OVMS# V (829230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (829230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# OVMS# module V (834230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (834230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# module fault abort() was called at PC 0x401184a3 on core 1 ELF file SHA256: 75c71ac8d6058b7f Backtrace: 0x4008ddae:0x3ffddf70 0x4008e049:0x3ffddf90 0x401184a3:0x3ffddfb0 0x4032e73f:0x3ffddfd0 0x40127862:0x3ffddff0 0x40127909:0x3ffde050 0x40127909:0x3ffde0b0 0x401279af:0x3ffde110 0x401138b7:0x3ffde130 0x40130427:0x3ffde150 0x401305de:0x3ffde1b0 0x401138e7:0x3ffde250 0x4032f79e:0x3ffde270 0x4012d559:0x3ffde290 0x40122885:0x3ffde2c0 0x40122a5d:0x3ffde2f0 0x4012d401:0x3ffde310 0x4012d410:0x3ffde330 0x4010c3eb:0x3ffde350 [OVMS] Current tasks: IDLE0|OVMS Console Rebooting... ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:5980 ho 0 tail 12 room 4 load:0x40078000,len:16028 load:0x40080400,len:3816 entry 0x40080600 I (1252) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1263) cpu_start: Pro cpu up. I (1267) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-427-g0dfb100b I (1283) cpu_start: Compile time: Mar 29 2025 17:49:58 I (1289) cpu_start: ELF file SHA256: 75c71ac8d6058b7f... I (1295) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1294) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2180) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2186) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (44) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Boot #2 reasons for CPU0=12 and CPU1=12 E (71) boot: Crash #1 detected I (75) boot: Reset reason Exception/panic (4) I (80) events: Initialising EVENTS (1200) I (85) config: Initialising CONFIG (1400) I (90) time: Initialising TIME (1500) I (94) script: Initialising SCRIPTS (1600) I (99) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (104) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (110) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (116) metrics: Initialising METRICS (1810) I (121) metrics: Expanding DUKTAPE javascript engine I (126) metrics: Persistent metrics serial 3 using 820 bytes, 66/100 slots used I (137) metrics: persist v.b.12v.voltage.ref = 12.6V I (148) metrics: persist v.e.parktime = 972Sec I (154) notify: Initialising NOTIFICATIONS (1820) I (155) notify: Registered notification type info I (156) notify: Registered notification type error I (161) notify: Registered notification type alert I (167) notify: Registered notification type data I (172) notify: Registered notification type stream I (177) notify: Expanding DUKTAPE javascript engine I (183) location: Initialising LOCATIONS (1900) I (192) location: Expanding DUKTAPE javascript engine I (194) vehicle: Initialising VEHICLE Factory (2000) I (205) tls: Initialising TLS (3000) I (206) pcp: Initialising POWER (4000) I (209) max7317: Initialising MAX7317 EGPIO (4200) I (215) sdcard: Initialising SD CARD (4400) I (219) ota: Initialising OTA (4400) I (225) canformat: Initialising CAN Format Factory (4500) I (229) canformat-cs11: Registering CAN Format: CS11 (4505) I (235) canformat-crtd: Registering CAN Format: CRTD (4505) I (241) canformat-gvret: Registering CAN Format: GVRET (4505) I (248) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (255) canformat-panda: Registering CAN Format: PANDA (4505) I (261) canformat-pcap: Registering CAN Format: PCAP (4505) I (267) canformat-raw: Registering CAN Format: RAW (4505) I (273) can: Initialising CAN (4510) I (285) dbc-app: Initialising DBC (4520) I (288) canlog: Initialising CAN logging (4550) I (289) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (295) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (305) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (312) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (318) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (327) canlog-vfs: Initialising CAN logging to VFS (4560) I (331) canplay: Initialising CAN play framework (4570) I (336) canplay-vfs: Initialising CAN playing from VFS (4580) I (343) cellular: Initialising CELLULAR (4600) I (350) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (355) cellular-modem-auto: Registering auto-detect modem driver (4650) I (362) SIM5360: Registering SIM5360 modem driver (4650) I (368) SIM7000: Registering SIM7000 modem driver (4650) I (374) SIM7600: Registering SIM7600 modem driver (4650) I (380) SIM7670: Registering Simcom A7670E modem driver (4660) I (387) tpms: Initialising TPMS (4700) I (392) test: Initialising TEST (5000) I (397) module: Initialising MODULE (5100) I (402) vfs: Initialising VFS (5200) I (406) ovms-server: Initialising OVMS Server (6000) I (410) ovms-server-v2: Initialising OVMS V2 Server (6100) I (417) ovms-server-v3: Initialising OVMS V3 Server (6200) I (423) vehicle-poll: Initialising Poller (7000) I (431) obd2ecu: Initialising OBD2ECU (7000) I (434) canopen: Initialising CANopen (7000) I (442) pluginstore: Initialising PLUGINS (7100) I (445) esp32wifi: Initialising ESP32WIFI (8000) I (450) ovms-mdns: Initialising MDNS (8100) I (453) webserver: Initialising WEBSERVER (8200) I (461) ssh: Initialising SSH (8300) I (463) powermgmt: Initialising POWERMGMT (8500) I (469) re: Initialising RE Tools (8800) I (475) pushover: Initialising Pushover client (8800) I (480) netmanager: Initialising NETMANAGER (8999) I (487) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (490) v-zeva: Registering Vehicle: ZEVA (9000) I (496) v-vweup: Registering Vehicle: VW e-Up (9000) I (501) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (509) v-track: Registering Vehicle: TRACK (9000) I (514) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (521) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (527) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (534) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (541) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (548) v-smarteq: Registering Vehicle: SMART EQ (9000) I (554) v-smarted: Registering Vehicle: SMART ED (9000) I (559) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (567) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (573) v-twizy: Registering Vehicle: Renault Twizy (9000) I (579) v-obdii: Registering Vehicle: OBDII (9000) I (585) v-none: Registering Vehicle: NONE (9000) I (590) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (597) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (606) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (612) v-mgev4: Registering Vehicle: MG4 (9000) I (618) v-mgev: Registering Vehicle: MG5 (9000) I (623) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (629) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (635) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (641) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (648) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (654) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (660) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (667) v-maple60s: Registering Vehicle: Maple 60S (9000) I (673) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (679) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (687) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (693) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (700) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (708) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (714) v-energica: Registering Vehicle: Energica (9000) I (720) v-demo: Registering Vehicle: DEMO (9000) I (725) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (731) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (739) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (747) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (753) v-boltev: Registering Vehicle: Bolt EV (9000) I (758) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (764) version: Initialising Versioning (9900) I (772) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (855) ovms_main: Executing on CPU core 0 I (855) ovms_main: Mounting CONFIG... I (975) ovms_main: Configure logging... W (985) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (985) ovms_main: Registering default configs... I (985) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (985) ovms_main: Starting HOUSEKEEPING... I (1005) housekeeping: Initialising HOUSEKEEPING Framework... I (1005) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2165) pluginstore: Loading enabled plugins (2) I (2165) pluginstore: Load retools web page /plugins/retools I (2165) pluginstore: Loading enabled plugins (3) D (2175) events: Signal(housekeeping.init) I (2175) housekeeping: Executing on CPU core 1 I (2175) housekeeping: reset_reason: cpu0=12, cpu1=12 I (2185) housekeeping: Starting PERIPHERALS... I (2185) peripherals: Initialising OVMS Peripherals... I (2195) peripherals: TCP/IP Adaptor I (2195) peripherals: ESP32 system I (2205) peripherals: SPI bus I (2205) peripherals: MAX7317 I/O Expander I (2215) peripherals: ESP32 CAN I (2215) peripherals: ESP32 WIFI I (2225) peripherals: ESP32 ADC I (2225) peripherals: MCP2515 CAN 1/2 I (2225) mcp2515: can2: SetPowerMode off I (2315) peripherals: MCP2515 CAN 2/2 I (2315) mcp2515: can3: SetPowerMode off I (2395) peripherals: SD CARD I (2395) peripherals: CELLULAR MODEM I (2395) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2405) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2415) cellular: Starting modem task I (2415) uart: queue free spaces: 50 I (2415) ext12v: Powering off external 12V devices I (2425) housekeeping: Auto init max7317 (free: 160656 bytes) I (2435) housekeeping: Auto init ext12v (free: 160656 bytes) I (2435) housekeeping: Auto init dbc (free: 160656 bytes) I (2445) housekeeping: Auto init wifi (free: 160656 bytes) I (2445) housekeeping: Auto init modem (free: 160656 bytes) I (2455) housekeeping: Auto init Pollers (free: 160656 bytes) I (2455) cellular: Set modem driver to 'auto' I (2465) housekeeping: Auto init vehicle (free: 160656 bytes) I (2465) cellular: State: Enter PowerOffOn state I (2475) v-none: Generic NONE vehicle module I (2475) cellular-modem-auto: Power Cycle I (2485) housekeeping: Auto init obd2ecu (free: 148856 bytes) I (2485) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2495) housekeeping: Auto init server v2 (free: 148856 bytes) I (2505) housekeeping: Auto init server v3 (free: 148856 bytes) I (2515) housekeeping: Auto init javascript (free: 148856 bytes) I (2525) housekeeping: Auto init done (free: 148816 bytes) I (2525) housekeeping: Starting USB console... I (2535) uart: queue free spaces: 100 D (2545) events: Signal(egpio.output.1.low) D (2545) events: Signal(power.cellular.on) D (2545) events: Signal(system.modem.stop) D (2555) events: Signal(vehicle.type.set) D (2555) events: Signal(egpio.output.0.low) D (2555) events: Signal(egpio.output.0.high) D (2565) events: Signal(system.start) I (2565) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console I (2575) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Firmware: 3.3.004-427-g0dfb100b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 OVMS> I (2715) ovms-duktape: Duktape: Initialising module system I (2885) pluginstore: Loading enabled plugins (1) OVMS> D (4185) events: Signal(vehicle.aux.12v.low) OVMS> D (5005) events: Signal(egpio.output.0.low) OVMS> I (7185) sdcard: SD CARD has been inserted I (7225) sdcard: mount done D (7225) events: Signal(sd.insert) OVMS> D (9185) events: Signal(sd.mounted) I (9205) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (10005) events: Signal(egpio.output.0.high) D (10205) events: Signal(egpio.output.0.low) D (10205) cellular: State timeout PowerOffOn => PoweringOn I (10205) cellular: State: Enter PoweringOn state I (10205) cellular-modem-auto: Power Cycle I (10205) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10205) events: Signal(system.modem.poweringon) D (10205) events: Signal(egpio.output.0.high) OVMS> D (12705) events: Signal(egpio.output.0.low) OVMS> D (17705) events: Signal(egpio.output.0.high) D (17905) events: Signal(egpio.output.0.low) I (18005) cellular: State: Enter Identify state D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18105) cellular: tx-cmd: AT+CGMM D (18185) cellular: tx-cmd: AT+CGMM OVMS> D (19185) cellular: tx-cmd: AT+CGMM OVMS> D (20185) cellular: tx-cmd: AT+CGMM OVMS> D (21185) cellular: tx-cmd: AT+CGMM OVMS> D (22185) cellular: tx-cmd: AT+CGMM OVMS> D (23185) cellular: tx-cmd: AT+CGMM OVMS> D (24185) cellular: tx-cmd: AT+CGMM OVMS> D (25185) cellular: tx-cmd: AT+CGMM OVMS> D (26185) cellular: tx-cmd: AT+CGMM OVMS> D (27185) cellular: tx-cmd: AT+CGMM OVMS> D (28185) cellular: tx-cmd: AT+CGMM OVMS> D (29185) cellular: tx-cmd: AT+CGMM OVMS> D (30185) cellular: tx-cmd: AT+CGMM OVMS> D (31185) cellular: tx-cmd: AT+CGMM OVMS> D (32185) cellular: tx-cmd: AT+CGMM OVMS> D (33185) cellular: tx-cmd: AT+CGMM OVMS> D (34185) cellular: tx-cmd: AT+CGMM OVMS> D (35185) cellular: tx-cmd: AT+CGMM D (35185) cellular: State timeout Identify => PowerOffOn I (35185) cellular: State: Enter PowerOffOn state I (35185) cellular-modem-auto: Power Cycle I (35185) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms D (35185) events: Signal(system.modem.stop) D (35185) events: Signal(egpio.output.0.high) OVMS> D (37685) events: Signal(egpio.output.0.low) OVMS> D (42685) events: Signal(egpio.output.0.high) OVMS> D (43685) events: Signal(egpio.output.0.low) D (43685) cellular: State timeout PowerOffOn => PoweringOn I (43685) cellular: State: Enter PoweringOn state I (43685) cellular-modem-auto: Power Cycle I (43685) Simcom: Power Cycle - T_off 2500 ms - T_on 1000 ms D (43685) events: Signal(system.modem.poweringon) D (43685) events: Signal(egpio.output.0.high) OVMS> D (46185) events: Signal(egpio.output.0.low) OVMS> D (51185) events: Signal(egpio.output.0.high) OVMS> D (52185) cellular: tx-cmd: AT D (52185) cellular: tx-cmd: AT D (52185) cellular: tx-cmd: AT D (52185) cellular: tx-cmd: AT D (52185) events: Signal(egpio.output.0.low) OVMS> I (52615) cellular: State: Enter Identify state OVMS> D (53185) cellular: tx-cmd: AT+CGMM I (53195) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (53195) cellular: Remove old 'auto' modem driver I (53195) cellular: Set modem driver to 'SIM7600' I (53195) cellular: State: Enter PoweredOn state D (53195) events: Signal(system.modem.installed) D (53195) events: Signal(system.modem.poweredon) OVMS> D (63185) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (63215) cellular: mux-rx-line #0 (2/120): OK D (63215) cellular: mux-rx-line #0 (124/0): AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (63215) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (63215) cellular: mux-rx-line #0 (10/6): +CSQ: 21,0 D (63215) cellular: Signal Quality is: 21 (-71 dBm) D (63225) cellular: mux-rx-line #0 (2/0): OK OVMS> D (65185) cellular: tx-cmd: AT+CGMR;+ICCID D (65195) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (65195) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (65205) cellular: mux-rx-line #0 (2/0): OK OVMS> D (73185) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (73195) cellular: mux-rx-line #0 (2/0): OK I (73195) cellular: State: Enter MuxStart state V (73195) cellular: Starting MUX D (73195) events: Signal(system.modem.muxstart) OVMS> D (74185) cellular: State transition MuxStart => NetWait I (74185) cellular: State: Enter NetWait state V (74185) cellular: Starting NMEA I (74185) gsm-nmea: Startup D (74185) cellular: mux-tx #1: AT+CGPS=0 D (74185) events: Signal(system.modem.netwait) OVMS> D (76185) cellular: mux-tx #1: AT+CGPSNMEA=258 D (76205) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (76225) cellular: mux-tx #1: AT+CGPS=1,1 D (76225) events: Signal(system.modem.gpsstart) D (76225) cellular: mux-rx-line #1 (2/0): OK D (76225) cellular: mux-rx-line #1 (2/0): OK D (76225) cellular: mux-rx-line #1 (2/0): OK D (76235) cellular: mux-rx-line #1 (2/0): OK OVMS> D (84185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (84205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 I (84205) cellular: Network Registration status: RegisteredRoaming D (84205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (84205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (84205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:11:40+04" D (84215) cellular: mux-rx-line #3 (10/6): +CSQ: 21,0 D (84215) cellular: mux-rx-line #3 (2/0): OK OVMS> D (85185) cellular: mux-tx #3: AT+CPSI? D (85185) cellular: State transition NetWait => NetStart I (85185) cellular: State: Enter NetStart state D (85185) events: Signal(system.modem.netstart) D (85195) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-72,0,0-0 I (85195) cellular: Network Mode: GSM,Online D (85195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (86185) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (86245) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (86245) cellular: PPP Connection is ready to start OVMS> D (87185) cellular: State transition NetStart => NetMode I (87185) cellular: State: Enter NetMode state V (87185) cellular: Launching PPP V (87185) cellular: Starting PPP I (87185) gsm-ppp: Initialising... D (87185) events: Signal(system.modem.netmode) I (87315) gsm-ppp: StatusCallBack: None I (87315) gsm-ppp: status_cb: Connected I (87315) gsm-ppp: our_ipaddr = 10.170.195.13 I (87325) gsm-ppp: his_ipaddr = 10.64.64.64 I (87325) gsm-ppp: netmask = 255.255.255.255 I (87325) gsm-ppp: DNS#0 = 8.8.8.8 I (87325) gsm-ppp: DNS#1 = 8.8.4.4 I (87325) gsm-ppp: our6_ipaddr = :: D (87325) events: Signal(network.interface.up) D (87325) events: Signal(system.modem.gotip) D (87325) netmanager: Saved DNS#0 8.8.8.8 D (87325) netmanager: Saved DNS#1 8.8.4.4 D (87325) netmanager: Saved DNS#2 0.0.0.0 I (87325) netmanager: Interface priority is pp1 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (87325) netmanager: Set DNS#2 0.0.0.0 I (87325) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (87325) events: Signal(network.modem.up) D (87335) events: Signal(network.up) D (87335) events: Signal(network.interface.change) D (87345) netmanager: MongooseTask starting D (87345) events: Signal(network.mgr.init) I (87365) ssh: Launching SSH Server OVMS> D (90755) cellular: mux-rx-line #3 (10/0): +CSQ: 21,4 OVMS> D (117185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (117205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (117205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (117205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (117205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:12:13+04" D (117205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (117205) cellular: mux-rx-line #3 (2/0): OK W (117255) cellular: UART frame error W (117255) cellular: UART frame error OVMS> D (118185) cellular: mux-tx #3: AT+CPSI? D (118205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-129,-1040,-716,10 I (118205) cellular: Network Mode: LTE,Online D (118205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (119185) cellular: mux-tx #3: AT+COPS? D (119205) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 I (119205) cellular: Network Provider is: vodafone.de Hologram D (119205) cellular: mux-rx-line #3 (2/0): OK OVMS> I (122195) housekeeping: System considered stable (RAM: 8b=102344-105060 32b=12128 SPI=3274120-3278604) OVMS> D (147185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (147205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (147205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (147205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (147205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:12:43+04" D (147205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (147205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (148185) cellular: mux-tx #3: AT+CPSI? D (148205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-110,-1041,-733,11 D (148205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (149185) cellular: mux-tx #3: AT+COPS? D (149195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (149195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (177185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (177205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (177205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (177205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (177205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:13:13+04" D (177205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (177205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (178185) cellular: mux-tx #3: AT+CPSI? D (178205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-105,-1040,-740,12 D (178205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (179185) cellular: mux-tx #3: AT+COPS? D (179205) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (179205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (207185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (207205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (207205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (207205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (207205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:13:43+04" D (207205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (207205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (208185) cellular: mux-tx #3: AT+CPSI? D (208205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-125,-1043,-720,11 D (208205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (209185) cellular: mux-tx #3: AT+COPS? D (209195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (209195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (237185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (237205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (237205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (237205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (237205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:14:13+04" D (237205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (237205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (238185) cellular: mux-tx #3: AT+CPSI? D (238205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-114,-1041,-726,11 D (238205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (239185) cellular: mux-tx #3: AT+COPS? D (239195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (239195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (267185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (267205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (267205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (267205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (267205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:14:43+04" D (267205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (267205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (268185) cellular: mux-tx #3: AT+CPSI? D (268205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-124,-1041,-720,11 D (268205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (269185) cellular: mux-tx #3: AT+COPS? D (269195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (269195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (297185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (297205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (297205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (297205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (297205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:15:13+04" D (297205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (297205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (298185) cellular: mux-tx #3: AT+CPSI? D (298205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-123,-1041,-718,10 D (298205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (299185) cellular: mux-tx #3: AT+COPS? D (299195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (299195) cellular: mux-rx-line #3 (2/0): OK OVMS> I (302205) housekeeping: 2025-03-29 18:15:19 CET (RAM: 8b=102344-104996 32b=12128 SPI=3274120-3278672) OVMS> D (327185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (327205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (327205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (327205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (327205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:15:43+04" D (327205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (327205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (328185) cellular: mux-tx #3: AT+CPSI? D (328205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-118,-1042,-737,11 D (328205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (329185) cellular: mux-tx #3: AT+COPS? D (329195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (329195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (357185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (357205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (357205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (357205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (357205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:16:13+04" D (357205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (357205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (358185) cellular: mux-tx #3: AT+CPSI? D (358205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-125,-1038,-718,9 D (358205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (359185) cellular: mux-tx #3: AT+COPS? D (359195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (359195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (387185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (387205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (387205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (387205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (387205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:16:43+04" D (387205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (387205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (388185) cellular: mux-tx #3: AT+CPSI? D (388205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-116,-1041,-723,10 D (388205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (389185) cellular: mux-tx #3: AT+COPS? D (389195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (389195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (417185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (417205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (417205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (417205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (417205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:17:13+04" D (417205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (417205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (418185) cellular: mux-tx #3: AT+CPSI? D (418205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-133,-1040,-707,8 D (418205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (419185) cellular: mux-tx #3: AT+COPS? D (419195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (419195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (447185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (447205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (447205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (447205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (447205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:17:43+04" D (447205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (447205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (448185) cellular: mux-tx #3: AT+CPSI? D (448205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-117,-1039,-723,11 D (448205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (449185) cellular: mux-tx #3: AT+COPS? D (449195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (449195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (477185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (477205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (477205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (477205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (477205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:18:13+04" D (477205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (477205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (478185) cellular: mux-tx #3: AT+CPSI? D (478205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-111,-1042,-736,11 D (478205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (479185) cellular: mux-tx #3: AT+COPS? D (479195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (479195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (507185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (507205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (507205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (507205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (507205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:18:43+04" D (507205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (507205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (508185) cellular: mux-tx #3: AT+CPSI? D (508205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-134,-1038,-702,8 D (508205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (509185) cellular: mux-tx #3: AT+COPS? D (509195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (509195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (537185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (537205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (537205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (537205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (537205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:19:13+04" D (537205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (537205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (538185) cellular: mux-tx #3: AT+CPSI? D (538205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-124,-1041,-717,10 D (538205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (539185) cellular: mux-tx #3: AT+COPS? D (539195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (539195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (567185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (567205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (567205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (567205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (567205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:19:43+04" D (567205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (567205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (568185) cellular: mux-tx #3: AT+CPSI? D (568205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-114,-1041,-732,11 D (568205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (569185) cellular: mux-tx #3: AT+COPS? D (569195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (569195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (597185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (597205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (597205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (597205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (597205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:20:13+04" D (597205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (597205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (598185) cellular: mux-tx #3: AT+CPSI? D (598205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-121,-1041,-719,11 D (598205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (599185) cellular: mux-tx #3: AT+COPS? D (599195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (599195) cellular: mux-rx-line #3 (2/0): OK OVMS> I (602205) housekeeping: 2025-03-29 18:20:19 CET (RAM: 8b=102344-104996 32b=12128 SPI=3274120-3278640) OVMS> D (627185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (627205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (627205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (627205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (627205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:20:43+04" D (627205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (627205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (628185) cellular: mux-tx #3: AT+CPSI? D (628205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-114,-1041,-730,11 D (628205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (629185) cellular: mux-tx #3: AT+COPS? D (629195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (629195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (657185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (657205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (657205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (657205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (657205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:21:13+04" D (657205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (657205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (658185) cellular: mux-tx #3: AT+CPSI? D (658205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-106,-1040,-736,11 D (658205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (659185) cellular: mux-tx #3: AT+COPS? D (659195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (659195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (687185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (687205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (687205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (687205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (687205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:21:43+04" D (687205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (687205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (688185) cellular: mux-tx #3: AT+CPSI? D (688205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-112,-1041,-731,11 D (688205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (689185) cellular: mux-tx #3: AT+COPS? D (689195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (689195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (717185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (717205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (717205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (717205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (717205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:22:13+04" D (717205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (717205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (718185) cellular: mux-tx #3: AT+CPSI? D (718205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-126,-1043,-711,8 D (718205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (719185) cellular: mux-tx #3: AT+COPS? D (719195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (719195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (747185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (747205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (747205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (747205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (747205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:22:43+04" D (747205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (747205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (748185) cellular: mux-tx #3: AT+CPSI? D (748205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-128,-1040,-711,8 D (748205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (749185) cellular: mux-tx #3: AT+COPS? D (749195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (749195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (777185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (777205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (777205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (777205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (777205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:23:13+04" D (777205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (777205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (778185) cellular: mux-tx #3: AT+CPSI? D (778205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-143,-1040,-699,8 D (778205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (779185) cellular: mux-tx #3: AT+COPS? D (779195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (779195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (807185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (807205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (807205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (807205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (807205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:23:43+04" D (807205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (807205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (808185) cellular: mux-tx #3: AT+CPSI? D (808205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-100,-1041,-742,11 D (808205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (809185) cellular: mux-tx #3: AT+COPS? D (809195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (809195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (837185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (837205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (837205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (837205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (837205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:24:13+04" D (837205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (837205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (838185) cellular: mux-tx #3: AT+CPSI? D (838205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-131,-1042,-709,11 D (838205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (839185) cellular: mux-tx #3: AT+COPS? D (839195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (839195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (867185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (867205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (867205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (867205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (867205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:24:43+04" D (867205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (867205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (868185) cellular: mux-tx #3: AT+CPSI? D (868205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-151,-1040,-687,11 D (868205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (869185) cellular: mux-tx #3: AT+COPS? D (869195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (869195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (897185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (897205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (897205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (897205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (897205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:25:13+04" D (897205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (897205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (898185) cellular: mux-tx #3: AT+CPSI? D (898205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-121,-1044,-728,10 D (898205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (899185) cellular: mux-tx #3: AT+COPS? D (899195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (899195) cellular: mux-rx-line #3 (2/0): OK OVMS> I (902205) housekeeping: 2025-03-29 18:25:19 CET (RAM: 8b=102344-104996 32b=12128 SPI=3274120-3278672) OVMS> D (927185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (927205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (927205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (927205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (927205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:25:43+04" D (927205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (927205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (928185) cellular: mux-tx #3: AT+CPSI? D (928205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-135,-1044,-706,9 D (928205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (929185) cellular: mux-tx #3: AT+COPS? D (929195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (929195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (957185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (957205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (957205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (957205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (957205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:26:13+04" D (957205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (957205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (958185) cellular: mux-tx #3: AT+CPSI? D (958205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-114,-1045,-737,11 D (958205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (959185) cellular: mux-tx #3: AT+COPS? D (959195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (959195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (987185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (987205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (987205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (987205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (987205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:26:43+04" D (987205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (987205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (988185) cellular: mux-tx #3: AT+CPSI? D (988205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-109,-1041,-731,11 D (988205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (989185) cellular: mux-tx #3: AT+COPS? D (989195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (989195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1017185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1017205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1017205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1017205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1017205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:27:13+04" D (1017205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1017205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1018185) cellular: mux-tx #3: AT+CPSI? D (1018205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-135,-1056,-719,11 D (1018205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1019185) cellular: mux-tx #3: AT+COPS? D (1019195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1019195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1047185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1047205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1047205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1047205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1047205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:27:43+04" D (1047205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1047205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1048185) cellular: mux-tx #3: AT+CPSI? D (1048205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-126,-1060,-734,8 D (1048205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1049185) cellular: mux-tx #3: AT+COPS? D (1049195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1049195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1077185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1077205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1077205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1077205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1077205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:28:13+04" D (1077205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1077205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1078185) cellular: mux-tx #3: AT+CPSI? D (1078205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-108,-1055,-749,10 D (1078205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1079185) cellular: mux-tx #3: AT+COPS? D (1079195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1079195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1105955) cellular: mux-rx-line #3 (10/0): +CSQ: 18,4 D (1105955) cellular: Signal Quality is: 18 (-77 dBm) OVMS> D (1107185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1107205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1107205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1107205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1107205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:28:43+04" D (1107205) cellular: mux-rx-line #3 (10/6): +CSQ: 18,4 D (1107205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1108185) cellular: mux-tx #3: AT+CPSI? D (1108205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-122,-1064,-738,11 D (1108205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1109185) cellular: mux-tx #3: AT+COPS? D (1109195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1109195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1120955) cellular: mux-rx-line #3 (10/0): +CSQ: 21,4 D (1120955) cellular: Signal Quality is: 21 (-71 dBm) OVMS> D (1137185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1137205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1137205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1137205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1137205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:29:13+04" D (1137205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1137205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1138185) cellular: mux-tx #3: AT+CPSI? D (1138205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-120,-1053,-732,10 D (1138205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1139185) cellular: mux-tx #3: AT+COPS? D (1139195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1139195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1167185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1167205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1167205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1167205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1167205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:29:43+04" D (1167205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1167205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1168185) cellular: mux-tx #3: AT+CPSI? D (1168205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-123,-1050,-721,8 D (1168205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1169185) cellular: mux-tx #3: AT+COPS? D (1169195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1169195) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1197185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1197205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1197205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1197205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1197205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:30:13+04" D (1197205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1197205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1198185) cellular: mux-tx #3: AT+CPSI? D (1198205) cellular: mux-rx-line #3 (83/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-131,-1044,-712,8 D (1198205) cellular: mux-rx-line #3 (2/0): OK OVMS> D (1199185) cellular: mux-tx #3: AT+COPS? D (1199195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1199195) cellular: mux-rx-line #3 (2/0): OK OVMS> I (1202205) housekeeping: 2025-03-29 18:30:19 CET (RAM: 8b=102344-104996 32b=12128 SPI=3274120-3278640) OVMS> enable Password: Secure mode OVMS# vehicle module VWUP D (1227185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1227205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1227205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1227205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1227205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:30:43+04" D (1227205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1227205) cellular: mux-rx-line #3 (2/0): OK OVMS# vehicle module VWUP D (1228185) cellular: mux-tx #3: AT+CPSI? D (1228205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-123,-1050,-729,11 D (1228205) cellular: mux-rx-line #3 (2/0): OK OVMS# vehicle module VWUP Vehicle module 'VW e-Up' (code VWUP) loaded and running OVMS# D (1228585) events: Signal(vehicle.type.cleared) I (1228595) v-none: Shutdown NONE vehicle module D (1228595) vehicle-poll: Pollers: Queue Command() D (1228595) vehicle-poll: Pollers: Queue Command() D (1228595) vehicle-poll: Pollers: Queue Command() I (1228595) v-vweup: Start VW e-Up vehicle module D (1228605) events: Signal(vehicle.charge.prepare) D (1228605) v-vweup: VW e-Up reload configuration D (1228605) v-vweup: ConfigChanged: chg_climit: 32, chg_climit_old: 0, cc_temp: 22, cc_temp_old: 0 I (1228605) v-vweup: Starting connection: OBDII D (1228625) events: Signal(power.can1.on) D (1228635) events: Signal(egpio.output.2.low) D (1228635) vehicle-poll: PollSetPidList - Setting NULL List D (1228635) vehicle-poll: Pollers: Queue Command() D (1228635) vehicle-poll: Pollers: Queue Command() I (1228635) v-vweup: PollSetState: OFF -> OFF D (1228645) v-vweup: Poll vector: size=146 cap=168 D (1228645) vehicle-poll: PollSetPidList - Setting for bus=1 defbus=1 D (1228645) vehicle-poll: Poll List: Added Entry !v.standard D (1228645) events: Signal(vehicle.charge.mode) D (1228655) events: Signal(vehicle.type.set) OVMS# D (1229185) cellular: mux-tx #3: AT+COPS? D (1229205) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1229205) cellular: mux-rx-line #3 (2/0): OK OVMS# D (1229475) v-vweup: PollerStateTicker: [online] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=1227 => PollState 0->1 I (1229475) v-vweup: PollerStateTicker: Setting car state to AWAKE I (1229475) v-vweup: PollSetState: OFF -> AWAKE D (1229475) vehicle-poll: Pollers: Queue SetState() D (1229475) vehicle-poll: Pollers: PollState(1) E (1229475) can: can1: intr=2 rxpkt=0 txpkt=0 errflags=0x8000a2 rxerr=10 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 txqueue=0 E (1229475) can: can1: intr=17 rxpkt=0 txpkt=0 errflags=0x8040a2 rxerr=135 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 txqueue=0 D (1229475) events: Signal(vehicle.aux.12v.on) OVMS# D (1230185) events: Signal(vehicle.aux.12v.low) OVMS# D (1230475) v-vweup: PollerStateTicker: [offline] LVPwrState=0 HVChgMode=0 SOC=0.0% LVAutoChg=0 12V=0.0 DCDC_U=0.0 DCDC_I=0.0 ChgEff=0.0 BatI=0.0 BatIAge=1228 => PollState 1->0 I (1230475) v-vweup: PollerStateTicker: Setting car state to OFF I (1230475) v-vweup: PollSetState: AWAKE -> OFF D (1230475) vehicle-poll: Pollers: Queue SetState() D (1230475) vehicle-poll: Pollers: PollState(0) D (1230475) events: Signal(vehicle.aux.12v.off) OVMS# location status Currently at 0.000000,0.000000 (without GPS lock) There is 1 location defined No active locations OVMS# cellular status MODEM Status Model: SIM7600 Network Registration: RegisteredRoaming Provider: vodafone.de Hologram Signal: -71 dBm Mode: LTE,Online State: NetMode Mux: Status up PPP: Connected on channel: #2 GPS: Connected on channel: #1 OVMS# lofg l g level D (1257185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (1257205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1257205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1257205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1257205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:31:13+04" D (1257205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1257205) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose D (1258185) cellular: mux-tx #3: AT+CPSI? D (1258205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-125,-1048,-721,11 D (1258205) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsmD (1259185) cellular: mux-tx #3: AT+COPS? D (1259195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1259195) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-nmea Logging level for gsm-nmea set to verbose OVMS# log level verbose gsm-nmea mux Logging level for gsm-mux set to verbose OVMS# V (1266225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1266225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (1271225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1271225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (1276225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1276225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (1281225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1281225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (1286225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1286225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (1287185) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (1287205) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (1287205) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (1287205) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (1287205) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (1287205) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:31:43+04" D (1287205) cellular: mux-rx-line #3 (10/6): +CSQ: 21,4 D (1287205) cellular: mux-rx-line #3 (2/0): OK OVMS# D (1288185) cellular: mux-tx #3: AT+CPSI? V (1288205) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (1288205) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-122,-1045,-723,11 V (1288205) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (1288205) cellular: mux-rx-line #3 (2/0): OK OVMS# D (1289185) cellular: mux-tx #3: AT+COPS? V (1289195) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (1289195) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (1289205) cellular: mux-rx-line #3 (2/0): OK OVMS# V (1291225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1291225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (1296225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (1296225) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS#
