I (1253) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1264) cpu_start: Pro cpu up. I (1268) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-426-g56a6a42b I (1284) cpu_start: Compile time: Mar 29 2025 08:14:13 I (1290) cpu_start: ELF file SHA256: 96d26c67fedbd772... I (1296) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (0) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2181) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2187) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (45) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Power cycle reset detected I (71) events: Initialising EVENTS (1200) I (75) config: Initialising CONFIG (1400) I (81) time: Initialising TIME (1500) I (84) script: Initialising SCRIPTS (1600) I (89) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (94) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (100) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (106) metrics: Initialising METRICS (1810) I (112) metrics: Expanding DUKTAPE javascript engine I (117) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used I (139) notify: Initialising NOTIFICATIONS (1820) I (141) notify: Registered notification type info I (141) notify: Registered notification type error I (145) notify: Registered notification type alert I (150) notify: Registered notification type data I (156) notify: Registered notification type stream I (161) notify: Expanding DUKTAPE javascript engine I (167) location: Initialising LOCATIONS (1900) I (175) location: Expanding DUKTAPE javascript engine I (178) vehicle: Initialising VEHICLE Factory (2000) I (189) tls: Initialising TLS (3000) I (190) pcp: Initialising POWER (4000) I (192) max7317: Initialising MAX7317 EGPIO (4200) I (198) sdcard: Initialising SD CARD (4400) I (203) ota: Initialising OTA (4400) I (209) canformat: Initialising CAN Format Factory (4500) I (213) canformat-cs11: Registering CAN Format: CS11 (4505) I (219) canformat-crtd: Registering CAN Format: CRTD (4505) I (225) canformat-gvret: Registering CAN Format: GVRET (4505) I (232) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (238) canformat-panda: Registering CAN Format: PANDA (4505) I (245) canformat-pcap: Registering CAN Format: PCAP (4505) I (251) canformat-raw: Registering CAN Format: RAW (4505) I (257) can: Initialising CAN (4510) I (269) dbc-app: Initialising DBC (4520) I (272) canlog: Initialising CAN logging (4550) I (273) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (279) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (288) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (296) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (301) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (311) canlog-vfs: Initialising CAN logging to VFS (4560) I (314) canplay: Initialising CAN play framework (4570) I (320) canplay-vfs: Initialising CAN playing from VFS (4580) I (327) cellular: Initialising CELLULAR (4600) I (333) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (338) cellular-modem-auto: Registering auto-detect modem driver (4650) I (346) SIM5360: Registering SIM5360 modem driver (4650) I (352) SIM7000: Registering SIM7000 modem driver (4650) I (358) SIM7600: Registering SIM7600 modem driver (4650) I (364) SIM7670: Registering Simcom A7670E modem driver (4660) I (370) tpms: Initialising TPMS (4700) I (375) test: Initialising TEST (5000) I (380) module: Initialising MODULE (5100) I (385) vfs: Initialising VFS (5200) I (389) ovms-server: Initialising OVMS Server (6000) I (394) ovms-server-v2: Initialising OVMS V2 Server (6100) I (401) ovms-server-v3: Initialising OVMS V3 Server (6200) I (407) vehicle-poll: Initialising Poller (7000) I (414) obd2ecu: Initialising OBD2ECU (7000) I (418) canopen: Initialising CANopen (7000) I (426) pluginstore: Initialising PLUGINS (7100) I (428) esp32wifi: Initialising ESP32WIFI (8000) I (433) ovms-mdns: Initialising MDNS (8100) I (437) webserver: Initialising WEBSERVER (8200) I (445) ssh: Initialising SSH (8300) I (447) powermgmt: Initialising POWERMGMT (8500) I (452) re: Initialising RE Tools (8800) I (459) pushover: Initialising Pushover client (8800) I (464) netmanager: Initialising NETMANAGER (8999) I (471) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (474) v-zeva: Registering Vehicle: ZEVA (9000) I (479) v-vweup: Registering Vehicle: VW e-Up (9000) I (485) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (492) v-track: Registering Vehicle: TRACK (9000) I (498) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (505) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (511) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (518) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (525) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (531) v-smarteq: Registering Vehicle: SMART EQ (9000) I (537) v-smarted: Registering Vehicle: SMART ED (9000) I (543) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (550) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (557) v-twizy: Registering Vehicle: Renault Twizy (9000) I (563) v-obdii: Registering Vehicle: OBDII (9000) I (569) v-none: Registering Vehicle: NONE (9000) I (574) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (580) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (590) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (596) v-mgev4: Registering Vehicle: MG4 (9000) I (601) v-mgev: Registering Vehicle: MG5 (9000) I (606) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (613) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (619) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (625) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (631) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (637) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (644) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (650) v-maple60s: Registering Vehicle: Maple 60S (9000) I (656) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (663) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (670) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (677) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (684) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (691) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (697) v-energica: Registering Vehicle: Energica (9000) I (703) v-demo: Registering Vehicle: DEMO (9000) I (709) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (715) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (723) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (730) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (736) v-boltev: Registering Vehicle: Bolt EV (9000) I (742) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (747) version: Initialising Versioning (9900) I (758) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (838) ovms_main: Executing on CPU core 0 I (838) ovms_main: Mounting CONFIG... I (958) ovms_main: Configure logging... W (968) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (968) ovms_main: Registering default configs... I (968) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (968) ovms_main: Starting HOUSEKEEPING... I (988) housekeeping: Initialising HOUSEKEEPING Framework... I (988) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2158) pluginstore: Loading enabled plugins (2) I (2158) pluginstore: Load retools web page /plugins/retools I (2158) pluginstore: Loading enabled plugins (3) D (2168) events: Signal(housekeeping.init) I (2168) housekeeping: Executing on CPU core 1 I (2168) housekeeping: reset_reason: cpu0=1, cpu1=14 I (2178) housekeeping: Starting PERIPHERALS... I (2178) peripherals: Initialising OVMS Peripherals... I (2188) peripherals: TCP/IP Adaptor I (2188) peripherals: ESP32 system I (2198) peripherals: SPI bus I (2198) peripherals: MAX7317 I/O Expander I (2208) peripherals: ESP32 CAN I (2208) peripherals: ESP32 WIFI I (2218) peripherals: ESP32 ADC I (2218) peripherals: MCP2515 CAN 1/2 I (2218) mcp2515: can2: SetPowerMode off I (2308) peripherals: MCP2515 CAN 2/2 I (2308) mcp2515: can3: SetPowerMode off I (2388) peripherals: SD CARD I (2388) peripherals: CELLULAR MODEM I (2388) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2398) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2408) cellular: Starting modem task I (2408) uart: queue free spaces: 50 I (2408) ext12v: Powering off external 12V devices I (2418) housekeeping: Auto init max7317 (free: 160936 bytes) I (2428) housekeeping: Auto init ext12v (free: 160936 bytes) I (2428) housekeeping: Auto init dbc (free: 160936 bytes) I (2438) housekeeping: Auto init wifi (free: 160936 bytes) I (2438) housekeeping: Auto init modem (free: 160936 bytes) I (2448) housekeeping: Auto init Pollers (free: 160936 bytes) I (2448) cellular: Set modem driver to 'auto' I (2458) housekeeping: Auto init vehicle (free: 160936 bytes) I (2458) cellular: State: Enter PowerOffOn state I (2468) v-none: Generic NONE vehicle module I (2468) cellular-modem-auto: Power Cycle I (2478) housekeeping: Auto init obd2ecu (free: 149136 bytes) I (2478) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2488) housekeeping: Auto init server v2 (free: 149136 bytes) I (2498) housekeeping: Auto init server v3 (free: 149136 bytes) I (2508) housekeeping: Auto init javascript (free: 149136 bytes) I (2518) housekeeping: Auto init done (free: 149096 bytes) I (2518) housekeeping: Starting USB console... I (2528) uart: queue free spaces: 100 D (2538) events: Signal(egpio.output.1.low) D (2538) events: Signal(power.cellular.on) D (2538) events: Signal(system.modem.stop) D (2548) events: Signal(vehicle.type.set) D (2548) events: Signal(egpio.output.0.low) D (2548) events: Signal(system.start) I (2558) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-426-g56a6a42b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (2568) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> I (2698) ovms-duktape: Duktape: Initialising module system I (2878) pluginstore: Loading enabled plugins (1) OVMS> D (4178) events: Signal(vehicle.aux.12v.low) OVMS> D (4998) events: Signal(egpio.output.0.high) OVMS> I (7178) sdcard: SD CARD has been inserted OVMS> I (7388) sdcard: mount done D (7388) events: Signal(sd.insert) OVMS> D (9178) events: Signal(sd.mounted) I (9198) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (9998) events: Signal(egpio.output.0.low) D (10198) events: Signal(egpio.output.0.high) D (10198) cellular: State timeout PowerOffOn => PoweringOn I (10198) cellular: State: Enter PoweringOn state I (10198) cellular-modem-auto: Power Cycle I (10198) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10198) events: Signal(system.modem.poweringon) D (10198) events: Signal(egpio.output.0.low) OVMS> D (12698) events: Signal(egpio.output.0.high) OVMS> D (17698) events: Signal(egpio.output.0.low) D (17898) cellular: tx-cmd: AT D (17898) events: Signal(egpio.output.0.high) D (17898) cellular: tx-cmd: AT D (17898) cellular: tx-cmd: AT I (17898) cellular: State: Enter Identify state D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM OVMS> D (18178) cellular: tx-cmd: AT+CGMM I (18188) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (18188) cellular: Remove old 'auto' modem driver I (18188) cellular: Set modem driver to 'SIM7600' I (18188) cellular: State: Enter PoweredOn state D (18188) events: Signal(system.modem.installed) D (18188) events: Signal(system.modem.poweredon) OVMS> D (28178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 OVMS> D (30178) cellular: tx-cmd: AT+CGMR;+ICCID OVMS> D (38178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 OVMS> D (56518) cellular: mux-rx-line #0 (2/46): OK D (56518) cellular: mux-rx-line #0 (3/39): RDY D (56518) cellular: mux-rx-line #0 (12/23): +CPIN: READY D (56518) cellular: mux-rx-line #0 (8/11): SMS DONE D (56518) cellular: mux-rx-line #0 (7/0): PB DONE I (56518) cellular: State: Enter MuxStart state V (56518) cellular: Starting MUX D (56518) events: Signal(system.modem.muxstart) OVMS> D (62188) events: Signal(vehicle.alert.12v.on) D (62188) events: Signal(notify.alert.batt.12v.alert) OVMS> D (86178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS> D (87178) cellular: mux-tx #3: AT+CPSI? OVMS> D (88178) cellular: mux-tx #3: AT+COPS? OVMS> D (116178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS> D (117178) cellular: mux-tx #3: AT+CPSI? OVMS> D (118178) cellular: mux-tx #3: AT+COPS? OVMS> I (122188) housekeeping: System considered stable (RAM: 8b=113788-119020 32b=12128 SPI=3289088-3290608) OVMS> D (146178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS> D (147178) cellular: mux-tx #3: AT+CPSI? OVMS> D (148178) cellular: mux-tx #3: AT+COPS? OVMS> echo modem flashes Error: Secure command requires 'enable' mode OVMS> D (176178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (176178) cellular: State timeout MuxStart => PoweringOn I (176178) cellular: State: Enter PoweringOn state D (176178) cellular: Remove old 'SIM7600' modem driver I (176178) cellular: Set modem driver to 'auto' I (176178) cellular-modem-auto: Power Cycle I (176178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (176178) events: Signal(system.modem.poweringon) D (176188) events: Signal(egpio.output.0.low) OVMS> D (178678) events: Signal(egpio.output.0.high) OVMS> D (183678) events: Signal(egpio.output.0.low) D (183878) events: Signal(egpio.output.0.high) I (183878) cellular: State: Enter Identify state D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM D (183978) cellular: tx-cmd: AT+CGMM I (183988) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (183988) cellular: Remove old 'auto' modem driver I (183988) cellular: Set modem driver to 'SIM7600' I (183988) cellular: State: Enter PoweredOn state D (183988) events: Signal(system.modem.installed) D (183998) events: Signal(system.modem.poweredon) OVMS> D (193178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 OVMS> D (195178) cellular: tx-cmd: AT+CGMR;+ICCID OVMS> D (203178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 OVMS> D (223178) cellular: State timeout PoweredOn => PoweringOn I (223178) cellular: State: Enter PoweringOn state D (223178) cellular: Remove old 'SIM7600' modem driver I (223178) cellular: Set modem driver to 'auto' I (223178) cellular-modem-auto: Power Cycle I (223178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (223178) events: Signal(system.modem.poweringon) D (223178) events: Signal(egpio.output.0.low) OVMS> D (225678) events: Signal(egpio.output.0.high) OVMS> D (230678) events: Signal(egpio.output.0.low) D (230878) events: Signal(egpio.output.0.high) I (230878) cellular: State: Enter Identify state D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM D (230878) cellular: tx-cmd: AT+CGMM I (230898) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (230898) cellular: Remove old 'auto' modem driver I (230898) cellular: Set modem driver to 'SIM7600' I (230898) cellular: State: Enter PoweredOn state D (230898) events: Signal(system.modem.installed) D (230898) events: Signal(system.modem.poweredon) OVMS> D (240178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 OVMS> D (242178) cellular: tx-cmd: AT+CGMR;+ICCID OVMS> D (250178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 OVMS> D (269738) cellular: mux-rx-line #0 (2/46): OK D (269738) cellular: mux-rx-line #0 (3/39): RDY D (269738) cellular: mux-rx-line #0 (12/23): +CPIN: READY D (269738) cellular: mux-rx-line #0 (8/11): SMS DONE D (269738) cellular: mux-rx-line #0 (7/0): PB DONE I (269738) cellular: State: Enter MuxStart state D (269748) events: Signal(system.modem.muxstart) OVMS> # modem flashes slowly Unrecognised command OVMS> D (299178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS> D (300178) cellular: mux-tx #3: AT+CPSI? OVMS> D (301178) cellular: mux-tx #3: AT+COPS? OVMS> I (302198) housekeeping: 1970-01-01 01:05:02 CET (RAM: 8b=113788-118956 32b=12128 SPI=3289088-3290632) OVMS> # modem flashes fast Unrecognised command OVMS> D (329178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS> D (330178) cellular: mux-tx #3: AT+CPSI? OVMS> D (331178) cellular: mux-tx #3: AT+COPS? OVMS> enable Password: Secure mode OVMS# cellular status debug MODEM Status Model: SIM7600 Network Registration: Unknown Provider: Signal: 0 dBm Mode: State: MuxStart Ticker: 88 User Data: 0 UART: FIFO overflows: 0 Buffer overflows: 0 Parity errors: 0 Frame errors: 0 Driver Buffer overflows: 0 State Timeout Goto: PoweringOn (in 32 seconds) Mux: Status down Open Channels: 0 Framing Errors: 0 RX frames: 0 TX frames: 17 Last RX frame: 0 sec(s) ago PPP: Not running GPS: Not running OVMS# D (359178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS# D (360178) cellular: mux-tx #3: AT+CPSI? OVMS# D (361178) cellular: mux-tx #3: AT+COPS? OVMS# D (389178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (389178) cellular: State timeout MuxStart => PoweringOn I (389178) cellular: State: Enter PoweringOn state D (389178) cellular: Remove old 'SIM7600' modem driver I (389178) cellular: Set modem driver to 'auto' I (389178) cellular-modem-auto: Power Cycle I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (389178) events: Signal(system.modem.poweringon) D (389188) events: Signal(egpio.output.0.low) OVMS# D (391678) events: Signal(egpio.output.0.high) OVMS# D (396678) events: Signal(egpio.output.0.low) D (396878) events: Signal(egpio.output.0.high) I (396878) cellular: State: Enter Identify state D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM D (396978) cellular: tx-cmd: AT+CGMM I (397008) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (397008) cellular: Remove old 'auto' modem driver I (397008) cellular: Set modem driver to 'SIM7600' I (397008) cellular: State: Enter PoweredOn state D (397008) events: Signal(system.modem.installed) D (397008) events: Signal(system.modem.poweredon) OVMS# D (406178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 OVMS# D (408178) cellular: tx-cmd: AT+CGMR;+ICCID OVMS# D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 OVMS# e # mdoem odem D (434808) cellular: mux-rx-line #0 (2/46): OK D (434808) cellular: mux-rx-line #0 (3/39): RDY D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE D (434808) cellular: mux-rx-line #0 (7/0): PB DONE I (434808) cellular: State: Enter MuxStart state D (434808) events: Signal(system.modem.muxstart) OVMS# # modem D (464178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS# D (465178) cellular: mux-tx #3: AT+CPSI? OVMS# D (466178) cellular: mux-tx #3: AT+COPS? OVMS#
