kommykt@Kovacss-Air ~ % a2l 0x4008b013 0x4008b2a9 0x4010daab 0x4009792b 0x400840b9 0x40084721 0x4000bec7 0x401c0ee9 0x401c80c2 0x400f1cc1 0x400f28cb 0x40157035 0x40155ee2 0x400f50a9 0x400f52a1 0x400f5309 0x400f5319 Using elf file: /Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf 0x4008b013 is in invoke_abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:156). 151 #endif 152 while (1) { 153 if (esp_cpu_in_ocd_debug_mode()) { 154 __asm__ ("break 0,0"); 155 } 156 *((int *) 0) = 0; 157 } 158 } 159 160 void abort() 0x4008b2a9 is in abort (/Users/kommykt/esp/esp-idf/components/esp32/panic.c:171). 166 * don't overwrite that. 167 */ 168 if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) { 169 esp_reset_reason_set_hint(ESP_RST_PANIC); 170 } 171 invoke_abort(); 172 } 173 174 175 static const char *edesc[] = { 0x4010daab is in __assert_func (../../../.././newlib/libc/stdlib/assert.c:63). 0x4009792b is in multi_heap_free (/Users/kommykt/esp/esp-idf/components/heap/multi_heap_poisoning.c:214). 209 return; 210 } 211 multi_heap_internal_lock(heap); 212 213 poison_head_t *head = verify_allocated_region(p, true); 214 assert(head != NULL); 215 216 #ifdef SLOW 217 /* replace everything with FREE_FILL_PATTERN, including the poison head/tail */ 218 memset(head, FREE_FILL_PATTERN, 0x400840b9 is in heap_caps_free (/Users/kommykt/esp/esp-idf/components/heap/heap_caps.c:268). 263 ptr = (void *)dramAddrPtr[-1]; 264 } 265 266 heap_t *heap = find_containing_heap(ptr); 267 assert(heap != NULL && "free() target pointer is outside heap areas"); 268 multi_heap_free(heap->heap, ptr); 269 } 270 271 IRAM_ATTR void *heap_caps_realloc( void *ptr, size_t size, int caps) 272 { 0x40084721 is in _free_r (/Users/kommykt/esp/esp-idf/components/newlib/syscalls.c:42). 37 return heap_caps_malloc_default( size ); 38 } 39 40 void IRAM_ATTR _free_r(struct _reent *r, void* ptr) 41 { 42 heap_caps_free( ptr ); 43 } 44 45 void* IRAM_ATTR _realloc_r(struct _reent *r, void* ptr, size_t size) 46 { 0x401c0ee9 is in operator delete(void*) (/builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc++-v3/libsupc++/del_op.cc:46). 0x401c80c2 is in std::__cxx11::basic_string, std::allocator >::_M_dispose() (/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/libstdc++-v3/include/ext/new_allocator.h:110). 0x400f1cc1 is in std::_Rb_tree, std::allocator >, std::pair, std::allocator > const, std::__cxx11::basic_string, std::allocator > >, std::_Select1st, std::allocator > const, std::__cxx11::basic_string, std::allocator > > >, std::less, std::allocator > >, std::allocator, std::allocator > const, std::__cxx11::basic_string, std::allocator > > > >::_M_drop_node(std::_Rb_tree_node, std::allocator > const, std::__cxx11::basic_string, std::allocator > > >*) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:544). 539 540 /** 541 * @brief Destroy the string instance. 542 */ 543 ~basic_string() 544 { _M_dispose(); } 545 546 /** 547 * @brief Assign the value of @a str to this string. 548 * @param __str Source string. 0x400f28cb is in std::_Rb_tree, std::allocator >, std::pair, std::allocator > const, std::__cxx11::basic_string, std::allocator > >, std::_Select1st, std::allocator > const, std::__cxx11::basic_string, std::allocator > > >, std::less, std::allocator > >, std::allocator, std::allocator > const, std::__cxx11::basic_string, std::allocator > > > >::_M_erase(std::_Rb_tree_node, std::allocator > const, std::__cxx11::basic_string, std::allocator > > >*) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:1614). 1609 // Erase without rebalancing. 1610 while (__x != 0) 1611 { 1612 _M_erase(_S_right(__x)); 1613 _Link_type __y = _S_left(__x); 1614 _M_drop_node(__x); 1615 __x = __y; 1616 } 1617 } 1618 0x40157035 is in Pushover::EventListener(std::__cxx11::basic_string, std::allocator >, void*) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:858). 853 854 _Rb_tree(_Rb_tree&& __x, _Node_allocator&& __a); 855 #endif 856 857 ~_Rb_tree() _GLIBCXX_NOEXCEPT 858 { _M_erase(_M_begin()); } 859 860 _Rb_tree& 861 operator=(const _Rb_tree& __x); 862 0x40155ee2 is in std::_Function_handler, std::allocator >, void*), std::_Bind, std::allocator >, void*)> (Pushover*, std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string, std::allocator >&&, void*&&) (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600). 595 template>>> 598 result_type 599 operator()(_Class* __object, _Args&&... __args) const 600 { return (__object->*_M_pmf)(std::forward<_Args>(__args)...); } 601 602 // Handle smart pointers, references and pointers to derived 603 template, _NotSame<_Class*, _Tp>, 0x400f50a9 is in std::function, std::allocator >, void*)>::operator()(std::__cxx11::basic_string, std::allocator >, void*) const (/Users/kommykt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271). 2266 function<_Res(_ArgTypes...)>:: 2267 operator()(_ArgTypes... __args) const 2268 { 2269 if (_M_empty()) 2270 __throw_bad_function_call(); 2271 return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...); 2272 } 2273 2274 #if __cpp_rtti 2275 template 0x400f52a1 is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:211). 206 if (el) 207 { 208 for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc) 209 { 210 EventCallbackEntry* ec = *itc; 211 ec->m_callback(event, msg->body.signal.data); 212 } 213 } 214 } 215 0x400f5309 is in OvmsEvents::EventTask() (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:165). 160 switch(msg.type) 161 { 162 case EVENT_none: 163 break; 164 case EVENT_signal: 165 HandleQueueSignalEvent(&msg); 166 break; 167 default: 168 break; 169 } 0x400f5319 is in EventLaunchTask(void*) (/Users/kommykt/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:56). 51 52 void EventLaunchTask(void *pvParameters) 53 { 54 OvmsEvents* me = (OvmsEvents*)pvParameters; 55 56 me->EventTask(); 57 } 58 59 void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int argc, const char* const* argv) 60 { kommykt@Kovacss-Air ~ %
