I (1192) psram: This chip is ESP32-D0WD I (1193) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (0) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2133) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (214) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (215) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Power cycle reset detected I (242) events: Initialising EVENTS (1200) I (247) config: Initialising CONFIG (1400) I (252) time: Initialising TIME (1500) I (256) script: Initialising SCRIPTS (1600) I (260) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (266) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (272) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (277) metrics: Initialising METRICS (1810) I (283) metrics: Expanding DUKTAPE javascript engine I (288) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used I (310) notify: Initialising NOTIFICATIONS (1820) I (312) notify: Registered notification type info I (312) notify: Registered notification type error I (316) notify: Registered notification type alert I (321) notify: Registered notification type data I (326) notify: Registered notification type stream I (332) notify: Expanding DUKTAPE javascript engine I (338) location: Initialising LOCATIONS (1900) I (346) location: Expanding DUKTAPE javascript engine I (349) vehicle: Initialising VEHICLE Factory (2000) I (360) tls: Initialising TLS (3000) I (361) pcp: Initialising POWER (4000) I (363) max7317: Initialising MAX7317 EGPIO (4200) I (369) sdcard: Initialising SD CARD (4400) I (374) ota: Initialising OTA (4400) I (380) canformat: Initialising CAN Format Factory (4500) I (383) canformat-cs11: Registering CAN Format: CS11 (4505) I (390) canformat-crtd: Registering CAN Format: CRTD (4505) I (396) canformat-gvret: Registering CAN Format: GVRET (4505) I (402) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (409) canformat-panda: Registering CAN Format: PANDA (4505) I (416) canformat-pcap: Registering CAN Format: PCAP (4505) I (422) canformat-raw: Registering CAN Format: RAW (4505) I (428) can: Initialising CAN (4510) I (439) dbc-app: Initialising DBC (4520) I (443) canlog: Initialising CAN logging (4550) I (444) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (450) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (459) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (467) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (472) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (481) canlog-vfs: Initialising CAN logging to VFS (4560) I (485) canplay: Initialising CAN play framework (4570) I (491) canplay-vfs: Initialising CAN playing from VFS (4580) I (497) cellular: Initialising CELLULAR (4600) I (504) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (509) cellular-modem-auto: Registering auto-detect modem driver (4650) I (517) SIM5360: Registering SIM5360 modem driver (4650) I (523) SIM7000: Registering SIM7000 modem driver (4650) I (529) SIM7600: Registering SIM7600 modem driver (4650) I (535) SIM7670: Registering Simcom A7670E modem driver (4660) I (541) tpms: Initialising TPMS (4700) I (546) test: Initialising TEST (5000) I (551) module: Initialising MODULE (5100) I (556) vfs: Initialising VFS (5200) I (560) ovms-server: Initialising OVMS Server (6000) I (565) ovms-server-v2: Initialising OVMS V2 Server (6100) I (572) ovms-server-v3: Initialising OVMS V3 Server (6200) I (578) vehicle-poll: Initialising Poller (7000) I (585) obd2ecu: Initialising OBD2ECU (7000) I (589) canopen: Initialising CANopen (7000) I (597) pluginstore: Initialising PLUGINS (7100) I (599) esp32wifi: Initialising ESP32WIFI (8000) I (604) ovms-mdns: Initialising MDNS (8100) I (608) webserver: Initialising WEBSERVER (8200) I (616) ssh: Initialising SSH (8300) I (618) powermgmt: Initialising POWERMGMT (8500) I (623) re: Initialising RE Tools (8800) I (630) pushover: Initialising Pushover client (8800) I (635) netmanager: Initialising NETMANAGER (8999) I (642) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (645) v-zeva: Registering Vehicle: ZEVA (9000) I (650) v-vweup: Registering Vehicle: VW e-Up (9000) I (656) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (663) v-track: Registering Vehicle: TRACK (9000) I (669) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (676) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (682) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (689) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (696) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (702) v-smarteq: Registering Vehicle: SMART EQ (9000) I (708) v-smarted: Registering Vehicle: SMART ED (9000) I (714) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (721) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (728) v-twizy: Registering Vehicle: Renault Twizy (9000) I (734) v-obdii: Registering Vehicle: OBDII (9000) I (739) v-none: Registering Vehicle: NONE (9000) I (745) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (751) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (761) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (767) v-mgev4: Registering Vehicle: MG4 (9000) I (772) v-mgev: Registering Vehicle: MG5 (9000) I (777) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (784) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (790) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (796) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (802) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (808) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (815) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (821) v-maple60s: Registering Vehicle: Maple 60S (9000) I (827) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (834) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (841) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (848) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (855) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (862) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (868) v-energica: Registering Vehicle: Energica (9000) I (874) v-demo: Registering Vehicle: DEMO (9000) I (879) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (886) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (894) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (901) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (907) v-boltev: Registering Vehicle: Bolt EV (9000) I (913) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (918) version: Initialising Versioning (9900) I (928) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (999) ovms_main: Executing on CPU core 0 I (1009) ovms_main: Mounting CONFIG... I (1119) ovms_main: Configure logging... W (1129) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1129) ovms_main: Registering default configs... I (1129) ovms_main: Starting HOUSEKEEPING... I (1139) housekeeping: Initialising HOUSEKEEPING Framework... I (1139) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1619) events: Signal(housekeeping.init) I (1619) housekeeping: Executing on CPU core 1 I (1619) housekeeping: reset_reason: cpu0=1, cpu1=14 I (1619) housekeeping: Starting PERIPHERALS... I (1629) peripherals: Initialising OVMS Peripherals... I (1629) peripherals: TCP/IP Adaptor I (1639) peripherals: ESP32 system I (1639) peripherals: SPI bus I (1649) peripherals: MAX7317 I/O Expander I (1649) peripherals: ESP32 CAN I (1659) peripherals: ESP32 WIFI I (1659) peripherals: ESP32 ADC I (1659) peripherals: MCP2515 CAN 1/2 I (1669) mcp2515: can2: SetPowerMode off I (1749) peripherals: MCP2515 CAN 2/2 I (1749) mcp2515: can3: SetPowerMode off I (1829) peripherals: SD CARD I (1829) peripherals: CELLULAR MODEM I (1829) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1839) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1849) cellular: Starting modem task I (1849) uart: queue free spaces: 50 I (1849) ext12v: Powering off external 12V devices I (1859) housekeeping: Auto init max7317 (free: 160848 bytes) I (1869) housekeeping: Auto init ext12v (free: 160848 bytes) I (1869) housekeeping: Auto init dbc (free: 160848 bytes) I (1879) housekeeping: Auto init wifi (free: 160848 bytes) I (1899) wifi:wifi driver task: 3ffd9a04, prio:23, stack:3584, core=0 I (1899) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1909) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1939) wifi:wifi firmware version: 30f9e79 I (1939) wifi:config NVS flash: enabled I (1939) wifi:config nano formating: disabled I (1939) wifi:Init data frame dynamic rx buffer num: 16 I (1939) wifi:Init management frame dynamic rx buffer num: 16 I (1949) wifi:Init management short buffer num: 32 I (1949) wifi:Init dynamic tx buffer num: 16 I (1949) wifi:Init static rx buffer size: 2212 I (1959) wifi:Init static rx buffer num: 16 I (1959) wifi:Init dynamic rx buffer num: 16 I (2739) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2739) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2739) wifi:Total power save buffer number: 8 I (2739) wifi:Init max length of beacon: 752/752 I (2749) wifi:Init max length of beacon: 752/752 I (2749) housekeeping: Auto init modem (free: 115428 bytes) I (2759) housekeeping: Auto init Pollers (free: 115008 bytes) I (2759) cellular: Set modem driver to 'auto' I (2759) housekeeping: Auto init vehicle (free: 115008 bytes) I (2769) cellular: State: Enter PowerOffOn state I (2779) v-twizy: Renault Twizy vehicle module I (2779) cellular-modem-auto: Power Cycle I (2789) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2789) v-twizy: battmon subsystem init I (2809) v-twizy: pwrmon subsystem init I (2809) v-twizy: charge subsystem init I (2809) canopen: Worker started on can1 I (2819) v-twizy: sevcon subsystem init I (2829) v-twizy: obd subsystem init I (2829) housekeeping: Auto init obd2ecu (free: 81752 bytes) I (2829) housekeeping: Auto init server v2 (free: 81752 bytes) I (2839) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2839) ovms-server-v2: Status: Server has been started I (2849) ovms-server-v2: OVMS Server v2 running I (2859) housekeeping: Auto init server v3 (free: 81200 bytes) I (2859) housekeeping: Auto init javascript (free: 81200 bytes) I (2869) housekeeping: Auto init done (free: 81160 bytes) I (2879) housekeeping: Starting USB console... I (2879) uart: queue free spaces: 100 D (2889) events: Signal(egpio.output.1.low) D (2899) events: Signal(system.event) D (2899) events: Signal(system.wifi.sta.start) D (2899) events: Signal(system.event) D (2909) events: Signal(system.wifi.ap.start) I (2909) netmanager: WIFI access point is up D (2919) events: Signal(power.cellular.on) D (2919) events: Signal(system.modem.stop) D (2919) events: Signal(vehicle.valet.on) D (2919) events: Signal(notify.info.valet.enabled) D (2929) events: Signal(egpio.output.0.low) D (2929) events: Signal(egpio.output.0.high) D (2939) events: Signal(power.can1.on) D (2939) events: Signal(egpio.output.2.low) D (2949) events: Signal(canopen.worker.start) D (2949) events: Signal(vehicle.drivemode.33882626) D (2959) events: Signal(vehicle.type.set) D (2959) events: Signal(server.v2.waitnetwork) D (2969) events: Signal(system.start) I (2969) ovms-mdns: Starting MDNS D (2969) netmanager: MongooseTask starting I (2969) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 D (2989) events: Signal(network.interface.change) D (2999) events: Signal(network.mgr.init) I (3019) ssh: Launching SSH Server OVMS> I (3149) ovms-duktape: Duktape: Initialising module system D (3169) ovms-duktape: Duktape: Pre-Registered function assert D (3169) ovms-duktape: Duktape: Pre-Registered function meminfo D (3169) ovms-duktape: Duktape: Pre-Registered function print D (3169) ovms-duktape: Duktape: Pre-Registered function write D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3169) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3169) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3179) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3189) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3199) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3209) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3219) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3219) ovms-duktape: Duktape: Pre-Registered object VFS D (3219) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3219) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3219) ovms-duktape: Duktape: Pre-Registered module JSON D (3239) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3239) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3239) ovms-duktape: Duktape: module load: int/JSON.js D (3329) ovms-duktape: Duktape: Pre-Registered module PubSub D (3349) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3349) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3349) ovms-duktape: Duktape: module load: int/PubSub.js I (3559) ovms-duktape: Duktape: Executing ovmsmain.js D (3559) ovms-duktape: Duktape: module load: ovmsmain.js D (3579) ovms-duktape: Duktape: module unload: ovmsmain.js D (3619) events: Signal(vehicle.charge.mode) OVMS> D (4619) events: Signal(vehicle.aux.12v.normal) OVMS> D (5299) events: Signal(egpio.output.0.low) D (5359) events: Signal(system.event) D (5359) events: Signal(system.wifi.scan.done) I (5489) wifi:ap channel adjust o:1,0 n:11,0 I (5489) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6169) wifi:state: init -> auth (b0) I (6189) wifi:state: auth -> assoc (0) I (6199) wifi:state: assoc -> run (10) I (6219) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85 I (6219) wifi:security type: 3, phy: bgn, rssi: -55 I (6219) wifi:pm start, type: 1 D (6229) events: Signal(system.event) D (6229) events: Signal(system.wifi.sta.connected) D (6229) netmanager: send cmd 3 from 0x0 D (6229) netmanager: done cmd 3 from 0x0 I (6249) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6249) events: Signal(system.event) D (6249) events: Signal(network.interface.up) D (6259) events: Signal(system.wifi.sta.gotip) I (6259) netmanager: WIFI client got IP D (6259) netmanager: Saved DNS#0 192.168.178.1 D (6259) netmanager: Saved DNS#1 0.0.0.0 D (6259) netmanager: Saved DNS#2 0.0.0.0 D (6259) netmanager: send cmd 3 from 0x0 D (6259) netmanager: done cmd 3 from 0x0 I (6269) wifi:AP's beacon interval = 102400 us, DTIM period = 1 D (6249) netmanager: MongooseTask: got cmd 3 from 0x0 D (6289) netmanager: MongooseTask: done cmd 3 from 0x0 D (6289) netmanager: MongooseTask: got cmd 3 from 0x0 D (6299) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> D (7619) events: Signal(network.wifi.sta.good) I (7619) netmanager: WIFI client has good signal quality (-85.3 dBm); connect I (7619) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (7619) netmanager: Set DNS#1 0.0.0.0 I (7619) netmanager: Set DNS#2 0.0.0.0 I (7619) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (7629) events: Signal(network.wifi.up) D (7629) events: Signal(network.up) I (7629) ovms-server-v2: Status: Network is up, so attempt network connection D (7629) events: Signal(network.interface.change) D (7639) events: Signal(server.v2.connectwait) OVMS> I (9619) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (9619) ovms-server-v2: Status: Connecting... D (9649) events: Signal(server.v2.connecting) OVMS> D (10299) events: Signal(egpio.output.0.high) D (10499) events: Signal(egpio.output.0.low) OVMS> D (10999) cellular: State timeout PowerOffOn => PoweringOn I (10999) cellular: State: Enter PoweringOn state I (10999) cellular-modem-auto: Power Cycle D (10999) events: Signal(system.modem.poweringon) I (10999) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10999) events: Signal(egpio.output.0.high) OVMS> I (13149) ovms-server-v2: Connection successful I (13149) ovms-server-v2: Status: Logging in... D (13159) events: Signal(server.v2.authenticating) I (13159) ovms-server-v2: Sending server login: MP-C 0 6EQPbaYviEeaaOE9kzsLyB //LWT79yBsM6Vei+A2HG9g== TEST1 I (13199) ovms-server-v2: Got server response: MP-S 0 I1mn1eqQv2tTW7A2RwHQ7r jTMnTslUVDNXFmkeBECwAA== I (13199) ovms-server-v2: Server token is I1mn1eqQv2tTW7A2RwHQ7r and digest is jTMnTslUVDNXFmkeBECwAA== I (13209) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (13209) ovms-server-v2: Shared secret key is I1mn1eqQv2tTW7A2RwHQ7r6EQPbaYviEeaaOE9kzsLyB (44 bytes) I (13209) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (13209) events: Signal(server.v2.connected) I (13239) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> D (13499) events: Signal(egpio.output.0.low) I (13619) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (13629) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,10,0,0,1,1,12.33,0,12.6,0,0,0,0 I (13629) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (13629) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (13629) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (13629) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,27,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18499) events: Signal(egpio.output.0.high) D (18699) events: Signal(egpio.output.0.low) I (18799) cellular: State: Enter Identify state D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM D (18899) cellular: tx-cmd: AT+CGMM I (18909) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (18909) cellular: Remove old 'auto' modem driver I (18909) cellular: Set modem driver to 'SIM5360' I (18909) cellular: State: Enter PoweredOn state D (18909) events: Signal(system.modem.installed) D (18919) events: Signal(system.modem.poweredon) D (19019) cellular: mux-rx-line #0 (2/0): OK OVMS> D (19809) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (19809) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (19809) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS> D (20539) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS> D (21139) cellular: mux-rx-line #0 (10/11): CALL READY D (21139) cellular: mux-rx-line #0 (7/0): PB DONE OVMS> D (26619) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26639) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (26679) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (26679) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0 D (26679) cellular: Signal Quality is: 23 (-67 dBm) D (26679) cellular: mux-rx-line #0 (2/0): OK OVMS> D (28059) cellular: mux-rx-line #0 (26/0): +CTZV: 8,25/03/30,11:31:00 OVMS> D (28619) cellular: tx-cmd: AT+CGMR;+ICCID D (28629) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (28629) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (28629) cellular: mux-rx-line #0 (2/0): OK OVMS> D (32339) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99 OVMS> D (32619) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (32629) cellular: mux-rx-line #0 (2/0): OK OVMS> D (33619) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (33629) cellular: mux-rx-line #0 (2/0): OK OVMS> D (34619) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (34629) cellular: mux-rx-line #0 (2/0): OK OVMS> D (35619) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (35629) cellular: mux-rx-line #0 (2/0): OK OVMS> D (36619) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (36629) cellular: mux-rx-line #0 (2/0): OK I (36629) cellular: State: Enter MuxStart state V (36629) cellular: Starting MUX D (36629) events: Signal(system.modem.muxstart) I (36629) gsm-mux: Start MUX I (36629) gsm-mux: Channel #0 is open I (36639) gsm-mux: Channel #1 is open I (36639) gsm-mux: Channel #2 is open I (36649) gsm-mux: Channel #3 is open I (36659) gsm-mux: Channel #4 is open OVMS> D (37619) cellular: State transition MuxStart => NetWait I (37619) cellular: State: Enter NetWait state V (37619) cellular: Starting NMEA I (37619) gsm-nmea: Startup D (37619) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 D (37619) events: Signal(system.modem.netwait) D (37629) events: Signal(system.modem.gpsstart) D (37709) cellular: mux-rx-line #4 (2/0): OK OVMS> I (45629) ovms-server-v2: Send MP-0 h1,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45629) ovms-server-v2: Send MP-0 h2,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45629) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45629) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45629) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45779) ovms-server-v2: Incoming Msg: MP-0 h1 I (45779) ovms-server-v2: Incoming Msg: MP-0 h2 I (45779) ovms-server-v2: Incoming Msg: MP-0 h3 I (45789) ovms-server-v2: Incoming Msg: MP-0 h4 I (45789) ovms-server-v2: Incoming Msg: MP-0 h5 OVMS> I (46619) ovms-server-v2: Send MP-0 h6,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46619) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46619) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46619) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46629) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46829) ovms-server-v2: Incoming Msg: MP-0 h6 I (46829) ovms-server-v2: Incoming Msg: MP-0 h7 I (46829) ovms-server-v2: Incoming Msg: MP-0 h8 I (46829) ovms-server-v2: Incoming Msg: MP-0 h9 I (46839) ovms-server-v2: Incoming Msg: MP-0 h10 OVMS> D (47619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ I (47619) ovms-server-v2: Send MP-0 h11,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47619) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47619) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47619) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47629) ovms-server-v2: Send MP-0 h15,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 D (47649) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (47649) cellular: Network Registration status: RegisteredRoaming D (47649) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:31:19+08" D (47649) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (47649) cellular: mux-rx-line #3 (2/0): OK I (47869) ovms-server-v2: Incoming Msg: MP-0 h11 I (47869) ovms-server-v2: Incoming Msg: MP-0 h12 I (47869) ovms-server-v2: Incoming Msg: MP-0 h13 I (47869) ovms-server-v2: Incoming Msg: MP-0 h14 I (47879) ovms-server-v2: Incoming Msg: MP-0 h15 OVMS> D (48619) cellular: mux-tx #3: AT+CPSI? D (48619) cellular: State transition NetWait => NetStart I (48619) cellular: State: Enter NetStart state D (48619) events: Signal(system.modem.netstart) D (48629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39 I (48629) cellular: Network Mode: GSM,Online D (48629) cellular: mux-rx-line #3 (2/0): OK OVMS> D (49619) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (49649) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (49649) cellular: PPP Connection is ready to start OVMS> D (50619) cellular: State transition NetStart => NetMode I (50619) cellular: State: Enter NetMode state V (50619) cellular: Launching PPP V (50619) cellular: Starting PPP I (50619) gsm-ppp: Initialising... D (50629) events: Signal(system.modem.netmode) OVMS> I (51469) gsm-ppp: StatusCallBack: None I (51469) gsm-ppp: status_cb: Connected I (51469) gsm-ppp: our_ipaddr = 10.170.195.13 I (51469) gsm-ppp: his_ipaddr = 10.64.64.64 I (51469) gsm-ppp: netmask = 255.255.255.255 I (51469) gsm-ppp: DNS#0 = 8.8.8.8 I (51469) gsm-ppp: DNS#1 = 8.8.4.4 I (51469) gsm-ppp: our6_ipaddr = :: D (51469) events: Signal(network.interface.up) D (51479) events: Signal(system.modem.gotip) D (51479) netmanager: Saved DNS#0 8.8.8.8 D (51479) netmanager: Saved DNS#1 8.8.4.4 D (51479) netmanager: Saved DNS#2 0.0.0.0 I (51479) netmanager: Set DNS#1 0.0.0.0 I (51479) netmanager: Set DNS#2 0.0.0.0 I (51479) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (51479) events: Signal(network.modem.up) D (51479) events: Signal(network.interface.change) OVMS> D (51889) events: Signal(gps.lock.acquired) D (51889) events: Signal(system.modem.gotgps) OVMS> I (52619) ovms-server-v2: Send MP-0 h16,0,RT-GPS-Log,0,86400,51.403725,7.440220,158,0,0,1,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (52679) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (53339) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0 OVMS> D (56339) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99 OVMS> D (62679) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms OVMS> D (80619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (80639) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (80639) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:31:52+08" D (80639) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (80639) cellular: mux-rx-line #3 (2/0): OK OVMS> D (81619) cellular: mux-tx #3: AT+CPSI? D (81629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (81629) cellular: mux-rx-line #3 (2/0): OK OVMS> D (82619) cellular: mux-tx #3: AT+COPS? D (82629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (82629) cellular: Network Provider is: vodafone.de Hologram D (82629) cellular: mux-rx-line #3 (2/0): OK OVMS> I (84619) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.403793,7.440117,159,0,0,1,0,-56,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (84829) ovms-server-v2: Incoming Msg: MP-0 h17 OVMS> D (110619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (110629) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (110629) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:32:22+08" D (110629) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (110639) cellular: mux-rx-line #3 (2/0): OK OVMS> D (111619) cellular: mux-tx #3: AT+CPSI? D (111629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39 D (111629) cellular: mux-rx-line #3 (2/0): OK OVMS> D (112619) cellular: mux-tx #3: AT+COPS? D (112629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (112629) cellular: mux-rx-line #3 (2/0): OK OVMS> I (122629) housekeeping: System considered stable (RAM: 8b=45708-48964 32b=12128 SPI=3203128-3218504) D (122679) ovms-duktape: Duktape: Compacting DukTape memory done in 30 ms OVMS> D (140619) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (140629) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (140639) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:32:52+08" D (140639) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (140639) cellular: mux-rx-line #3 (2/0): OK OVMS> D (141619) cellular: mux-tx #3: AT+CPSI? D (141629) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-68,0,39-39 D (141629) cellular: mux-rx-line #3 (2/0): OK OVMS> D (142619) cellular: mux-tx #3: AT+COPS? D (142629) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (142629) cellular: mux-rx-line #3 (2/0): OK OVMS> I (144619) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.403797,7.440110,158,0,0,1,0,-57,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 OVMS> I (144829) ovms-server-v2: Incoming Msg: MP-0 h18 OVMS> enable Password: Secure mode OVMS# module reset Resetting system... OVMS# I (168689) boot: Shutting down for Restart... D (168689) events: Signal(system.shuttingdown) W (168689) boot: Shutdown: vehicle pending, 1 total I (168699) v-twizy: Shutdown Renault Twizy vehicle module I (168699) v-twizy: obd subsystem shutdown I (168699) v-twizy: sevcon subsystem shutdown I (168699) v-twizy: charge subsystem shutdown I (168699) v-twizy: pwrmon subsystem shutdown I (168709) v-twizy: battmon subsystem shutdown W (168709) boot: Shutdown: vehicle-poll pending, 2 total I (168719) wifi:state: run -> init (0) I (168719) wifi:pm stop, total sleep time: 152092279 us / 162499490 us I (168719) wifi:new:<11,0>, old:<11,0>, ap:<11,0>, sta:<11,0>, prof:1 I (168729) wifi:flush txq I (168729) wifi:stop sw txq E (168729) mongoose: mg_ssl_if_mbed_err 0x3f864380 SSL error: -1 I (168729) wifi:lmac stop hw txq I (168739) wifi:Deinit lldesc rx mblock:16 E (168739) event: system_event_ap_stop_handle_default 223 esp_wifi_internal_reg_rxcb ret=0x3001 E (168739) ovms-server-v2: Status: Connection lost, reconnecting W (168749) boot: Shutdown: cellular pending, 3 total I (168749) cellular: State: Enter PoweringOff state W (168749) boot: Shutdown: ovms-duktape pending, 4 total V (168749) cellular: Stopping PPP W (168749) boot: Shutdown: webserver pending, 5 total I (168749) gsm-ppp: Shutting down (hard)... I (168749) gsm-ppp: StatusCallBack: User Interrupt I (168759) gsm-ppp: PPP is shutdown V (168759) cellular: Stopping NMEA D (168759) cellular: mux-tx #4: AT+CGPSNMEA=0 D (168759) events: Signal(power.can1.off) D (168759) events: Signal(egpio.output.2.high) D (168769) events: Signal(system.wifi.down) I (168769) netmanager: WIFI client stop I (168769) netmanager: Interface priority is pp3 (0.0.0.0/255.255.255.255 gateway 0.0.0.0) I (168769) netmanager: Set DNS#2 0.0.0.0 I (168769) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority D (168769) netmanager: send cmd 3 from 0x0 D (168769) netmanager: done cmd 3 from 0x0 D (168769) events: Signal(system.event) D (168769) events: Signal(system.wifi.sta.disconnected) I (168769) netmanager: Set DNS#2 0.0.0.0 D (168769) netmanager: send cmd 3 from 0x0 D (168769) netmanager: done cmd 3 from 0x0 D (168779) events: Signal(system.event) D (168779) events: Signal(network.wifi.sta.bad) D (168779) events: Signal(system.wifi.sta.stop) I (168779) netmanager: Set DNS#2 0.0.0.0 D (168779) netmanager: send cmd 3 from 0x0 D (168779) netmanager: done cmd 3 from 0x0 D (168789) events: Signal(system.event) D (168789) events: Signal(system.wifi.ap.stop) I (168789) netmanager: Set DNS#2 0.0.0.0 I (168789) netmanager: WIFI access point is down W (168789) ovms-duktape: EventScript: event 'system.wifi.ap.stop' delayed, queued at position 11/40 D (168789) events: Signal(server.v2.waitreconnect) W (168789) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 12/40 D (168789) events: Signal(system.modem.down) I (168799) netmanager: MODEM down (with WIFI client down): network connectivity has been lost W (168799) ovms-duktape: EventScript: event 'system.modem.down' delayed, queued at position 13/40 D (168799) events: Signal(network.wifi.down) W (168799) ovms-duktape: EventScript: event 'network.wifi.down' delayed, queued at position 14/40 D (168799) events: Signal(network.reconfigured) I (168799) ovms-server-v2: Status: Network was reconfigured: disconnect and reconnect W (168799) ovms-duktape: EventScript: event 'network.reconfigured' delayed, queued at position 15/40 D (168799) events: Signal(network.interface.change) W (168809) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 16/40 D (168809) events: Signal(network.interface.change) W (168809) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 17/40 D (168809) events: Signal(network.modem.down) W (168809) ovms-duktape: EventScript: event 'network.modem.down' delayed, queued at position 18/40 D (168809) events: Signal(network.down) W (168809) ovms-duktape: EventScript: event 'network.down' delayed, queued at position 19/40 D (168819) events: Signal(network.interface.change) W (168819) ovms-duktape: EventScript: event 'network.interface.change' delayed, queued at position 20/40 D (168819) events: Signal(server.v2.connectwait) W (168819) ovms-duktape: EventScript: event 'server.v2.connectwait' delayed, queued at position 21/40 D (168829) ovms-duktape: Duktape: module unload all I (168829) ovms-duktape: Duktape: Clearing existing context D (168859) cellular: mux-tx #4: AT+CGPS=0 I (168859) gsm-nmea: Shutdown (direct) D (168859) events: Signal(gps.lock.lost) I (168859) cellular-modem-auto: Power Off - timing: 2500 ms W (168859) ovms-duktape: EventScript: event 'gps.lock.lost' delayed, queued at position 22/40 I (168859) Simcom: Power Off - 2500 ms D (168859) events: Signal(system.modem.lostgps) W (168859) ovms-duktape: EventScript: event 'system.modem.lostgps' delayed, queued at position 23/40 D (168869) events: Signal(system.modem.gpsstop) W (168869) ovms-duktape: EventScript: event 'system.modem.gpsstop' delayed, queued at position 24/40 D (168869) events: Signal(egpio.output.3.low) W (168869) ovms-duktape: EventScript: event 'egpio.output.3.low' delayed, queued at position 25/40 D (168869) events: Signal(egpio.output.0.high) W (168869) ovms-duktape: EventScript: event 'egpio.output.0.high' delayed, queued at position 26/40 D (168989) netmanager: MongooseTask: got cmd 3 from 0x0 D (168989) netmanager: MongooseTask: done cmd 3 from 0x0 D (168989) netmanager: MongooseTask: got cmd 3 from 0x0 D (168989) netmanager: MongooseTask: done cmd 3 from 0x0 D (168989) netmanager: MongooseTask: got cmd 3 from 0x0 D (168989) netmanager: MongooseTask: done cmd 3 from 0x0 D (168989) netmanager: MongooseTask stopping D (168989) events: Signal(network.mgr.stop) I (168989) ssh: Stopping SSH Server OVMS# I (169619) ovms-server-v2: Status: Server is ready to start I (169619) boot: Shutdown: vehicle ready, 4 pending I (169619) boot: Shutdown: vehicle-poll ready, 3 pending I (169619) boot: Shutdown: ovms-duktape ready, 2 pending D (169619) events: Signal(server.v2.waitnetwork) OVMS# D (171359) events: Signal(egpio.output.0.low) OVMS# I (171619) boot: Shutdown: webserver ready, 1 pending OVMS# I (173619) boot: Restart in 65 seconds (1 pending)... OVMS# D (176359) events: Signal(system.modem.stop) OVMS# I (178619) boot: Restart in 60 seconds (1 pending)... OVMS# I (183619) boot: Restart in 55 seconds (1 pending)... OVMS# I (188619) boot: Restart in 50 seconds (1 pending)... D (188619) cellular: State timeout PoweringOff => CheckPowerOff I (188619) cellular: State: Enter CheckPowerOff state OVMS# D (191619) cellular: tx-cmd: AT OVMS# I (193619) boot: Restart in 45 seconds (1 pending)... OVMS# D (194619) cellular: tx-cmd: AT OVMS# D (197619) cellular: tx-cmd: AT OVMS# I (198619) boot: Restart in 40 seconds (1 pending)... OVMS# D (200619) cellular: tx-cmd: AT OVMS# D (203619) cellular: tx-cmd: AT I (203619) boot: Restart in 35 seconds (1 pending)... D (203619) cellular: State timeout CheckPowerOff => PoweredOff I (203619) cellular: State: Enter PoweredOff state V (203619) cellular: Stopping MUX I (203619) gsm-mux: Stop MUX D (203619) events: Signal(system.modem.poweredoff) D (203619) cellular: UART shutdown I (203619) boot: Shutdown: cellular ready, 0 pending OVMS# I (204619) boot: Restart now OVMS# D (205619) events: Signal(system.shutdown)ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5328 ho 0 tail 12 room 4 load:0x40078000,len:11332 load:0x40080400,len:6204 entry 0x400806cc I (1192) psram: This chip is ESP32-D0WD I (1192) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1233) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2127) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2133) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (215) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (215) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Boot #1 reasons for CPU0=12 and CPU1=12 I (242) boot: Soft reset by user I (247) events: Initialising EVENTS (1200) I (252) config: Initialising CONFIG (1400) I (257) time: Initialising TIME (1500) I (261) script: Initialising SCRIPTS (1600) I (265) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (271) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (277) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (283) metrics: Initialising METRICS (1810) I (288) metrics: Expanding DUKTAPE javascript engine I (293) metrics: Persistent metrics serial 2 using 820 bytes, 68/100 slots used I (303) metrics: persist v.b.cac = 92.9772Ah I (307) metrics: persist v.b.range.est = 50km I (311) metrics: persist v.b.12v.voltage = 12.59V I (317) metrics: persist v.b.12v.voltage.ref = 12.6V I (323) metrics: persist v.c.climit = 15A I (328) metrics: persist v.c.limit.range = 56km I (332) metrics: persist v.c.limit.soc = 21% I (341) metrics: persist v.e.drivemode = 33882626 I (343) metrics: persist v.e.valet = yes I (347) metrics: persist v.e.parktime = 165Sec I (354) metrics: persist v.p.latitude = 51.4038 I (358) metrics: persist v.p.longitude = 7.44011 I (363) metrics: persist v.p.altitude = 158.5m I (370) notify: Initialising NOTIFICATIONS (1820) I (374) notify: Registered notification type info I (378) notify: Registered notification type error I (384) notify: Registered notification type alert I (389) notify: Registered notification type data I (395) notify: Registered notification type stream I (400) notify: Expanding DUKTAPE javascript engine I (406) location: Initialising LOCATIONS (1900) I (414) location: Expanding DUKTAPE javascript engine I (417) vehicle: Initialising VEHICLE Factory (2000) I (428) tls: Initialising TLS (3000) I (429) pcp: Initialising POWER (4000) I (431) max7317: Initialising MAX7317 EGPIO (4200) I (437) sdcard: Initialising SD CARD (4400) I (442) ota: Initialising OTA (4400) I (448) canformat: Initialising CAN Format Factory (4500) I (452) canformat-cs11: Registering CAN Format: CS11 (4505) I (458) canformat-crtd: Registering CAN Format: CRTD (4505) I (464) canformat-gvret: Registering CAN Format: GVRET (4505) I (471) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (477) canformat-panda: Registering CAN Format: PANDA (4505) I (484) canformat-pcap: Registering CAN Format: PCAP (4505) I (490) canformat-raw: Registering CAN Format: RAW (4505) I (496) can: Initialising CAN (4510) I (508) dbc-app: Initialising DBC (4520) I (511) canlog: Initialising CAN logging (4550) I (512) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (518) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (528) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (535) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (541) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (550) canlog-vfs: Initialising CAN logging to VFS (4560) I (554) canplay: Initialising CAN play framework (4570) I (559) canplay-vfs: Initialising CAN playing from VFS (4580) I (566) cellular: Initialising CELLULAR (4600) I (572) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (577) cellular-modem-auto: Registering auto-detect modem driver (4650) I (585) SIM5360: Registering SIM5360 modem driver (4650) I (591) SIM7000: Registering SIM7000 modem driver (4650) I (597) SIM7600: Registering SIM7600 modem driver (4650) I (603) SIM7670: Registering Simcom A7670E modem driver (4660) I (609) tpms: Initialising TPMS (4700) I (615) test: Initialising TEST (5000) I (620) module: Initialising MODULE (5100) I (625) vfs: Initialising VFS (5200) I (629) ovms-server: Initialising OVMS Server (6000) I (633) ovms-server-v2: Initialising OVMS V2 Server (6100) I (640) ovms-server-v3: Initialising OVMS V3 Server (6200) I (646) vehicle-poll: Initialising Poller (7000) I (654) obd2ecu: Initialising OBD2ECU (7000) I (657) canopen: Initialising CANopen (7000) I (665) pluginstore: Initialising PLUGINS (7100) I (668) esp32wifi: Initialising ESP32WIFI (8000) I (672) ovms-mdns: Initialising MDNS (8100) I (676) webserver: Initialising WEBSERVER (8200) I (684) ssh: Initialising SSH (8300) I (686) powermgmt: Initialising POWERMGMT (8500) I (692) re: Initialising RE Tools (8800) I (698) pushover: Initialising Pushover client (8800) I (703) netmanager: Initialising NETMANAGER (8999) I (710) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (713) v-zeva: Registering Vehicle: ZEVA (9000) I (719) v-vweup: Registering Vehicle: VW e-Up (9000) I (724) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (732) v-track: Registering Vehicle: TRACK (9000) I (737) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (744) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (750) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (757) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (764) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (770) v-smarteq: Registering Vehicle: SMART EQ (9000) I (776) v-smarted: Registering Vehicle: SMART ED (9000) I (782) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (790) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (796) v-twizy: Registering Vehicle: Renault Twizy (9000) I (802) v-obdii: Registering Vehicle: OBDII (9000) I (808) v-none: Registering Vehicle: NONE (9000) I (813) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (819) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (829) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (835) v-mgev4: Registering Vehicle: MG4 (9000) I (840) v-mgev: Registering Vehicle: MG5 (9000) I (846) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (852) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (858) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (864) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (870) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (877) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (883) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (889) v-maple60s: Registering Vehicle: Maple 60S (9000) I (895) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (902) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (909) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (916) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (923) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (930) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (936) v-energica: Registering Vehicle: Energica (9000) I (942) v-demo: Registering Vehicle: DEMO (9000) I (948) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (954) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (962) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (970) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (975) v-boltev: Registering Vehicle: Bolt EV (9000) I (981) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (987) version: Initialising Versioning (9900) I (995) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (1067) ovms_main: Executing on CPU core 0 I (1077) ovms_main: Mounting CONFIG... I (1187) ovms_main: Configure logging... W (1197) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1197) ovms_main: Registering default configs... I (1197) ovms_main: Starting HOUSEKEEPING... I (1207) housekeeping: Initialising HOUSEKEEPING Framework... I (1207) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1687) events: Signal(housekeeping.init) I (1687) housekeeping: Executing on CPU core 1 I (1687) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1687) housekeeping: Starting PERIPHERALS... I (1697) peripherals: Initialising OVMS Peripherals... I (1697) peripherals: TCP/IP Adaptor I (1707) peripherals: ESP32 system I (1707) peripherals: SPI bus I (1717) peripherals: MAX7317 I/O Expander I (1717) peripherals: ESP32 CAN I (1727) peripherals: ESP32 WIFI I (1727) peripherals: ESP32 ADC I (1727) peripherals: MCP2515 CAN 1/2 I (1737) mcp2515: can2: SetPowerMode off I (1817) peripherals: MCP2515 CAN 2/2 I (1817) mcp2515: can3: SetPowerMode off I (1897) peripherals: SD CARD I (1897) peripherals: CELLULAR MODEM I (1897) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1907) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1917) cellular: Starting modem task I (1917) uart: queue free spaces: 50 I (1917) ext12v: Powering off external 12V devices I (1927) housekeeping: Auto init max7317 (free: 160572 bytes) I (1937) housekeeping: Auto init ext12v (free: 160572 bytes) I (1937) housekeeping: Auto init dbc (free: 160572 bytes) I (1947) housekeeping: Auto init wifi (free: 160572 bytes) I (1967) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0 I (1967) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1977) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1997) wifi:wifi firmware version: 30f9e79 I (2007) wifi:config NVS flash: enabled I (2007) wifi:config nano formating: disabled I (2007) wifi:Init data frame dynamic rx buffer num: 16 I (2007) wifi:Init management frame dynamic rx buffer num: 16 I (2017) wifi:Init management short buffer num: 32 I (2017) wifi:Init dynamic tx buffer num: 16 I (2017) wifi:Init static rx buffer size: 2212 I (2027) wifi:Init static rx buffer num: 16 I (2027) wifi:Init dynamic rx buffer num: 16 I (2807) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2807) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2807) wifi:Total power save buffer number: 8 I (2807) wifi:Init max length of beacon: 752/752 I (2817) wifi:Init max length of beacon: 752/752 I (2817) housekeeping: Auto init modem (free: 115148 bytes) I (2827) housekeeping: Auto init Pollers (free: 114728 bytes) I (2827) cellular: Set modem driver to 'auto' I (2837) housekeeping: Auto init vehicle (free: 114728 bytes) I (2837) cellular: State: Enter PowerOffOn state I (2847) v-twizy: Renault Twizy vehicle module I (2847) cellular-modem-auto: Power Cycle I (2857) v-twizy: battmon subsystem init I (2857) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2867) v-twizy: pwrmon subsystem init I (2877) v-twizy: charge subsystem init I (2877) canopen: Worker started on can1 I (2887) v-twizy: sevcon subsystem init I (2897) v-twizy: obd subsystem init I (2897) housekeeping: Auto init obd2ecu (free: 81464 bytes) I (2897) housekeeping: Auto init server v2 (free: 81464 bytes) I (2907) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2917) ovms-server-v2: Status: Server has been started I (2917) ovms-server-v2: OVMS Server v2 running I (2927) housekeeping: Auto init server v3 (free: 80912 bytes) I (2927) housekeeping: Auto init javascript (free: 80912 bytes) I (2937) housekeeping: Auto init done (free: 80872 bytes) I (2947) housekeeping: Starting USB console... I (2947) uart: queue free spaces: 100 D (2957) events: Signal(egpio.output.1.low) D (2967) events: Signal(system.event) D (2967) events: Signal(system.wifi.sta.start) D (2977) events: Signal(system.event) D (2977) events: Signal(system.wifi.ap.start) I (2977) netmanager: WIFI access point is up D (2987) events: Signal(power.cellular.on) D (2987) events: Signal(system.modem.stop) D (2987) events: Signal(egpio.output.0.low) D (2997) events: Signal(egpio.output.0.high) D (2997) events: Signal(power.can1.on) D (2997) events: Signal(egpio.output.2.low) D (3007) events: Signal(canopen.worker.start) D (3007) events: Signal(vehicle.type.set) D (3017) events: Signal(server.v2.waitnetwork) D (3017) events: Signal(system.start) I (3017) ovms-mdns: Starting MDNS D (3027) netmanager: MongooseTask starting I (3027) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console D (3047) events: Signal(network.interface.change) D (3057) events: Signal(network.mgr.init) I (3077) ssh: Launching SSH Server Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 OVMS> I (3197) ovms-duktape: Duktape: Initialising module system D (3217) ovms-duktape: Duktape: Pre-Registered function assert D (3217) ovms-duktape: Duktape: Pre-Registered function meminfo D (3217) ovms-duktape: Duktape: Pre-Registered function print D (3227) ovms-duktape: Duktape: Pre-Registered function write D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3227) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3227) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3237) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3247) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3257) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3267) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3277) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3277) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3277) ovms-duktape: Duktape: Pre-Registered object VFS D (3277) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3277) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3277) ovms-duktape: Duktape: Pre-Registered module JSON D (3287) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3297) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3297) ovms-duktape: Duktape: module load: int/JSON.js D (3377) ovms-duktape: Duktape: Pre-Registered module PubSub D (3387) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3387) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3387) ovms-duktape: Duktape: module load: int/PubSub.js I (3617) ovms-duktape: Duktape: Executing ovmsmain.js D (3617) ovms-duktape: Duktape: module load: ovmsmain.js D (3627) ovms-duktape: Duktape: module unload: ovmsmain.js D (3687) events: Signal(vehicle.charge.mode) OVMS> D (4687) events: Signal(vehicle.aux.12v.normal) OVMS> D (5367) events: Signal(egpio.output.0.low) D (5427) events: Signal(system.event) D (5437) events: Signal(system.wifi.scan.done) I (5557) wifi:ap channel adjust o:1,0 n:11,0 I (5557) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6247) wifi:state: init -> auth (b0) I (6257) wifi:state: auth -> assoc (0) I (6267) wifi:state: assoc -> run (10) I (6287) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85 I (6287) wifi:security type: 3, phy: bgn, rssi: -60 I (6287) wifi:pm start, type: 1 D (6297) events: Signal(system.event) D (6297) events: Signal(system.wifi.sta.connected) D (6297) netmanager: send cmd 3 from 0x0 D (6297) netmanager: done cmd 3 from 0x0 I (6317) wifi:AP's beacon interval = 102400 us, DTIM period = 1 D (6317) netmanager: MongooseTask: got cmd 3 from 0x0 D (6317) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> I (6777) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6777) events: Signal(system.event) D (6777) events: Signal(network.interface.up) D (6777) events: Signal(system.wifi.sta.gotip) I (6777) netmanager: WIFI client got IP D (6777) netmanager: Saved DNS#0 192.168.178.1 D (6777) netmanager: Saved DNS#1 0.0.0.0 D (6777) netmanager: Saved DNS#2 0.0.0.0 D (6777) netmanager: send cmd 3 from 0x0 D (6777) netmanager: done cmd 3 from 0x0 D (6817) netmanager: MongooseTask: got cmd 3 from 0x0 D (6817) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> D (8687) events: Signal(network.wifi.sta.good) I (8687) netmanager: WIFI client has good signal quality (-81.1 dBm); connect I (8687) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (8687) netmanager: Set DNS#1 0.0.0.0 I (8687) netmanager: Set DNS#2 0.0.0.0 I (8687) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (8697) events: Signal(network.wifi.up) D (8697) events: Signal(network.up) I (8697) ovms-server-v2: Status: Network is up, so attempt network connection D (8697) events: Signal(network.interface.change) D (8707) events: Signal(server.v2.connectwait) OVMS> D (10367) events: Signal(egpio.output.0.high) D (10567) events: Signal(egpio.output.0.low) D (10567) cellular: State timeout PowerOffOn => PoweringOn I (10567) cellular: State: Enter PoweringOn state I (10567) cellular-modem-auto: Power Cycle I (10567) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10567) events: Signal(system.modem.poweringon) D (10567) events: Signal(egpio.output.0.high) I (10687) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (10687) ovms-server-v2: Status: Connecting... D (10717) events: Signal(server.v2.connecting) OVMS> D (13067) events: Signal(egpio.output.0.low) OVMS> I (14257) ovms-server-v2: Connection successful I (14257) ovms-server-v2: Status: Logging in... D (14257) events: Signal(server.v2.authenticating) I (14257) ovms-server-v2: Sending server login: MP-C 0 tEGwdgWRdMbD8SwvQncceo lMrakF68LqYE1rEyfixHFg== TEST1 I (14297) ovms-server-v2: Got server response: MP-S 0 OGiiwunTBubdgRsYK5CM6n AtfoPKZ4WkKmQqYVVbWJjw== I (14297) ovms-server-v2: Server token is OGiiwunTBubdgRsYK5CM6n and digest is AtfoPKZ4WkKmQqYVVbWJjw== I (14297) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (14297) ovms-server-v2: Shared secret key is OGiiwunTBubdgRsYK5CM6ntEGwdgWRdMbD8SwvQncceo (44 bytes) I (14297) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (14297) events: Signal(server.v2.connected) I (14327) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> I (14687) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (14697) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,176,0,0,1,1,12.35,0,12.6,0,0,0,0 I (14697) ovms-server-v2: Send MP-0 L51.403797,7.440107,0,158.5,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (14697) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (14697) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (14697) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,25,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18067) events: Signal(egpio.output.0.high) D (18267) events: Signal(egpio.output.0.low) D (18267) cellular: tx-cmd: AT I (18367) cellular: State: Enter Identify state D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM D (18367) cellular: tx-cmd: AT+CGMM OVMS> D (18687) cellular: tx-cmd: AT+CGMM OVMS> D (19687) cellular: tx-cmd: AT+CGMM OVMS> D (20687) cellular: tx-cmd: AT+CGMM OVMS> D (21687) cellular: tx-cmd: AT+CGMM OVMS> D (22687) cellular: tx-cmd: AT+CGMM OVMS> D (23687) cellular: tx-cmd: AT+CGMM OVMS> D (24687) cellular: tx-cmd: AT+CGMM I (24687) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403797,7.440107,158,0,0,0,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (24697) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (24697) cellular: Remove old 'auto' modem driver I (24697) cellular: Set modem driver to 'SIM5360' I (24697) cellular: State: Enter PoweredOn state D (24697) events: Signal(system.modem.installed) D (24697) events: Signal(system.modem.poweredon) I (24857) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS> D (27057) cellular: mux-rx-line #0 (2/48): OK D (27057) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (27057) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (27057) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS> D (27677) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS> D (28267) cellular: mux-rx-line #0 (10/11): CALL READY D (28267) cellular: mux-rx-line #0 (7/0): PB DONE OVMS> D (34687) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (34707) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (34737) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (34737) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0 D (34737) cellular: Signal Quality is: 23 (-67 dBm) D (34747) cellular: mux-rx-line #0 (2/0): OK OVMS> D (36687) cellular: tx-cmd: AT+CGMR;+ICCID D (36697) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (36697) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (36697) cellular: mux-rx-line #0 (2/0): OK OVMS> D (39287) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99 OVMS> D (40687) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (40697) cellular: mux-rx-line #0 (2/0): OK OVMS> D (41687) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (41697) cellular: mux-rx-line #0 (2/0): OK OVMS> D (42687) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (42697) cellular: mux-rx-line #0 (2/0): OK OVMS> D (43687) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (43697) cellular: mux-rx-line #0 (2/0): OK OVMS> D (44687) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (44697) cellular: mux-rx-line #0 (2/0): OK I (44697) cellular: State: Enter MuxStart state V (44697) cellular: Starting MUX D (44697) events: Signal(system.modem.muxstart) I (44697) gsm-mux: Start MUX I (44697) gsm-mux: Channel #0 is open I (44707) gsm-mux: Channel #1 is open I (44717) gsm-mux: Channel #2 is open I (44717) gsm-mux: Channel #3 is open I (44727) gsm-mux: Channel #4 is open OVMS> D (45687) cellular: State transition MuxStart => NetWait I (45687) cellular: State: Enter NetWait state V (45687) cellular: Starting NMEA I (45687) gsm-nmea: Startup D (45687) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 I (45697) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45697) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45697) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45697) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45707) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 D (45707) events: Signal(system.modem.netwait) D (45707) events: Signal(system.modem.gpsstart) D (45787) cellular: mux-rx-line #4 (2/0): OK I (45887) ovms-server-v2: Incoming Msg: MP-0 h2 I (45887) ovms-server-v2: Incoming Msg: MP-0 h3 I (45887) ovms-server-v2: Incoming Msg: MP-0 h4 I (45897) ovms-server-v2: Incoming Msg: MP-0 h5 I (45897) ovms-server-v2: Incoming Msg: MP-0 h6 OVMS> I (46687) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46687) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46687) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46687) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46697) ovms-server-v2: Send MP-0 h11,0,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 OVMS> I (46937) ovms-server-v2: Incoming Msg: MP-0 h7 I (46937) ovms-server-v2: Incoming Msg: MP-0 h8 I (46937) ovms-server-v2: Incoming Msg: MP-0 h9 I (46947) ovms-server-v2: Incoming Msg: MP-0 h10 I (46947) ovms-server-v2: Incoming Msg: MP-0 h11 OVMS> I (47687) ovms-server-v2: Send MP-0 h12,-1,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47687) ovms-server-v2: Send MP-0 h13,-1,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47687) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47687) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47697) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47747) ovms-server-v2: Incoming Msg: MP-0 h12 I (47747) ovms-server-v2: Incoming Msg: MP-0 h13 I (47747) ovms-server-v2: Incoming Msg: MP-0 h14 I (47757) ovms-server-v2: Incoming Msg: MP-0 h15 I (47757) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (51147) events: Signal(gps.lock.acquired) D (51157) events: Signal(system.modem.gotgps) OVMS> I (51687) ovms-server-v2: Send MP-0 h17,0,RT-GPS-Log,0,86400,51.404251,7.439373,159,132,0,1,0,-61,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (51797) ovms-server-v2: Incoming Msg: MP-0 h17 OVMS> D (55687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (55717) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (55717) cellular: Network Registration status: RegisteredRoaming D (55717) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:34:55+08" D (55717) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (55717) cellular: mux-rx-line #3 (2/0): OK OVMS> D (56687) cellular: mux-tx #3: AT+CPSI? D (56687) cellular: State transition NetWait => NetStart I (56687) cellular: State: Enter NetStart state D (56687) events: Signal(system.modem.netstart) D (56697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-70,0,37-37 I (56697) cellular: Network Mode: GSM,Online D (56697) cellular: mux-rx-line #3 (2/0): OK OVMS> D (57687) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (57727) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (57727) cellular: PPP Connection is ready to start OVMS> D (58687) cellular: State transition NetStart => NetMode I (58687) cellular: State: Enter NetMode state V (58687) cellular: Launching PPP V (58687) cellular: Starting PPP I (58687) gsm-ppp: Initialising... D (58697) events: Signal(system.modem.netmode) OVMS> I (59737) gsm-ppp: StatusCallBack: None I (59737) gsm-ppp: status_cb: Connected I (59737) gsm-ppp: our_ipaddr = 10.170.195.13 I (59737) gsm-ppp: his_ipaddr = 10.64.64.64 I (59737) gsm-ppp: netmask = 255.255.255.255 I (59737) gsm-ppp: DNS#0 = 8.8.8.8 I (59737) gsm-ppp: DNS#1 = 8.8.4.4 I (59737) gsm-ppp: our6_ipaddr = :: D (59737) events: Signal(network.interface.up) D (59737) events: Signal(system.modem.gotip) D (59737) netmanager: Saved DNS#0 8.8.8.8 D (59737) netmanager: Saved DNS#1 8.8.4.4 D (59737) netmanager: Saved DNS#2 0.0.0.0 I (59747) netmanager: Set DNS#1 0.0.0.0 I (59747) netmanager: Set DNS#2 0.0.0.0 I (59747) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (59747) events: Signal(network.modem.up) D (59747) events: Signal(network.interface.change) OVMS> D (60287) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0 OVMS> D (62767) ovms-duktape: Duktape: Compacting DukTape memory done in 70 ms OVMS> D (66287) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99 OVMS> I (84687) ovms-server-v2: Send MP-0 h18,0,RT-GPS-Log,0,86400,51.404083,7.439659,152,132,0,1,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (84787) ovms-server-v2: Incoming Msg: MP-0 h18 OVMS> D (88687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (88707) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (88707) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:35:28+08" D (88707) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (88707) cellular: mux-rx-line #3 (2/0): OK OVMS> D (89687) cellular: mux-tx #3: AT+CPSI? D (89697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (89697) cellular: mux-rx-line #3 (2/0): OK OVMS> D (90687) cellular: mux-tx #3: AT+COPS? D (90697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (90697) cellular: Network Provider is: vodafone.de Hologram D (90697) cellular: mux-rx-line #3 (2/0): OK OVMS> D (118687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (118697) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (118697) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:35:58+08" D (118697) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (118697) cellular: mux-rx-line #3 (2/0): OK OVMS> D (119687) cellular: mux-tx #3: AT+CPSI? D (119697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-70,0,37-37 D (119697) cellular: mux-rx-line #3 (2/0): OK OVMS> D (120687) cellular: mux-tx #3: AT+COPS? D (120697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (120697) cellular: mux-rx-line #3 (2/0): OK OVMS> I (122697) housekeeping: System considered stable (RAM: 8b=47812-48588 32b=12128 SPI=3202892-3218508) D (122767) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms OVMS> enable Password: Secure mode OVMS# module fault I (144687) ovms-server-v2: Send MP-0 h19,0,RT-GPS-Log,0,86400,51.404083,7.439662,152,132,0,1,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (144787) ovms-server-v2: Incoming Msg: MP-0 h19 OVMS# module fault powD (148687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ D (148697) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 D (148697) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:36:28+08" D (148697) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (148707) cellular: mux-rx-line #3 (2/0): OK OVMS# power celD (149687) cellular: mux-tx #3: AT+CPSI? D (149697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (149697) cellular: mux-rx-line #3 (2/0): OK OVMS# power cellular oD (150687) cellular: mux-tx #3: AT+COPS? D (150697) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (150697) cellular: mux-rx-line #3 (2/0): OK OVMS# power cellular off Power mode of cellular is now off OVMS# D (151287) events: Signal(power.cellular.off) I (151287) cellular: State: Enter PoweringOff state V (151297) cellular: Stopping PPP I (151297) gsm-ppp: Shutting down (hard)... I (151297) gsm-ppp: StatusCallBack: User Interrupt I (151297) gsm-ppp: PPP is shutdown D (151297) events: Signal(system.modem.down) V (151297) cellular: Stopping NMEA D (151297) cellular: mux-tx #4: AT+CGPSNMEA=0 I (151297) netmanager: Set DNS#1 0.0.0.0 I (151297) netmanager: Set DNS#2 0.0.0.0 I (151297) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority D (151297) netmanager: send cmd 3 from 0x0 D (151297) netmanager: done cmd 3 from 0x0 D (151297) events: Signal(network.modem.down) D (151307) events: Signal(network.interface.change) D (151397) cellular: mux-tx #4: AT+CGPS=0 I (151397) gsm-nmea: Shutdown (direct) D (151397) events: Signal(gps.lock.lost) I (151397) cellular-modem-auto: Power Off - timing: 2500 ms I (151397) Simcom: Power Off - 2500 ms D (151397) events: Signal(system.modem.lostgps) D (151397) events: Signal(system.modem.gpsstop) D (151407) events: Signal(egpio.output.3.low) D (151407) events: Signal(egpio.output.0.high) D (151537) netmanager: MongooseTask: got cmd 3 from 0x0 D (151537) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1 D (151537) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS# D (153897) events: Signal(egpio.output.0.low) OVMS# D (158897) events: Signal(system.modem.stop) I (158897) netmanager: Set DNS#1 0.0.0.0 I (158897) netmanager: Set DNS#2 0.0.0.0 D (158897) netmanager: send cmd 3 from 0x0 D (158897) netmanager: done cmd 3 from 0x0 D (159047) netmanager: MongooseTask: got cmd 3 from 0x0 D (159047) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1 D (159047) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS# D (170687) cellular: State timeout PoweringOff => CheckPowerOff I (170687) cellular: State: Enter CheckPowerOff state OVMS# D (173687) cellular: tx-cmd: AT OVMS# D (176687) cellular: tx-cmd: AT OVMS# D (179687) cellular: tx-cmd: AT OVMS# D (182687) cellular: tx-cmd: AT D (182757) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms OVMS# D (185687) cellular: tx-cmd: AT D (185687) cellular: State timeout CheckPowerOff => PoweredOff I (185687) cellular: State: Enter PoweredOff state V (185687) cellular: Stopping MUX I (185687) gsm-mux: Stop MUX D (185687) events: Signal(system.modem.poweredoff) OVMS# power cellular off n Power mode of cellular is now on OVMS# D (196647) events: Signal(power.cellular.on) I (196657) cellular: Set modem driver to 'auto' I (196657) cellular: State: Enter PowerOffOn state V (196657) cellular: Stopping PPP I (196657) gsm-ppp: Shutting down (hard)... I (196657) gsm-ppp: StatusCallBack: User Interrupt I (196657) gsm-ppp: PPP is shutdown D (196657) events: Signal(system.modem.down) I (196657) cellular-modem-auto: Power Cycle I (196657) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (196657) netmanager: Set DNS#1 0.0.0.0 I (196657) netmanager: Set DNS#2 0.0.0.0 D (196657) netmanager: send cmd 3 from 0x0 D (196657) netmanager: done cmd 3 from 0x0 D (196667) events: Signal(system.modem.stop) I (196667) netmanager: Set DNS#1 0.0.0.0 I (196667) netmanager: Set DNS#2 0.0.0.0 D (196667) netmanager: send cmd 3 from 0x0 D (196667) netmanager: done cmd 3 from 0x0 D (196667) events: Signal(egpio.output.0.high) D (196757) netmanager: MongooseTask: got cmd 3 from 0x0 D (196757) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1 D (196757) netmanager: MongooseTask: done cmd 3 from 0x0 D (196767) netmanager: MongooseTask: got cmd 3 from 0x0 D (196777) netmanager: CleanupConnections: conn 3f8e4ef4 -> iface st1 D (196777) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS# D (199157) events: Signal(egpio.output.0.low) OVMS# D (204157) events: Signal(egpio.output.0.high) D (204357) cellular: State timeout PowerOffOn => PoweringOn D (204357) events: Signal(egpio.output.0.low) I (204357) cellular: State: Enter PoweringOn state I (204357) cellular-modem-auto: Power Cycle I (204357) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (204357) events: Signal(system.modem.poweringon) D (204357) events: Signal(egpio.output.0.high) OVMS# I (204687) ovms-server-v2: Send MP-0 h20,0,RT-GPS-Log,0,86400,51.404083,7.439664,152,132,0,0,0,-62,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (204807) ovms-server-v2: Incoming Msg: MP-0 h20 OVMS# D (206857) events: Signal(egpio.output.0.low) OVMS# D (211857) events: Signal(egpio.output.0.high) D (212057) cellular: tx-cmd: AT D (212057) events: Signal(egpio.output.0.low) I (212157) cellular: State: Enter Identify state D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM D (212157) cellular: tx-cmd: AT+CGMM OVMS# D (212687) cellular: tx-cmd: AT+CGMM OVMS# D (213687) cellular: tx-cmd: AT+CGMM OVMS# D (214687) cellular: tx-cmd: AT+CGMM OVMS# D (215687) cellular: tx-cmd: AT+CGMM OVMS# D (216687) cellular: tx-cmd: AT+CGMM OVMS# D (217687) cellular: tx-cmd: AT+CGMM OVMS# D (218687) cellular: tx-cmd: AT+CGMM I (218697) cellular: Identified cellular modem: SIM5360/SIMCOM SIM5360 (include US and EU variants) D (218697) cellular: Remove old 'auto' modem driver I (218697) cellular: Set modem driver to 'SIM5360' I (218697) cellular: State: Enter PoweredOn state D (218697) events: Signal(system.modem.installed) D (218697) events: Signal(system.modem.poweredon) OVMS# D (221037) cellular: mux-rx-line #0 (2/48): OK D (221037) cellular: mux-rx-line #0 (12/32): +CPIN: READY D (221037) cellular: mux-rx-line #0 (12/16): OPL UPDATING D (221037) cellular: mux-rx-line #0 (12/0): PNN UPDATING OVMS# D (221677) cellular: mux-rx-line #0 (8/0): SMS DONE OVMS# D (222227) cellular: mux-rx-line #0 (10/11): CALL READY D (222227) cellular: mux-rx-line #0 (7/0): PB DONE OVMS# D (228687) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (228707) cellular: mux-rx-line #0 (106/0): AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (228737) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (228737) cellular: mux-rx-line #0 (10/6): +CSQ: 23,0 D (228737) cellular: Signal Quality is: 23 (-67 dBm) D (228737) cellular: mux-rx-line #0 (2/0): OK OVMS# D (230687) cellular: tx-cmd: AT+CGMR;+ICCID D (230697) cellular: mux-rx-line #0 (23/37): +CGMR: 35316B11SIM5360E D (230697) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (230697) cellular: mux-rx-line #0 (2/0): OK OVMS# D (233237) cellular: mux-rx-line #0 (11/0): +CSQ: 23,99 OVMS# D (234687) cellular: tx-cmd: AT+CMUXSRVPORT=3,1 D (234697) cellular: mux-rx-line #0 (2/0): OK OVMS# D (235687) cellular: tx-cmd: AT+CMUXSRVPORT=2,1 D (235697) cellular: mux-rx-line #0 (2/0): OK OVMS# D (236687) cellular: tx-cmd: AT+CMUXSRVPORT=1,1 D (236697) cellular: mux-rx-line #0 (2/0): OK OVMS# D (237687) cellular: tx-cmd: AT+CMUXSRVPORT=0,5 D (237707) cellular: mux-rx-line #0 (2/0): OK OVMS# D (238687) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (238697) cellular: mux-rx-line #0 (2/0): OK I (238697) cellular: State: Enter MuxStart state V (238697) cellular: Starting MUX I (238697) gsm-mux: Start MUX D (238697) events: Signal(system.modem.muxstart) I (238697) gsm-mux: Channel #0 is open I (238707) gsm-mux: Channel #1 is open I (238707) gsm-mux: Channel #2 is open I (238717) gsm-mux: Channel #3 is open I (238727) gsm-mux: Channel #4 is open OVMS# D (239687) cellular: State transition MuxStart => NetWait I (239687) cellular: State: Enter NetWait state V (239687) cellular: Starting NMEA I (239687) gsm-nmea: Startup D (239687) cellular: mux-tx #4: AT+CGPSNMEA=66;+CGPS=1,1 D (239687) events: Signal(system.modem.netwait) D (239697) events: Signal(system.modem.gpsstart) D (239777) cellular: mux-rx-line #4 (2/0): OK OVMS# D (242757) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms OVMS# D (248937) events: Signal(gps.lock.acquired) D (248947) events: Signal(system.modem.gotgps) OVMS# D (249687) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ I (249687) ovms-server-v2: Send MP-0 h21,0,RT-GPS-Log,0,86400,51.403915,7.439944,160,132,0,1,0,-63,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 D (249717) cellular: mux-rx-line #3 (10/54): +CREG: 1,5 I (249717) cellular: Network Registration status: RegisteredRoaming D (249717) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/30,13:38:08+08" D (249727) cellular: mux-rx-line #3 (11/6): +CSQ: 23,99 D (249727) cellular: mux-rx-line #3 (2/0): OK I (249787) ovms-server-v2: Incoming Msg: MP-0 h21 OVMS# D (250687) cellular: mux-tx #3: AT+CPSI? D (250687) cellular: State transition NetWait => NetStart I (250687) cellular: State: Enter NetStart state D (250687) events: Signal(system.modem.netstart) D (250697) cellular: mux-rx-line #3 (61/0): +CPSI: GSM,Online,262-02,0x011a,17603,46 EGSM 900,-69,0,38-38 D (250697) cellular: mux-rx-line #3 (2/0): OK OVMS# D (251687) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (251717) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (251717) cellular: PPP Connection is ready to start OVMS# D (252687) cellular: State transition NetStart => NetMode I (252687) cellular: State: Enter NetMode state V (252687) cellular: Starting PPP I (252687) gsm-ppp: Initialising... D (252697) events: Signal(system.modem.netmode) OVMS# I (253487) gsm-ppp: StatusCallBack: None I (253487) gsm-ppp: status_cb: Connected I (253487) gsm-ppp: our_ipaddr = 10.170.195.13 I (253487) gsm-ppp: his_ipaddr = 10.64.64.64 I (253487) gsm-ppp: netmask = 255.255.255.255 I (253487) gsm-ppp: DNS#0 = 8.8.8.8 I (253487) gsm-ppp: DNS#1 = 8.8.4.4 I (253487) gsm-ppp: our6_ipaddr = :: D (253487) events: Signal(network.interface.up) D (253497) events: Signal(system.modem.gotip) D (253497) netmanager: Saved DNS#0 8.8.8.8 D (253497) netmanager: Saved DNS#1 8.8.4.4 D (253497) netmanager: Saved DNS#2 0.0.0.0 I (253497) netmanager: Set DNS#1 0.0.0.0 I (253497) netmanager: Set DNS#2 0.0.0.0 I (253497) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority D (253497) events: Signal(network.modem.up) D (253497) events: Signal(network.interface.change) OVMS# D (254247) cellular: mux-rx-line #3 (10/0): +CSQ: 23,0 OVMS# D (257247) cellular: mux-rx-line #3 (11/0): +CSQ: 23,99 OVMS# I (264687) ovms-server-v2: Send MP-0 h22,0,RT-GPS-Log,0,86400,51.403980,7.439810,159,132,0,1,0,-63,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (264817) ovms-server-v2: Incoming Msg: MP-0 h22 OVMS# module fault abort() was called at PC 0x401184a3 on core 1 ELF file SHA256: 8ba7ed1fff95ef4c Backtrace: 0x4008ddae:0x3ffef190 0x4008e049:0x3ffef1b0 0x401184a3:0x3ffef1d0 0x4032e70b:0x3ffef1f0 0x40127862:0x3ffef210 0x40127909:0x3ffef270 0x40127909:0x3ffef2d0 0x401279af:0x3ffef330 0x401138b7:0x3ffef350 0x40130427:0x3ffef370 0x401305de:0x3ffef3d0 0x401138e7:0x3ffef470 0x4032f76a:0x3ffef490 0x4012d559:0x3ffef4b0 0x40122885:0x3ffef4e0 0x40122a5d:0x3ffef510 0x4012d401:0x3ffef530 0x4012d410:0x3ffef550 0x4010c3eb:0x3ffef570 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:5328 ho 0 tail 12 room 4 load:0x40078000,len:11332 load:0x40080400,len:6204 entry 0x400806cc I (1192) psram: This chip is ESP32-D0WD I (1193) spiram: Found 32MBit SPI RAM device I (1193) spiram: SPI RAM mode: flash 40m sram 40m I (1196) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1203) cpu_start: Pro cpu up. I (1207) cpu_start: Application information: I (1212) cpu_start: Project name: ovms3 I (1217) cpu_start: App version: 3.3.004-429-g629e5b8b I (1223) cpu_start: Compile time: Mar 30 2025 13:28:23 I (1229) cpu_start: ELF file SHA256: 8ba7ed1fff95ef4c... I (1235) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1242) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1233) cpu_start: App cpu up. I (2127) spiram: SPI SRAM memory test OK I (2127) heap_init: Initializing. RAM available for dynamic allocation: I (2128) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2134) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2140) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2146) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2153) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2159) cpu_start: Pro cpu start user code I (2164) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (215) ovms_main: Set default logging level for * to INFO I (215) ovms_main: WATCHDOG already initialized... I (216) ovms-duktape: Initialising DUKTAPE Registry (1000) I (222) command: Initialising COMMAND (1010) I (228) command: Expanding DUKTAPE javascript engine I (232) boot: Initialising BOOT (1100) I (237) boot: Boot #2 reasons for CPU0=12 and CPU1=12 E (242) boot: Crash #1 detected I (246) boot: Reset reason Exception/panic (4) I (252) events: Initialising EVENTS (1200) I (257) config: Initialising CONFIG (1400) I (262) time: Initialising TIME (1500) I (266) script: Initialising SCRIPTS (1600) I (271) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (276) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (282) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (288) metrics: Initialising METRICS (1810) I (293) metrics: Expanding DUKTAPE javascript engine I (299) metrics: Persistent metrics serial 3 using 820 bytes, 68/100 slots used I (308) metrics: persist v.b.cac = 92.9772Ah I (312) metrics: persist v.b.range.est = 50km I (317) metrics: persist v.b.12v.voltage = 12.34V I (322) metrics: persist v.b.12v.voltage.ref = 12.6V I (328) metrics: persist v.c.climit = 15A I (333) metrics: persist v.c.limit.range = 56km I (337) metrics: persist v.c.limit.soc = 21% I (346) metrics: persist v.e.drivemode = 33882626 I (348) metrics: persist v.e.valet = yes I (352) metrics: persist v.e.parktime = 442Sec I (359) metrics: persist v.p.latitude = 51.404 I (363) metrics: persist v.p.longitude = 7.43981 I (368) metrics: persist v.p.altitude = 158.8m I (375) notify: Initialising NOTIFICATIONS (1820) I (380) notify: Registered notification type info I (384) notify: Registered notification type error I (389) notify: Registered notification type alert I (394) notify: Registered notification type data I (400) notify: Registered notification type stream I (405) notify: Expanding DUKTAPE javascript engine I (411) location: Initialising LOCATIONS (1900) I (419) location: Expanding DUKTAPE javascript engine I (422) vehicle: Initialising VEHICLE Factory (2000) I (433) tls: Initialising TLS (3000) I (434) pcp: Initialising POWER (4000) I (436) max7317: Initialising MAX7317 EGPIO (4200) I (443) sdcard: Initialising SD CARD (4400) I (447) ota: Initialising OTA (4400) I (453) canformat: Initialising CAN Format Factory (4500) I (457) canformat-cs11: Registering CAN Format: CS11 (4505) I (463) canformat-crtd: Registering CAN Format: CRTD (4505) I (469) canformat-gvret: Registering CAN Format: GVRET (4505) I (476) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (483) canformat-panda: Registering CAN Format: PANDA (4505) I (489) canformat-pcap: Registering CAN Format: PCAP (4505) I (495) canformat-raw: Registering CAN Format: RAW (4505) I (501) can: Initialising CAN (4510) I (513) dbc-app: Initialising DBC (4520) I (516) canlog: Initialising CAN logging (4550) I (517) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (523) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (533) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (540) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (546) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (555) canlog-vfs: Initialising CAN logging to VFS (4560) I (559) canplay: Initialising CAN play framework (4570) I (564) canplay-vfs: Initialising CAN playing from VFS (4580) I (571) cellular: Initialising CELLULAR (4600) I (578) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (583) cellular-modem-auto: Registering auto-detect modem driver (4650) I (590) SIM5360: Registering SIM5360 modem driver (4650) I (596) SIM7000: Registering SIM7000 modem driver (4650) I (602) SIM7600: Registering SIM7600 modem driver (4650) I (608) SIM7670: Registering Simcom A7670E modem driver (4660) I (614) tpms: Initialising TPMS (4700) I (620) test: Initialising TEST (5000) I (625) module: Initialising MODULE (5100) I (630) vfs: Initialising VFS (5200) I (634) ovms-server: Initialising OVMS Server (6000) I (638) ovms-server-v2: Initialising OVMS V2 Server (6100) I (645) ovms-server-v3: Initialising OVMS V3 Server (6200) I (651) vehicle-poll: Initialising Poller (7000) I (659) obd2ecu: Initialising OBD2ECU (7000) I (662) canopen: Initialising CANopen (7000) I (670) pluginstore: Initialising PLUGINS (7100) I (673) esp32wifi: Initialising ESP32WIFI (8000) I (678) ovms-mdns: Initialising MDNS (8100) I (681) webserver: Initialising WEBSERVER (8200) I (689) ssh: Initialising SSH (8300) I (691) powermgmt: Initialising POWERMGMT (8500) I (697) re: Initialising RE Tools (8800) I (703) pushover: Initialising Pushover client (8800) I (708) netmanager: Initialising NETMANAGER (8999) I (715) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (718) v-zeva: Registering Vehicle: ZEVA (9000) I (724) v-vweup: Registering Vehicle: VW e-Up (9000) I (729) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (737) v-track: Registering Vehicle: TRACK (9000) I (742) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (749) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (755) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (762) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (769) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (776) v-smarteq: Registering Vehicle: SMART EQ (9000) I (781) v-smarted: Registering Vehicle: SMART ED (9000) I (787) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (795) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (801) v-twizy: Registering Vehicle: Renault Twizy (9000) I (807) v-obdii: Registering Vehicle: OBDII (9000) I (813) v-none: Registering Vehicle: NONE (9000) I (818) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (825) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (834) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (840) v-mgev4: Registering Vehicle: MG4 (9000) I (846) v-mgev: Registering Vehicle: MG5 (9000) I (851) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (857) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (863) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (869) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (875) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (882) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (888) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (894) v-maple60s: Registering Vehicle: Maple 60S (9000) I (901) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (907) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (915) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (921) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (928) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (935) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (942) v-energica: Registering Vehicle: Energica (9000) I (948) v-demo: Registering Vehicle: DEMO (9000) I (953) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (959) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (967) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (975) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (980) v-boltev: Registering Vehicle: Bolt EV (9000) I (986) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (992) version: Initialising Versioning (9900) I (1000) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (1072) ovms_main: Executing on CPU core 0 I (1082) ovms_main: Mounting CONFIG... I (1192) ovms_main: Configure logging... W (1202) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (1202) ovms_main: Registering default configs... I (1202) ovms_main: Starting HOUSEKEEPING... I (1212) housekeeping: Initialising HOUSEKEEPING Framework... I (1212) tls: Built trusted CA cache (5 entries, 8101 bytes) D (1682) events: Signal(housekeeping.init) I (1682) housekeeping: Executing on CPU core 1 I (1682) housekeeping: reset_reason: cpu0=12, cpu1=12 I (1682) housekeeping: Starting PERIPHERALS... I (1692) peripherals: Initialising OVMS Peripherals... I (1692) peripherals: TCP/IP Adaptor I (1702) peripherals: ESP32 system I (1702) peripherals: SPI bus I (1712) peripherals: MAX7317 I/O Expander I (1712) peripherals: ESP32 CAN I (1722) peripherals: ESP32 WIFI I (1722) peripherals: ESP32 ADC I (1722) peripherals: MCP2515 CAN 1/2 I (1732) mcp2515: can2: SetPowerMode off I (1812) peripherals: MCP2515 CAN 2/2 I (1812) mcp2515: can3: SetPowerMode off I (1892) peripherals: SD CARD I (1892) peripherals: CELLULAR MODEM I (1892) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (1902) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (1912) cellular: Starting modem task I (1912) uart: queue free spaces: 50 I (1912) ext12v: Powering off external 12V devices I (1922) housekeeping: Auto init max7317 (free: 160572 bytes) I (1932) housekeeping: Auto init ext12v (free: 160572 bytes) I (1932) housekeeping: Auto init dbc (free: 160572 bytes) I (1942) housekeeping: Auto init wifi (free: 160572 bytes) I (1962) wifi:wifi driver task: 3ffd9afc, prio:23, stack:3584, core=0 I (1962) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1972) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (1992) wifi:wifi firmware version: 30f9e79 I (2002) wifi:config NVS flash: enabled I (2002) wifi:config nano formating: disabled I (2002) wifi:Init data frame dynamic rx buffer num: 16 I (2002) wifi:Init management frame dynamic rx buffer num: 16 I (2012) wifi:Init management short buffer num: 32 I (2012) wifi:Init dynamic tx buffer num: 16 I (2012) wifi:Init static rx buffer size: 2212 I (2022) wifi:Init static rx buffer num: 16 I (2022) wifi:Init dynamic rx buffer num: 16 I (2802) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0 I (2802) wifi:mode : sta (30:ae:a4:43:87:ec) + softAP (30:ae:a4:43:87:ed) I (2802) wifi:Total power save buffer number: 8 I (2802) wifi:Init max length of beacon: 752/752 I (2812) wifi:Init max length of beacon: 752/752 I (2812) housekeeping: Auto init modem (free: 115408 bytes) I (2822) housekeeping: Auto init Pollers (free: 114728 bytes) I (2822) housekeeping: Auto init vehicle (free: 114728 bytes) I (2842) v-twizy: Renault Twizy vehicle module I (2842) v-twizy: battmon subsystem init I (2852) v-twizy: pwrmon subsystem init I (2852) v-twizy: charge subsystem init I (2852) canopen: Worker started on can1 I (2852) v-twizy: sevcon subsystem init I (2872) v-twizy: obd subsystem init I (2872) housekeeping: Auto init obd2ecu (free: 81496 bytes) I (2872) housekeeping: Auto init server v2 (free: 81496 bytes) I (2882) ovms-server-v2: OVMS Server V2 registered metric modifier is #2 I (2882) ovms-server-v2: Status: Server has been started I (2892) ovms-server-v2: OVMS Server v2 running I (2902) housekeeping: Auto init server v3 (free: 80944 bytes) I (2902) housekeeping: Auto init javascript (free: 80944 bytes) I (2912) cellular: Set modem driver to 'auto' I (2912) housekeeping: Auto init done (free: 80904 bytes) I (2912) cellular: State: Enter PowerOffOn state I (2922) housekeeping: Starting USB console... I (2932) cellular-modem-auto: Power Cycle I (2932) uart: queue free spaces: 100 I (2932) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (2942) events: Signal(egpio.output.1.low) D (2952) events: Signal(system.event) D (2962) events: Signal(system.wifi.sta.start) Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console D (2962) events: Signal(system.event) D (2972) events: Signal(system.wifi.ap.start) I (2972) netmanager: WIFI access point is up D (2982) events: Signal(power.cellular.on) D (2982) events: Signal(power.can1.on) D (2992) events: Signal(egpio.output.2.low) D (2992) events: Signal(canopen.worker.start) D (3002) events: Signal(vehicle.type.set) D (3002) events: Signal(server.v2.waitnetwork) D (3012) events: Signal(system.modem.stop) D (3012) events: Signal(system.start) I (3012) ovms-mdns: Starting MDNS D (3022) netmanager: MongooseTask starting Firmware: 3.3.004-429-g629e5b8b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (2912) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) OVMS> D (3042) events: Signal(egpio.output.0.low) D (3052) events: Signal(egpio.output.0.high) D (3052) events: Signal(network.interface.change) D (3052) events: Signal(network.mgr.init) I (3072) ssh: Launching SSH Server I (3202) ovms-duktape: Duktape: Initialising module system D (3222) ovms-duktape: Duktape: Pre-Registered function assert D (3222) ovms-duktape: Duktape: Pre-Registered function meminfo D (3222) ovms-duktape: Duktape: Pre-Registered function print D (3222) ovms-duktape: Duktape: Pre-Registered function write D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP function Request D (3222) ovms-duktape: Duktape: Pre-Registered object HTTP function request D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Exec D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsCommand function Register D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Delete D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Get D (3222) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function GetValues D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Instances D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Params D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function Set D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsConfig function SetValues D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsEvents D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsEvents function Raise D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsLocation D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsLocation function Status D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Age D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsFloat D (3232) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function AsJSON D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function GetValues D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function HasValue D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsFresh D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function IsStale D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsMetrics function Value D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsNotify D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsNotify function Raise D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetPaused D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetTraceStatus D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function GetUserPaused D (3242) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Pause D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Resume D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPoller function Trace D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStarted D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function GetStatus D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Reset D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Start D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsPollerTimes function Stop D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ClimateControl D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Homelink D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Lock D (3252) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function ObdRequest D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeCurrent D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeMode D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function SetChargeTimer D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCharge D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StartCooldown D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCharge D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function StopCooldown D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Type D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unlock D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Unvalet D (3262) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Valet D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsVehicle function Wakeup D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Disable D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Enable D (3272) ovms-duktape: Duktape: Pre-Registered object OvmsAuxMonitor function Status D (3272) ovms-duktape: Duktape: Pre-Registered object VFS D (3272) ovms-duktape: Duktape: Pre-Registered object VFS function Load D (3272) ovms-duktape: Duktape: Pre-Registered object VFS function Save D (3272) ovms-duktape: Duktape: Pre-Registered module JSON D (3292) ovms-duktape: resolve_cb: id:'int/JSON', parent-id:'', resolve-to:'int/JSON.js' D (3292) ovms-duktape: load_cb: id:'int/JSON.js' internally provided int/JSON.js (713 bytes) D (3292) ovms-duktape: Duktape: module load: int/JSON.js D (3382) ovms-duktape: Duktape: Pre-Registered module PubSub D (3402) ovms-duktape: resolve_cb: id:'int/PubSub', parent-id:'', resolve-to:'int/PubSub.js' D (3402) ovms-duktape: load_cb: id:'int/PubSub.js' internally provided int/PubSub.js (2293 bytes) D (3402) ovms-duktape: Duktape: module load: int/PubSub.js I (3612) ovms-duktape: Duktape: Executing ovmsmain.js D (3612) ovms-duktape: Duktape: module load: ovmsmain.js D (3632) ovms-duktape: Duktape: module unload: ovmsmain.js D (3682) events: Signal(vehicle.charge.mode) OVMS> D (4682) events: Signal(vehicle.aux.12v.normal) OVMS> D (5422) events: Signal(system.event) D (5422) events: Signal(system.wifi.scan.done) D (5452) events: Signal(egpio.output.0.low) I (5542) wifi:ap channel adjust o:1,0 n:11,0 I (5552) wifi:new:<11,0>, old:<1,0>, ap:<11,0>, sta:<11,0>, prof:1 OVMS> I (6232) wifi:state: init -> auth (b0) I (6252) wifi:state: auth -> assoc (0) I (6262) wifi:state: assoc -> run (10) I (6292) wifi:connected with LeonsLair, aid = 2, channel 11, BW20, bssid = d4:24:dd:88:1e:85 I (6302) wifi:security type: 3, phy: bgn, rssi: -61 I (6302) wifi:pm start, type: 1 D (6302) events: Signal(system.event) D (6302) events: Signal(system.wifi.sta.connected) D (6302) netmanager: send cmd 3 from 0x0 D (6302) netmanager: done cmd 3 from 0x0 I (6312) wifi:AP's beacon interval = 102400 us, DTIM period = 1 I (6332) event: sta ip: 192.168.178.33, mask: 255.255.255.0, gw: 192.168.178.1 D (6332) events: Signal(system.event) D (6332) events: Signal(network.interface.up) D (6332) events: Signal(system.wifi.sta.gotip) I (6332) netmanager: WIFI client got IP D (6332) netmanager: Saved DNS#0 192.168.178.1 D (6332) netmanager: Saved DNS#1 0.0.0.0 D (6332) netmanager: Saved DNS#2 0.0.0.0 D (6342) netmanager: send cmd 3 from 0x0 D (6342) netmanager: done cmd 3 from 0x0 D (6542) netmanager: MongooseTask: got cmd 3 from 0x0 D (6542) netmanager: MongooseTask: done cmd 3 from 0x0 D (6542) netmanager: MongooseTask: got cmd 3 from 0x0 D (6552) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> D (8682) events: Signal(network.wifi.sta.good) I (8682) netmanager: WIFI client has good signal quality (-81.8 dBm); connect I (8682) netmanager: Interface priority is st1 (192.168.178.33/255.255.255.0 gateway 192.168.178.1) I (8682) netmanager: Set DNS#1 0.0.0.0 I (8682) netmanager: Set DNS#2 0.0.0.0 I (8682) netmanager: WIFI client up (with MODEM down): starting network with WIFI client D (8692) events: Signal(network.wifi.up) D (8692) events: Signal(network.up) I (8692) ovms-server-v2: Status: Network is up, so attempt network connection D (8692) events: Signal(network.interface.change) D (8702) events: Signal(server.v2.connectwait) OVMS> D (10452) events: Signal(egpio.output.0.high) D (10652) events: Signal(egpio.output.0.low) I (10682) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (10682) ovms-server-v2: Status: Connecting... D (10712) events: Signal(server.v2.connecting) D (10852) cellular: State timeout PowerOffOn => PoweringOn I (10852) cellular: State: Enter PoweringOn state I (10852) cellular-modem-auto: Power Cycle D (10852) events: Signal(system.modem.poweringon) I (10852) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms D (10852) events: Signal(egpio.output.0.high) OVMS> D (13352) events: Signal(egpio.output.0.low) OVMS> I (14122) ovms-server-v2: Connection successful I (14122) ovms-server-v2: Status: Logging in... D (14122) events: Signal(server.v2.authenticating) I (14122) ovms-server-v2: Sending server login: MP-C 0 BgLNQXHKd5z1eSqrZeF24F kvQAZSHdib2kENsZ3O2ypw== TEST1 I (14152) ovms-server-v2: Got server response: MP-S 0 qDyZ4KO8ERt1Zk7nEfgJaF atF5mJrBMXDG2fydaH6dwQ== I (14152) ovms-server-v2: Server token is qDyZ4KO8ERt1Zk7nEfgJaF and digest is atF5mJrBMXDG2fydaH6dwQ== I (14162) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (14162) ovms-server-v2: Shared secret key is qDyZ4KO8ERt1Zk7nEfgJaFBgLNQXHKd5z1eSqrZeF24F (44 bytes) I (14162) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (14162) events: Signal(server.v2.connected) I (14192) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS> I (14682) ovms-server-v2: Send MP-0 S0,K,0,0.00,,standard,50,50,15,0,0,0,0,0,0,0,0,0,92.98,0,0,56,21,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (14692) ovms-server-v2: Send MP-0 D0,16,5,0,0,0,0,0,0,453,0,0,1,1,12.34,0,12.6,0,0,0,0 I (14692) ovms-server-v2: Send MP-0 L51.403984,7.439806,0,158.8,0,0,0,0,2050202,0,0.000,0.000,0,0,,0,0,0,0 I (14692) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (14692) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (14692) ovms-server-v2: Send MP-0 F3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),,24,0,RT,LeonsLair,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/1, OVMS> D (18352) events: Signal(egpio.output.0.high) OVMS> D (19352) events: Signal(egpio.output.0.low) I (19452) cellular: State: Enter Identify state D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19552) cellular: tx-cmd: AT+CGMM D (19652) cellular: tx-cmd: AT+CGMM D (19652) cellular: tx-cmd: AT+CGMM D (19682) cellular: tx-cmd: AT+CGMM OVMS> D (20682) cellular: tx-cmd: AT+CGMM OVMS> D (21682) cellular: tx-cmd: AT+CGMM OVMS> D (22682) cellular: tx-cmd: AT+CGMM OVMS> D (23682) cellular: tx-cmd: AT+CGMM OVMS> D (24682) cellular: tx-cmd: AT+CGMM I (24682) ovms-server-v2: Send MP-0 h1,0,RT-GPS-Log,0,86400,51.403984,7.439806,159,0,0,0,0,-60,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0 I (24742) ovms-server-v2: Incoming Msg: MP-0 h1 OVMS> D (25682) cellular: tx-cmd: AT+CGMM OVMS> D (26682) cellular: tx-cmd: AT+CGMM OVMS> D (27682) cellular: tx-cmd: AT+CGMM OVMS> D (28682) cellular: tx-cmd: AT+CGMM OVMS> D (29682) cellular: tx-cmd: AT+CGMM OVMS> D (30682) cellular: tx-cmd: AT+CGMM OVMS> D (31682) cellular: tx-cmd: AT+CGMM OVMS> D (32682) cellular: tx-cmd: AT+CGMM OVMS> D (33682) cellular: tx-cmd: AT+CGMM OVMS> D (34682) cellular: tx-cmd: AT+CGMM OVMS> D (35682) cellular: tx-cmd: AT+CGMM D (35682) cellular: State timeout Identify => PowerOffOn I (35682) cellular: State: Enter PowerOffOn state I (35682) cellular-modem-auto: Power Cycle I (35682) Simcom: Power Cycle - T_off 2500 ms - T_on 1126913089 ms D (35682) events: Signal(system.modem.stop) I (35692) netmanager: Set DNS#1 0.0.0.0 I (35692) netmanager: Set DNS#2 0.0.0.0 D (35692) netmanager: send cmd 3 from 0x0 D (35692) netmanager: done cmd 3 from 0x0 D (35692) events: Signal(egpio.output.0.high) D (35742) netmanager: MongooseTask: got cmd 3 from 0x0 D (35742) netmanager: CleanupConnections: conn 3f8e4028 -> iface st1 D (35752) netmanager: MongooseTask: done cmd 3 from 0x0 OVMS> D (38182) events: Signal(egpio.output.0.low) OVMS> D (43182) events: Signal(egpio.output.0.high) OVMS> I (45692) ovms-server-v2: Send MP-0 h2,0,RT-BAT-P,1,86400,1,1,0,10000,0,0,1000,0,-40,200,-40,0,0,0,0,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45692) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (45782) ovms-server-v2: Incoming Msg: MP-0 h2 I (45782) ovms-server-v2: Incoming Msg: MP-0 h3 I (45802) ovms-server-v2: Incoming Msg: MP-0 h4 I (45802) ovms-server-v2: Incoming Msg: MP-0 h5 I (45802) ovms-server-v2: Incoming Msg: MP-0 h6 OVMS> I (46682) ovms-server-v2: Send MP-0 h7,-1,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h8,-1,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h9,-1,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h10,-1,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46682) ovms-server-v2: Send MP-0 h11,-1,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (46832) ovms-server-v2: Incoming Msg: MP-0 h7 I (46832) ovms-server-v2: Incoming Msg: MP-0 h8 I (46832) ovms-server-v2: Incoming Msg: MP-0 h9 I (46832) ovms-server-v2: Incoming Msg: MP-0 h10 I (46852) ovms-server-v2: Incoming Msg: MP-0 h11 OVMS> I (47682) ovms-server-v2: Send MP-0 h12,-2,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h13,-2,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h14,-1,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47682) ovms-server-v2: Send MP-0 h15,-1,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47692) ovms-server-v2: Send MP-0 h16,-2,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0,0,0,0 I (47882) ovms-server-v2: Incoming Msg: MP-0 h12 I (47882) ovms-server-v2: Incoming Msg: MP-0 h13 I (47882) ovms-server-v2: Incoming Msg: MP-0 h14 I (47892) ovms-server-v2: Incoming Msg: MP-0 h15 I (47892) ovms-server-v2: Incoming Msg: MP-0 h16 OVMS> D (62752) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms OVMS> enable Password: Secure mode OVMS# cellular sza tatus debug MODEM Status Model: auto Network Registration: Unknown Provider: Signal: 0 dBm Mode: State: PowerOffOn Ticker: 0 User Data: 0 UART: FIFO overflows: 0 Buffer overflows: 0 Parity errors: 0 Frame errors: 0 Driver Buffer overflows: 0 Mux: Not running PPP: Not running GPS: Not running OVMS# I (122692) housekeeping: System considered stable (RAM: 8b=49404-49560 32b=12128 SPI=3208412-3234380) D (122762) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms OVMS# I (123682) ovms-server-v2: Send MP-0 h17,0,*-OVM-DebugCrash,0,2592000,3.3.004-429-g629e5b8b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 30 2025 13:28:26),2,Crash,12,12,1,0,abort(),1,,0x4008ddae 0x4008e049 0x401184a3 0x4032e70b 0x40127862 0x40127909 0x40127909 0x401279af 0x401138b7 0x40130427 0x401305de 0x401138e7 0x4032f76a 0x4012d559 0x40122885 0x40122a5d 0x4012d401 0x4012d410 0x4010c3eb ,4,Exception/panic,,,0,,OVMS WIFI BLE BT cores=2 rev=ESP32/1,,IDLE0,524,OVMS Console,3416 I (123892) ovms-server-v2: Incoming Msg: MP-0 h17 OVMS# echo "modem led on" modem led on OVMS# cellular tx ATI OVMS# D (159502) cellular: tx-cmd: ATI OVMS# D (182742) ovms-duktape: Duktape: Compacting DukTape memory done in 50 ms OVMS#
