt I (505188) gsm-ppp: PPP is shutdown D (505188) events: Signal(system.modem.down) I (505188) Simcom: Power Off - 3000 ms D (505188) events: Signal(system.modem.stop) D (505188) events: Signal(egpio.output.0.low) OVMS# D (508188) events: Signal(egpio.output.0.high) OVMS# I (509178) boot: Restart in 20 seconds (1 pending)... OVMS# I (514178) boot: Restart in 15 seconds (1 pending)... OVMS# I (519178) boot: Restart in 10 seconds (1 pending)... OVMS# I (524178) boot: Restart in 5 seconds (1 pending)... OVMS# D (525178) cellular: State timeout PoweringOff => CheckPowerOff I (525178) cellular: State: Enter CheckPowerOff state OVMS# D (528178) cellular: tx-cmd: AT I (528178) boot: Restart now I (528188) cellular: State: Enter PoweringOff state V (528188) cellular: Stopping PPP I (528188) gsm-ppp: Shutting down (hard)... I (528188) gsm-ppp: StatusCallBack: User Interrupt I (528188) gsm-ppp: PPP is shutdown D (528188) events: Signal(system.modem.down) I (528188) Simcom: Power Off - 3000 ms D (528188) events: Signal(system.modem.stop) D (528188) events: Signal(egpio.output.0.low) OVMS# D (529178) events: Signal(system.shutdown)ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:5980 ho 0 tail 12 room 4 load:0x40078000,len:16028 load:0x40080400,len:3816 entry 0x40080600 I (1252) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1263) cpu_start: Pro cpu up. I (1267) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-426-g56a6a42b I (1283) cpu_start: Compile time: Mar 29 2025 08:14:13 I (1289) cpu_start: ELF file SHA256: 96d26c67fedbd772... I (1295) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1294) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2180) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2186) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (44) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Boot #1 reasons for CPU0=12 and CPU1=12 I (71) boot: Soft reset by user I (75) events: Initialising EVENTS (1200) I (80) config: Initialising CONFIG (1400) I (85) time: Initialising TIME (1500) I (89) script: Initialising SCRIPTS (1600) I (94) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (99) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (105) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (111) metrics: Initialising METRICS (1810) I (116) metrics: Expanding DUKTAPE javascript engine I (121) metrics: Persistent metrics serial 2 using 820 bytes, 66/100 slots used I (132) metrics: persist v.b.12v.voltage.ref = 12.6V I (143) metrics: persist v.e.parktime = 457Sec I (149) notify: Initialising NOTIFICATIONS (1820) I (150) notify: Registered notification type info I (151) notify: Registered notification type error I (156) notify: Registered notification type alert I (161) notify: Registered notification type data I (167) notify: Registered notification type stream I (172) notify: Expanding DUKTAPE javascript engine I (178) location: Initialising LOCATIONS (1900) I (187) location: Expanding DUKTAPE javascript engine I (189) vehicle: Initialising VEHICLE Factory (2000) I (200) tls: Initialising TLS (3000) I (201) pcp: Initialising POWER (4000) I (204) max7317: Initialising MAX7317 EGPIO (4200) I (210) sdcard: Initialising SD CARD (4400) I (214) ota: Initialising OTA (4400) I (220) canformat: Initialising CAN Format Factory (4500) I (224) canformat-cs11: Registering CAN Format: CS11 (4505) I (230) canformat-crtd: Registering CAN Format: CRTD (4505) I (236) canformat-gvret: Registering CAN Format: GVRET (4505) I (243) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (250) canformat-panda: Registering CAN Format: PANDA (4505) I (256) canformat-pcap: Registering CAN Format: PCAP (4505) I (262) canformat-raw: Registering CAN Format: RAW (4505) I (268) can: Initialising CAN (4510) I (280) dbc-app: Initialising DBC (4520) I (283) canlog: Initialising CAN logging (4550) I (284) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (290) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (300) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (307) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (313) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (322) canlog-vfs: Initialising CAN logging to VFS (4560) I (326) canplay: Initialising CAN play framework (4570) I (331) canplay-vfs: Initialising CAN playing from VFS (4580) I (338) cellular: Initialising CELLULAR (4600) I (345) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (350) cellular-modem-auto: Registering auto-detect modem driver (4650) I (357) SIM5360: Registering SIM5360 modem driver (4650) I (363) SIM7000: Registering SIM7000 modem driver (4650) I (369) SIM7600: Registering SIM7600 modem driver (4650) I (375) SIM7670: Registering Simcom A7670E modem driver (4660) I (381) tpms: Initialising TPMS (4700) I (387) test: Initialising TEST (5000) I (392) module: Initialising MODULE (5100) I (397) vfs: Initialising VFS (5200) I (401) ovms-server: Initialising OVMS Server (6000) I (405) ovms-server-v2: Initialising OVMS V2 Server (6100) I (412) ovms-server-v3: Initialising OVMS V3 Server (6200) I (418) vehicle-poll: Initialising Poller (7000) I (426) obd2ecu: Initialising OBD2ECU (7000) I (429) canopen: Initialising CANopen (7000) I (437) pluginstore: Initialising PLUGINS (7100) I (440) esp32wifi: Initialising ESP32WIFI (8000) I (445) ovms-mdns: Initialising MDNS (8100) I (448) webserver: Initialising WEBSERVER (8200) I (456) ssh: Initialising SSH (8300) I (458) powermgmt: Initialising POWERMGMT (8500) I (464) re: Initialising RE Tools (8800) I (470) pushover: Initialising Pushover client (8800) I (475) netmanager: Initialising NETMANAGER (8999) I (482) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (485) v-zeva: Registering Vehicle: ZEVA (9000) I (491) v-vweup: Registering Vehicle: VW e-Up (9000) I (496) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (504) v-track: Registering Vehicle: TRACK (9000) I (509) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (516) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (522) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (529) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (536) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (543) v-smarteq: Registering Vehicle: SMART EQ (9000) I (548) v-smarted: Registering Vehicle: SMART ED (9000) I (554) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (562) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (568) v-twizy: Registering Vehicle: Renault Twizy (9000) I (574) v-obdii: Registering Vehicle: OBDII (9000) I (580) v-none: Registering Vehicle: NONE (9000) I (585) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (592) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (601) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (607) v-mgev4: Registering Vehicle: MG4 (9000) I (613) v-mgev: Registering Vehicle: MG5 (9000) I (618) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (624) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (630) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (636) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (642) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (649) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (655) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (662) v-maple60s: Registering Vehicle: Maple 60S (9000) I (668) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (674) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (682) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (688) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (695) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (702) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (709) v-energica: Registering Vehicle: Energica (9000) I (715) v-demo: Registering Vehicle: DEMO (9000) I (720) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (726) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (734) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (742) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (748) v-boltev: Registering Vehicle: Bolt EV (9000) I (753) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (759) version: Initialising Versioning (9900) I (767) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (850) ovms_main: Executing on CPU core 0 I (850) ovms_main: Mounting CONFIG... I (970) ovms_main: Configure logging... W (980) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (980) ovms_main: Registering default configs... I (980) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (980) ovms_main: Starting HOUSEKEEPING... I (1000) housekeeping: Initialising HOUSEKEEPING Framework... I (1000) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2170) pluginstore: Loading enabled plugins (2) I (2170) pluginstore: Load retools web page /plugins/retools I (2170) pluginstore: Loading enabled plugins (3) D (2180) events: Signal(housekeeping.init) I (2180) housekeeping: Executing on CPU core 1 I (2180) housekeeping: reset_reason: cpu0=12, cpu1=12 I (2190) housekeeping: Starting PERIPHERALS... I (2190) peripherals: Initialising OVMS Peripherals... I (2200) peripherals: TCP/IP Adaptor I (2200) peripherals: ESP32 system I (2210) peripherals: SPI bus I (2210) peripherals: MAX7317 I/O Expander I (2220) peripherals: ESP32 CAN I (2220) peripherals: ESP32 WIFI I (2230) peripherals: ESP32 ADC I (2230) peripherals: MCP2515 CAN 1/2 I (2230) mcp2515: can2: SetPowerMode off I (2320) peripherals: MCP2515 CAN 2/2 I (2320) mcp2515: can3: SetPowerMode off I (2400) peripherals: SD CARD I (2400) peripherals: CELLULAR MODEM I (2400) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2410) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2420) cellular: Starting modem task I (2420) uart: queue free spaces: 50 I (2420) ext12v: Powering off external 12V devices I (2430) housekeeping: Auto init max7317 (free: 160656 bytes) I (2440) housekeeping: Auto init ext12v (free: 160656 bytes) I (2440) housekeeping: Auto init dbc (free: 160656 bytes) I (2450) housekeeping: Auto init wifi (free: 160656 bytes) I (2450) housekeeping: Auto init modem (free: 160656 bytes) I (2460) housekeeping: Auto init Pollers (free: 160656 bytes) I (2460) cellular: Set modem driver to 'auto' I (2470) housekeeping: Auto init vehicle (free: 160656 bytes) I (2470) cellular: State: Enter PowerOffOn state I (2480) v-none: Generic NONE vehicle module I (2480) cellular-modem-auto: Power Cycle I (2490) housekeeping: Auto init obd2ecu (free: 148856 bytes) I (2490) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2500) housekeeping: Auto init server v2 (free: 148856 bytes) I (2510) housekeeping: Auto init server v3 (free: 148856 bytes) I (2520) housekeeping: Auto init javascript (free: 148856 bytes) I (2530) housekeeping: Auto init done (free: 148816 bytes) I (2530) housekeeping: Starting USB console... I (2540) uart: queue free spaces: 100 D (2550) events: Signal(egpio.output.1.low) D (2550) events: Signal(power.cellular.on) D (2550) events: Signal(system.modem.stop) D (2560) events: Signal(vehicle.type.set) D (2560) events: Signal(egpio.output.0.low) D (2560) events: Signal(system.start) I (2570) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-426-g56a6a42b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (2580) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> I (2710) ovms-duktape: Duktape: Initialising module system I (2890) pluginstore: Loading enabled plugins (1) OVMS> D (4190) events: Signal(vehicle.aux.12v.low) OVMS> D (5010) events: Signal(egpio.output.0.high) OVMS> I (7190) sdcard: SD CARD has been inserted I (7230) sdcard: mount done D (7230) events: Signal(sd.insert) OVMS> D (9190) events: Signal(sd.mounted) I (9210) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (10010) events: Signal(egpio.output.0.low) D (10210) events: Signal(egpio.output.0.high) D (10210) cellular: State timeout PowerOffOn => PoweringOn I (10210) cellular: State: Enter PoweringOn state I (10210) cellular-modem-auto: Power Cycle I (10210) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10210) events: Signal(system.modem.poweringon) D (10210) events: Signal(egpio.output.0.low) OVMS> D (12710) events: Signal(egpio.output.0.high) OVMS> D (17710) events: Signal(egpio.output.0.low) D (17910) cellular: tx-cmd: AT D (17910) events: Signal(egpio.output.0.high) D (17910) cellular: tx-cmd: AT D (17910) cellular: tx-cmd: AT D (17910) cellular: tx-cmd: AT OVMS> D (20190) cellular: tx-cmd: AT I (20190) cellular: State: Enter Identify state OVMS> D (21190) cellular: tx-cmd: AT+CGMM W (21190) cellular: UART frame error OVMS> D (22190) cellular: tx-cmd: AT+CGMM OVMS> D (23190) cellular: tx-cmd: AT+CGMM OVMS> D (24190) cellular: tx-cmd: AT+CGMM OVMS> D (25190) cellular: tx-cmd: AT+CGMM OVMS> D (26190) cellular: tx-cmd: AT+CGMM OVMS> D (27190) cellular: tx-cmd: AT+CGMM OVMS> D (28190) cellular: tx-cmd: AT+CGMM OVMS> D (29190) cellular: tx-cmd: AT+CGMM OVMS> D (30190) cellular: tx-cmd: AT+CGMM OVMS> D (31190) cellular: tx-cmd: AT+CGMM OVMS> D (32190) cellular: tx-cmd: AT+CGMM OVMS> D (33190) cellular: tx-cmd: AT+CGMM OVMS> D (34190) cellular: tx-cmd: AT+CGMM OVMS> D (35190) cellular: tx-cmd: AT+CGMM OVMS> D (36190) cellular: tx-cmd: AT+CGMM OVMS> D (37190) cellular: tx-cmd: AT+CGMM I (37200) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (37200) cellular: Remove old 'auto' modem driver I (37200) cellular: Set modem driver to 'SIM7600' I (37200) cellular: State: Enter PoweredOn state D (37200) events: Signal(system.modem.installed) D (37200) events: Signal(system.modem.poweredon) OVMS> D (47190) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 W (47190) cellular: UART frame error D (47200) cellular: mux-rx-line #0 (2/1): OK D (47220) cellular: mux-rx-line #0 (125/0): ™AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (47220) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (47220) cellular: mux-rx-line #0 (10/6): +CSQ: 19,0 D (47220) cellular: Signal Quality is: 19 (-75 dBm) D (47220) cellular: mux-rx-line #0 (2/0): OK OVMS> D (49190) cellular: tx-cmd: AT+CGMR;+ICCID D (49200) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (49200) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (49210) cellular: mux-rx-line #0 (2/0): OK OVMS> D (57190) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (57200) cellular: mux-rx-line #0 (2/0): OK I (57200) cellular: State: Enter MuxStart state V (57200) cellular: Starting MUX D (57200) events: Signal(system.modem.muxstart) OVMS> D (58190) cellular: State transition MuxStart => NetWait I (58190) cellular: State: Enter NetWait state V (58190) cellular: Starting NMEA D (58190) cellular: mux-tx #1: AT+CGPS=0 D (58190) events: Signal(system.modem.netwait) OVMS> D (60190) cellular: mux-tx #1: AT+CGPSNMEA=258 D (60210) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (60230) cellular: mux-tx #1: AT+CGPS=1,1 D (60230) events: Signal(system.modem.gpsstart) D (60230) cellular: mux-rx-line #1 (2/0): OK D (60230) cellular: mux-rx-line #1 (2/0): OK D (60230) cellular: mux-rx-line #1 (2/0): OK D (60240) cellular: mux-rx-line #1 (2/0): OK W (60240) cellular: UART frame error W (60240) cellular: UART frame error W (60240) cellular: UART frame error W (60240) cellular: UART frame error OVMS> D (68190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (68210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 I (68210) cellular: Network Registration status: RegisteredRoaming D (68210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,2 D (68210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (68210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:35:26+04" D (68210) cellular: mux-rx-line #3 (10/6): +CSQ: 19,0 D (68210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (69190) cellular: mux-tx #3: AT+CPSI? D (69190) cellular: State transition NetWait => NetStart I (69190) cellular: State: Enter NetStart state D (69190) events: Signal(system.modem.netstart) D (69200) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-77,0,0-0 I (69210) cellular: Network Mode: GSM,Online D (69210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (70190) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (70260) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (70260) cellular: PPP Connection is ready to start OVMS> D (71190) cellular: State transition NetStart => NetMode I (71190) cellular: State: Enter NetMode state V (71190) cellular: Launching PPP V (71190) cellular: Starting PPP I (71190) gsm-ppp: Initialising... D (71190) events: Signal(system.modem.netmode) W (71220) cellular: UART frame error W (71240) cellular: UART frame error OVMS> D (74210) cellular: mux-rx-line #3 (9/0): +CGREG: 5 OVMS> D (74500) cellular: mux-rx-line #3 (26/0): +CTZV: 4,25/03/29,07:35:33 OVMS> I (74740) gsm-ppp: StatusCallBack: None I (74740) gsm-ppp: status_cb: Connected I (74740) gsm-ppp: our_ipaddr = 10.170.195.13 I (74740) gsm-ppp: his_ipaddr = 10.64.64.64 I (74740) gsm-ppp: netmask = 255.255.255.255 I (74740) gsm-ppp: DNS#0 = 8.8.8.8 I (74740) gsm-ppp: DNS#1 = 8.8.4.4 I (74740) gsm-ppp: our6_ipaddr = :: D (74740) events: Signal(network.interface.up) D (74740) events: Signal(system.modem.gotip) D (74740) netmanager: Saved DNS#0 8.8.8.8 D (74740) netmanager: Saved DNS#1 8.8.4.4 D (74740) netmanager: Saved DNS#2 0.0.0.0 I (74740) netmanager: Interface priority is pp1 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (74740) netmanager: Set DNS#2 0.0.0.0 I (74740) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (74750) events: Signal(network.modem.up) D (74750) events: Signal(network.up) D (74750) events: Signal(network.interface.change) D (74760) netmanager: MongooseTask starting D (74760) events: Signal(network.mgr.init) I (74780) ssh: Launching SSH Server OVMS> D (79030) cellular: mux-rx-line #3 (10/0): +CSQ: 19,1 OVMS> D (84040) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 OVMS> D (101190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (101210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (101210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (101210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (101210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:35:59+04" D (101210) cellular: mux-rx-line #3 (10/6): +CSQ: 19,0 D (101210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (102190) cellular: mux-tx #3: AT+CPSI? D (102200) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-76,0,0-0 D (102210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (103190) cellular: mux-tx #3: AT+COPS? D (103200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (103210) cellular: Network Provider is: vodafone.de Hologram D (103210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (112060) cellular: mux-rx-line #3 (10/0): +CSQ: 19,7 OVMS> D (114060) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 OVMS> D (116060) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 OVMS> D (120070) cellular: mux-rx-line #3 (10/0): +CSQ: 19,3 OVMS> I (122200) housekeeping: System considered stable (RAM: 8b=102344-105056 32b=12128 SPI=3274048-3278596) OVMS> D (124080) cellular: mux-rx-line #3 (10/0): +CSQ: 17,3 D (124080) cellular: Signal Quality is: 17 (-79 dBm) OVMS> D (131190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (131210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (131210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (131210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (131210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:36:29+04" D (131210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (131210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (132190) cellular: mux-tx #3: AT+CPSI? D (132330) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-135,-1123,-801,10 I (132330) cellular: Network Mode: LTE,Online D (132330) cellular: mux-rx-line #3 (2/0): OK OVMS> D (133190) cellular: mux-tx #3: AT+COPS? D (133210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (133210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (161190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (161210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (161210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (161210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (161210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:36:59+04" D (161210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (161210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (162190) cellular: mux-tx #3: AT+CPSI? D (162210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-127,-1123,-798,11 D (162210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (163190) cellular: mux-tx #3: AT+COPS? D (163210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (163210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (191190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (191210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (191210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (191210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (191210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:37:29+04" D (191210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (191210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (192190) cellular: mux-tx #3: AT+CPSI? D (192210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-116,-1105,-792,11 D (192210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (193190) cellular: mux-tx #3: AT+COPS? D (193200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (193200) cellular: mux-rx-line #3 (2/0): OK OVMS> D (221190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (221210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (221210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (221210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (221210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:37:59+04" D (221210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (221210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (222190) cellular: mux-tx #3: AT+CPSI? D (222210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-122,-1081,-752,11 D (222210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (223190) cellular: mux-tx #3: AT+COPS? D (223200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (223200) cellular: mux-rx-line #3 (2/0): OK OVMS> enable Secure mode OVMS# test canrx cantx chargen commands echo javascript mkstemp realloc sdcard sleep spiram stackoverflow string strverscmp watchdog OVMS# test D (251190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (251210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (251210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (251210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (251210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:38:29+04" D (251210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (251210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (252190) cellular: mux-tx #3: AT+CPSI? D (252210) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-133,-1079,-741,9 D (252210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (253190) cellular: mux-tx #3: AT+COPS? D (253200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (253200) cellular: mux-rx-line #3 (2/0): OK OVMS# D (281190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (281210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (281210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (281210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (281210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:38:59+04" D (281210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (281210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (282190) cellular: mux-tx #3: AT+CPSI? D (282210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-101,-1079,-782,12 D (282210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (283190) cellular: mux-tx #3: AT+COPS? D (283200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (283200) cellular: mux-rx-line #3 (2/0): OK OVMS# s test I (302210) housekeeping: 2025-03-29 08:39:20 CET (RAM: 8b=102344-104992 32b=12128 SPI=3274048-3278664) OVMS# test D (311190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (311210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (311210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (311210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (311210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:39:29+04" D (311210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (311210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (312190) cellular: mux-tx #3: AT+CPSI? D (312210) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-97,-1077,-779,13 D (312210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (313190) cellular: mux-tx #3: AT+COPS? D (313200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (313200) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (341190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (341210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (341210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (341210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (341210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:39:59+04" D (341210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (341210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (342190) cellular: mux-tx #3: AT+CPSI? D (342210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-101,-1080,-781,11 D (342210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (343190) cellular: mux-tx #3: AT+COPS? D (343200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (343200) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (371190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (371210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (371210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (371210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (371210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,08:40:29+04" D (371210) cellular: mux-rx-line #3 (10/6): +CSQ: 17,3 D (371210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (372190) cellular: mux-tx #3: AT+CPSI? D (372210) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,14062611,194,EUTRAN-BAND1,100,5,5,-93,-1078,-785,14 D (372210) cellular: mux-rx-line #3 (2/0): OK OVMS# test D (373190) cellular: mux-tx #3: AT+COPS? D (373200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (373200) cellular: mux-rx-line #3 (2/0): OK OVMS# test stackoverflow [OVMS] ***ERROR*** A stack overflow in task OVMS Console has been detected. abort() was called at PC 0x4012a3f2 on core 1 ELF file SHA256: 96d26c67fedbd772 Backtrace: 0x4008ddae:0x3ffdcff0 0x4008e049:0x3ffdd010 0x4012a3f2:0x3ffdd030 0x4009001c:0x3ffdd050 0x40091a0c:0x3ffdd070 0x400919c2:0x3f413129 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:5980 ho 0 tail 12 room 4 load:0x40078000,len:16028 load:0x40080400,len:3816 entry 0x40080600 I (1252) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1263) cpu_start: Pro cpu up. I (1267) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-426-g56a6a42b I (1283) cpu_start: Compile time: Mar 29 2025 08:14:13 I (1289) cpu_start: ELF file SHA256: 96d26c67fedbd772... I (1295) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1294) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2180) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2186) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (44) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Boot #2 reasons for CPU0=12 and CPU1=12 E (71) boot: Crash #1 detected I (75) boot: Reset reason Exception/panic (4) I (80) events: Initialising EVENTS (1200) I (85) config: Initialising CONFIG (1400) I (90) time: Initialising TIME (1500) I (94) script: Initialising SCRIPTS (1600) I (99) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (104) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (110) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (116) metrics: Initialising METRICS (1810) I (121) metrics: Expanding DUKTAPE javascript engine I (126) metrics: Persistent metrics serial 3 using 820 bytes, 66/100 slots used I (137) metrics: persist v.b.12v.voltage.ref = 12.6V I (148) metrics: persist v.e.parktime = 872Sec I (154) notify: Initialising NOTIFICATIONS (1820) I (155) notify: Registered notification type info I (156) notify: Registered notification type error I (161) notify: Registered notification type alert I (167) notify: Registered notification type data I (172) notify: Registered notification type stream I (177) notify: Expanding DUKTAPE javascript engine I (183) location: Initialising LOCATIONS (1900) I (192) location: Expanding DUKTAPE javascript engine I (194) vehicle: Initialising VEHICLE Factory (2000) I (205) tls: Initialising TLS (3000) I (206) pcp: Initialising POWER (4000) I (209) max7317: Initialising MAX7317 EGPIO (4200) I (215) sdcard: Initialising SD CARD (4400) I (219) ota: Initialising OTA (4400) I (225) canformat: Initialising CAN Format Factory (4500) I (229) canformat-cs11: Registering CAN Format: CS11 (4505) I (235) canformat-crtd: Registering CAN Format: CRTD (4505) I (241) canformat-gvret: Registering CAN Format: GVRET (4505) I (248) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (255) canformat-panda: Registering CAN Format: PANDA (4505) I (261) canformat-pcap: Registering CAN Format: PCAP (4505) I (267) canformat-raw: Registering CAN Format: RAW (4505) I (273) can: Initialising CAN (4510) I (285) dbc-app: Initialising DBC (4520) I (288) canlog: Initialising CAN logging (4550) I (289) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (295) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (305) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (312) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (318) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (327) canlog-vfs: Initialising CAN logging to VFS (4560) I (331) canplay: Initialising CAN play framework (4570) I (336) canplay-vfs: Initialising CAN playing from VFS (4580) I (343) cellular: Initialising CELLULAR (4600) I (350) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (355) cellular-modem-auto: Registering auto-detect modem driver (4650) I (362) SIM5360: Registering SIM5360 modem driver (4650) I (368) SIM7000: Registering SIM7000 modem driver (4650) I (374) SIM7600: Registering SIM7600 modem driver (4650) I (380) SIM7670: Registering Simcom A7670E modem driver (4660) I (387) tpms: Initialising TPMS (4700) I (392) test: Initialising TEST (5000) I (397) module: Initialising MODULE (5100) I (402) vfs: Initialising VFS (5200) I (406) ovms-server: Initialising OVMS Server (6000) I (410) ovms-server-v2: Initialising OVMS V2 Server (6100) I (417) ovms-server-v3: Initialising OVMS V3 Server (6200) I (423) vehicle-poll: Initialising Poller (7000) I (431) obd2ecu: Initialising OBD2ECU (7000) I (434) canopen: Initialising CANopen (7000) I (442) pluginstore: Initialising PLUGINS (7100) I (445) esp32wifi: Initialising ESP32WIFI (8000) I (450) ovms-mdns: Initialising MDNS (8100) I (453) webserver: Initialising WEBSERVER (8200) I (461) ssh: Initialising SSH (8300) I (463) powermgmt: Initialising POWERMGMT (8500) I (469) re: Initialising RE Tools (8800) I (475) pushover: Initialising Pushover client (8800) I (480) netmanager: Initialising NETMANAGER (8999) I (487) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (491) v-zeva: Registering Vehicle: ZEVA (9000) I (496) v-vweup: Registering Vehicle: VW e-Up (9000) I (501) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (509) v-track: Registering Vehicle: TRACK (9000) I (514) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (521) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (527) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (534) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (541) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (548) v-smarteq: Registering Vehicle: SMART EQ (9000) I (554) v-smarted: Registering Vehicle: SMART ED (9000) I (559) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (567) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (573) v-twizy: Registering Vehicle: Renault Twizy (9000) I (579) v-obdii: Registering Vehicle: OBDII (9000) I (585) v-none: Registering Vehicle: NONE (9000) I (590) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (597) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (606) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (612) v-mgev4: Registering Vehicle: MG4 (9000) I (618) v-mgev: Registering Vehicle: MG5 (9000) I (623) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (629) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (635) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (641) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (648) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (654) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (660) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (667) v-maple60s: Registering Vehicle: Maple 60S (9000) I (673) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (679) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (687) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (693) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (700) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (708) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (714) v-energica: Registering Vehicle: Energica (9000) I (720) v-demo: Registering Vehicle: DEMO (9000) I (725) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (731) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (739) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (747) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (753) v-boltev: Registering Vehicle: Bolt EV (9000) I (758) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (764) version: Initialising Versioning (9900) I (772) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (855) ovms_main: Executing on CPU core 0 I (855) ovms_main: Mounting CONFIG... I (975) ovms_main: Configure logging... W (985) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (985) ovms_main: Registering default configs... I (985) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (985) ovms_main: Starting HOUSEKEEPING... I (1005) housekeeping: Initialising HOUSEKEEPING Framework... I (1005) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2175) pluginstore: Loading enabled plugins (2) I (2175) pluginstore: Load retools web page /plugins/retools I (2175) pluginstore: Loading enabled plugins (3) D (2185) events: Signal(housekeeping.init) I (2185) housekeeping: Executing on CPU core 1 I (2185) housekeeping: reset_reason: cpu0=12, cpu1=12 I (2195) housekeeping: Starting PERIPHERALS... I (2195) peripherals: Initialising OVMS Peripherals... I (2205) peripherals: TCP/IP Adaptor I (2205) peripherals: ESP32 system I (2215) peripherals: SPI bus I (2215) peripherals: MAX7317 I/O Expander I (2225) peripherals: ESP32 CAN I (2225) peripherals: ESP32 WIFI I (2235) peripherals: ESP32 ADC I (2235) peripherals: MCP2515 CAN 1/2 I (2235) mcp2515: can2: SetPowerMode off I (2325) peripherals: MCP2515 CAN 2/2 I (2325) mcp2515: can3: SetPowerMode off I (2405) peripherals: SD CARD I (2405) peripherals: CELLULAR MODEM I (2405) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2415) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2425) cellular: Starting modem task I (2425) uart: queue free spaces: 50 I (2425) ext12v: Powering off external 12V devices I (2435) housekeeping: Auto init max7317 (free: 160656 bytes) I (2445) housekeeping: Auto init ext12v (free: 160656 bytes) I (2445) housekeeping: Auto init dbc (free: 160656 bytes) I (2455) housekeeping: Auto init wifi (free: 160656 bytes) I (2455) housekeeping: Auto init modem (free: 160656 bytes) I (2465) housekeeping: Auto init Pollers (free: 160656 bytes) I (2465) cellular: Set modem driver to 'auto' I (2475) housekeeping: Auto init vehicle (free: 160656 bytes) I (2475) cellular: State: Enter PowerOffOn state I (2485) v-none: Generic NONE vehicle module I (2485) cellular-modem-auto: Power Cycle I (2495) housekeeping: Auto init obd2ecu (free: 148856 bytes) I (2495) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2505) housekeeping: Auto init server v2 (free: 148856 bytes) I (2515) housekeeping: Auto init server v3 (free: 148856 bytes) I (2525) housekeeping: Auto init javascript (free: 148856 bytes) I (2535) housekeeping: Auto init done (free: 148816 bytes) I (2535) housekeeping: Starting USB console... I (2545) uart: queue free spaces: 100 D (2555) events: Signal(egpio.output.1.low) D (2555) events: Signal(power.cellular.on) D (2555) events: Signal(system.modem.stop) D (2565) events: Signal(vehicle.type.set) D (2565) events: Signal(egpio.output.0.low) D (2565) events: Signal(system.start) I (2575) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-426-g56a6a42b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (2585) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> I (2715) ovms-duktape: Duktape: Initialising module system I (2895) pluginstore: Loading enabled plugins (1) OVMS> D (4195) events: Signal(vehicle.aux.12v.low) OVMS> D (5015) events: Signal(egpio.output.0.high) OVMS> I (7195) sdcard: SD CARD has been inserted I (7235) sdcard: mount done D (7235) events: Signal(sd.insert) OVMS> D (9195) events: Signal(sd.mounted) I (9215) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (10015) events: Signal(egpio.output.0.low) D (10215) events: Signal(egpio.output.0.high) D (10215) cellular: State timeout PowerOffOn => PoweringOn I (10215) cellular: State: Enter PoweringOn state I (10215) cellular-modem-auto: Power Cycle I (10215) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10215) events: Signal(system.modem.poweringon) D (10215) events: Signal(egpio.output.0.low) OVMS> D (12715) events: Signal(egpio.output.0.high) OVMS> D (17715) events: Signal(egpio.output.0.low) D (17915) events: Signal(egpio.output.0.high) I (18015) cellular: State: Enter Identify state D (18115) cellular: tx-cmd: AT+CGMM D (18115) cellular: tx-cmd: AT+CGMM D (18115) cellular: tx-cmd: AT+CGMM D (18115) cellular: tx-cmd: AT+CGMM D (18215) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM D (18415) cellular: tx-cmd: AT+CGMM OVMS> D (19195) cellular: tx-cmd: AT+CGMM OVMS> D (20195) cellular: tx-cmd: AT+CGMM OVMS> D (21195) cellular: tx-cmd: AT+CGMM OVMS> D (22195) cellular: tx-cmd: AT+CGMM OVMS> D (23195) cellular: tx-cmd: AT+CGMM OVMS> D (24195) cellular: tx-cmd: AT+CGMM OVMS> D (25195) cellular: tx-cmd: AT+CGMM OVMS> D (26195) cellular: tx-cmd: AT+CGMM OVMS> D (27195) cellular: tx-cmd: AT+CGMM OVMS> D (28195) cellular: tx-cmd: AT+CGMM OVMS> D (29195) cellular: tx-cmd: AT+CGMM OVMS> D (30195) cellular: tx-cmd: AT+CGMM OVMS> D (31195) cellular: tx-cmd: AT+CGMM W (31195) cellular: UART frame error W (31195) cellular: UART frame error OVMS> D (32195) cellular: tx-cmd: AT+CGMM W (32195) cellular: UART frame error OVMS> D (33195) cellular: tx-cmd: AT+CGMM W (33195) cellular: UART frame error W (33195) cellular: UART frame error W (33195) cellular: UART frame error OVMS> D (34195) cellular: tx-cmd: AT+CGMM OVMS> D (35195) cellular: tx-cmd: AT+CGMM D (35195) cellular: State timeout Identify => PowerOffOn I (35195) cellular: State: Enter PowerOffOn state I (35195) cellular-modem-auto: Power Cycle I (35195) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms D (35195) events: Signal(system.modem.stop) D (35195) events: Signal(egpio.output.0.low) OVMS> D (37695) events: Signal(egpio.output.0.high) OVMS> D (42695) events: Signal(egpio.output.0.low) OVMS> D (43695) events: Signal(egpio.output.0.high) D (43695) cellular: State timeout PowerOffOn => PoweringOn I (43695) cellular: State: Enter PoweringOn state I (43695) cellular-modem-auto: Power Cycle I (43695) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms D (43695) events: Signal(system.modem.poweringon) D (43695) events: Signal(egpio.output.0.low) OVMS> D (46195) events: Signal(egpio.output.0.high) OVMS> D (51195) events: Signal(egpio.output.0.low) OVMS> D (52195) cellular: tx-cmd: AT D (52195) cellular: tx-cmd: AT D (52195) cellular: tx-cmd: AT I (52195) cellular: State: Enter Identify state D (52195) cellular: tx-cmd: AT+CGMM D (52195) cellular: tx-cmd: AT+CGMM D (52195) cellular: tx-cmd: AT+CGMM D (52195) cellular: tx-cmd: AT+CGMM D (52195) events: Signal(egpio.output.0.high) OVMS> D (53195) cellular: tx-cmd: AT+CGMM OVMS> D (54195) cellular: tx-cmd: AT+CGMM OVMS> D (55195) cellular: tx-cmd: AT+CGMM OVMS> D (56195) cellular: tx-cmd: AT+CGMM OVMS> D (57195) cellular: tx-cmd: AT+CGMM OVMS> D (58195) cellular: tx-cmd: AT+CGMM OVMS> D (59195) cellular: tx-cmd: AT+CGMM OVMS> D (60195) cellular: tx-cmd: AT+CGMM OVMS> D (61195) cellular: tx-cmd: AT+CGMM OVMS> D (62195) cellular: tx-cmd: AT+CGMM OVMS> D (63195) cellular: tx-cmd: AT+CGMM OVMS> D (64195) cellular: tx-cmd: AT+CGMM OVMS> D (65195) cellular: tx-cmd: AT+CGMM OVMS> D (66195) cellular: tx-cmd: AT+CGMM OVMS> D (67195) cellular: tx-cmd: AT+CGMM OVMS> D (68195) cellular: tx-cmd: AT+CGMM OVMS> D (69195) cellular: tx-cmd: AT+CGMM OVMS> D (70195) cellular: tx-cmd: AT+CGMM OVMS> D (71195) cellular: tx-cmd: AT+CGMM OVMS> D (72195) cellular: tx-cmd: AT+CGMM OVMS> D (73195) cellular: tx-cmd: AT+CGMM W (73195) cellular: UART frame error OVMS> D (74195) cellular: tx-cmd: AT+CGMM W (74195) cellular: UART frame error W (74195) cellular: UART frame error OVMS> D (75195) cellular: tx-cmd: AT+CGMM W (75195) cellular: UART frame error OVMS> D (76195) cellular: tx-cmd: AT+CGMM OVMS> D (77195) cellular: tx-cmd: AT+CGMM OVMS> D (78195) cellular: tx-cmd: AT+CGMM D (78195) cellular: State timeout Identify => PowerOffOn I (78195) cellular: State: Enter PowerOffOn state I (78195) cellular-modem-auto: Power Cycle I (78195) Simcom: Power Cycle - T_off 2500 ms - T_on 1126913089 ms D (78195) events: Signal(system.modem.stop) D (78195) events: Signal(egpio.output.0.low) OVMS> D (80695) events: Signal(egpio.output.0.high) OVMS> D (85695) events: Signal(egpio.output.0.low) OVMS> I (122205) housekeeping: System considered stable (RAM: 8b=113788-119376 32b=12128 SPI=3300264-3301076) OVMS> OVMS> I (302215) housekeeping: 2025-03-29 08:46:19 CET (RAM: 8b=113788-119312 32b=12128 SPI=3300264-3301108) OVMS>
