module fault abort() was called at PC 0x401184a3 on core 1 ELF file SHA256: 8ba7ed1fff95ef4c Backtrace: 0x4008ddae:0x3ffef1a0 0x4008e049:0x3ffef1c0 0x401184a3:0x3ffef1e0 0x4032e70b:0x3ffef200 0x40127862:0x3ffef220 0x40127909:0x3ffef280 0x40127909:0x3ffef2e0 0x401279af:0x3ffef340 0x401138b7:0x3ffef360 0x40130427:0x3ffef380 0x401305de:0x3ffef3e0 0x401138e7:0x3ffef480 0x4032f76a:0x3ffef4a0 0x4012d559:0x3ffef4c0 0x40122885:0x3ffef4f0 0x40122a5d:0x3ffef520 0x4012d401:0x3ffef540 0x4012d410:0x3ffef560 0x4010c3eb:0x3ffef580 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5328 ho 0 tail 12 room 4 load:0x40078000,len:11332 load:0x40080400,len:6204 entry 0x400806cc I (1192) psram: This chip is ESP32-D0WD I (1193) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1233) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2134) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (215) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (215) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Boot #3 reasons for CPU0=12 and CPU1=12 E (242) boot: Crash #2 detected I (246) boot: Reset reason Exception/panic (4) I (252) events: Initialising EVENTS (1200) I (257) config: Initialising CONFIG (1400) I (262) time: Initialising TIME (1500) I (266) script: Initialising SCRIPTS (1600) I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (282) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (288) metrics: Initialising METRICS (1810) I (293) metrics: Expanding DUKTAPE javascript engine I (298) metrics: Persistent metrics serial 4 using 820 bytes, 68/100 slots used I (308) metrics: persist v.b.cac = 92.9772Ah I (312) metrics: persist v.b.range.est = 50km I (316) metrics: persist v.b.12v.voltage = 12.3V I (322) metrics: persist v.b.12v.voltage.ref = 12.6V I (328) metrics: persist v.c.climit = 15A I (333) metrics: persist v.c.limit.range = 56km I (337) metrics: persist v.c.limit.soc = 21% I (346) metrics: persist v.e.drivemode = 33882626 I (348) metrics: persist v.e.valet = yes I (352) metrics: persist v.e.parktime = 642Sec I (359) metrics: persist v.p.latitude = 51.404 I (363) metrics: persist v.p.longitude = 7.43981 I (368) metrics: persist v.p.altitude = 158.8m I (375) notify: Initialising NOTIFICATIONS (1820) I (379) notify: Registered notification type info I (383) notify: Registered notification type error I (389) notify: Registered notification type alert I (394) notify: Registered notification type data I (400) notify: Registered notification type stream I (405) notify: Expanding DUKTAPE javascript engine I (411) location: Initialising LOCATIONS (1900) I (419) location: Expanding DUKTAPE javascript engine I (422) vehicle: Initialising VEHICLE Factory (2000) I (433) tls: Initialising TLS (3000) I (434) pcp: Initialising POWER (4000) I (436) max7317: Initialising MAX7317 EGPIO (4200) I (442) sdcard: Initialising SD CARD (4400) I (447) ota: Initialising OTA (4400) I (453) canformat: Initialising CAN Format Factory (4500) I (457) canformat-cs11: Registering CAN Format: CS11 (4505) I (463) canformat-crtd: Registering CAN Format: CRTD (4505) I (469) canformat-gvret: Registering CAN Format: GVRET (4505) I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (482) canformat-panda: Registering CAN Format: PANDA (4505) I (489) canformat-pcap: Registering CAN Format: PCAP (4505) I (495) canformat-raw: Registering CAN Format: RAW (4505) I (501) can: Initialising CAN (4510) I (513) dbc-app: Initialising DBC (4520) I (516) canlog: Initialising CAN logging (4550) I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (523) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (545) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (555) canlog-vfs: Initialising CAN logging to VFS (4560) I (558) canplay: Initialising CAN play framework (4570) I (564) canplay-vfs: Initialising CAN playing from VFS (4580) I (571) cellular: Initialising CELLULAR (4600) I (577) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (582) cellular-modem-auto: Registering auto-detect modem driver (4650) I (590) SIM5360: Registering SIM5360 modem driver (4650) I (596) SIM7000: Registering SIM7000 modem driver (4650) I (602) SIM7600: Registering SIM7600 modem driver (4650) I (608) SIM7670: Registering Simcom A7670E modem driver (4660) I (614) tpms: Initialising TPMS (4700) I (620) test: Initialising TEST (5000) I (625) module: Initialising MODULE (5100) I (630) vfs: Initialising VFS (5200) I (634) ovms-server: Initialising OVMS Server (6000) I (638) ovms-server-v2: Initialising OVMS V2 Server (6100) I (645) ovms-server-v3: Initialising OVMS V3 Server (6200) I (651) vehicle-poll: Initialising Poller (7000) I (659) obd2ecu: Initialising OBD2ECU (7000) I (662) canopen: Initialising CANopen (7000) I (670) pluginstore: Initialising PLUGINS (7100) I (673) esp32wifi: Initialising ESP32WIFI (8000) I (677) ovms-mdns: Initialising MDNS (8100) I (681) webserver: Initialising WEBSERVER (8200) I (689) ssh: Initialising SSH (8300) I (691) powermgmt: Initialising POWERMGMT (8500) I (696) re: Initialising RE Tools (8800) I (703) pushover: Initialising Pushover client (8800) I (708) netmanager: Initialising NETMANAGER (8999) I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (718) v-zeva: Registering Vehicle: ZEVA (9000) I (724) v-vweup: Registering Vehicle: VW e-Up (9000) I (729) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (736) v-track: Registering Vehicle: TRACK (9000) I (742) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (755) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (762) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (775) v-smarteq: Registering Vehicle: SMART EQ (9000) I (781) v-smarted: Registering Vehicle: SMART ED (9000) I (787) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (801) v-twizy: Registering Vehicle: Renault Twizy (9000) I (807) v-obdii: Registering Vehicle: OBDII (9000) I (813) v-none: Registering Vehicle: NONE (9000) I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (824) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (840) v-mgev4: Registering Vehicle: MG4 (9000) I (845) v-mgev: Registering Vehicle: MG5 (9000) I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (863) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (869) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (875) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (881) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (894) v-maple60s: Registering Vehicle: Maple 60S (9000) I (900) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (914) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (921) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (935) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (941) v-energica: Registering Vehicle: Energica (9000) I (947) v-demo: Registering Vehicle: DEMO (9000) I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (959) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (967) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (974) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (980) v-boltev: Registering Vehicle: Bolt EV (9000) I (986) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (992) version: Initialising Versioning (9900) I (1000) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (1072) ovms_main: Executing on CPU core 0 I (1082) ovms_main: Mounting CONFIG... I (1192) ovms_main: Configure logging... W (1202) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1202) ovms_main: Registering default configs... I (1202) ovms_main: Starting HOUSEKEEPING... I (1212) housekeeping: Initialising HOUSEKEEPING Framework... I (1212) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1672) events: Signal(housekeeping.init) I (1672) housekeeping: Executing on CPU core 1 I (1672) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1672) housekeeping: Starting PERIPHERALS... I (1682) peripherals: Initialising OVMS Peripherals... I (1682) peripherals: TCP/IP Adaptor I (1692) peripherals: ESP32 system I (1692) peripherals: SPI bus I (1702) peripherals: MAX7317 I/O Expander I (1702) peripherals: ESP32 CAN I (1712) peripherals: ESP32 WIFI I (1712) peripherals: ESP32 ADC I (1712) peripherals: MCP2515 CAN 1/2 I (1722) mcp2515: can2: SetPowerMode off I (1802) peripherals: MCP2515 CAN 2/2 I (1802) mcp2515: can3: SetPowerMode off I (1882) peripherals: SD CARD I (1882) peripherals: CELLULAR MODEM I (1882) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1892) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1902) cellular: Starting modem task I (1902) uart: queue free spaces: 50 I (1902) ext12v: Powering off external 12V devices I (1912) housekeeping: Auto init max7317 (free: 160572 bytes) I (1922) housekeeping: Auto init ext12v (free: 160572 bytes) I (1922) housekeeping: Auto init dbc (free: 160572 bytes) I (1932) housekeeping: Auto init wifi (free: 160572 bytes) I (1952) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0 I (1952) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1962) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1982) wifi:wifi firmware version: 30f9e79 I (1992) wifi:config NVS flash: enabled I (1992) wifi:config nano formating: disabled I (1992) wifi:Init data frame dynamic rx buffer num: 16 I (1992) wifi:Init management frame dynamic rx buffer num: 16 I (2002) wifi:Init management short buffer num: 32 I (2002) wifi:Init dynamic tx buffer num: 16 I (2002) wifi:Init static rx buffer size: 2212 I (2012) wifi:Init static rx buffer num: 16 I (2012) wifi:Init dynamic rx buffer num: 16 I (2792) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2792) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2792) wifi:Total power save buffer number: 8 I (2792) wifi:Init max length of beacon: 752/752 I (2802) wifi:Init max length of beacon: 752/752 I (2802) housekeeping: Auto init modem (free: 115148 bytes) I (2812) housekeeping: Auto init Pollers (free: 114728 bytes) I (2812) cellular: Set modem driver to 'auto' I (2812) housekeeping: Auto init vehicle (free: 114728 bytes) I (2822) cellular: State: Enter PowerOffOn state I (2832) v-twizy: Renault Twizy vehicle module I (2832) cellular-modem-auto: Power Cycle I (2842) v-twizy: battmon subsystem init I (2842) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2852) v-twizy: pwrmon subsystem init I (2862) v-twizy: charge subsystem init I (2862) canopen: Worker started on can1 I (2862) v-twizy: sevcon subsystem init I (2882) v-twizy: obd subsystem init I (2882) housekeeping: Auto init obd2ecu (free: 81464 bytes) I (2882) housekeeping: Auto init server v2 (free: 81464 bytes) I (2892) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2892) ovms-server-v2: Status: Server has been started I (2902) ovms-server-v2: OVMS Server v2 running I (2912) housekeeping: Auto init server v3 (free: 80912 bytes) I (2912) housekeeping: Auto init javascript (free: 80912 bytes) I (2922) housekeeping: Auto init done (free: 80872 bytes) I (2922) housekeeping: Starting USB console... I (2932) uart: queue free spaces: 100 D (2942) events: Signal(egpio.output.1.low) D (2942) events: Signal(system.event) D (2952) events: Signal(system.wifi.sta.start) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console D (2952) events: Signal(system.event) D (2962) events: Signal(system.wifi.ap.start) I (2962) netmanager: WIFI access point is up D (2972) events: Signal(power.cellular.on) D (2972) events: Signal(system.modem.stop) D (2982) events: Signal(egpio.output.0.low) D (2982) events: Signal(egpio.output.0.high) D (2982) events: Signal(power.can1.on) D (2992) events: Signal(egpio.output.2.low) D (2992) events: Signal(canopen.worker.start) D (3002) events: Signal(vehicle.type.set) D (3002) events: Signal(server.v2.waitnetwork) D (3012) events: Signal(system.start) I (3012) ovms-mdns: Starting MDNS D (3012) netmanager: MongooseTask starting Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (3022) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) D (3032) events: Signal(network.interface.change) D (3042) events: Signal(network.mgr.init) I (3062) ssh: Launching SSH Server OVMS> I (3192) ovms-duktape: Duktape: Initialising module system D (3202) ovms-duktape: Duktape: Pre-Registered function assert D (3202) ovms-duktape: Duktape: Pre-Registered function meminfo D (3202) ovms-duktape: Duktape: Pre-Registered function print D (3212) ovms-duktape: Duktape: Pre-Registered function write D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3212) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3212) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3262) ovms-duktape: Duktape: Pre-Registered object VFS D (3262) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3272) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3272) ovms-duktape: Duktape: Pre-Registered module JSON D (3282) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3282) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3292) ovms-duktape: Duktape: module load: int/JSON.js D (3372) ovms-duktape: Duktape: Pre-Registered module PubSub D (3382) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3382) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3392) ovms-duktape: Duktape: module load: int/PubSub.js I (3602) ovms-duktape: Duktape: Executing ovmsmain.js D (3602) ovms-duktape: Duktape: module load: ovmsmain.js D (3612) ovms-duktape: Duktape: module unload: ovmsmain.js D (3672) events: Signal(vehicle.charge.mode) OVMS> D (4672) events: Signal(vehicle.aux.12v.normal) OVMS> D (5352) events: Signal(egpio.output.0.low) D (5412) events: Signal(system.event) D (5412) events: Signal(system.wifi.scan.done) I (5532) wifi:ap channel adjust o:1,0 n:11,0 I (5542) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6222) wifi:state: init -> auth (b0) I (6232) wifi:state: auth -> assoc (0) I (6242) wifi:state: assoc -> run (10) I (6262) wifi:connected with LeonsLair, aid = 17, channel 11, BW20, bssid = d4:24:dd:88:64:46 I (6262) wifi:security type: 3, phy: bgn, rssi: -68 I (6262) wifi:pm start, type: 1 D (6272) events: Signal(system.event) D (6272) events: Signal(system.wifi.sta.connected) D (6272) netmanager: send cmd 3 from 0x0 D (6272) netmanager: done cmd 3 from 0x0 I (6282) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6282) events: Signal(system.event) D (6292) events: Signal(network.interface.up) D (6292) events: Signal(system.wifi.sta.gotip) I (6292) netmanager: WIFI client got IP D (6292) netmanager: Saved DNS#0 192.168.178.1 D (6292) netmanager: Saved DNS#1 0.0.0.0 D (6292) netmanager: Saved DNS#2 0.0.0.0 D (6292) netmanager: send cmd 3 from 0x0 D (6292) netmanager: done cmd 3 from 0x0 D (6292) netmanager: MongooseTask: got cmd 3 from 0x0 D (6312) netmanager: MongooseTask: done cmd 3 from 0x0 D (6312) netmanager: MongooseTask: got cmd 3 from 0x0 D (6322) netmanager: MongooseTask: done cmd 3 from 0x0 I (6352) wifi:AP's beacon interval = 102400 us, DTIM period = 1 OVMS> D (9672) events: Signal(network.wifi.sta.good) I (9672) netmanager: WIFI client has good signal quality (-84.5 dBm); connect I (9672) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (9672) netmanager: Set DNS#1 0.0.0.0 I (9672) netmanager: Set DNS#2 0.0.0.0 I (9682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (9682) events: Signal(network.wifi.up) D (9682) events: Signal(network.up) I (9682) ovms-server-v2: Status: Network is up, so attempt network connection D (9692) events: Signal(network.interface.change) D (9692) events: Signal(server.v2.connectwait) OVMS> D (10352) events: Signal(egpio.output.0.high) D (10552) events: Signal(egpio.output.0.low) D (10552) cellular: State timeout PowerOffOn => PoweringOn I (10552) cellular: State: Enter PoweringOn state I (10552) cellular-modem-auto: Power Cycle I (10552) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10552) events: Signal(system.modem.poweringon) D (10552) events: Signal(egpio.output.0.high) OVMS> I (11672) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (11672) ovms-server-v2: Status: Connecting... D (11702) events: Signal(server.v2.connecting) OVMS> D (13052) events: Signal(egpio.output.0.low) OVMS> I (15032) ovms-server-v2: Connection successful I (15032) ovms-server-v2: Status: Logging in... D (15032) events: Signal(server.v2.authenticating) I (15032) ovms-server-v2: Sending server login: MP-C 0 Cj2s2/OScrzgXugZLPyWeV 3CuKR76wTwPzTHQX73sT/Q== TEST1 I (15062) ovms-server-v2: Got server response: MP-S 0 MNhAzzc2XB52e4MTRB0Ffp 0l1TcI9RwCWy1XLKJEgtVg== I (15062) ovms-server-v2: Server token is MNhAzzc2XB52e4MTRB0Ffp and digest is 0l1TcI9RwCWy1XLKJEgtVg== I (15072) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (15082) ovms-server-v2: Shared secret key is MNhAzzc2XB52e4MTRB0FfpCj2s2/OScrzgXugZLPyWeV (44 bytes) I (15082) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (15082) events: Signal(server.v2.connected) I (15102) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> I (15672) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (15682) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,654,0,0,1,1,12.34,0,12.6,0,0,0,0 I (15682) ovms-server-v2: Send MP-0 L51.403984,7.439806,0,158.8,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (15682) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (15682) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (15682) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,20,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18052) events: Signal(egpio.output.0.high) D (18252) events: Signal(egpio.output.0.low) D (18252) cellular: tx-cmd: AT I (18352) cellular: State: Enter Identify state D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM D (18352) cellular: tx-cmd: AT+CGMM OVMS> D (18672) cellular: tx-cmd: AT+CGMM OVMS> D (19672) cellular: tx-cmd: AT+CGMM OVMS> D (20672) cellular: tx-cmd: AT+CGMM OVMS> D (21672) cellular: tx-cmd: AT+CGMM OVMS> D (22672) cellular: tx-cmd: AT+CGMM OVMS> D (23672) cellular: tx-cmd: AT+CGMM OVMS> D (24672) cellular: tx-cmd: AT+CGMM I (24672) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403984,7.439806,159,0,0,0,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (24682) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (24682) cellular: Remove old 'auto' modem driver I (24682) cellular: Set modem driver to 'SIM5360' I (24682) cellular: State: Enter PoweredOn state D (24682) events: Signal(system.modem.installed) D (24692) events: Signal(system.modem.poweredon) I (24882) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS> D (27612) cellular: mux-rx-line #0 (2/48): OK D (27612) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (27612) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (27612) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS> D (28362) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS> D (28962) cellular: mux-rx-line #0 (10/11): CALL READY D (28962) cellular: mux-rx-line #0 (7/0): PB DONE OVMS> D (34672) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (34692) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (34722) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (34722) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0 D (34722) cellular: Signal Quality is: 22 (-69 dBm) D (34722) cellular: mux-rx-line #0 (2/0): OK OVMS> D (36102) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:42:45 OVMS> D (36672) cellular: tx-cmd: AT+CGMR;+ICCID D (36682) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (36682) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (36682) cellular: mux-rx-line #0 (2/0): OK OVMS> D (40412) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99 OVMS> D (40672) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (40682) cellular: mux-rx-line #0 (2/0): OK OVMS> D (41672) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (41682) cellular: mux-rx-line #0 (2/0): OK OVMS> D (42672) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (42682) cellular: mux-rx-line #0 (2/0): OK OVMS> D (43672) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (43702) cellular: mux-rx-line #0 (2/0): OK OVMS> D (44672) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (44672) cellular: mux-rx-line #0 (2/0): OK I (44682) cellular: State: Enter MuxStart state V (44682) cellular: Starting MUX D (44682) events: Signal(system.modem.muxstart) I (44682) gsm-mux: Start MUX I (44682) gsm-mux: Channel #0 is open I (44692) gsm-mux: Channel #1 is open I (44692) gsm-mux: Channel #2 is open I (44702) gsm-mux: Channel #3 is open I (44702) gsm-mux: Channel #4 is open OVMS> D (45672) cellular: State transition MuxStart => NetWait I (45672) cellular: State: Enter NetWait state V (45672) cellular: Starting NMEA I (45672) gsm-nmea: Startup D (45672) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 I (45682) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45682) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45682) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 D (45692) events: Signal(system.modem.netwait) D (45692) events: Signal(system.modem.gpsstart) D (45762) cellular: mux-rx-line #4 (2/0): OK I (45922) ovms-server-v2: Incoming Msg: MP-0 h2 I (45932) ovms-server-v2: Incoming Msg: MP-0 h3 I (45932) ovms-server-v2: Incoming Msg: MP-0 h4 I (45932) ovms-server-v2: Incoming Msg: MP-0 h5 I (45942) ovms-server-v2: Incoming Msg: MP-0 h6 OVMS> I (46672) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46672) ovms-server-v2: Send MP-0 h8,0,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46672) ovms-server-v2: Send MP-0 h9,0,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46672) ovms-server-v2: Send MP-0 h10,0,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h11,0,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46732) ovms-server-v2: Incoming Msg: MP-0 h7 I (46732) ovms-server-v2: Incoming Msg: MP-0 h8 I (46732) ovms-server-v2: Incoming Msg: MP-0 h9 I (46732) ovms-server-v2: Incoming Msg: MP-0 h10 I (46742) ovms-server-v2: Incoming Msg: MP-0 h11 OVMS> I (47672) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47672) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47672) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47672) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h16,-1,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47772) ovms-server-v2: Incoming Msg: MP-0 h12 I (47772) ovms-server-v2: Incoming Msg: MP-0 h13 I (47772) ovms-server-v2: Incoming Msg: MP-0 h14 I (47772) ovms-server-v2: Incoming Msg: MP-0 h15 I (47782) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (55672) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (55702) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (55702) cellular: Network Registration status: RegisteredRoaming D (55702) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:43:04+08" D (55702) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (55702) cellular: mux-rx-line #3 (2/0): OK OVMS> D (56672) cellular: mux-tx #3: AT+CPSI? D (56672) cellular: State transition NetWait => NetStart I (56672) cellular: State: Enter NetStart state D (56672) events: Signal(system.modem.netstart) D (56682) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 I (56682) cellular: Network Mode: GSM,Online D (56682) cellular: mux-rx-line #3 (2/0): OK OVMS> D (57672) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (57702) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (57702) cellular: PPP Connection is ready to start OVMS> D (58672) cellular: State transition NetStart => NetMode I (58672) cellular: State: Enter NetMode state V (58672) cellular: Launching PPP V (58672) cellular: Starting PPP I (58672) gsm-ppp: Initialising... D (58682) events: Signal(system.modem.netmode) OVMS> I (59422) gsm-ppp: StatusCallBack: None I (59422) gsm-ppp: status_cb: Connected I (59422) gsm-ppp: our_ipaddr = 10.170.195.13 I (59422) gsm-ppp: his_ipaddr = 10.64.64.64 I (59422) gsm-ppp: netmask = 255.255.255.255 I (59422) gsm-ppp: DNS#0 = 8.8.8.8 I (59422) gsm-ppp: DNS#1 = 8.8.4.4 I (59422) gsm-ppp: our6_ipaddr = :: D (59422) events: Signal(network.interface.up) D (59422) events: Signal(system.modem.gotip) D (59422) netmanager: Saved DNS#0 8.8.8.8 D (59422) netmanager: Saved DNS#1 8.8.4.4 D (59422) netmanager: Saved DNS#2 0.0.0.0 I (59432) netmanager: Set DNS#1 0.0.0.0 I (59432) netmanager: Set DNS#2 0.0.0.0 I (59432) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (59432) events: Signal(network.modem.up) D (59432) events: Signal(network.interface.change) OVMS> D (59752) events: Signal(gps.lock.acquired) D (59762) events: Signal(system.modem.gotgps) OVMS> I (60672) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.404034,7.439826,155,0,0,1,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (60812) ovms-server-v2: Incoming Msg: MP-0 h17 OVMS> D (61422) cellular: mux-rx-line #3 (10/0): +CSQ: 22,0 OVMS> D (62732) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms OVMS> D (64422) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99 OVMS> enable Password: Secure mode OVMS# module fault abort() was called at PC 0x401184a3 on core 1 ELF file SHA256: 8ba7ed1fff95ef4c Backtrace: 0x4008ddae:0x3ffef190 0x4008e049:0x3ffef1b0 0x401184a3:0x3ffef1d0 0x4032e70b:0x3ffef1f0 0x40127862:0x3ffef210 0x40127909:0x3ffef270 0x40127909:0x3ffef2d0 0x401279af:0x3ffef330 0x401138b7:0x3ffef350 0x40130427:0x3ffef370 0x401305de:0x3ffef3d0 0x401138e7:0x3ffef470 0x4032f76a:0x3ffef490 0x4012d559:0x3ffef4b0 0x40122885:0x3ffef4e0 0x40122a5d:0x3ffef510 0x4012d401:0x3ffef530 0x4012d410:0x3ffef550 0x4010c3eb:0x3ffef570 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5328 ho 0 tail 12 room 4 load:0x40078000,len:11332 load:0x40080400,len:6204 entry 0x400806cc I (1192) psram: This chip is ESP32-D0WD I (1192) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1233) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2133) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (214) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (215) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Boot #4 reasons for CPU0=12 and CPU1=12 E (242) boot: Early crash #1 detected I (247) boot: Reset reason Exception/panic (4) I (252) events: Initialising EVENTS (1200) I (257) config: Initialising CONFIG (1400) I (262) time: Initialising TIME (1500) I (266) script: Initialising SCRIPTS (1600) I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (283) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (288) metrics: Initialising METRICS (1810) I (294) metrics: Expanding DUKTAPE javascript engine I (299) metrics: Persistent metrics serial 5 using 820 bytes, 68/100 slots used I (308) metrics: persist v.b.cac = 92.9772Ah I (313) metrics: persist v.b.range.est = 50km I (317) metrics: persist v.b.12v.voltage = 12.32V I (322) metrics: persist v.b.12v.voltage.ref = 12.6V I (329) metrics: persist v.c.climit = 15A I (334) metrics: persist v.c.limit.range = 56km I (338) metrics: persist v.c.limit.soc = 21% I (347) metrics: persist v.e.drivemode = 33882626 I (349) metrics: persist v.e.valet = yes I (353) metrics: persist v.e.parktime = 715Sec I (359) metrics: persist v.p.latitude = 51.4041 I (363) metrics: persist v.p.longitude = 7.43977 I (369) metrics: persist v.p.altitude = 153.7m I (376) notify: Initialising NOTIFICATIONS (1820) I (380) notify: Registered notification type info I (384) notify: Registered notification type error I (389) notify: Registered notification type alert I (395) notify: Registered notification type data I (400) notify: Registered notification type stream I (406) notify: Expanding DUKTAPE javascript engine I (412) location: Initialising LOCATIONS (1900) I (420) location: Expanding DUKTAPE javascript engine I (422) vehicle: Initialising VEHICLE Factory (2000) I (433) tls: Initialising TLS (3000) I (435) pcp: Initialising POWER (4000) I (437) max7317: Initialising MAX7317 EGPIO (4200) I (443) sdcard: Initialising SD CARD (4400) I (447) ota: Initialising OTA (4400) I (453) canformat: Initialising CAN Format Factory (4500) I (457) canformat-cs11: Registering CAN Format: CS11 (4505) I (464) canformat-crtd: Registering CAN Format: CRTD (4505) I (470) canformat-gvret: Registering CAN Format: GVRET (4505) I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (483) canformat-panda: Registering CAN Format: PANDA (4505) I (489) canformat-pcap: Registering CAN Format: PCAP (4505) I (496) canformat-raw: Registering CAN Format: RAW (4505) I (502) can: Initialising CAN (4510) I (513) dbc-app: Initialising DBC (4520) I (517) canlog: Initialising CAN logging (4550) I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (524) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (546) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (555) canlog-vfs: Initialising CAN logging to VFS (4560) I (559) canplay: Initialising CAN play framework (4570) I (564) canplay-vfs: Initialising CAN playing from VFS (4580) I (571) cellular: Initialising CELLULAR (4600) I (578) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (583) cellular-modem-auto: Registering auto-detect modem driver (4650) I (590) SIM5360: Registering SIM5360 modem driver (4650) I (596) SIM7000: Registering SIM7000 modem driver (4650) I (602) SIM7600: Registering SIM7600 modem driver (4650) I (608) SIM7670: Registering Simcom A7670E modem driver (4660) I (615) tpms: Initialising TPMS (4700) I (620) test: Initialising TEST (5000) I (625) module: Initialising MODULE (5100) I (630) vfs: Initialising VFS (5200) I (634) ovms-server: Initialising OVMS Server (6000) I (638) ovms-server-v2: Initialising OVMS V2 Server (6100) I (645) ovms-server-v3: Initialising OVMS V3 Server (6200) I (652) vehicle-poll: Initialising Poller (7000) I (659) obd2ecu: Initialising OBD2ECU (7000) I (662) canopen: Initialising CANopen (7000) I (671) pluginstore: Initialising PLUGINS (7100) I (673) esp32wifi: Initialising ESP32WIFI (8000) I (678) ovms-mdns: Initialising MDNS (8100) I (682) webserver: Initialising WEBSERVER (8200) I (690) ssh: Initialising SSH (8300) I (692) powermgmt: Initialising POWERMGMT (8500) I (697) re: Initialising RE Tools (8800) I (703) pushover: Initialising Pushover client (8800) I (709) netmanager: Initialising NETMANAGER (8999) I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (719) v-zeva: Registering Vehicle: ZEVA (9000) I (724) v-vweup: Registering Vehicle: VW e-Up (9000) I (730) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (737) v-track: Registering Vehicle: TRACK (9000) I (743) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (756) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (763) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (776) v-smarteq: Registering Vehicle: SMART EQ (9000) I (782) v-smarted: Registering Vehicle: SMART ED (9000) I (788) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (802) v-twizy: Registering Vehicle: Renault Twizy (9000) I (808) v-obdii: Registering Vehicle: OBDII (9000) I (813) v-none: Registering Vehicle: NONE (9000) I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (825) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (841) v-mgev4: Registering Vehicle: MG4 (9000) I (846) v-mgev: Registering Vehicle: MG5 (9000) I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (864) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (870) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (876) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (882) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (895) v-maple60s: Registering Vehicle: Maple 60S (9000) I (901) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (915) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (922) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (936) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (942) v-energica: Registering Vehicle: Energica (9000) I (948) v-demo: Registering Vehicle: DEMO (9000) I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (960) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (968) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (975) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (981) v-boltev: Registering Vehicle: Bolt EV (9000) I (987) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (992) version: Initialising Versioning (9900) I (1001) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (1073) ovms_main: Executing on CPU core 0 I (1083) ovms_main: Mounting CONFIG... I (1193) ovms_main: Configure logging... W (1203) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1203) ovms_main: Registering default configs... I (1203) ovms_main: Starting HOUSEKEEPING... I (1213) housekeeping: Initialising HOUSEKEEPING Framework... I (1213) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1693) events: Signal(housekeeping.init) I (1693) housekeeping: Executing on CPU core 1 I (1693) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1693) housekeeping: Starting PERIPHERALS... I (1703) peripherals: Initialising OVMS Peripherals... I (1703) peripherals: TCP/IP Adaptor I (1713) peripherals: ESP32 system I (1713) peripherals: SPI bus I (1723) peripherals: MAX7317 I/O Expander I (1723) peripherals: ESP32 CAN I (1733) peripherals: ESP32 WIFI I (1733) peripherals: ESP32 ADC I (1733) peripherals: MCP2515 CAN 1/2 I (1743) mcp2515: can2: SetPowerMode off I (1823) peripherals: MCP2515 CAN 2/2 I (1823) mcp2515: can3: SetPowerMode off I (1903) peripherals: SD CARD I (1903) peripherals: CELLULAR MODEM I (1903) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1913) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1923) cellular: Starting modem task I (1923) uart: queue free spaces: 50 I (1923) ext12v: Powering off external 12V devices I (1933) housekeeping: Auto init max7317 (free: 160572 bytes) I (1943) housekeeping: Auto init ext12v (free: 160572 bytes) I (1943) housekeeping: Auto init dbc (free: 160572 bytes) I (1953) housekeeping: Auto init wifi (free: 160572 bytes) I (1973) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0 I (1973) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1983) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (2003) wifi:wifi firmware version: 30f9e79 I (2013) wifi:config NVS flash: enabled I (2013) wifi:config nano formating: disabled I (2013) wifi:Init data frame dynamic rx buffer num: 16 I (2013) wifi:Init management frame dynamic rx buffer num: 16 I (2023) wifi:Init management short buffer num: 32 I (2023) wifi:Init dynamic tx buffer num: 16 I (2023) wifi:Init static rx buffer size: 2212 I (2033) wifi:Init static rx buffer num: 16 I (2033) wifi:Init dynamic rx buffer num: 16 I (2813) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2813) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2813) wifi:Total power save buffer number: 8 I (2813) wifi:Init max length of beacon: 752/752 I (2823) wifi:Init max length of beacon: 752/752 I (2823) housekeeping: Auto init modem (free: 115408 bytes) I (2833) housekeeping: Auto init Pollers (free: 114728 bytes) I (2843) housekeeping: Auto init vehicle (free: 114728 bytes) I (2853) v-twizy: Renault Twizy vehicle module I (2853) v-twizy: battmon subsystem init I (2863) v-twizy: pwrmon subsystem init I (2863) v-twizy: charge subsystem init I (2863) canopen: Worker started on can1 I (2873) v-twizy: sevcon subsystem init I (2883) v-twizy: obd subsystem init I (2883) housekeeping: Auto init obd2ecu (free: 81496 bytes) I (2883) housekeeping: Auto init server v2 (free: 81496 bytes) I (2893) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2893) ovms-server-v2: Status: Server has been started I (2903) ovms-server-v2: OVMS Server v2 running I (2913) housekeeping: Auto init server v3 (free: 80944 bytes) I (2913) housekeeping: Auto init javascript (free: 80944 bytes) I (2923) cellular: Set modem driver to 'auto' I (2923) housekeeping: Auto init done (free: 80904 bytes) I (2923) cellular: State: Enter PowerOffOn state I (2933) housekeeping: Starting USB console... I (2943) cellular-modem-auto: Power Cycle I (2943) uart: queue free spaces: 100 I (2943) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (2963) events: Signal(egpio.output.1.low) D (2963) events: Signal(system.event) D (2973) events: Signal(system.wifi.sta.start) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console D (2973) events: Signal(system.event) D (2983) events: Signal(system.wifi.ap.start) I (2983) netmanager: WIFI access point is up D (2993) events: Signal(power.cellular.on) D (2993) events: Signal(power.can1.on) D (3003) events: Signal(egpio.output.2.low) D (3003) events: Signal(canopen.worker.start) D (3013) events: Signal(vehicle.type.set) D (3013) events: Signal(server.v2.waitnetwork) D (3023) events: Signal(system.modem.stop) D (3023) events: Signal(system.start) I (3023) ovms-mdns: Starting MDNS D (3033) netmanager: MongooseTask starting Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (2923) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> D (3053) events: Signal(egpio.output.0.low) D (3063) events: Signal(egpio.output.0.high) D (3063) events: Signal(network.interface.change) D (3063) events: Signal(network.mgr.init) I (3083) ssh: Launching SSH Server I (3213) ovms-duktape: Duktape: Initialising module system D (3233) ovms-duktape: Duktape: Pre-Registered function assert D (3233) ovms-duktape: Duktape: Pre-Registered function meminfo D (3233) ovms-duktape: Duktape: Pre-Registered function print D (3243) ovms-duktape: Duktape: Pre-Registered function write D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3243) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3243) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3253) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3263) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3273) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3283) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3293) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3293) ovms-duktape: Duktape: Pre-Registered object VFS D (3293) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3293) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3293) ovms-duktape: Duktape: Pre-Registered module JSON D (3303) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3303) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3303) ovms-duktape: Duktape: module load: int/JSON.js D (3393) ovms-duktape: Duktape: Pre-Registered module PubSub D (3403) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3403) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3403) ovms-duktape: Duktape: module load: int/PubSub.js I (3623) ovms-duktape: Duktape: Executing ovmsmain.js D (3623) ovms-duktape: Duktape: module load: ovmsmain.js D (3633) ovms-duktape: Duktape: module unload: ovmsmain.js D (3693) events: Signal(vehicle.charge.mode) OVMS> D (4693) events: Signal(vehicle.aux.12v.normal) OVMS> D (5433) events: Signal(system.event) D (5433) events: Signal(system.wifi.scan.done) D (5463) events: Signal(egpio.output.0.low) I (5553) wifi:ap channel adjust o:1,0 n:11,0 I (5563) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6243) wifi:state: init -> auth (b0) I (6263) wifi:state: auth -> assoc (0) I (6273) wifi:state: assoc -> run (10) I (6313) wifi:connected with LeonsLair, aid = 20, channel 11, BW20, bssid = d4:24:dd:88:64:46 I (6313) wifi:security type: 3, phy: bgn, rssi: -68 I (6313) wifi:pm start, type: 1 D (6313) events: Signal(system.event) D (6323) events: Signal(system.wifi.sta.connected) D (6323) netmanager: send cmd 3 from 0x0 D (6323) netmanager: done cmd 3 from 0x0 I (6323) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6323) events: Signal(system.event) D (6333) events: Signal(network.interface.up) D (6333) events: Signal(system.wifi.sta.gotip) I (6333) netmanager: WIFI client got IP D (6333) netmanager: Saved DNS#0 192.168.178.1 D (6333) netmanager: Saved DNS#1 0.0.0.0 D (6333) netmanager: Saved DNS#2 0.0.0.0 D (6333) netmanager: send cmd 3 from 0x0 D (6333) netmanager: done cmd 3 from 0x0 I (6373) wifi:AP's beacon interval = 102400 us, DTIM period = 1 D (6553) netmanager: MongooseTask: got cmd 3 from 0x0 D (6553) netmanager: MongooseTask: done cmd 3 from 0x0 D (6553) netmanager: MongooseTask: got cmd 3 from 0x0 D (6563) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> D (9693) events: Signal(network.wifi.sta.good) I (9693) netmanager: WIFI client has good signal quality (-84.5 dBm); connect I (9693) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (9693) netmanager: Set DNS#1 0.0.0.0 I (9693) netmanager: Set DNS#2 0.0.0.0 I (9693) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (9703) events: Signal(network.wifi.up) D (9703) events: Signal(network.up) I (9703) ovms-server-v2: Status: Network is up, so attempt network connection D (9703) events: Signal(network.interface.change) D (9713) events: Signal(server.v2.connectwait) OVMS> D (10463) events: Signal(egpio.output.0.high) D (10663) events: Signal(egpio.output.0.low) OVMS> D (11063) cellular: State timeout PowerOffOn => PoweringOn I (11063) cellular: State: Enter PoweringOn state I (11063) cellular-modem-auto: Power Cycle D (11063) events: Signal(system.modem.poweringon) I (11063) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (11063) events: Signal(egpio.output.0.high) OVMS> I (11693) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (11693) ovms-server-v2: Status: Connecting... D (11723) events: Signal(server.v2.connecting) OVMS> D (13563) events: Signal(egpio.output.0.low) OVMS> I (15313) ovms-server-v2: Connection successful I (15313) ovms-server-v2: Status: Logging in... D (15313) events: Signal(server.v2.authenticating) I (15313) ovms-server-v2: Sending server login: MP-C 0 nojf4vVho/sveBK1aQuyV8 U9sbCREBp8+8uL8s7smHjg== TEST1 I (15343) ovms-server-v2: Got server response: MP-S 0 5fp6dF41wlI69FsJC5uEla Vqkc/9GA6H+dbFlGSPLihg== I (15343) ovms-server-v2: Server token is 5fp6dF41wlI69FsJC5uEla and digest is Vqkc/9GA6H+dbFlGSPLihg== I (15353) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (15353) ovms-server-v2: Shared secret key is 5fp6dF41wlI69FsJC5uElanojf4vVho/sveBK1aQuyV8 (44 bytes) I (15353) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (15353) events: Signal(server.v2.connected) I (15383) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> I (15693) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (15703) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,727,0,0,1,1,12.34,0,12.6,0,0,0,0 I (15703) ovms-server-v2: Send MP-0 L51.404079,7.439766,0,153.7,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (15703) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (15703) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (15703) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,20,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18563) events: Signal(egpio.output.0.high) D (18763) events: Signal(egpio.output.0.low) I (18863) cellular: State: Enter Identify state D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM D (19063) cellular: tx-cmd: AT+CGMM I (19073) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (19073) cellular: Remove old 'auto' modem driver I (19073) cellular: Set modem driver to 'SIM5360' I (19073) cellular: State: Enter PoweredOn state D (19073) events: Signal(system.modem.installed) D (19083) events: Signal(system.modem.poweredon) D (19183) cellular: mux-rx-line #0 (2/0): OK OVMS> D (20193) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (20193) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (20193) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS> D (20813) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS> D (21363) cellular: mux-rx-line #0 (10/11): CALL READY D (21363) cellular: mux-rx-line #0 (7/0): PB DONE OVMS> I (24693) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.404079,7.439766,154,0,0,0,0,-72,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 OVMS> I (24903) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS> D (26693) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26723) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26753) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (26753) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0 D (26753) cellular: Signal Quality is: 22 (-69 dBm) D (26753) cellular: mux-rx-line #0 (2/0): OK OVMS> D (27603) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:43:56 OVMS> D (28693) cellular: tx-cmd: AT+CGMR;+ICCID D (28703) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (28703) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (28703) cellular: mux-rx-line #0 (2/0): OK OVMS> D (32523) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99 D (32693) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (32703) cellular: mux-rx-line #0 (2/0): OK OVMS> D (33693) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (33703) cellular: mux-rx-line #0 (2/0): OK OVMS> D (34693) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (34703) cellular: mux-rx-line #0 (2/0): OK OVMS> D (35693) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (35703) cellular: mux-rx-line #0 (2/0): OK OVMS> D (36693) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (36703) cellular: mux-rx-line #0 (2/0): OK I (36703) cellular: State: Enter MuxStart state V (36703) cellular: Starting MUX I (36703) gsm-mux: Start MUX D (36703) events: Signal(system.modem.muxstart) I (36703) gsm-mux: Channel #0 is open I (36713) gsm-mux: Channel #1 is open I (36723) gsm-mux: Channel #2 is open I (36723) gsm-mux: Channel #3 is open I (36733) gsm-mux: Channel #4 is open OVMS> D (37693) cellular: State transition MuxStart => NetWait I (37693) cellular: State: Enter NetWait state V (37693) cellular: Starting NMEA I (37693) gsm-nmea: Startup D (37693) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 D (37693) events: Signal(system.modem.netwait) D (37703) events: Signal(system.modem.gpsstart) D (37793) cellular: mux-rx-line #4 (2/0): OK OVMS> I (45703) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45703) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45703) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45703) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45713) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45943) ovms-server-v2: Incoming Msg: MP-0 h2 I (45943) ovms-server-v2: Incoming Msg: MP-0 h3 I (45943) ovms-server-v2: Incoming Msg: MP-0 h4 I (45943) ovms-server-v2: Incoming Msg: MP-0 h5 I (45953) ovms-server-v2: Incoming Msg: MP-0 h6 OVMS> D (46313) events: Signal(gps.lock.acquired) D (46313) events: Signal(system.modem.gotgps) OVMS> I (46693) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46693) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46703) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46703) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46703) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46743) ovms-server-v2: Incoming Msg: MP-0 h7 I (46753) ovms-server-v2: Incoming Msg: MP-0 h8 I (46763) ovms-server-v2: Incoming Msg: MP-0 h9 I (46763) ovms-server-v2: Incoming Msg: MP-0 h10 I (46773) ovms-server-v2: Incoming Msg: MP-0 h11 OVMS> D (47693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ I (47693) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47693) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47693) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47693) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47703) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 D (47723) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (47723) cellular: Network Registration status: RegisteredRoaming D (47723) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:44:16+08" D (47723) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (47723) cellular: mux-rx-line #3 (2/0): OK I (47803) ovms-server-v2: Incoming Msg: MP-0 h12 I (47803) ovms-server-v2: Incoming Msg: MP-0 h13 I (47813) ovms-server-v2: Incoming Msg: MP-0 h14 I (47813) ovms-server-v2: Incoming Msg: MP-0 h15 I (47823) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (48693) cellular: mux-tx #3: AT+CPSI? D (48693) cellular: State transition NetWait => NetStart I (48693) cellular: State: Enter NetStart state I (48693) ovms-server-v2: Send MP-0 h17,-2,RT-GPS-Log,0,86400,51.404243,7.439665,137,0,0,1,0,-72,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 D (48703) events: Signal(system.modem.netstart) D (48703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 I (48703) cellular: Network Mode: GSM,Online D (48703) cellular: mux-rx-line #3 (2/0): OK I (48843) ovms-server-v2: Incoming Msg: MP-0 h17 OVMS> D (49693) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (49733) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (49733) cellular: PPP Connection is ready to start OVMS> D (50693) cellular: State transition NetStart => NetMode I (50693) cellular: State: Enter NetMode state V (50693) cellular: Launching PPP V (50693) cellular: Starting PPP I (50693) gsm-ppp: Initialising... D (50703) events: Signal(system.modem.netmode) OVMS> I (51573) gsm-ppp: StatusCallBack: None I (51583) gsm-ppp: status_cb: Connected I (51583) gsm-ppp: our_ipaddr = 10.170.195.13 I (51583) gsm-ppp: his_ipaddr = 10.64.64.64 I (51583) gsm-ppp: netmask = 255.255.255.255 I (51583) gsm-ppp: DNS#0 = 8.8.8.8 I (51583) gsm-ppp: DNS#1 = 8.8.4.4 I (51583) gsm-ppp: our6_ipaddr = :: D (51583) events: Signal(network.interface.up) D (51583) events: Signal(system.modem.gotip) D (51583) netmanager: Saved DNS#0 8.8.8.8 D (51583) netmanager: Saved DNS#1 8.8.4.4 D (51583) netmanager: Saved DNS#2 0.0.0.0 I (51583) netmanager: Set DNS#1 0.0.0.0 I (51583) netmanager: Set DNS#2 0.0.0.0 I (51583) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (51593) events: Signal(network.modem.up) D (51593) events: Signal(network.interface.change) OVMS> D (62763) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms OVMS> D (80693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (80703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (80713) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:44:49+08" D (80713) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (80713) cellular: mux-rx-line #3 (2/0): OK OVMS> D (81693) cellular: mux-tx #3: AT+CPSI? D (81703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (81703) cellular: mux-rx-line #3 (2/0): OK OVMS> D (82693) cellular: mux-tx #3: AT+COPS? D (82703) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (82703) cellular: Network Provider is: vodafone.de Hologram D (82703) cellular: mux-rx-line #3 (2/0): OK OVMS> I (84693) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.404110,7.439844,142,0,0,1,0,-71,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (84873) ovms-server-v2: Incoming Msg: MP-0 h18 OVMS> D (110693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (110703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (110703) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:45:19+08" D (110703) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (110703) cellular: mux-rx-line #3 (2/0): OK OVMS> D (111693) cellular: mux-tx #3: AT+CPSI? D (111703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (111703) cellular: mux-rx-line #3 (2/0): OK OVMS> D (112693) cellular: mux-tx #3: AT+COPS? D (112703) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (112703) cellular: mux-rx-line #3 (2/0): OK OVMS> I (122693) housekeeping: System considered stable (RAM: 8b=47972-48676 32b=12128 SPI=3205136-3218336) D (122763) ovms-duktape: Duktape: Compacting DukTape memory done in 40 ms OVMS> I (123693) ovms-server-v2: Send MP-0 h19,0,*-OVM-DebugCrash,0,2592000,3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),4,EarlyCrash,12,12,3,1,abort(),1,,0x4008ddae 0x4008e049 0x401184a3 0x4032e70b 0x40127862 0x40127909 0x40127909 0x401279af 0x401138b7 0x40130427 0x401305de 0x401138e7 0x4032f76a 0x4012d559 0x40122885 0x40122a5d 0x4012d401 0x4012d410 0x4010c3eb ,4,Exception/panic,,,0,,OVMS WIFI BLE BT cores=2 rev=ESP32/1; MODEM SIM5360,,IDLE0,524,OVMS Console,3464 I (123873) ovms-server-v2: Incoming Msg: MP-0 h19 OVMS> enable Password: Secure mode OVMS# module faD (140693) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (140703) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (140703) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:45:49+08" D (140703) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (140713) cellular: mux-rx-line #3 (2/0): OK OVMS# module fault D (141693) cellular: mux-tx #3: AT+CPSI? D (141703) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (141703) cellular: mux-rx-line #3 (2/0): OK OVMS# module fault abort() was called at PC 0x401184a3 on core 1 ELF file SHA256: 8ba7ed1fff95ef4c Backtrace: 0x4008ddae:0x3ffef1a0 0x4008e049:0x3ffef1c0 0x401184a3:0x3ffef1e0 0x4032e70b:0x3ffef200 0x40127862:0x3ffef220 0x40127909:0x3ffef280 0x40127909:0x3ffef2e0 0x401279af:0x3ffef340 0x401138b7:0x3ffef360 0x40130427:0x3ffef380 0x401305de:0x3ffef3e0 0x401138e7:0x3ffef480 0x4032f76a:0x3ffef4a0 0x4012d559:0x3ffef4c0 0x40122885:0x3ffef4f0 0x40122a5d:0x3ffef520 0x4012d401:0x3ffef540 0x4012d410:0x3ffef560 0x4010c3eb:0x3ffef580 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5328 ho 0 tail 12 room 4 load:0x40078000,len:11332 load:0x40080400,len:6204 entry 0x400806cc I (1192) psram: This chip is ESP32-D0WD I (1193) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1233) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2134) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (215) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (215) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Boot #5 reasons for CPU0=12 and CPU1=12 E (242) boot: Crash #4 detected I (246) boot: Reset reason Exception/panic (4) I (252) events: Initialising EVENTS (1200) I (257) config: Initialising CONFIG (1400) I (262) time: Initialising TIME (1500) I (266) script: Initialising SCRIPTS (1600) I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (282) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (288) metrics: Initialising METRICS (1810) I (293) metrics: Expanding DUKTAPE javascript engine I (298) metrics: Persistent metrics serial 6 using 820 bytes, 68/100 slots used I (308) metrics: persist v.b.cac = 92.9772Ah I (312) metrics: persist v.b.range.est = 50km I (316) metrics: persist v.b.12v.voltage = 12.3V I (322) metrics: persist v.b.12v.voltage.ref = 12.6V I (328) metrics: persist v.c.climit = 15A I (333) metrics: persist v.c.limit.range = 56km I (337) metrics: persist v.c.limit.soc = 21% I (346) metrics: persist v.e.drivemode = 33882626 I (348) metrics: persist v.e.valet = yes I (352) metrics: persist v.e.parktime = 853Sec I (359) metrics: persist v.p.latitude = 51.4041 I (363) metrics: persist v.p.longitude = 7.43985 I (368) metrics: persist v.p.altitude = 142.3m I (375) notify: Initialising NOTIFICATIONS (1820) I (379) notify: Registered notification type info I (383) notify: Registered notification type error I (389) notify: Registered notification type alert I (394) notify: Registered notification type data I (400) notify: Registered notification type stream I (405) notify: Expanding DUKTAPE javascript engine I (411) location: Initialising LOCATIONS (1900) I (419) location: Expanding DUKTAPE javascript engine I (422) vehicle: Initialising VEHICLE Factory (2000) I (433) tls: Initialising TLS (3000) I (434) pcp: Initialising POWER (4000) I (436) max7317: Initialising MAX7317 EGPIO (4200) I (443) sdcard: Initialising SD CARD (4400) I (447) ota: Initialising OTA (4400) I (453) canformat: Initialising CAN Format Factory (4500) I (457) canformat-cs11: Registering CAN Format: CS11 (4505) I (463) canformat-crtd: Registering CAN Format: CRTD (4505) I (469) canformat-gvret: Registering CAN Format: GVRET (4505) I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (482) canformat-panda: Registering CAN Format: PANDA (4505) I (489) canformat-pcap: Registering CAN Format: PCAP (4505) I (495) canformat-raw: Registering CAN Format: RAW (4505) I (501) can: Initialising CAN (4510) I (513) dbc-app: Initialising DBC (4520) I (516) canlog: Initialising CAN logging (4550) I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (523) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (546) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (555) canlog-vfs: Initialising CAN logging to VFS (4560) I (559) canplay: Initialising CAN play framework (4570) I (564) canplay-vfs: Initialising CAN playing from VFS (4580) I (571) cellular: Initialising CELLULAR (4600) I (578) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (582) cellular-modem-auto: Registering auto-detect modem driver (4650) I (590) SIM5360: Registering SIM5360 modem driver (4650) I (596) SIM7000: Registering SIM7000 modem driver (4650) I (602) SIM7600: Registering SIM7600 modem driver (4650) I (608) SIM7670: Registering Simcom A7670E modem driver (4660) I (614) tpms: Initialising TPMS (4700) I (620) test: Initialising TEST (5000) I (625) module: Initialising MODULE (5100) I (630) vfs: Initialising VFS (5200) I (634) ovms-server: Initialising OVMS Server (6000) I (638) ovms-server-v2: Initialising OVMS V2 Server (6100) I (645) ovms-server-v3: Initialising OVMS V3 Server (6200) I (651) vehicle-poll: Initialising Poller (7000) I (659) obd2ecu: Initialising OBD2ECU (7000) I (662) canopen: Initialising CANopen (7000) I (670) pluginstore: Initialising PLUGINS (7100) I (673) esp32wifi: Initialising ESP32WIFI (8000) I (677) ovms-mdns: Initialising MDNS (8100) I (681) webserver: Initialising WEBSERVER (8200) I (689) ssh: Initialising SSH (8300) I (691) powermgmt: Initialising POWERMGMT (8500) I (697) re: Initialising RE Tools (8800) I (703) pushover: Initialising Pushover client (8800) I (708) netmanager: Initialising NETMANAGER (8999) I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (718) v-zeva: Registering Vehicle: ZEVA (9000) I (724) v-vweup: Registering Vehicle: VW e-Up (9000) I (729) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (737) v-track: Registering Vehicle: TRACK (9000) I (742) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (755) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (762) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (775) v-smarteq: Registering Vehicle: SMART EQ (9000) I (781) v-smarted: Registering Vehicle: SMART ED (9000) I (787) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (801) v-twizy: Registering Vehicle: Renault Twizy (9000) I (807) v-obdii: Registering Vehicle: OBDII (9000) I (813) v-none: Registering Vehicle: NONE (9000) I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (824) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (840) v-mgev4: Registering Vehicle: MG4 (9000) I (845) v-mgev: Registering Vehicle: MG5 (9000) I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (863) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (869) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (875) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (882) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (894) v-maple60s: Registering Vehicle: Maple 60S (9000) I (900) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (914) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (921) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (935) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (941) v-energica: Registering Vehicle: Energica (9000) I (947) v-demo: Registering Vehicle: DEMO (9000) I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (959) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (967) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (975) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (980) v-boltev: Registering Vehicle: Bolt EV (9000) I (986) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (992) version: Initialising Versioning (9900) I (1000) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (1072) ovms_main: Executing on CPU core 0 I (1082) ovms_main: Mounting CONFIG... I (1192) ovms_main: Configure logging... W (1202) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1202) ovms_main: Registering default configs... I (1202) ovms_main: Starting HOUSEKEEPING... I (1212) housekeeping: Initialising HOUSEKEEPING Framework... I (1212) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1682) events: Signal(housekeeping.init) I (1682) housekeeping: Executing on CPU core 1 I (1682) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1682) housekeeping: Starting PERIPHERALS... I (1692) peripherals: Initialising OVMS Peripherals... I (1692) peripherals: TCP/IP Adaptor I (1702) peripherals: ESP32 system I (1702) peripherals: SPI bus I (1712) peripherals: MAX7317 I/O Expander I (1712) peripherals: ESP32 CAN I (1722) peripherals: ESP32 WIFI I (1722) peripherals: ESP32 ADC I (1722) peripherals: MCP2515 CAN 1/2 I (1732) mcp2515: can2: SetPowerMode off I (1812) peripherals: MCP2515 CAN 2/2 I (1812) mcp2515: can3: SetPowerMode off I (1892) peripherals: SD CARD I (1892) peripherals: CELLULAR MODEM I (1892) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1902) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1912) cellular: Starting modem task I (1912) uart: queue free spaces: 50 I (1912) ext12v: Powering off external 12V devices I (1922) housekeeping: Auto init max7317 (free: 160572 bytes) I (1932) housekeeping: Auto init ext12v (free: 160572 bytes) I (1932) housekeeping: Auto init dbc (free: 160572 bytes) I (1942) housekeeping: Auto init wifi (free: 160572 bytes) I (1962) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0 I (1962) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1972) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1992) wifi:wifi firmware version: 30f9e79 I (2002) wifi:config NVS flash: enabled I (2002) wifi:config nano formating: disabled I (2002) wifi:Init data frame dynamic rx buffer num: 16 I (2002) wifi:Init management frame dynamic rx buffer num: 16 I (2012) wifi:Init management short buffer num: 32 I (2012) wifi:Init dynamic tx buffer num: 16 I (2012) wifi:Init static rx buffer size: 2212 I (2022) wifi:Init static rx buffer num: 16 I (2022) wifi:Init dynamic rx buffer num: 16 I (2802) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2802) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2802) wifi:Total power save buffer number: 8 I (2812) wifi:Init max length of beacon: 752/752 I (2812) wifi:Init max length of beacon: 752/752 I (2822) housekeeping: Auto init modem (free: 115148 bytes) I (2822) housekeeping: Auto init Pollers (free: 114728 bytes) I (2822) cellular: Set modem driver to 'auto' I (2832) housekeeping: Auto init vehicle (free: 114728 bytes) I (2832) cellular: State: Enter PowerOffOn state I (2842) v-twizy: Renault Twizy vehicle module I (2842) cellular-modem-auto: Power Cycle I (2852) v-twizy: battmon subsystem init I (2852) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2862) v-twizy: pwrmon subsystem init I (2872) v-twizy: charge subsystem init I (2882) canopen: Worker started on can1 I (2882) v-twizy: sevcon subsystem init I (2892) v-twizy: obd subsystem init I (2892) housekeeping: Auto init obd2ecu (free: 81464 bytes) I (2902) housekeeping: Auto init server v2 (free: 81464 bytes) I (2902) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2912) ovms-server-v2: Status: Server has been started I (2912) ovms-server-v2: OVMS Server v2 running I (2922) housekeeping: Auto init server v3 (free: 80912 bytes) I (2922) housekeeping: Auto init javascript (free: 80912 bytes) I (2932) housekeeping: Auto init done (free: 80872 bytes) I (2942) housekeeping: Starting USB console... I (2942) uart: queue free spaces: 100 D (2952) events: Signal(egpio.output.1.low) D (2962) events: Signal(system.event) D (2962) events: Signal(system.wifi.sta.start) D (2972) events: Signal(system.event) D (2972) events: Signal(system.wifi.ap.start) I (2972) netmanager: WIFI access point is up D (2982) events: Signal(power.cellular.on) D (2982) events: Signal(system.modem.stop) D (2982) events: Signal(egpio.output.0.low) D (2992) events: Signal(egpio.output.0.high) D (2992) events: Signal(power.can1.on) D (2992) events: Signal(egpio.output.2.low) D (3002) events: Signal(canopen.worker.start) D (3002) events: Signal(vehicle.type.set) D (3012) events: Signal(server.v2.waitnetwork) D (3012) events: Signal(system.start) I (3012) ovms-mdns: Starting MDNS D (3022) netmanager: MongooseTask starting I (3022) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 D (3042) events: Signal(network.interface.change) D (3052) events: Signal(network.mgr.init) I (3072) ssh: Launching SSH Server OVMS> I (3202) ovms-duktape: Duktape: Initialising module system D (3222) ovms-duktape: Duktape: Pre-Registered function assert D (3222) ovms-duktape: Duktape: Pre-Registered function meminfo D (3222) ovms-duktape: Duktape: Pre-Registered function print D (3232) ovms-duktape: Duktape: Pre-Registered function write D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3232) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3282) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3282) ovms-duktape: Duktape: Pre-Registered object VFS D (3282) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3282) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3282) ovms-duktape: Duktape: Pre-Registered module JSON D (3292) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3292) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3292) ovms-duktape: Duktape: module load: int/JSON.js D (3372) ovms-duktape: Duktape: Pre-Registered module PubSub D (3392) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3392) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3392) ovms-duktape: Duktape: module load: int/PubSub.js I (3612) ovms-duktape: Duktape: Executing ovmsmain.js D (3622) ovms-duktape: Duktape: module load: ovmsmain.js D (3632) ovms-duktape: Duktape: module unload: ovmsmain.js D (3682) events: Signal(vehicle.charge.mode) OVMS> D (4682) events: Signal(vehicle.aux.12v.normal) OVMS> D (5372) events: Signal(egpio.output.0.low) D (5422) events: Signal(system.event) D (5422) events: Signal(system.wifi.scan.done) I (5552) wifi:ap channel adjust o:1,0 n:11,0 I (5552) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6232) wifi:state: init -> auth (b0) I (6252) wifi:state: auth -> assoc (0) I (6262) wifi:state: assoc -> run (10) I (6282) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85 I (6282) wifi:security type: 3, phy: bgn, rssi: -62 I (6282) wifi:pm start, type: 1 D (6282) events: Signal(system.event) D (6292) events: Signal(system.wifi.sta.connected) D (6292) netmanager: send cmd 3 from 0x0 D (6292) netmanager: done cmd 3 from 0x0 D (6292) netmanager: MongooseTask: got cmd 3 from 0x0 I (6302) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6302) events: Signal(system.event) D (6312) events: Signal(network.interface.up) D (6312) events: Signal(system.wifi.sta.gotip) I (6312) netmanager: WIFI client got IP D (6312) netmanager: Saved DNS#0 192.168.178.1 D (6312) netmanager: Saved DNS#1 0.0.0.0 D (6312) netmanager: Saved DNS#2 0.0.0.0 D (6312) netmanager: send cmd 3 from 0x0 D (6312) netmanager: done cmd 3 from 0x0 D (6302) netmanager: MongooseTask: done cmd 3 from 0x0 D (6322) netmanager: MongooseTask: got cmd 3 from 0x0 D (6352) netmanager: MongooseTask: done cmd 3 from 0x0 I (6372) wifi:AP's beacon interval = 102400 us, DTIM period = 1 OVMS> D (8682) events: Signal(network.wifi.sta.good) I (8682) netmanager: WIFI client has good signal quality (-83.0 dBm); connect I (8682) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (8682) netmanager: Set DNS#1 0.0.0.0 I (8682) netmanager: Set DNS#2 0.0.0.0 I (8682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (8692) events: Signal(network.wifi.up) D (8692) events: Signal(network.up) I (8692) ovms-server-v2: Status: Network is up, so attempt network connection D (8692) events: Signal(network.interface.change) D (8702) events: Signal(server.v2.connectwait) OVMS> D (10372) events: Signal(egpio.output.0.high) D (10572) events: Signal(egpio.output.0.low) I (10682) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (10682) ovms-server-v2: Status: Connecting... D (10712) events: Signal(server.v2.connecting) OVMS> D (10972) cellular: State timeout PowerOffOn => PoweringOn I (10972) cellular: State: Enter PoweringOn state I (10972) cellular-modem-auto: Power Cycle D (10972) events: Signal(system.modem.poweringon) I (10972) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10972) events: Signal(egpio.output.0.high) OVMS> D (13472) events: Signal(egpio.output.0.low) OVMS> I (14252) ovms-server-v2: Connection successful I (14252) ovms-server-v2: Status: Logging in... D (14252) events: Signal(server.v2.authenticating) I (14262) ovms-server-v2: Sending server login: MP-C 0 Yu8DEPRjRT8QKnIu9282gr Kfkv9DBfw7ITt4ffMXbZmg== TEST1 OVMS> I (15982) ovms-server-v2: Got server response: MP-S 0 yjqUlH9NVyAICzYzodUz+t fNsMgt8ZUaouC+Em3X/FNg== I (15982) ovms-server-v2: Server token is yjqUlH9NVyAICzYzodUz+t and digest is fNsMgt8ZUaouC+Em3X/FNg== I (15992) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (15992) ovms-server-v2: Shared secret key is yjqUlH9NVyAICzYzodUz+tYu8DEPRjRT8QKnIu9282gr (44 bytes) I (15992) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (15992) events: Signal(server.v2.connected) I (16022) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> I (16682) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (16692) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,866,0,0,1,1,12.31,0,12.6,0,0,0,0 I (16692) ovms-server-v2: Send MP-0 L51.404099,7.439854,0,142.3,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (16692) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (16692) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (16692) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,25,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18472) events: Signal(egpio.output.0.high) D (18672) events: Signal(egpio.output.0.low) I (18772) cellular: State: Enter Identify state D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM D (18872) cellular: tx-cmd: AT+CGMM I (18882) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (18882) cellular: Remove old 'auto' modem driver I (18882) cellular: Set modem driver to 'SIM5360' I (18882) cellular: State: Enter PoweredOn state D (18882) events: Signal(system.modem.installed) D (18892) events: Signal(system.modem.poweredon) D (18992) cellular: mux-rx-line #0 (2/0): OK OVMS> D (19762) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (19772) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (19772) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS> D (20482) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS> D (21052) cellular: mux-rx-line #0 (10/11): CALL READY D (21062) cellular: mux-rx-line #0 (7/0): PB DONE OVMS> I (24682) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.404099,7.439854,142,0,0,0,0,-61,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (24802) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS> D (26682) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26702) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26742) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (26742) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0 D (26742) cellular: Signal Quality is: 22 (-69 dBm) D (26742) cellular: mux-rx-line #0 (2/0): OK OVMS> D (27362) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:46:20 OVMS> D (28682) cellular: tx-cmd: AT+CGMR;+ICCID D (28692) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (28692) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (28692) cellular: mux-rx-line #0 (2/0): OK OVMS> D (32222) cellular: mux-rx-line #0 (11/0): +CSQ: 22,99 OVMS> D (32682) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (32692) cellular: mux-rx-line #0 (2/0): OK OVMS> D (33682) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (33692) cellular: mux-rx-line #0 (2/0): OK OVMS> D (34682) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (34692) cellular: mux-rx-line #0 (2/0): OK OVMS> D (35682) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (35692) cellular: mux-rx-line #0 (2/0): OK OVMS> D (36682) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (36692) cellular: mux-rx-line #0 (2/0): OK I (36692) cellular: State: Enter MuxStart state V (36692) cellular: Starting MUX D (36692) events: Signal(system.modem.muxstart) I (36692) gsm-mux: Start MUX I (36702) gsm-mux: Channel #0 is open I (36702) gsm-mux: Channel #1 is open I (36712) gsm-mux: Channel #2 is open I (36712) gsm-mux: Channel #3 is open I (36722) gsm-mux: Channel #4 is open OVMS> D (37682) cellular: State transition MuxStart => NetWait I (37682) cellular: State: Enter NetWait state V (37682) cellular: Starting NMEA I (37682) gsm-nmea: Startup D (37682) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 D (37682) events: Signal(system.modem.netwait) D (37692) events: Signal(system.modem.gpsstart) D (37772) cellular: mux-rx-line #4 (2/0): OK OVMS> I (45692) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45702) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45832) ovms-server-v2: Incoming Msg: MP-0 h2 I (45832) ovms-server-v2: Incoming Msg: MP-0 h3 I (45832) ovms-server-v2: Incoming Msg: MP-0 h4 I (45842) ovms-server-v2: Incoming Msg: MP-0 h5 I (45852) ovms-server-v2: Incoming Msg: MP-0 h6 OVMS> I (46682) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46692) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46882) ovms-server-v2: Incoming Msg: MP-0 h7 I (46882) ovms-server-v2: Incoming Msg: MP-0 h8 I (46882) ovms-server-v2: Incoming Msg: MP-0 h9 I (46892) ovms-server-v2: Incoming Msg: MP-0 h10 I (46892) ovms-server-v2: Incoming Msg: MP-0 h11 OVMS> D (47682) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ I (47682) ovms-server-v2: Send MP-0 h12,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47692) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47692) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 D (47712) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (47712) cellular: Network Registration status: RegisteredRoaming D (47712) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:46:40+08" D (47712) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (47712) cellular: mux-rx-line #3 (2/0): OK I (47932) ovms-server-v2: Incoming Msg: MP-0 h12 I (47932) ovms-server-v2: Incoming Msg: MP-0 h13 I (47932) ovms-server-v2: Incoming Msg: MP-0 h14 I (47942) ovms-server-v2: Incoming Msg: MP-0 h15 I (47942) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (48682) cellular: mux-tx #3: AT+CPSI? D (48682) cellular: State transition NetWait => NetStart I (48682) cellular: State: Enter NetStart state D (48682) events: Signal(system.modem.netstart) D (48692) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-72,0,35-35 I (48692) cellular: Network Mode: GSM,Online D (48692) cellular: mux-rx-line #3 (2/0): OK D (48892) events: Signal(gps.lock.acquired) D (48902) events: Signal(system.modem.gotgps) OVMS> D (49682) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 I (49692) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.403904,7.439991,155,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (49742) ovms-server-v2: Incoming Msg: MP-0 h17 D (49742) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (49742) cellular: PPP Connection is ready to start OVMS> D (50682) cellular: State transition NetStart => NetMode I (50682) cellular: State: Enter NetMode state V (50682) cellular: Launching PPP V (50682) cellular: Starting PPP I (50682) gsm-ppp: Initialising... D (50692) events: Signal(system.modem.netmode) OVMS> I (51512) gsm-ppp: StatusCallBack: None I (51512) gsm-ppp: status_cb: Connected I (51512) gsm-ppp: our_ipaddr = 10.170.195.13 I (51512) gsm-ppp: his_ipaddr = 10.64.64.64 I (51522) gsm-ppp: netmask = 255.255.255.255 I (51522) gsm-ppp: DNS#0 = 8.8.8.8 I (51522) gsm-ppp: DNS#1 = 8.8.4.4 I (51522) gsm-ppp: our6_ipaddr = :: D (51522) events: Signal(network.interface.up) D (51522) events: Signal(system.modem.gotip) D (51522) netmanager: Saved DNS#0 8.8.8.8 D (51522) netmanager: Saved DNS#1 8.8.4.4 D (51522) netmanager: Saved DNS#2 0.0.0.0 I (51522) netmanager: Set DNS#1 0.0.0.0 I (51522) netmanager: Set DNS#2 0.0.0.0 I (51522) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (51532) events: Signal(network.modem.up) D (51532) events: Signal(network.interface.change) OVMS> D (53232) cellular: mux-rx-line #3 (10/0): +CSQ: 22,0 OVMS> D (56232) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99 OVMS> D (62762) ovms-duktape: Duktape: Compacting DukTape memory done in 70 ms OVMS> D (80682) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (80702) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (80702) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:47:13+08" D (80702) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (80702) cellular: mux-rx-line #3 (2/0): OK OVMS> D (81682) cellular: mux-tx #3: AT+CPSI? D (81692) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-72,0,35-35 D (81692) cellular: mux-rx-line #3 (2/0): OK OVMS> D (82682) cellular: mux-tx #3: AT+COPS? D (82692) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (82692) cellular: Network Provider is: vodafone.de Hologram D (82692) cellular: mux-rx-line #3 (2/0): OK OVMS> I (84682) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.403942,7.439952,153,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (84732) ovms-server-v2: Incoming Msg: MP-0 h18 OVMS>
