OVMS# ota status Running partition: ota_0 Boot partition: ota_0 Factory image: 3.1.001 OTA_O image: 3.2.008-121-g4c6c9fe OTA_1 image: 3.2.008-121-g4c6c9fe Server Available: 3.2.008-121-g4c6c9fe (is newer) Tue Jan 28 16:03:10 UTC 2020 Automated build (markhk8) Toolchain path: /home/openvehicles/build/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc Toolchain version: crosstool-ng-1.22.0-80-g6c4433a Compiler version: 5.2.0 App "ovms3" version: 3.2.008-121-g4c6c9fe Python requirements from /home/openvehicles/build/esp-idf/requirements.txt are satisfied. Total sizes: DRAM .data size: 16096 bytes DRAM .bss size: 34296 bytes Used static DRAM: 50392 bytes ( 130344 available, 27.9% used) Used static IRAM: 105513 bytes ( 25559 available, 80.5% used) Flash code: 1863954 bytes Flash rodata: 904016 bytes Total image size:~2889579 bytes (.bin may be padded larger) * cd55eb3 (origin/spiram-fix-test) Merge branch 'master' into spiram-fix-test |\ | * 4c6c9fe (HEAD, origin/master, origin/HEAD, master) Docs: put SSH cipher info in a note box * | 5773423 Merge branch 'master' into spiram-fix-test |\ \ | |/ | * cfb7864 New plugin: ChgInd: Charge State Indicator * | c9ff599 Merge branch 'master' into spiram-fix-test |\ \ | |/ | * bb40fcf EGPIO: address multiple ports by input & output command | * aa87d64 Tesla Roadster: Ambient temperature is signed #326 * | 5c4425a Merge branch 'master' into spiram-fix-test |\ \ | |/ | * a862373 New plugin: PwrMon: Trip Power Chart | * b417463 Docs: add screenshot for AuxBatMon plugin OVMS# boot status Last boot was 777 second(s) ago Time at boot: 2020-01-30 03:01:18 GMT This is reset #95 since last power cycle Detected boot reason: FirmwareUpdate (12/12) Reset reason: Exception/panic (4) Crash counters: 0 total, 0 early
