################################################################################ ### COLD BOOT ################################################################################ I (1098) psram: This chip is ESP32-D0WD I (1098) spiram: Found 64MBit SPI RAM device I (1098) spiram: SPI RAM mode: flash 40m sram 40m I (1101) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1109) cpu_start: Pro cpu up. I (1112) cpu_start: Application information: I (1117) cpu_start: Project name: ovms3 I (1122) cpu_start: App version: 3.3.002-49-gffed9502 I (1128) cpu_start: Compile time: Aug 31 2022 11:09:19 I (1135) cpu_start: ELF file SHA256: 0cb3308b102d40e9... I (1141) cpu_start: ESP-IDF: v3.3.4-848-g1ff5e24b1b I (1147) cpu_start: Starting app cpu, entry point is 0x400818d4 I (0) cpu_start: App cpu up. I (2025) spiram: SPI SRAM memory test OK I (2025) heap_init: Initializing. RAM available for dynamic allocation: I (2025) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2031) heap_init: At 3FFBF790 len 00020870 (130 KiB): DRAM I (2038) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2044) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2051) heap_init: At 4009CCFC len 00003304 (12 KiB): IRAM I (2057) cpu_start: Pro cpu start user code I (2062) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (69) ovms_main: Set default logging level for * to INFO I (69) ovms_main: Initialising WATCHDOG... I (69) ovms-duktape: Initialising DUKTAPE Registry (1000) I (76) command: Initialising COMMAND (1010) I (81) command: Expanding DUKTAPE javascript engine I (86) boot: Initialising BOOT (1100) I (91) boot: Power cycle reset detected I (95) events: Initialising EVENTS (1200) I (100) config: Initialising CONFIG (1400) I (105) time: Initialising TIME (1500) I (110) script: Initialising SCRIPTS (1600) I (114) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (120) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (126) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (131) metrics: Initialising METRICS (1810) I (136) metrics: Expanding DUKTAPE javascript engine I (142) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used I (162) notify: Initialising NOTIFICATIONS (1820) I (163) notify: Registered notification type info I (163) notify: Registered notification type error I (168) notify: Registered notification type alert I (174) notify: Registered notification type data I (179) notify: Registered notification type stream I (185) notify: Expanding DUKTAPE javascript engine I (190) location: Initialising LOCATIONS (1900) I (198) location: Expanding DUKTAPE javascript engine I (201) vehicle: Initialising VEHICLE Factory (2000) I (209) tls: Initialising TLS (3000) I (211) pcp: Initialising POWER (4000) I (216) max7317: Initialising MAX7317 EGPIO (4200) I (221) sdcard: Initialising SD CARD (4400) I (226) ota: Initialising OTA (4400) I (231) canformat: Initialising CAN Format Factory (4500) I (236) canformat-crtd: Registering CAN Format: CS11 (4505) I (242) canformat-crtd: Registering CAN Format: CRTD (4505) I (249) canformat-gvret: Registering CAN Format: GVRET (4505) I (255) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (262) canformat-pcap: Registering CAN Format: PCAP (4505) I (268) canformat-raw: Registering CAN Format: RAW (4505) I (274) can: Initialising CAN (4510) I (282) dbc-app: Initialising DBC (4520) I (285) canlog: Initialising CAN logging (4550) I (289) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (296) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (304) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (312) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (318) canlog-vfs: Initialising CAN logging to VFS (4560) I (324) canplay: Initialising CAN play framework (4570) I (329) canplay-vfs: Initialising CAN playing from VFS (4580) I (336) cellular: Initialising CELLULAR (4600) I (342) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (348) cellular-modem-auto: Registering auto-detect modem driver (4650) I (356) SIM5360: Registering SIM5360 modem driver (4650) I (362) SIM7000: Registering SIM7000 modem driver (4650) I (368) SIM7600: Registering SIM7600 modem driver (4650) I (374) tpms: Initialising TPMS (4700) I (379) test: Initialising TEST (5000) I (383) module: Initialising MODULE (5100) I (388) vfs: Initialising VFS (5200) I (392) ovms-server: Initialising OVMS Server (6000) I (397) ovms-server-v2: Initialising OVMS V2 Server (6100) I (404) ovms-server-v3: Initialising OVMS V3 Server (6200) I (410) obd2ecu: Initialising OBD2ECU (7000) I (415) canopen: Initialising CANopen (7000) I (422) pluginstore: Initialising PLUGINS (7100) I (426) esp32wifi: Initialising ESP32WIFI (8000) I (431) ovms-mdns: Initialising MDNS (8100) I (435) webserver: Initialising WEBSERVER (8200) I (443) ssh: Initialising SSH (8300) I (445) powermgmt: Initialising POWERMGMT (8500) I (450) re: Initialising RE Tools (8800) I (456) pushover: Initialising Pushover client (8800) I (462) netmanager: Initialising NETMANAGER (8999) I (470) v-zeva: Registering Vehicle: ZEVA (9000) I (471) v-vweup: Registering Vehicle: VW e-Up (9000) I (476) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (484) v-track: Registering Vehicle: TRACK (9000) I (489) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (496) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (502) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (509) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (516) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (523) v-smarteq: Registering Vehicle: SMART EQ (9000) I (528) v-smarted: Registering Vehicle: SMART ED (9000) I (534) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (541) v-twizy: Registering Vehicle: Renault Twizy (9000) I (547) v-obdii: Registering Vehicle: OBDII (9000) I (552) v-none: Registering Vehicle: NONE (9000) I (558) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (564) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (573) v-mgev: Registering Vehicle: MG EV (UK/EU) (9000) I (580) v-mgev: Registering Vehicle: MG EV (TH) (9000) I (585) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (592) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (598) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (604) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (612) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (619) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (626) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (632) v-demo: Registering Vehicle: DEMO (9000) I (637) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (643) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (651) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (659) v-boltev: Registering Vehicle: Bolt EV (9000) I (665) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (670) version: Initialising Versioning (9900) I (680) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) ovms-duktape: Duktape: Scripting task is running I (748) ovms_main: Executing on CPU core 0 I (748) ovms_main: Mounting CONFIG... I (848) ovms_main: Configure logging... I (848) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 W (848) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (858) tls: Built trusted CA cache (5 entries, 8101 bytes) I (858) ovms_main: Registering default configs... I (898) ovms_main: Starting HOUSEKEEPING... I (898) housekeeping: Initialising HOUSEKEEPING Framework... I (1148) housekeeping: Executing on CPU core 1 I (1148) housekeeping: reset_reason: cpu0=1, cpu1=14 I (1148) housekeeping: Starting PERIPHERALS... I (1158) peripherals: Initialising OVMS Peripherals... I (1158) peripherals: TCP/IP Adaptor I (1168) peripherals: ESP32 system I (1168) peripherals: SPI bus I (1178) peripherals: MAX7317 I/O Expander I (1178) peripherals: ESP32 CAN I (1188) peripherals: ESP32 WIFI I (1188) peripherals: ESP32 ADC I (1188) peripherals: MCP2515 CAN 1/2 I (1198) mcp2515: can2: SetPowerMode off I (1278) peripherals: MCP2515 CAN 2/2 I (1278) mcp2515: can3: SetPowerMode off I (1358) peripherals: SD CARD I (1358) peripherals: CELLULAR MODEM I (1358) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1368) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1378) cellular: Starting modem task I (1378) uart: queue free spaces: 50 I (1378) ext12v: Powering off external 12V devices I (1388) housekeeping: Auto init max7317 (free: 174308 bytes) I (1398) housekeeping: Auto init ext12v (free: 174308 bytes) I (1398) housekeeping: Auto init dbc (free: 174308 bytes) I (1408) housekeeping: Auto init wifi (free: 174308 bytes) I (1428) wifi:wifi driver task: 3ffd650c, prio:23, stack:3584, core=0 I (1428) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1438) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1458) wifi:wifi firmware version: 30f9e79 I (1458) wifi:config NVS flash: enabled I (1458) wifi:config nano formating: disabled I (1458) wifi:Init data frame dynamic rx buffer num: 16 I (1468) wifi:Init management frame dynamic rx buffer num: 16 I (1478) wifi:Init management short buffer num: 32 I (1478) wifi:Init dynamic tx buffer num: 16 I (1478) wifi:Init static rx buffer size: 2212 I (1488) wifi:Init static rx buffer num: 16 I (1488) wifi:Init dynamic rx buffer num: 16 I (1578) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (1588) wifi:mode : sta (78:e3:6d:61:e5:e0) I (1588) housekeeping: Auto init modem (free: 131036 bytes) I (1588) housekeeping: Auto init vehicle (free: 130776 bytes) I (1588) cellular: Set modem driver to 'auto' I (1598) v-vweup: Start VW e-Up vehicle module I (1598) cellular: State: Enter PoweringOn state D (1608) v-vweup: VW e-Up reload configuration I (1608) cellular-modem-auto: Power Cycle 2000ms I (1618) v-vweup: Starting connection: OBDII I (1628) v-vweup: PollSetState: OFF -> OFF D (1628) v-vweup: Poll vector: size=145 cap=164 I (1638) housekeeping: Auto init obd2ecu (free: 118824 bytes) I (1638) housekeeping: Auto init server v2 (free: 118824 bytes) I (1648) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (1658) ovms-server-v2: Status: Server has been started I (1658) ovms-server-v2: OVMS Server v2 running I (1668) housekeeping: Auto init server v3 (free: 118716 bytes) I (1668) housekeeping: Auto init javascript (free: 118716 bytes) I (1678) housekeeping: Auto init done (free: 118716 bytes) I (1688) housekeeping: Starting USB console... I (1688) uart: queue free spaces: 100 I (1718) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.002-49-gffed9502/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (1728) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) I (1858) ovms-duktape: Duktape: Initialising module system D (1868) ovms-duktape: Duktape: Pre-Registered function assert D (1878) ovms-duktape: Duktape: Pre-Registered function meminfo D (1878) ovms-duktape: Duktape: Pre-Registered function print D (1878) ovms-duktape: Duktape: Pre-Registered function write D (1878) ovms-duktape: Duktape: Pre-Registered object HTTP D (1878) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (1878) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (1878) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (1888) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (1898) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (1908) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (1908) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (1908) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (1908) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (1908) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (1908) ovms-duktape: Duktape: Pre-Registered object VFS D (1908) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (1908) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (1908) ovms-duktape: Duktape: Pre-Registered module JSON D (1928) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (1928) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (1928) ovms-duktape: Duktape: module load: int/JSON.js D (2008) ovms-duktape: Duktape: Pre-Registered module PubSub D (2028) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (2028) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (2028) ovms-duktape: Duktape: module load: int/PubSub.js D (2148) v-vweup: PollerStateTicker: [online] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=1 => PollState 0->1 I (2148) v-vweup: PollerStateTicker: Setting car state to AWAKE I (2148) v-vweup: PollSetState: OFF -> AWAKE E (2148) can: can1: intr=2 rxpkt=0 txpkt=0 errflags=0x8000a2 rxerr=10 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 E (2148) can: can1: intr=25 rxpkt=0 txpkt=0 errflags=0x8040a2 rxerr=135 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 D (3148) v-vweup: PollerStateTicker: [offline] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=2 => PollState 1->0 I (3148) v-vweup: PollerStateTicker: Setting car state to OFF I (3148) v-vweup: PollSetState: AWAKE -> OFF D (3618) cellular: tx-cmd: AT D (3618) cellular: tx-cmd: AT D (4148) cellular: tx-cmd: AT D (5148) cellular: tx-cmd: AT I (6148) sdcard: SD CARD has been inserted I (6398) sdcard: mount done D (6398) cellular: tx-cmd: AT D (7148) cellular: tx-cmd: AT D (8148) cellular: tx-cmd: AT I (8388) command: OpenLogfile: now logging to file '/sd/logs/log' D (9148) cellular: tx-cmd: AT D (10148) cellular: tx-cmd: AT D (11148) cellular: tx-cmd: AT D (12148) cellular: tx-cmd: AT D (13148) cellular: tx-cmd: AT D (14148) cellular: tx-cmd: AT D (15148) cellular: tx-cmd: AT I (15368) cellular: State: Enter Identify state D (16148) cellular: tx-cmd: AT+CGMM I (16158) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (16158) cellular: Remove old 'auto' modem driver I (16158) cellular: Set modem driver to 'SIM7600' I (16158) cellular: State: Enter PoweredOn state D (26148) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26178) cellular: mux-rx-line #0: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26178) cellular: mux-rx-line #0: +CPIN: READY D (26178) cellular: mux-rx-line #0: +CSQ: 19,0 I (26178) cellular: Signal Quality is: 19 (-75 dBm) D (28148) cellular: tx-cmd: AT+CGMR;+ICCID D (28158) cellular: mux-rx-line #0: +CGMR: LE20B03SIM7600M21-A D (28158) cellular: mux-rx-line #0: +ICCID: 8944500408175816389 D (36148) cellular: tx-cmd: AT+CMUX=0 I (36158) cellular: State: Enter MuxStart state V (36158) cellular: Starting MUX D (37148) cellular: State transition MuxStart => NetWait I (37148) cellular: State: Enter NetWait state V (37148) cellular: Starting NMEA D (37148) cellular: mux-tx #4: AT+CGPS=0 D (39148) cellular: mux-tx #4: AT+CGPSNMEA=258 D (39148) cellular: mux-tx #4: AT+CGPSINFOCFG=5,258 D (39148) cellular: mux-tx #4: AT+CGPS=1,1 D (47148) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? D (47178) cellular: mux-rx-line #3: +CPSI: GSM,Online,262-02,0x011f,1161,5 EGSM 900,-71,0,0-0 D (47178) cellular: mux-rx-line #3: +CREG: 1,5 I (47188) cellular: Network Registration status: RegisteredRoaming D (47188) cellular: mux-rx-line #3: +CGREG: 1,5 D (47188) cellular: mux-rx-line #3: +CEREG: 1,4 D (47188) cellular: mux-rx-line #3: +CCLK: "22/09/04,09:57:01+08" D (47188) cellular: mux-rx-line #3: +CSQ: 19,0 D (47188) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",0 I (47188) cellular: Network Provider is: vodafone.de Hologram D (48148) cellular: State transition NetWait => NetStart I (48148) cellular: State: Enter NetStart state D (49148) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (49208) cellular: mux-rx-line #2: CONNECT 115200 I (49208) cellular: PPP Connection is ready to start D (50148) cellular: State transition NetStart => NetMode I (50148) cellular: State: Enter NetMode state V (50148) cellular: Launching PPP V (50148) cellular: Starting PPP D (50278) netmanager: Saved DNS#0 8.8.8.8 D (50278) netmanager: Saved DNS#1 8.8.4.4 D (50278) netmanager: Saved DNS#2 0.0.0.0 I (50278) netmanager: Interface priority is pp2 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (50278) netmanager: Set DNS#2 0.0.0.0 I (50278) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (50298) netmanager: MongooseTask starting I (50318) ssh: Launching SSH Server I (50328) ovms-server-v2: Status: Network is up, so attempt network connection I (52148) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (52148) ovms-server-v2: Status: Connecting... D (53768) cellular: mux-rx-line #3: +CSQ: 19,4 D (53778) cellular: mux-rx-line #4: +CSQ: 19,4 I (57408) ovms-server-v2: Connection successful I (57408) ovms-server-v2: Status: Logging in... I (57408) ovms-server-v2: Sending server login: MP-C 0 9aLCV1XC6aRA1mY7C7vWsN 4cPUXCevkC2ACgIMYPCSjw== TEST1 I (57678) ovms-server-v2: Got server response: MP-S 0 gpci2Zbz6Rf5SYu0df7Ed8 GYS67nIbmNv8jpXW7FrlzQ== I (57678) ovms-server-v2: Server token is gpci2Zbz6Rf5SYu0df7Ed8 and digest is GYS67nIbmNv8jpXW7FrlzQ== I (57678) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (57678) ovms-server-v2: Shared secret key is gpci2Zbz6Rf5SYu0df7Ed89aLCV1XC6aRA1mY7C7vWsN (44 bytes) I (57678) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (57708) ovms-server-v2: Incoming Msg: MP-0 Z0 I (58148) ovms-server-v2: Send MP-0 S0,K,0,0.00,stopped,range,0,0,32,0,0,0,0,21,3,0,0,0,120.00,318,0,0,80,-1,0,0,0,0,247,260,0,0.00,0.00,0,0.00,0.00,0.00,0.0 I (58148) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,57,0,0,1,1,0,0,12.6,0,0,0,0 I (58148) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0.000,0,0,0,0,,0,0,0,0 I (58158) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (58158) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (58158) ovms-server-v2: Send MP-0 F3.3.002-49-gffed9502/factory/edge (build idf v3.3.4-848-g1ff5e24b1b Aug 31 2022 11:09:20),,19,0,VWUP,vodafone.de Hologram,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 D (59708) cellular: mux-rx-line #3: +CSQ: 19,0 D (59708) cellular: mux-rx-line #4: +CSQ: 19,0 D (61198) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms D (61708) cellular: mux-rx-line #3: +CSQ: 19,99 D (61708) cellular: mux-rx-line #4: +CSQ: 19,99 D (66888) cellular: mux-rx-line #3: +CTZV: 8,22/09/04,07:57:06 D (66888) cellular: mux-rx-line #4: +CTZV: 8,22/09/04,07:57:06 D (66908) cellular: mux-rx-line #3: +CTZV: 8,22/09/04,07:57:22 D (66908) cellular: mux-rx-line #4: +CTZV: 8,22/09/04,07:57:22 I (69198) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=12 hdop=1.0 sq=100 invalid=1 D (69718) cellular: mux-rx-line #3: +CSQ: 14,99 I (69718) cellular: Signal Quality is: 14 (-85 dBm) D (69718) cellular: mux-rx-line #4: +CSQ: 14,99 D (70718) cellular: mux-rx-line #3: +CSQ: 21,99 I (70718) cellular: Signal Quality is: 21 (-71 dBm) D (70718) cellular: mux-rx-line #4: +CSQ: 21,99 D (80148) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? D (80178) cellular: mux-rx-line #3: +CPSI: LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-113,-980,-698,17 D (80188) cellular: mux-rx-line #3: +CREG: 1,5 D (80188) cellular: mux-rx-line #3: +CGREG: 1,5 D (80188) cellular: mux-rx-line #3: +CEREG: 1,5 D (80188) cellular: mux-rx-line #3: +CCLK: "22/09/04,09:57:35+08" D (80188) cellular: mux-rx-line #3: +CSQ: 21,99 D (80188) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7 OVMS# module reset Resetting system... I (107518) boot: Shutting down for Restart... I (107528) wifi:flush txq I (107528) wifi:stop sw txq I (107538) wifi:lmac stop hw txq I (107538) wifi:Deinit lldesc rx mblock:16 W (107548) boot: Shutdown: sdcard pending, 1 total I (107548) sdcard: Unmounting SDCARD for reset W (107548) boot: Shutdown: cellular pending, 2 total I (107548) cellular: State: Enter PoweringOff state W (107548) boot: Shutdown: webserver pending, 3 total V (107548) cellular: Stopping PPP V (107548) cellular: Stopping NMEA D (107548) cellular: mux-tx #4: AT+CGPS=0 I (107548) SIM7600: Power Cycle (SIM7600) 2000ms I (107548) netmanager: Set DNS#2 0.0.0.0 D (107548) netmanager: send cmd 3 from 0x0 D (107558) netmanager: done cmd 3 from 0x0 I (107558) netmanager: Set DNS#2 0.0.0.0 D (107558) netmanager: send cmd 3 from 0x0 D (107558) netmanager: done cmd 3 from 0x0 E (107558) mongoose: mg_ssl_if_mbed_err 0x3f8bf3e4 SSL error: -1 I (107588) ovms-server-v2: Status: Disconnected D (107588) netmanager: MongooseTask: got cmd 3 from 0x0 D (107588) netmanager: MongooseTask: done cmd 3 from 0x0 D (107588) netmanager: MongooseTask: got cmd 3 from 0x0 D (107588) netmanager: MongooseTask: done cmd 3 from 0x0 I (107748) command: CloseLogfile: file logging stopped I (107748) sdcard: unmount done I (107748) netmanager: MODEM down (with WIFI client down): network connectivity has been lost W (107768) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 11/40 D (107848) netmanager: MongooseTask stopping I (107848) ssh: Stopping SSH Server I (108148) ovms-server-v2: Status: Server is ready to start I (110148) boot: Shutdown: sdcard ready, 2 pending I (110148) boot: Shutdown: webserver ready, 1 pending I (112148) boot: Restart in 55 seconds (1 pending)... I (117148) boot: Restart in 50 seconds (1 pending)... I (121158) housekeeping: System considered stable (RAM: 8b=66492-140392 32b=12344 SPI=3396076-3420796) D (121208) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms I (122148) boot: Restart in 45 seconds (1 pending)... D (127148) cellular: State timeout PoweringOff => CheckPowerOff I (127148) cellular: State: Enter CheckPowerOff state I (127148) boot: Restart in 40 seconds (1 pending)... I (129168) cellular: State: Enter PoweringOff state V (129178) cellular: Stopping PPP I (129178) SIM7600: Power Cycle (SIM7600) 4000ms I (132148) boot: Restart in 35 seconds (1 pending)... I (137148) boot: Restart in 30 seconds (1 pending)... I (142148) boot: Restart in 25 seconds (1 pending)... I (147148) boot: Restart in 20 seconds (1 pending)... D (149148) cellular: State timeout PoweringOff => CheckPowerOff I (149148) cellular: State: Enter CheckPowerOff state I (152148) boot: Restart in 15 seconds (1 pending)... I (157148) boot: Restart in 10 seconds (1 pending)... D (160148) cellular: tx-cmd: AT D (161148) cellular: tx-cmd: AT D (162148) cellular: tx-cmd: AT I (162148) boot: Restart in 5 seconds (1 pending)... D (163148) cellular: tx-cmd: AT D (164148) cellular: tx-cmd: AT D (164148) cellular: State timeout CheckPowerOff => PoweredOff I (164148) cellular: State: Enter PoweredOff state I (164148) boot: Shutdown: cellular ready, 0 pending V (164148) cellular: Stopping MUX I (164148) boot: Restart now ################################################################################ ################################################################################ ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5324 load:0x40078000,len:11256 load:0x40080400,len:6252 entry 0x400806d4 I (1097) psram: This chip is ESP32-D0WD I (1098) spiram: Found 64MBit SPI RAM device I (1098) spiram: SPI RAM mode: flash 40m sram 40m I (1101) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1108) cpu_start: Pro cpu up. I (1112) cpu_start: Application information: I (1117) cpu_start: Project name: ovms3 I (1122) cpu_start: App version: 3.3.002-49-gffed9502 I (1128) cpu_start: Compile time: Aug 31 2022 11:09:19 I (1134) cpu_start: ELF file SHA256: 0cb3308b102d40e9... I (1140) cpu_start: ESP-IDF: v3.3.4-848-g1ff5e24b1b I (1147) cpu_start: Starting app cpu, entry point is 0x400818d4 I (1139) cpu_start: App cpu up. I (2024) spiram: SPI SRAM memory test OK I (2025) heap_init: Initializing. RAM available for dynamic allocation: I (2025) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2031) heap_init: At 3FFBF790 len 00020870 (130 KiB): DRAM I (2038) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2044) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2050) heap_init: At 4009CCFC len 00003304 (12 KiB): IRAM I (2057) cpu_start: Pro cpu start user code I (2062) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (68) ovms_main: Set default logging level for * to INFO I (69) ovms_main: Initialising WATCHDOG... I (69) ovms-duktape: Initialising DUKTAPE Registry (1000) I (76) command: Initialising COMMAND (1010) I (81) command: Expanding DUKTAPE javascript engine I (86) boot: Initialising BOOT (1100) I (91) boot: Boot #1 reasons for CPU0=12 and CPU1=12 I (96) boot: Reset reason Unknown/unset (0) I (101) boot: Soft reset by user I (105) events: Initialising EVENTS (1200) I (110) config: Initialising CONFIG (1400) I (115) time: Initialising TIME (1500) I (119) script: Initialising SCRIPTS (1600) I (124) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (129) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (135) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (141) metrics: Initialising METRICS (1810) I (146) metrics: Expanding DUKTAPE javascript engine I (152) metrics: Persistent metrics serial 2 using 820 bytes, 71/100 slots used I (161) metrics: persist v.b.cac = 120Ah I (165) metrics: persist v.b.12v.voltage.ref = 12.6V I (171) metrics: persist v.c.climit = 32A I (176) metrics: persist v.c.limit.soc = 80% I (184) metrics: persist v.e.parktime = 164Sec I (186) metrics: persist v.p.latitude = 51.3024 I (190) metrics: persist v.p.longitude = 7.38981 I (196) metrics: persist v.p.altitude = 343.6m I (202) notify: Initialising NOTIFICATIONS (1820) I (207) notify: Registered notification type info I (211) notify: Registered notification type error I (216) notify: Registered notification type alert I (222) notify: Registered notification type data I (227) notify: Registered notification type stream I (233) notify: Expanding DUKTAPE javascript engine I (239) location: Initialising LOCATIONS (1900) I (246) location: Expanding DUKTAPE javascript engine I (249) vehicle: Initialising VEHICLE Factory (2000) I (257) tls: Initialising TLS (3000) I (260) pcp: Initialising POWER (4000) I (264) max7317: Initialising MAX7317 EGPIO (4200) I (270) sdcard: Initialising SD CARD (4400) I (274) ota: Initialising OTA (4400) I (280) canformat: Initialising CAN Format Factory (4500) I (284) canformat-crtd: Registering CAN Format: CS11 (4505) I (291) canformat-crtd: Registering CAN Format: CRTD (4505) I (297) canformat-gvret: Registering CAN Format: GVRET (4505) I (303) canformat-lawricel: Registering CAN Format: LAWRICEL (4505) I (310) canformat-pcap: Registering CAN Format: PCAP (4505) I (316) canformat-raw: Registering CAN Format: RAW (4505) I (323) can: Initialising CAN (4510) I (330) dbc-app: Initialising DBC (4520) I (333) canlog: Initialising CAN logging (4550) I (337) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (344) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (352) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (360) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (366) canlog-vfs: Initialising CAN logging to VFS (4560) I (372) canplay: Initialising CAN play framework (4570) I (378) canplay-vfs: Initialising CAN playing from VFS (4580) I (384) cellular: Initialising CELLULAR (4600) I (390) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (396) cellular-modem-auto: Registering auto-detect modem driver (4650) I (404) SIM5360: Registering SIM5360 modem driver (4650) I (410) SIM7000: Registering SIM7000 modem driver (4650) I (416) SIM7600: Registering SIM7600 modem driver (4650) I (422) tpms: Initialising TPMS (4700) I (427) test: Initialising TEST (5000) I (432) module: Initialising MODULE (5100) I (437) vfs: Initialising VFS (5200) I (441) ovms-server: Initialising OVMS Server (6000) I (445) ovms-server-v2: Initialising OVMS V2 Server (6100) I (452) ovms-server-v3: Initialising OVMS V3 Server (6200) I (458) obd2ecu: Initialising OBD2ECU (7000) I (463) canopen: Initialising CANopen (7000) I (471) pluginstore: Initialising PLUGINS (7100) I (474) esp32wifi: Initialising ESP32WIFI (8000) I (479) ovms-mdns: Initialising MDNS (8100) I (483) webserver: Initialising WEBSERVER (8200) I (491) ssh: Initialising SSH (8300) I (493) powermgmt: Initialising POWERMGMT (8500) I (499) re: Initialising RE Tools (8800) I (504) pushover: Initialising Pushover client (8800) I (510) netmanager: Initialising NETMANAGER (8999) I (518) v-zeva: Registering Vehicle: ZEVA (9000) I (519) v-vweup: Registering Vehicle: VW e-Up (9000) I (525) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (532) v-track: Registering Vehicle: TRACK (9000) I (537) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (544) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (550) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (557) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (564) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (571) v-smarteq: Registering Vehicle: SMART EQ (9000) I (577) v-smarted: Registering Vehicle: SMART ED (9000) I (583) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (589) v-twizy: Registering Vehicle: Renault Twizy (9000) I (595) v-obdii: Registering Vehicle: OBDII (9000) I (601) v-none: Registering Vehicle: NONE (9000) I (606) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (612) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (622) v-mgev: Registering Vehicle: MG EV (UK/EU) (9000) I (628) v-mgev: Registering Vehicle: MG EV (TH) (9000) I (634) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (640) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (646) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (653) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (660) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (667) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (674) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (680) v-demo: Registering Vehicle: DEMO (9000) I (685) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (692) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (700) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (707) v-boltev: Registering Vehicle: Bolt EV (9000) I (713) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (718) version: Initialising Versioning (9900) I (727) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (0) ovms-duktape: Duktape: Scripting task is running I (796) ovms_main: Executing on CPU core 0 I (796) ovms_main: Mounting CONFIG... I (896) ovms_main: Configure logging... I (896) location: UpdateParkPosition: vehicle is parking @51.302448,7.389812 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 W (896) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (906) tls: Built trusted CA cache (5 entries, 8101 bytes) I (906) ovms_main: Registering default configs... I (946) ovms_main: Starting HOUSEKEEPING... I (946) housekeeping: Initialising HOUSEKEEPING Framework... I (1196) housekeeping: Executing on CPU core 1 I (1196) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1196) housekeeping: Starting PERIPHERALS... I (1206) peripherals: Initialising OVMS Peripherals... I (1206) peripherals: TCP/IP Adaptor I (1216) peripherals: ESP32 system I (1216) peripherals: SPI bus I (1226) peripherals: MAX7317 I/O Expander I (1226) peripherals: ESP32 CAN I (1236) peripherals: ESP32 WIFI I (1236) peripherals: ESP32 ADC I (1236) peripherals: MCP2515 CAN 1/2 I (1246) mcp2515: can2: SetPowerMode off I (1326) peripherals: MCP2515 CAN 2/2 I (1326) mcp2515: can3: SetPowerMode off I (1406) peripherals: SD CARD I (1406) peripherals: CELLULAR MODEM I (1406) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1416) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1426) cellular: Starting modem task I (1426) uart: queue free spaces: 50 I (1426) ext12v: Powering off external 12V devices I (1436) housekeeping: Auto init max7317 (free: 173788 bytes) I (1446) housekeeping: Auto init ext12v (free: 173788 bytes) I (1446) housekeeping: Auto init dbc (free: 173788 bytes) I (1456) housekeeping: Auto init wifi (free: 173788 bytes) I (1476) wifi:wifi driver task: 3ffd6720, prio:23, stack:3584, core=0 I (1476) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1486) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1506) wifi:wifi firmware version: 30f9e79 I (1506) wifi:config NVS flash: enabled I (1506) wifi:config nano formating: disabled I (1506) wifi:Init data frame dynamic rx buffer num: 16 I (1516) wifi:Init management frame dynamic rx buffer num: 16 I (1526) wifi:Init management short buffer num: 32 I (1526) wifi:Init dynamic tx buffer num: 16 I (1526) wifi:Init static rx buffer size: 2212 I (1536) wifi:Init static rx buffer num: 16 I (1536) wifi:Init dynamic rx buffer num: 16 I (1626) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (1626) wifi:mode : sta (78:e3:6d:61:e5:e0) I (1626) housekeeping: Auto init modem (free: 130516 bytes) I (1636) housekeeping: Auto init vehicle (free: 130256 bytes) I (1636) cellular: Set modem driver to 'auto' I (1646) v-vweup: Start VW e-Up vehicle module I (1646) cellular: State: Enter PoweringOn state D (1646) v-vweup: VW e-Up reload configuration I (1656) cellular-modem-auto: Power Cycle 2000ms I (1656) v-vweup: Starting connection: OBDII I (1676) v-vweup: PollSetState: OFF -> OFF D (1676) v-vweup: Poll vector: size=145 cap=164 I (1676) housekeeping: Auto init obd2ecu (free: 118304 bytes) I (1686) housekeeping: Auto init server v2 (free: 118304 bytes) I (1696) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (1696) ovms-server-v2: Status: Server has been started I (1706) ovms-server-v2: OVMS Server v2 running I (1716) housekeeping: Auto init server v3 (free: 118196 bytes) I (1716) housekeeping: Auto init javascript (free: 118196 bytes) I (1726) housekeeping: Auto init done (free: 118196 bytes) I (1726) housekeeping: Starting USB console... I (1736) uart: queue free spaces: 100 I (1766) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.002-49-gffed9502/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 I (1776) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) I (1896) ovms-duktape: Duktape: Initialising module system D (1906) ovms-duktape: Duktape: Pre-Registered function assert D (1916) ovms-duktape: Duktape: Pre-Registered function meminfo D (1916) ovms-duktape: Duktape: Pre-Registered function print D (1916) ovms-duktape: Duktape: Pre-Registered function write D (1916) ovms-duktape: Duktape: Pre-Registered object HTTP D (1916) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (1916) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (1916) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (1926) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (1936) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (1946) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (1946) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (1946) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (1946) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (1946) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (1946) ovms-duktape: Duktape: Pre-Registered object VFS D (1946) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (1946) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (1946) ovms-duktape: Duktape: Pre-Registered module JSON D (1956) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (1966) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (1966) ovms-duktape: Duktape: module load: int/JSON.js D (2046) ovms-duktape: Duktape: Pre-Registered module PubSub D (2056) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (2066) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (2066) ovms-duktape: Duktape: module load: int/PubSub.js D (2196) v-vweup: PollerStateTicker: [online] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=1 => PollState 0->1 I (2196) v-vweup: PollerStateTicker: Setting car state to AWAKE I (2196) v-vweup: PollSetState: OFF -> AWAKE E (2196) can: can1: intr=2 rxpkt=0 txpkt=0 errflags=0x8000a2 rxerr=10 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 E (2196) can: can1: intr=25 rxpkt=0 txpkt=0 errflags=0x8040a2 rxerr=135 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 D (3196) v-vweup: PollerStateTicker: [offline] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=2 => PollState 1->0 I (3196) v-vweup: PollerStateTicker: Setting car state to OFF I (3196) v-vweup: PollSetState: AWAKE -> OFF D (3666) cellular: tx-cmd: AT D (3666) cellular: tx-cmd: AT D (4196) cellular: tx-cmd: AT D (5196) cellular: tx-cmd: AT I (5196) cellular: State: Enter Identify state I (6196) sdcard: SD CARD has been inserted I (6266) sdcard: mount done D (6266) cellular: tx-cmd: AT+CGMM D (7196) cellular: tx-cmd: AT+CGMM D (8196) cellular: tx-cmd: AT+CGMM I (8436) command: OpenLogfile: now logging to file '/sd/logs/log' D (9196) cellular: tx-cmd: AT+CGMM D (10196) cellular: tx-cmd: AT+CGMM D (11196) cellular: tx-cmd: AT+CGMM D (12196) cellular: tx-cmd: AT+CGMM D (13196) cellular: tx-cmd: AT+CGMM W (13196) cellular: UART frame error D (14196) cellular: tx-cmd: AT+CGMM D (15196) cellular: tx-cmd: AT+CGMM D (16196) cellular: tx-cmd: AT+CGMM D (17196) cellular: tx-cmd: AT+CGMM D (18196) cellular: tx-cmd: AT+CGMM D (19196) cellular: tx-cmd: AT+CGMM I (19206) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (19206) cellular: Remove old 'auto' modem driver I (19206) cellular: Set modem driver to 'SIM7600' I (19206) cellular: State: Enter PoweredOn state D (29196) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 W (29196) cellular: UART frame error W (29196) cellular: UART frame error W (29196) cellular: UART frame error W (29206) cellular: UART frame error W (29206) cellular: UART frame error W (29206) cellular: UART frame error W (29206) cellular: UART frame error D (29226) cellular: mux-rx-line #0: ­ÿÿß×ÿïýýÿw¿ÿíß_÷ïœÿÿÿuÿœêÕÿ××AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (29226) cellular: mux-rx-line #0: +CPIN: READY D (29226) cellular: mux-rx-line #0: +CSQ: 18,0 I (29226) cellular: Signal Quality is: 18 (-77 dBm) D (31196) cellular: tx-cmd: AT+CGMR;+ICCID D (31216) cellular: mux-rx-line #0: ÿÿý¿ D (31216) cellular: mux-rx-line #0: +CGMR: LE20B03SIM7600M21-A D (31216) cellular: mux-rx-line #0: +ICCID: 8944500408175816389 D (39196) cellular: tx-cmd: AT+CMUX=0 I (39206) cellular: State: Enter MuxStart state V (39206) cellular: Starting MUX W (39226) cellular: UART frame error D (40196) cellular: State transition MuxStart => NetWait I (40196) cellular: State: Enter NetWait state V (40196) cellular: Starting NMEA D (40196) cellular: mux-tx #4: AT+CGPS=0 D (42196) cellular: mux-tx #4: AT+CGPSNMEA=258 D (42196) cellular: mux-tx #4: AT+CGPSINFOCFG=5,258 D (42196) cellular: mux-tx #4: AT+CGPS=1,1 I (47256) location: UpdateParkPosition: vehicle is parking @51.302448,7.389812 gpslock=0 satcount=12 hdop=1.1 sq=99 invalid=1 I (47256) location: UpdateParkPosition: vehicle is parking @51.302414,7.389933 gpslock=0 satcount=12 hdop=1.1 sq=99 invalid=0 D (50196) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? D (50226) cellular: mux-rx-line #3: +CPSI: GSM,Online,262-02,0x011f,1161,5 EGSM 900,-72,0,0-0 D (50236) cellular: mux-rx-line #3: +CREG: 1,5 I (50236) cellular: Network Registration status: RegisteredRoaming D (50236) cellular: mux-rx-line #3: +CGREG: 1,5 D (50236) cellular: mux-rx-line #3: +CEREG: 1,4 D (50236) cellular: mux-rx-line #3: +CCLK: "22/09/04,09:59:52+08" D (50236) cellular: mux-rx-line #3: +CSQ: 18,0 D (50236) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",0 I (50236) cellular: Network Provider is: vodafone.de Hologram D (51196) cellular: State transition NetWait => NetStart I (51196) cellular: State: Enter NetStart state D (51326) cellular: mux-rx-line #2: +CSQ: 18,7 D (51326) cellular: mux-rx-line #3: +CSQ: 18,7 D (51326) cellular: mux-rx-line #4: +CSQ: 18,7 D (52196) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 W (52196) cellular: UART frame error D (52286) cellular: mux-rx-line #2: CONNECT 115200 I (52286) cellular: PPP Connection is ready to start D (53196) cellular: State transition NetStart => NetMode I (53196) cellular: State: Enter NetMode state V (53196) cellular: Launching PPP V (53196) cellular: Starting PPP W (53226) cellular: UART frame error W (53226) cellular: UART frame error D (53336) cellular: mux-rx-line #3: +CSQ: 18,0 D (53336) cellular: mux-rx-line #4: +CSQ: 18,0 D (53346) netmanager: Saved DNS#0 8.8.8.8 D (53346) netmanager: Saved DNS#1 8.8.4.4 D (53346) netmanager: Saved DNS#2 0.0.0.0 I (53346) netmanager: Interface priority is pp2 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (53346) netmanager: Set DNS#2 0.0.0.0 I (53346) netmanager: MODEM up (with WIFI client down): starting network with MODEM W (53356) cellular: UART frame error W (53356) cellular: UART frame error D (53366) netmanager: MongooseTask starting I (53386) ssh: Launching SSH Server I (53396) ovms-server-v2: Status: Network is up, so attempt network connection W (54216) cellular: UART frame error W (54216) cellular: UART frame error W (54226) cellular: UART frame error D (54916) cellular: mux-rx-line #3: +CSQ: 18,7 D (54916) cellular: mux-rx-line #4: +CSQ: 18,7 I (55196) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (55196) ovms-server-v2: Status: Connecting... W (55206) cellular: UART frame error W (55216) cellular: UART frame error W (55216) cellular: UART frame error W (55226) cellular: UART frame error W (55226) cellular: UART frame error W (55226) cellular: UART frame error W (55226) cellular: UART frame error W (55226) cellular: UART frame error D (55336) cellular: mux-rx-line #3: +CSQ: 18,99 D (55336) cellular: mux-rx-line #4: +CSQ: 18,99 W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57216) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) gsm-mux: Frame error: EOF mismatch (CHAN=1, ADDR=05, CTRL=ff, FCS=eb, LEN=78) W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error W (57226) cellular: UART frame error D (57506) cellular: UART rx break W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57506) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) gsm-mux: Frame error: EOF mismatch (CHAN=2, ADDR=09, CTRL=ff, FCS=82, LEN=85) W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error D (57516) cellular: UART rx break W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57516) cellular: UART frame error W (57546) cellular: UART frame error W (57546) cellular: UART frame error W (57656) cellular: UART frame error W (57656) cellular: UART frame error W (57656) cellular: UART frame error W (57656) cellular: UART frame error W (58386) cellular: UART frame error W (58396) cellular: UART frame error W (58406) cellular: UART frame error W (58406) cellular: UART frame error W (58406) cellular: UART frame error W (58406) cellular: UART frame error W (58406) cellular: UART frame error W (59266) cellular: UART frame error W (59346) gsm-mux: Frame error: EOF mismatch (CHAN=58, ADDR=ea, CTRL=fd, FCS=ff, LEN=120) W (59796) cellular: UART frame error W (59796) cellular: UART frame error W (60546) cellular: UART frame error D (61246) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms D (61406) cellular: mux-rx-line #3: +CSQ: 21,4 I (61416) cellular: Signal Quality is: 21 (-71 dBm) D (61416) cellular: mux-rx-line #4: +CSQ: 21,4 V (62246) location: CheckTheft: vehicle parked @51.302414,7.389933 now @51.302456,7.389905 dist=5 smoothed=2 alarm=500 gpsmode=AA satcount=12 hdop=1.0 gpsspeed=0.0 W (63486) cellular: UART frame error W (63486) cellular: UART frame error W (63486) cellular: UART frame error W (64356) gsm-mux: Frame error: EOF mismatch (CHAN=61, ADDR=f7, CTRL=ff, FCS=53, LEN=101) D (64356) cellular: mux-rx-line #4: +CSQ: 14,4 I (64356) cellular: Signal Quality is: 14 (-85 dBm) W (65266) cellular: UART frame error D (65356) cellular: mux-rx-line #3: +CSQ: 22,4 I (65356) cellular: Signal Quality is: 22 (-69 dBm) D (65356) cellular: mux-rx-line #4: +CSQ: 22,4 W (66796) cellular: UART frame error W (66796) cellular: UART frame error W (66796) cellular: UART frame error W (67216) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=ff, FCS=30, LEN=133) V (67246) location: CheckTheft: vehicle parked @51.302414,7.389933 now @51.302444,7.389904 dist=4 smoothed=2 alarm=500 gpsmode=AA satcount=13 hdop=0.9 gpsspeed=0.0 W (73796) cellular: UART frame error W (73796) cellular: UART frame error W (73796) cellular: UART frame error W (73806) cellular: UART frame error W (73806) cellular: UART frame error W (77216) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=dd, FCS=30, LEN=133) D (83196) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? W (83196) cellular: UART frame error W (83266) cellular: UART frame error W (83336) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=e7, FCS=45, LEN=133) D (83336) cellular: mux-rx-line #3: ologram",7 W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87796) cellular: UART frame error W (87806) cellular: UART frame error W (87806) cellular: UART frame error W (87806) cellular: UART frame error W (87806) cellular: UART frame error W (88066) gsm-mux: Frame error: EOF mismatch (CHAN=61, ADDR=f7, CTRL=f9, FCS=e2, LEN=85) W (89266) cellular: UART frame error W (92226) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=ff, FCS=41, LEN=114) W (93716) cellular: UART frame error E (93716) mongoose: mg_ssl_if_mbed_err 0x3f8bc85c SSL error: -29312 W (93716) cellular: UART frame error W (93716) ovms-server-v2: Connection failed E (93716) ovms-server-v2: Status: Error: Connection failed W (93716) cellular: UART frame error W (93716) cellular: UART frame error W (93716) cellular: UART frame error W (93716) cellular: UART frame error W (93716) cellular: UART frame error W (93716) cellular: UART frame error I (93726) ovms-server-v2: Status: Disconnected W (93726) cellular: UART frame error W (95266) cellular: UART frame error W (97216) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=ff, FCS=35, LEN=133) W (101266) cellular: UART frame error W (102226) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=ed, FCS=33, LEN=133) W (102306) cellular: UART frame error W (102306) cellular: UART frame error W (107266) cellular: UART frame error D (113196) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? D (113326) cellular: mux-rx-line #3: +CPSI: LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-100,-978,-703,18 D (113336) cellular: mux-rx-line #3: +CREG: 1,5 D (113336) cellular: mux-rx-line #3: +CGREG: 1,5 D (113336) cellular: mux-rx-line #3: +CEREG: 1,5 D (113336) cellular: mux-rx-line #3: +CCLK: "22/09/04,10:00:55+08" D (113336) cellular: mux-rx-line #3: +CSQ: 22,4 D (113336) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7 I (121206) housekeeping: System considered stable (RAM: 8b=58884-66912 32b=12344 SPI=3407184-3411300) D (121256) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms W (133766) cellular: UART frame error D (143196) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? W (143336) gsm-mux: Frame error: EOF mismatch (CHAN=31, ADDR=7f, CTRL=ff, FCS=47, LEN=133) D (143356) cellular: mux-rx-line #3: ologram",7 I (153196) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (153196) ovms-server-v2: Status: Connecting... W (153216) cellular: UART frame error W (153216) cellular: UART frame error W (154906) gsm-mux: Frame error: EOF mismatch (CHAN=19, ADDR=4f, CTRL=ff, FCS=6c, LEN=114) W (155966) cellular: UART frame error W (155976) cellular: UART frame error W (157216) gsm-mux: Frame error: EOF mismatch (CHAN=59, ADDR=ed, CTRL=fd, FCS=33, LEN=115) W (158116) cellular: UART frame error W (158116) cellular: UART frame error W (158116) cellular: UART frame error W (158116) cellular: UART frame error W (158116) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158126) cellular: UART frame error W (158136) cellular: UART frame error W (158136) cellular: UART frame error W (158136) cellular: UART frame error W (158136) cellular: UART frame error W (158136) cellular: UART frame error W (158226) gsm-mux: Frame error: EOF mismatch (CHAN=27, ADDR=6f, CTRL=69, FCS=c8, LEN=132) W (158466) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) cellular: UART frame error W (158716) gsm-mux: Frame error: EOF mismatch (CHAN=2, ADDR=09, CTRL=ff, FCS=b9, LEN=124) W (158866) cellular: UART frame error W (160046) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=fd, CTRL=f7, FCS=64, LEN=132) W (162086) cellular: UART frame error W (164906) cellular: UART frame error W (164906) cellular: UART frame error W (164906) cellular: UART frame error W (164906) cellular: UART frame error W (164916) cellular: UART frame error W (164916) cellular: UART frame error W (164916) cellular: UART frame error W (164916) cellular: UART frame error W (164916) cellular: UART frame error W (164926) cellular: UART frame error W (164926) cellular: UART frame error W (164926) cellular: UART frame error W (165066) gsm-mux: Frame error: EOF mismatch (CHAN=47, ADDR=bf, CTRL=ef, FCS=70, LEN=125) W (168966) cellular: UART frame error W (168966) cellular: UART frame error W (168966) cellular: UART frame error W (168966) cellular: UART frame error W (168976) cellular: UART frame error W (168976) cellular: UART frame error W (168976) cellular: UART frame error W (168976) cellular: UART frame error W (168976) cellular: UART frame error W (172216) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff, CTRL=fb, FCS=2e, LEN=130) D (173196) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS? W (173196) cellular: UART frame error W (173196) cellular: UART frame error D (173346) cellular: mux-rx-line #3: +CPSI: LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-94,-972,-705,17 D (173356) cellular: mux-rx-line #3: +CREG: 1,5 D (173356) cellular: mux-rx-line #3: +CGREG: 1,5 D (173356) cellular: mux-rx-line #3: +CEREG: 1,5 D (173356) cellular: mux-rx-line #3: +CCLK: "22/09/04,10:01:55+08" D (173356) cellular: mux-rx-line #3: +CSQ: 22,4 D (173356) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7 W (177966) cellular: UART frame error W (177966) cellular: UART frame error W (177966) cellular: UART frame error W (177966) cellular: UART frame error W (177966) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error W (177976) cellular: UART frame error
