I (1253) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1264) cpu_start: Pro cpu up. I (1268) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-427-g0dfb100b I (1284) cpu_start: Compile time: Mar 29 2025 17:49:58 I (1290) cpu_start: ELF file SHA256: 75c71ac8d6058b7f... I (1296) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (0) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2181) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2187) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (45) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Power cycle reset detected I (71) events: Initialising EVENTS (1200) I (75) config: Initialising CONFIG (1400) I (81) time: Initialising TIME (1500) I (84) script: Initialising SCRIPTS (1600) I (89) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (94) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (100) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (106) metrics: Initialising METRICS (1810) I (112) metrics: Expanding DUKTAPE javascript engine I (117) metrics: Persistent metrics serial 1 using 820 bytes, 0/100 slots used I (139) notify: Initialising NOTIFICATIONS (1820) I (141) notify: Registered notification type info I (141) notify: Registered notification type error I (145) notify: Registered notification type alert I (150) notify: Registered notification type data I (156) notify: Registered notification type stream I (161) notify: Expanding DUKTAPE javascript engine I (167) location: Initialising LOCATIONS (1900) I (175) location: Expanding DUKTAPE javascript engine I (178) vehicle: Initialising VEHICLE Factory (2000) I (189) tls: Initialising TLS (3000) I (190) pcp: Initialising POWER (4000) I (192) max7317: Initialising MAX7317 EGPIO (4200) I (198) sdcard: Initialising SD CARD (4400) I (203) ota: Initialising OTA (4400) I (209) canformat: Initialising CAN Format Factory (4500) I (213) canformat-cs11: Registering CAN Format: CS11 (4505) I (219) canformat-crtd: Registering CAN Format: CRTD (4505) I (225) canformat-gvret: Registering CAN Format: GVRET (4505) I (232) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (238) canformat-panda: Registering CAN Format: PANDA (4505) I (245) canformat-pcap: Registering CAN Format: PCAP (4505) I (251) canformat-raw: Registering CAN Format: RAW (4505) I (257) can: Initialising CAN (4510) I (269) dbc-app: Initialising DBC (4520) I (272) canlog: Initialising CAN logging (4550) I (273) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (279) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (288) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (296) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (301) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (311) canlog-vfs: Initialising CAN logging to VFS (4560) I (314) canplay: Initialising CAN play framework (4570) I (320) canplay-vfs: Initialising CAN playing from VFS (4580) I (327) cellular: Initialising CELLULAR (4600) I (333) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (338) cellular-modem-auto: Registering auto-detect modem driver (4650) I (346) SIM5360: Registering SIM5360 modem driver (4650) I (352) SIM7000: Registering SIM7000 modem driver (4650) I (358) SIM7600: Registering SIM7600 modem driver (4650) I (364) SIM7670: Registering Simcom A7670E modem driver (4660) I (370) tpms: Initialising TPMS (4700) I (375) test: Initialising TEST (5000) I (380) module: Initialising MODULE (5100) I (385) vfs: Initialising VFS (5200) I (389) ovms-server: Initialising OVMS Server (6000) I (394) ovms-server-v2: Initialising OVMS V2 Server (6100) I (401) ovms-server-v3: Initialising OVMS V3 Server (6200) I (407) vehicle-poll: Initialising Poller (7000) I (414) obd2ecu: Initialising OBD2ECU (7000) I (418) canopen: Initialising CANopen (7000) I (426) pluginstore: Initialising PLUGINS (7100) I (428) esp32wifi: Initialising ESP32WIFI (8000) I (433) ovms-mdns: Initialising MDNS (8100) I (437) webserver: Initialising WEBSERVER (8200) I (445) ssh: Initialising SSH (8300) I (447) powermgmt: Initialising POWERMGMT (8500) I (452) re: Initialising RE Tools (8800) I (459) pushover: Initialising Pushover client (8800) I (464) netmanager: Initialising NETMANAGER (8999) I (471) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (474) v-zeva: Registering Vehicle: ZEVA (9000) I (479) v-vweup: Registering Vehicle: VW e-Up (9000) I (485) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (492) v-track: Registering Vehicle: TRACK (9000) I (498) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (505) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (511) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (518) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (525) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (531) v-smarteq: Registering Vehicle: SMART EQ (9000) I (537) v-smarted: Registering Vehicle: SMART ED (9000) I (543) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (550) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (557) v-twizy: Registering Vehicle: Renault Twizy (9000) I (563) v-obdii: Registering Vehicle: OBDII (9000) I (568) v-none: Registering Vehicle: NONE (9000) I (574) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (580) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (590) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (596) v-mgev4: Registering Vehicle: MG4 (9000) I (601) v-mgev: Registering Vehicle: MG5 (9000) I (606) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (613) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (619) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (625) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (631) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (637) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (644) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (650) v-maple60s: Registering Vehicle: Maple 60S (9000) I (656) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (663) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (670) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (677) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (684) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (691) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (697) v-energica: Registering Vehicle: Energica (9000) I (703) v-demo: Registering Vehicle: DEMO (9000) I (709) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (715) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (723) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (730) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (736) v-boltev: Registering Vehicle: Bolt EV (9000) I (742) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (747) version: Initialising Versioning (9900) I (758) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (838) ovms_main: Executing on CPU core 0 I (838) ovms_main: Mounting CONFIG... I (958) ovms_main: Configure logging... W (968) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (968) ovms_main: Registering default configs... I (968) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (968) ovms_main: Starting HOUSEKEEPING... I (988) housekeeping: Initialising HOUSEKEEPING Framework... I (988) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2158) pluginstore: Loading enabled plugins (2) I (2158) pluginstore: Load retools web page /plugins/retools I (2158) pluginstore: Loading enabled plugins (3) D (2168) events: Signal(housekeeping.init) I (2168) housekeeping: Executing on CPU core 1 I (2168) housekeeping: reset_reason: cpu0=1, cpu1=14 I (2178) housekeeping: Starting PERIPHERALS... I (2178) peripherals: Initialising OVMS Peripherals... I (2188) peripherals: TCP/IP Adaptor I (2188) peripherals: ESP32 system I (2198) peripherals: SPI bus I (2198) peripherals: MAX7317 I/O Expander I (2208) peripherals: ESP32 CAN I (2208) peripherals: ESP32 WIFI I (2218) peripherals: ESP32 ADC I (2218) peripherals: MCP2515 CAN 1/2 I (2218) mcp2515: can2: SetPowerMode off I (2308) peripherals: MCP2515 CAN 2/2 I (2308) mcp2515: can3: SetPowerMode off I (2388) peripherals: SD CARD I (2388) peripherals: CELLULAR MODEM I (2388) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2398) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2408) cellular: Starting modem task I (2408) uart: queue free spaces: 50 I (2408) ext12v: Powering off external 12V devices I (2418) housekeeping: Auto init max7317 (free: 160936 bytes) I (2428) housekeeping: Auto init ext12v (free: 160936 bytes) I (2428) housekeeping: Auto init dbc (free: 160936 bytes) I (2438) housekeeping: Auto init wifi (free: 160936 bytes) I (2438) housekeeping: Auto init modem (free: 160936 bytes) I (2448) housekeeping: Auto init Pollers (free: 160936 bytes) I (2448) cellular: Set modem driver to 'auto' I (2458) housekeeping: Auto init vehicle (free: 160936 bytes) I (2458) cellular: State: Enter PowerOffOn state I (2468) v-none: Generic NONE vehicle module I (2468) cellular-modem-auto: Power Cycle I (2478) housekeeping: Auto init obd2ecu (free: 149136 bytes) I (2478) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2488) housekeeping: Auto init server v2 (free: 149136 bytes) I (2498) housekeeping: Auto init server v3 (free: 149136 bytes) I (2508) housekeeping: Auto init javascript (free: 149136 bytes) I (2518) housekeeping: Auto init done (free: 149096 bytes) I (2518) housekeeping: Starting USB console... I (2528) uart: queue free spaces: 100 D (2538) events: Signal(egpio.output.1.low) D (2538) events: Signal(power.cellular.on) D (2538) events: Signal(system.modem.stop) D (2548) events: Signal(vehicle.type.set) D (2548) events: Signal(egpio.output.0.low) D (2548) events: Signal(egpio.output.0.high) D (2558) events: Signal(system.start) I (2558) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console I (2568) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Firmware: 3.3.004-427-g0dfb100b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 OVMS> I (2708) ovms-duktape: Duktape: Initialising module system I (2878) pluginstore: Loading enabled plugins (1) OVMS> D (4178) events: Signal(vehicle.aux.12v.low) OVMS> D (4998) events: Signal(egpio.output.0.low) OVMS> I (7178) sdcard: SD CARD has been inserted OVMS> I (7398) sdcard: mount done D (7398) events: Signal(sd.insert) OVMS> D (9178) events: Signal(sd.mounted) I (9198) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (9998) events: Signal(egpio.output.0.high) D (10198) events: Signal(egpio.output.0.low) D (10198) cellular: State timeout PowerOffOn => PoweringOn I (10198) cellular: State: Enter PoweringOn state I (10198) cellular-modem-auto: Power Cycle I (10198) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10198) events: Signal(system.modem.poweringon) D (10198) events: Signal(egpio.output.0.high) OVMS> D (12698) events: Signal(egpio.output.0.low) OVMS> D (17698) events: Signal(egpio.output.0.high) D (17898) events: Signal(egpio.output.0.low) D (17898) cellular: tx-cmd: AT D (17898) cellular: tx-cmd: AT D (17898) cellular: tx-cmd: AT I (17898) cellular: State: Enter Identify state D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM D (17898) cellular: tx-cmd: AT+CGMM OVMS> D (18178) cellular: tx-cmd: AT+CGMM I (18188) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (18188) cellular: Remove old 'auto' modem driver I (18188) cellular: Set modem driver to 'SIM7600' I (18188) cellular: State: Enter PoweredOn state D (18188) events: Signal(system.modem.installed) D (18198) events: Signal(system.modem.poweredon) OVMS> D (28178) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (28208) cellular: mux-rx-line #0 (2/120): OK D (28208) cellular: mux-rx-line #0 (124/0): AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (28208) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (28208) cellular: mux-rx-line #0 (10/6): +CSQ: 20,0 D (28208) cellular: Signal Quality is: 20 (-73 dBm) D (28208) cellular: mux-rx-line #0 (2/0): OK OVMS> D (30178) cellular: tx-cmd: AT+CGMR;+ICCID D (30188) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (30188) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (30198) cellular: mux-rx-line #0 (2/0): OK OVMS> D (38178) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (38188) cellular: mux-rx-line #0 (2/0): OK I (38188) cellular: State: Enter MuxStart state V (38188) cellular: Starting MUX D (38188) events: Signal(system.modem.muxstart) OVMS> D (39178) cellular: State transition MuxStart => NetWait I (39178) cellular: State: Enter NetWait state V (39178) cellular: Starting NMEA D (39178) cellular: mux-tx #1: AT+CGPS=0 D (39178) events: Signal(system.modem.netwait) OVMS> D (41178) cellular: mux-tx #1: AT+CGPSNMEA=258 D (41198) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (41218) cellular: mux-tx #1: AT+CGPS=1,1 D (41218) events: Signal(system.modem.gpsstart) D (41218) cellular: mux-rx-line #1 (2/0): OK D (41218) cellular: mux-rx-line #1 (2/0): OK D (41218) cellular: mux-rx-line #1 (2/0): OK D (41228) cellular: mux-rx-line #1 (2/0): OK OVMS> D (48528) cellular: mux-rx-line #3 (11/0): +CSQ: 20,99 OVMS> D (49178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (49198) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 I (49198) cellular: Network Registration status: RegisteredRoaming D (49198) cellular: mux-rx-line #3 (11/69): +CGREG: 1,2 D (49198) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (49198) cellular: mux-rx-line #3 (29/21): +CCLK: "80/01/06,01:00:51+04" D (49198) cellular: mux-rx-line #3 (11/6): +CSQ: 20,99 D (49198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (50178) cellular: mux-tx #3: AT+CPSI? D (50178) cellular: State transition NetWait => NetStart I (50178) cellular: State: Enter NetStart state D (50178) events: Signal(system.modem.netstart) D (50198) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-74,0,33-33 I (50198) cellular: Network Mode: GSM,Online D (50198) cellular: mux-rx-line #3 (2/0): OK OVMS> D (50728) cellular: mux-rx-line #3 (9/0): +CGREG: 5 D (50908) cellular: mux-rx-line #3 (26/0): +CTZV: 4,25/03/29,16:54:09 OVMS> D (51178) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (51228) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (51228) cellular: PPP Connection is ready to start OVMS> D (52178) cellular: State transition NetStart => NetMode I (52178) cellular: State: Enter NetMode state V (52178) cellular: Launching PPP V (52178) cellular: Starting PPP I (52178) gsm-ppp: Initialising... D (52188) events: Signal(system.modem.netmode) OVMS> I (52758) gsm-ppp: StatusCallBack: None I (52758) gsm-ppp: status_cb: Connected I (52758) gsm-ppp: our_ipaddr = 10.170.195.13 I (52758) gsm-ppp: his_ipaddr = 10.64.64.64 I (52758) gsm-ppp: netmask = 255.255.255.255 I (52758) gsm-ppp: DNS#0 = 8.8.8.8 I (52758) gsm-ppp: DNS#1 = 8.8.4.4 I (52758) gsm-ppp: our6_ipaddr = :: D (52768) events: Signal(network.interface.up) D (52768) events: Signal(system.modem.gotip) D (52768) netmanager: Saved DNS#0 8.8.8.8 D (52768) netmanager: Saved DNS#1 8.8.4.4 D (52768) netmanager: Saved DNS#2 0.0.0.0 I (52768) netmanager: Interface priority is pp1 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (52768) netmanager: Set DNS#2 0.0.0.0 I (52768) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (52768) events: Signal(network.modem.up) D (52778) events: Signal(network.up) D (52778) events: Signal(network.interface.change) D (52788) netmanager: MongooseTask starting D (52788) events: Signal(network.mgr.init) I (52808) ssh: Launching SSH Server OVMS> D (54528) cellular: mux-rx-line #3 (10/0): +CSQ: 20,0 OVMS> D (56668) cellular: mux-rx-line #3 (10/0): +CSQ: 99,0 D (56668) cellular: Signal Quality is: 99 (0 dBm) OVMS> D (57088) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 D (57088) cellular: Signal Quality is: 19 (-75 dBm) OVMS> ena enable d Password: Secure mode OVMS# server v2 start D (82178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (82198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (82198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (82198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (82198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,17:54:40+04" D (82198) cellular: mux-rx-line #3 (10/6): +CSQ: 19,0 D (82198) cellular: mux-rx-line #3 (2/0): OK OVMS# server v2 start Launching OVMS Server V2 connection (oscv2) OVMS# I (82438) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (82438) ovms-server-v2: Status: Server has been started D (82438) events: Signal(server.v2.waitnetwork) I (82448) ovms-server-v2: OVMS Server v2 running I (82458) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1 I (82458) ovms-server-v2: Status: Connecting... D (82458) events: Signal(server.v2.connecting) D (83178) cellular: mux-tx #3: AT+CPSI? D (83198) cellular: mux-rx-line #3 (58/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-74,0,0-0 D (83198) cellular: mux-rx-line #3 (2/0): OK D (84178) cellular: mux-tx #3: AT+COPS? D (84188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (84188) cellular: Network Provider is: vodafone.de Hologram D (84198) cellular: mux-rx-line #3 (2/0): OK D (90558) cellular: mux-rx-line #3 (10/0): +CSQ: 19,7 D (93558) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 OVMS# D (99568) cellular: mux-rx-line #3 (10/0): +CSQ: 21,0 D (99568) cellular: Signal Quality is: 21 (-71 dBm) OVMS# I (100288) ovms-server-v2: Connection successful I (100288) ovms-server-v2: Status: Logging in... D (100288) events: Signal(server.v2.authenticating) I (100288) ovms-server-v2: Sending server login: MP-C 0 BEJDK49PdLCjC+XhJ8HAxy DCvXVPdiHuBCuduWVRwMsw== TEST1 I (100418) ovms-server-v2: Got server response: MP-S 0 PlGw1rpSWwlTw+XT2DWQkz 3VEX8cKyXogEBb/MjlTdFQ== I (100418) ovms-server-v2: Server token is PlGw1rpSWwlTw+XT2DWQkz and digest is 3VEX8cKyXogEBb/MjlTdFQ== I (100418) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (100418) ovms-server-v2: Shared secret key is PlGw1rpSWwlTw+XT2DWQkzBEJDK49PdLCjC+XhJ8HAxy (44 bytes) I (100418) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established D (100418) events: Signal(server.v2.connected) I (100448) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS# I (101178) ovms-server-v2: Send MP-0 S0,K,0,0.00,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.0,0.0,0.0,0.0,-1 I (101178) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,99,0,0,1,1,0,0,12.6,0,0,0,0 I (101188) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0,0,0,0,,0,0,0,0 I (101188) ovms-server-v2: Send MP-0 Y4,FL,FR,RL,RR,0,-1,0,-1,0,-1,0,-1 I (101188) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,-1 I (101188) ovms-server-v2: Send MP-0 F3.3.004-427-g0dfb100b/factory/edge (build idf v3.3.4-851-gfa4f07fb3b Mar 29 2025 17:50:01),,21,0,NONE,vodafone.de Hologram,-1,-1,OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600,GSM;Online OVMS# D (112178) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (112198) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (112198) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (112198) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (112198) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,17:55:10+04" D (112198) cellular: mux-rx-line #3 (10/6): +CSQ: 21,0 D (112198) cellular: mux-rx-line #3 (2/0): OK OVMS# D (113178) cellular: mux-tx #3: AT+CPSI? D (113318) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-116,-1038,-716,10 I (113318) cellular: Network Mode: LTE,Online D (113318) cellular: mux-rx-line #3 (2/0): OK OVMS# D (114178) cellular: mux-tx #3: AT+COPS? D (114188) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (114198) cellular: mux-rx-line #3 (2/0): OK OVMS# I (122188) housekeeping: System considered stable (RAM: 8b=102540-103616 32b=12128 SPI=3225352-3247776) OVMS# module reset Resetting system... OVMS# I (142038) boot: Shutting down for Restart... D (142038) events: Signal(system.shuttingdown) W (142038) boot: Shutdown: vehicle pending, 1 total I (142038) v-none: Shutdown NONE vehicle module W (142038) boot: Shutdown: vehicle-poll pending, 2 total D (142048) vehicle-poll: Poller Shutdown Sending Shut-Down V (142048) vehicle-poll: Poller Shutdown Powering Down Busses V (142048) vehicle-poll: Poller Shutdown Finished D (142048) vehicle-poll: Pollers: Shutdown null W (142058) boot: Shutdown: sdcard pending, 3 total I (142058) sdcard: Unmounting SDCARD for reset W (142058) boot: Shutdown: cellular pending, 4 total W (142058) boot: Shutdown: ovms-duktape pending, 5 total I (142058) cellular: State: Enter PoweringOff state V (142058) cellular: Stopping PPP W (142058) boot: Shutdown: webserver pending, 6 total I (142058) gsm-ppp: Shutting down (hard)... I (142068) gsm-ppp: StatusCallBack: User Interrupt I (142068) gsm-ppp: PPP is shutdown V (142068) cellular: Stopping NMEA D (142068) cellular: mux-tx #1: AT+CGPSNMEA=0 D (142068) events: Signal(sd.unmounting) E (142068) mongoose: mg_ssl_if_mbed_err 0x3f8e1488 SSL error: -1 I (142078) ovms-duktape: Duktape: Clearing existing context D (142088) cellular: mux-tx #1: AT+CGPSINFOCFG=0 E (142108) ovms-server-v2: Status: Connection lost, reconnecting D (142188) cellular: mux-tx #1: AT+CGPS=0 I (142188) Simcom: Power Off - 3000 ms I (142208) command: CloseLogfile: file logging stopped I (142208) sdcard: unmount done D (142208) events: Signal(system.modem.down) I (142218) netmanager: MODEM down (with WIFI client down): network connectivity has been lost D (142218) events: Signal(server.v2.waitreconnect) I (142218) ovms-server-v2: Status: Server is ready to start I (142218) boot: Shutdown: vehicle ready, 5 pending I (142218) boot: Shutdown: vehicle-poll ready, 4 pending I (142218) boot: Shutdown: ovms-duktape ready, 3 pending D (142228) events: Signal(system.modem.gpsstop) D (142228) events: Signal(system.modem.stop) D (142228) events: Signal(egpio.output.3.low) D (142228) events: Signal(egpio.output.0.high) D (142238) events: Signal(network.modem.down) D (142238) events: Signal(network.down) D (142238) events: Signal(network.interface.change) D (142238) events: Signal(server.v2.waitnetwork) D (142368) netmanager: MongooseTask stopping D (142368) events: Signal(network.mgr.stop) I (142368) ssh: Stopping SSH Server OVMS# I (144178) boot: Shutdown: sdcard ready, 2 pending I (144178) boot: Shutdown: webserver ready, 1 pending D (144178) events: Signal(sd.unmounted) OVMS# D (145188) events: Signal(egpio.output.0.low) OVMS# I (146178) boot: Restart in 65 seconds (1 pending)... OVMS# I (151178) boot: Restart in 60 seconds (1 pending)... OVMS# I (156178) boot: Restart in 55 seconds (1 pending)... OVMS# I (161178) boot: Restart in 50 seconds (1 pending)... D (161178) cellular: State timeout PoweringOff => CheckPowerOff I (161178) cellular: State: Enter CheckPowerOff state OVMS# D (164178) cellular: tx-cmd: AT OVMS# I (166178) boot: Restart in 45 seconds (1 pending)... OVMS# D (167178) cellular: tx-cmd: AT OVMS# D (170178) cellular: tx-cmd: AT OVMS# I (171178) boot: Restart in 40 seconds (1 pending)... OVMS# D (173178) cellular: tx-cmd: AT OVMS# D (176178) cellular: tx-cmd: AT I (176178) boot: Restart in 35 seconds (1 pending)... D (176178) cellular: State timeout CheckPowerOff => PoweredOff I (176178) cellular: State: Enter PoweredOff state V (176178) cellular: Stopping MUX D (176178) events: Signal(system.modem.poweredoff) D (176178) cellular: UART shutdown I (176178) boot: Shutdown: cellular ready, 0 pending OVMS# I (177178) boot: Restart now OVMS# D (178178) events: Signal(system.shutdown)ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:5980 ho 0 tail 12 room 4 load:0x40078000,len:16028 load:0x40080400,len:3816 entry 0x40080600 I (1252) psram: This chip is ESP32-D0WD I (1253) spiram: Found 64MBit SPI RAM device I (1253) spiram: SPI RAM mode: flash 40m sram 40m I (1256) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (1263) cpu_start: Pro cpu up. I (1267) cpu_start: Application information: I (1272) cpu_start: Project name: ovms3 I (1277) cpu_start: App version: 3.3.004-427-g0dfb100b I (1283) cpu_start: Compile time: Mar 29 2025 17:49:58 I (1289) cpu_start: ELF file SHA256: 75c71ac8d6058b7f... I (1295) cpu_start: ESP-IDF: v3.3.4-851-gfa4f07fb3b I (1302) cpu_start: Starting app cpu, entry point is 0x400818e0 I (1294) cpu_start: App cpu up. I (2180) spiram: SPI SRAM memory test OK I (2180) heap_init: Initializing. RAM available for dynamic allocation: I (2180) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (2186) heap_init: At 3FFC1F80 len 0001E080 (120 KiB): DRAM I (2193) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (2199) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (2206) heap_init: At 4009CDD4 len 0000322C (12 KiB): IRAM I (2212) cpu_start: Pro cpu start user code I (2217) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (44) ovms_main: Set default logging level for * to INFO I (44) ovms_main: WATCHDOG already initialized... I (44) ovms-duktape: Initialising DUKTAPE Registry (1000) I (51) command: Initialising COMMAND (1010) I (57) command: Expanding DUKTAPE javascript engine I (61) boot: Initialising BOOT (1100) I (66) boot: Boot #1 reasons for CPU0=12 and CPU1=12 I (71) boot: Soft reset by user I (75) events: Initialising EVENTS (1200) I (80) config: Initialising CONFIG (1400) I (85) time: Initialising TIME (1500) I (89) script: Initialising SCRIPTS (1600) I (94) ovms-duk-http: Installing DUKTAPE HTTP (1710) I (99) ovms-duk-util: Installing DUKTAPE Utilities (1710) I (105) ovms-duk-vfs: Installing DUKTAPE VFS (1710) I (111) metrics: Initialising METRICS (1810) I (116) metrics: Expanding DUKTAPE javascript engine I (121) metrics: Persistent metrics serial 2 using 820 bytes, 66/100 slots used I (132) metrics: persist v.b.12v.voltage.ref = 12.6V I (143) metrics: persist v.e.parktime = 139Sec I (149) notify: Initialising NOTIFICATIONS (1820) I (150) notify: Registered notification type info I (151) notify: Registered notification type error I (156) notify: Registered notification type alert I (162) notify: Registered notification type data I (167) notify: Registered notification type stream I (172) notify: Expanding DUKTAPE javascript engine I (178) location: Initialising LOCATIONS (1900) I (187) location: Expanding DUKTAPE javascript engine I (189) vehicle: Initialising VEHICLE Factory (2000) I (200) tls: Initialising TLS (3000) I (201) pcp: Initialising POWER (4000) I (204) max7317: Initialising MAX7317 EGPIO (4200) I (210) sdcard: Initialising SD CARD (4400) I (214) ota: Initialising OTA (4400) I (220) canformat: Initialising CAN Format Factory (4500) I (224) canformat-cs11: Registering CAN Format: CS11 (4505) I (230) canformat-crtd: Registering CAN Format: CRTD (4505) I (236) canformat-gvret: Registering CAN Format: GVRET (4505) I (243) canformat-lawicel: Registering CAN Format: LAWICEL (4505) I (250) canformat-panda: Registering CAN Format: PANDA (4505) I (256) canformat-pcap: Registering CAN Format: PCAP (4505) I (262) canformat-raw: Registering CAN Format: RAW (4505) I (268) can: Initialising CAN (4510) I (280) dbc-app: Initialising DBC (4520) I (283) canlog: Initialising CAN logging (4550) I (284) canlog-monitor: Initialising CAN logging to MONITOR (4560) I (290) canlog-tcpclient: Initialising CAN logging as TCP client (4560) I (300) canlog-tcpserver: Initialising CAN logging as TCP server (4560) I (307) canlog-udpclient: Initialising CAN logging as UDP client (4560) I (313) canlog-udpserver: Initialising CAN logging as UDP server (4560) I (322) canlog-vfs: Initialising CAN logging to VFS (4560) I (326) canplay: Initialising CAN play framework (4570) I (331) canplay-vfs: Initialising CAN playing from VFS (4580) I (338) cellular: Initialising CELLULAR (4600) I (345) cellular-modem-factory: Initialising CELLULAR MODEM Factory (4601) I (350) cellular-modem-auto: Registering auto-detect modem driver (4650) I (357) SIM5360: Registering SIM5360 modem driver (4650) I (363) SIM7000: Registering SIM7000 modem driver (4650) I (369) SIM7600: Registering SIM7600 modem driver (4650) I (375) SIM7670: Registering Simcom A7670E modem driver (4660) I (381) tpms: Initialising TPMS (4700) I (387) test: Initialising TEST (5000) I (392) module: Initialising MODULE (5100) I (397) vfs: Initialising VFS (5200) I (401) ovms-server: Initialising OVMS Server (6000) I (405) ovms-server-v2: Initialising OVMS V2 Server (6100) I (412) ovms-server-v3: Initialising OVMS V3 Server (6200) I (418) vehicle-poll: Initialising Poller (7000) I (426) obd2ecu: Initialising OBD2ECU (7000) I (429) canopen: Initialising CANopen (7000) I (437) pluginstore: Initialising PLUGINS (7100) I (440) esp32wifi: Initialising ESP32WIFI (8000) I (445) ovms-mdns: Initialising MDNS (8100) I (448) webserver: Initialising WEBSERVER (8200) I (456) ssh: Initialising SSH (8300) I (458) powermgmt: Initialising POWERMGMT (8500) I (464) re: Initialising RE Tools (8800) I (470) pushover: Initialising Pushover client (8800) I (475) netmanager: Initialising NETMANAGER (8999) I (482) v-zombie-vcu: Registering Vehicle: ZombieVerter VCU (9000) I (485) v-zeva: Registering Vehicle: ZEVA (9000) I (491) v-vweup: Registering Vehicle: VW e-Up (9000) I (496) v-voltampera: Registering Vehicle: Chevrolet Volt/Ampera (9000) I (504) v-track: Registering Vehicle: TRACK (9000) I (509) v-toyotarav4ev: Registering Vehicle: Toyota RAV4 EV (9000) I (516) v-thinkcity: Registering Vehicle: THINK CITY (9000) I (522) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (529) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (536) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000) I (543) v-smarteq: Registering Vehicle: SMART EQ (9000) I (549) v-smarted: Registering Vehicle: SMART ED (9000) I (554) v-zoe-ph2-obd: Registering Vehicle: Renault Zoe Ph2 (OBD) (9000) I (562) v-zoe: Registering Vehicle: Renault Zoe/Kangoo (9000) I (568) v-twizy: Registering Vehicle: Renault Twizy (9000) I (574) v-obdii: Registering Vehicle: OBDII (9000) I (580) v-none: Registering Vehicle: NONE (9000) I (585) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000) I (592) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000) I (601) v-minise: Registering Vehicle: Mini Cooper SE (9000) I (607) v-mgev4: Registering Vehicle: MG4 (9000) I (613) v-mgev: Registering Vehicle: MG5 (9000) I (618) v-mgev: Registering Vehicle: MG ZS EV (UK/EU) (9000) I (624) v-mgev: Registering Vehicle: MG ZS EV (AU/TH) (9000) I (630) v-mgev: Registering Vehicle: MG ZS EV (2023-) I (636) v-mbb250e: Registering Vehicle: MERCEDESB250E (9000) I (642) v-maxe6: Registering Vehicle: Maxus Euniq 6 (9000) I (649) v-maxe56: Registering Vehicle: Maxus eDeliver3 (9000) I (655) v-maxed3: Registering Vehicle: Maxus eDeliver3 (9000) I (662) v-maple60s: Registering Vehicle: Maple 60S (9000) I (668) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000) I (674) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000) I (682) v-jaguaripace: Registering Vehicle: Jaguar Ipace (9000) I (688) v-hyundaivfl: Registering Vehicle: Hyundai Ioniq vFL (9000) I (695) v-ioniq5: Registering Vehicle: Hyundai Ioniq 5 EV/KIA EV6 (9000) I (702) v-fiat500e: Registering Vehicle: FIAT 500e (9000) I (709) v-energica: Registering Vehicle: Energica (9000) I (715) v-demo: Registering Vehicle: DEMO (9000) I (720) v-dbc: Registering Vehicle: DBC based vehicle (9000) I (726) v-chevroletc6corvette: Registering Vehicle: Chevrolet C6 Corvette (9000) I (734) v-cadillacc2cts: Registering Vehicle: Cadillac 2nd gen CTS (9000) I (742) v-atto3: Registering Vehicle: BYD Atto3 (9000) I (748) v-boltev: Registering Vehicle: Bolt EV (9000) I (753) v-bmwi3: Registering Vehicle: BMW i3 (9000) I (759) version: Initialising Versioning (9900) I (767) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (30) ovms-duktape: Duktape: Scripting task is running I (850) ovms_main: Executing on CPU core 0 I (850) ovms_main: Mounting CONFIG... I (970) ovms_main: Configure logging... W (980) command: OpenLogfile: cannot open '/sd/logs/log', will retry on SD mount I (980) ovms_main: Registering default configs... I (980) location: UpdateParkPosition: vehicle is parking @0.000000,0.000000 gpslock=0 satcount=0 hdop=0.0 sq=0 invalid=1 I (980) ovms_main: Starting HOUSEKEEPING... I (1000) housekeeping: Initialising HOUSEKEEPING Framework... I (1000) tls: Built trusted CA cache (5 entries, 8101 bytes) I (2170) pluginstore: Loading enabled plugins (2) I (2170) pluginstore: Load retools web page /plugins/retools I (2170) pluginstore: Loading enabled plugins (3) D (2180) events: Signal(housekeeping.init) I (2180) housekeeping: Executing on CPU core 1 I (2180) housekeeping: reset_reason: cpu0=12, cpu1=12 I (2190) housekeeping: Starting PERIPHERALS... I (2190) peripherals: Initialising OVMS Peripherals... I (2200) peripherals: TCP/IP Adaptor I (2200) peripherals: ESP32 system I (2210) peripherals: SPI bus I (2210) peripherals: MAX7317 I/O Expander I (2220) peripherals: ESP32 CAN I (2220) peripherals: ESP32 WIFI I (2230) peripherals: ESP32 ADC I (2230) peripherals: MCP2515 CAN 1/2 I (2230) mcp2515: can2: SetPowerMode off I (2320) peripherals: MCP2515 CAN 2/2 I (2320) mcp2515: can3: SetPowerMode off I (2400) peripherals: SD CARD I (2400) peripherals: CELLULAR MODEM I (2400) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (2410) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 V (2420) cellular: Starting modem task I (2420) uart: queue free spaces: 50 I (2420) ext12v: Powering off external 12V devices I (2430) housekeeping: Auto init max7317 (free: 160656 bytes) I (2440) housekeeping: Auto init ext12v (free: 160656 bytes) I (2440) housekeeping: Auto init dbc (free: 160656 bytes) I (2450) housekeeping: Auto init wifi (free: 160656 bytes) I (2450) housekeeping: Auto init modem (free: 160656 bytes) I (2460) housekeeping: Auto init Pollers (free: 160656 bytes) I (2460) cellular: Set modem driver to 'auto' I (2470) housekeeping: Auto init vehicle (free: 160656 bytes) I (2470) cellular: State: Enter PowerOffOn state I (2480) v-none: Generic NONE vehicle module I (2480) cellular-modem-auto: Power Cycle I (2490) housekeeping: Auto init obd2ecu (free: 148856 bytes) I (2490) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms I (2500) housekeeping: Auto init server v2 (free: 148856 bytes) I (2510) housekeeping: Auto init server v3 (free: 148856 bytes) I (2520) housekeeping: Auto init javascript (free: 148856 bytes) I (2530) housekeeping: Auto init done (free: 148816 bytes) I (2530) housekeeping: Starting USB console... I (2540) uart: queue free spaces: 100 D (2550) events: Signal(egpio.output.1.low) D (2550) events: Signal(power.cellular.on) D (2550) events: Signal(system.modem.stop) D (2560) events: Signal(vehicle.type.set) D (2560) events: Signal(egpio.output.0.low) D (2560) events: Signal(egpio.output.0.high) D (2570) events: Signal(system.start) I (2570) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console I (2580) ovms-duktape: Duktape: Creating heap (size: 524288 bytes) Firmware: 3.3.004-427-g0dfb100b/factory/edge Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3 OVMS> I (2720) ovms-duktape: Duktape: Initialising module system I (2890) pluginstore: Loading enabled plugins (1) OVMS> D (4190) events: Signal(vehicle.aux.12v.low) OVMS> D (5010) events: Signal(egpio.output.0.low) OVMS> I (7190) sdcard: SD CARD has been inserted I (7230) sdcard: mount done D (7230) events: Signal(sd.insert) OVMS> D (9190) events: Signal(sd.mounted) I (9210) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS> D (10010) events: Signal(egpio.output.0.high) D (10210) events: Signal(egpio.output.0.low) D (10210) cellular: State timeout PowerOffOn => PoweringOn I (10210) cellular: State: Enter PoweringOn state I (10210) cellular-modem-auto: Power Cycle I (10210) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (10210) events: Signal(system.modem.poweringon) D (10210) events: Signal(egpio.output.0.high) OVMS> D (12710) events: Signal(egpio.output.0.low) OVMS> D (17710) events: Signal(egpio.output.0.high) D (17910) events: Signal(egpio.output.0.low) D (17910) cellular: tx-cmd: AT D (17910) cellular: tx-cmd: AT D (17910) cellular: tx-cmd: AT D (17910) cellular: tx-cmd: AT OVMS> I (19940) cellular: State: Enter Identify state OVMS> D (20190) cellular: tx-cmd: AT+CGMM I (20200) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (20200) cellular: Remove old 'auto' modem driver I (20200) cellular: Set modem driver to 'SIM7600' I (20200) cellular: State: Enter PoweredOn state D (20200) events: Signal(system.modem.installed) D (20200) events: Signal(system.modem.poweredon) OVMS> D (30190) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (30220) cellular: mux-rx-line #0 (2/120): OK D (30220) cellular: mux-rx-line #0 (124/0): AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (30220) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (30220) cellular: mux-rx-line #0 (10/6): +CSQ: 16,0 D (30220) cellular: Signal Quality is: 16 (-81 dBm) D (30220) cellular: mux-rx-line #0 (2/0): OK OVMS> D (32190) cellular: tx-cmd: AT+CGMR;+ICCID D (32200) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (32200) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (32210) cellular: mux-rx-line #0 (2/0): OK OVMS> D (40190) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (40200) cellular: mux-rx-line #0 (2/0): OK I (40200) cellular: State: Enter MuxStart state V (40200) cellular: Starting MUX D (40200) events: Signal(system.modem.muxstart) OVMS> D (41190) cellular: State transition MuxStart => NetWait I (41190) cellular: State: Enter NetWait state V (41190) cellular: Starting NMEA D (41190) cellular: mux-tx #1: AT+CGPS=0 D (41190) events: Signal(system.modem.netwait) OVMS> D (43190) cellular: mux-tx #1: AT+CGPSNMEA=258 D (43210) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (43230) cellular: mux-tx #1: AT+CGPS=1,1 D (43230) events: Signal(system.modem.gpsstart) D (43230) cellular: mux-rx-line #1 (2/0): OK D (43230) cellular: mux-rx-line #1 (2/0): OK D (43230) cellular: mux-rx-line #1 (2/0): OK D (43240) cellular: mux-rx-line #1 (2/0): OK OVMS> D (50050) cellular: mux-rx-line #3 (10/0): +CSQ: 20,0 D (50050) cellular: Signal Quality is: 20 (-73 dBm) OVMS> D (51190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (51210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 I (51210) cellular: Network Registration status: RegisteredRoaming D (51210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (51210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (51210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,17:57:09+04" D (51210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,0 D (51210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (52050) cellular: mux-rx-line #3 (10/0): +CSQ: 20,7 D (52190) cellular: mux-tx #3: AT+CPSI? D (52190) cellular: State transition NetWait => NetStart I (52190) cellular: State: Enter NetStart state D (52190) events: Signal(system.modem.netstart) D (52200) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-74,0,0-0 I (52210) cellular: Network Mode: GSM,Online D (52210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (53190) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (53240) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (53240) cellular: PPP Connection is ready to start OVMS> D (54050) cellular: mux-rx-line #3 (10/0): +CSQ: 20,4 D (54190) cellular: State transition NetStart => NetMode I (54190) cellular: State: Enter NetMode state V (54190) cellular: Launching PPP V (54190) cellular: Starting PPP I (54190) gsm-ppp: Initialising... D (54190) events: Signal(system.modem.netmode) W (54220) cellular: UART frame error W (54260) cellular: UART frame error W (54260) cellular: UART frame error I (54320) gsm-ppp: StatusCallBack: None I (54320) gsm-ppp: status_cb: Connected I (54320) gsm-ppp: our_ipaddr = 10.170.195.13 I (54320) gsm-ppp: his_ipaddr = 10.64.64.64 I (54320) gsm-ppp: netmask = 255.255.255.255 I (54320) gsm-ppp: DNS#0 = 8.8.8.8 I (54320) gsm-ppp: DNS#1 = 8.8.4.4 I (54320) gsm-ppp: our6_ipaddr = :: D (54320) events: Signal(network.interface.up) D (54330) events: Signal(system.modem.gotip) D (54330) netmanager: Saved DNS#0 8.8.8.8 D (54330) netmanager: Saved DNS#1 8.8.4.4 D (54330) netmanager: Saved DNS#2 0.0.0.0 I (54330) netmanager: Interface priority is pp1 (10.170.195.13/255.255.255.255 gateway 10.64.64.64) I (54330) netmanager: Set DNS#2 0.0.0.0 I (54330) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (54330) events: Signal(network.modem.up) D (54330) events: Signal(network.up) D (54340) events: Signal(network.interface.change) W (54340) cellular: UART frame error D (54340) netmanager: MongooseTask starting D (54360) events: Signal(network.mgr.init) I (54380) ssh: Launching SSH Server OVMS> D (59000) cellular: mux-rx-line #3 (9/0): +CGREG: 3 D (59060) cellular: mux-rx-line #3 (10/0): NO CARRIER D (59060) cellular: mux-rx-line #3 (19/0): +PPPD: DISCONNECTED I (59060) cellular: PPP Connection disconnected W (59190) cellular: Lost network connection (+PPP disconnect in NetMode) D (59190) cellular: State transition NetMode => NetLoss I (59190) cellular: State: Enter NetLoss state D (59190) cellular: mux-tx #3: AT+CGATT=0 V (59190) cellular: Stopping PPP I (59190) gsm-ppp: Shutting down (hard)... I (59190) gsm-ppp: PPP is shutdown W (59190) cellular: UART frame error D (59190) events: Signal(system.modem.netloss) D (59200) events: Signal(system.modem.down) I (59200) netmanager: MODEM down (with WIFI client down): network connectivity has been lost D (59200) events: Signal(network.modem.down) D (59200) events: Signal(network.down) D (59200) events: Signal(network.interface.change) D (59410) netmanager: MongooseTask stopping D (59410) events: Signal(network.mgr.stop) I (59410) ssh: Stopping SSH Server OVMS> I (65040) gsm-ppp: StatusCallBack: User Interrupt OVMS> D (69190) cellular: State timeout NetLoss => NetWait I (69190) cellular: State: Enter NetWait state D (69190) events: Signal(system.modem.netwait) OVMS> D (73190) cellular: State transition NetWait => NetStart I (73190) cellular: State: Enter NetStart state D (73190) events: Signal(system.modem.netstart) OVMS> D (74190) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (74240) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (74240) cellular: PPP Connection is ready to start OVMS> D (75190) cellular: State transition NetStart => NetMode I (75190) cellular: State: Enter NetMode state V (75190) cellular: Starting PPP I (75190) gsm-ppp: Initialising... D (75190) events: Signal(system.modem.netmode) W (75230) cellular: UART frame error W (75240) cellular: UART frame error OVMS> W (76280) cellular: UART frame error OVMS> D (88090) cellular: mux-rx-line #3 (11/0): +CSQ: 99,99 D (88090) cellular: Signal Quality is: 99 (0 dBm) OVMS> D (103710) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 D (103710) cellular: Signal Quality is: 19 (-75 dBm) D (103710) cellular: mux-rx-line #3 (8/13): +CREG: 2 I (103710) cellular: Network Registration status: Searching D (103710) cellular: mux-rx-line #3 (9/0): +CGREG: 2 OVMS> W (104190) cellular: Lost network connection (NetworkRegistration in NetMode) D (104190) cellular: State transition NetMode => NetLoss I (104190) cellular: State: Enter NetLoss state D (104190) cellular: mux-tx #3: AT+CGATT=0 V (104190) cellular: Stopping PPP I (104190) gsm-ppp: Shutting down (hard)... I (104190) gsm-ppp: PPP is shutdown D (104190) events: Signal(system.modem.netloss) D (104200) events: Signal(system.modem.down) OVMS> D (114190) cellular: State timeout NetLoss => NetWait I (114190) cellular: State: Enter NetWait state D (114190) events: Signal(system.modem.netwait) OVMS> I (116190) gsm-ppp: StatusCallBack: User Interrupt OVMS> I (122200) housekeeping: System considered stable (RAM: 8b=102716-117708 32b=12128 SPI=3284180-3285320) OVMS> D (124190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (124210) cellular: mux-rx-line #3 (10/84): +CREG: 1,2 D (124210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,2 D (124210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (124210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,17:58:22+04" D (124210) cellular: mux-rx-line #3 (11/6): +CSQ: 99,99 D (124210) cellular: Signal Quality is: 99 (0 dBm) D (124210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (125190) cellular: mux-tx #3: AT+CPSI? D (125200) cellular: mux-rx-line #3 (24/0): +CPSI: NO SERVICE,Online D (125200) cellular: mux-rx-line #3 (2/0): OK OVMS> D (126190) cellular: mux-tx #3: AT+COPS? D (126200) cellular: mux-rx-line #3 (8/6): +COPS: 0 D (126200) cellular: mux-rx-line #3 (2/0): OK OVMS> D (132510) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 D (132510) cellular: Signal Quality is: 19 (-75 dBm) OVMS> D (134190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (134210) cellular: mux-rx-line #3 (10/84): +CREG: 1,2 D (134210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,2 D (134210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (134210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,17:58:32+04" D (134210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (134210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (135190) cellular: mux-tx #3: AT+CPSI? D (135200) cellular: mux-rx-line #3 (24/0): +CPSI: NO SERVICE,Online D (135200) cellular: mux-rx-line #3 (2/0): OK OVMS> D (136190) cellular: mux-tx #3: AT+COPS? D (136200) cellular: mux-rx-line #3 (8/6): +COPS: 0 D (136200) cellular: mux-rx-line #3 (2/0): OK OVMS> D (136520) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 D (136520) cellular: mux-rx-line #3 (8/0): +CREG: 5 I (136520) cellular: Network Registration status: RegisteredRoaming OVMS> D (137190) cellular: State transition NetWait => NetStart I (137190) cellular: State: Enter NetStart state D (137190) events: Signal(system.modem.netstart) OVMS> D (138190) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (138250) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (138250) cellular: PPP Connection is ready to start OVMS> D (139190) cellular: State transition NetStart => NetMode I (139190) cellular: State: Enter NetMode state V (139190) cellular: Starting PPP I (139190) gsm-ppp: Initialising... D (139190) events: Signal(system.modem.netmode) D (139330) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 OVMS> D (141680) cellular: mux-rx-line #3 (10/0): +CSQ: 19,3 D (141680) cellular: mux-rx-line #3 (9/0): +CGREG: 5 OVMS> I (142270) gsm-ppp: StatusCallBack: None I (142270) gsm-ppp: status_cb: Connected I (142270) gsm-ppp: our_ipaddr = 10.170.195.13 I (142270) gsm-ppp: his_ipaddr = 10.64.64.64 I (142270) gsm-ppp: netmask = 255.255.255.255 I (142270) gsm-ppp: DNS#0 = 8.8.8.8 I (142270) gsm-ppp: DNS#1 = 8.8.4.4 I (142270) gsm-ppp: our6_ipaddr = :: D (142270) events: Signal(network.interface.up) D (142270) events: Signal(system.modem.gotip) D (142270) netmanager: Saved DNS#0 8.8.8.8 D (142270) netmanager: Saved DNS#1 8.8.4.4 D (142270) netmanager: Saved DNS#2 0.0.0.0 I (142270) netmanager: Set DNS#2 0.0.0.0 I (142270) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (142280) events: Signal(network.modem.up) D (142280) events: Signal(network.up) D (142280) events: Signal(network.interface.change) D (142290) netmanager: MongooseTask starting D (142290) events: Signal(network.mgr.init) I (142310) ssh: Launching SSH Server OVMS> D (146130) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 OVMS> W (161720) cellular: UART frame error W (161720) cellular: UART frame error OVMS> D (164140) cellular: mux-rx-line #3 (10/0): +CSQ: 19,0 OVMS> D (167130) cellular: mux-rx-line #3 (11/0): +CSQ: 19,99 OVMS> D (169190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (169210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (169210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (169210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (169210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,17:59:07+04" D (169210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (169210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (170190) cellular: mux-tx #3: AT+CPSI? D (170210) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-74,0,33-33 D (170210) cellular: mux-rx-line #3 (2/0): OK OVMS> D (171190) cellular: mux-tx #3: AT+COPS? D (171210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (171210) cellular: Network Provider is: vodafone.de Hologram D (171210) cellular: mux-rx-line #3 (2/0): OK OVMS> enable Password: Secure mode OVMS# module check factory fault leaks memory reset sleep summary tasks trigger OVMS# module tD (199190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (199210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (199210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (199210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (199210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,17:59:37+04" D (199210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (199220) cellular: mux-rx-line #3 (2/0): OK OVMS# module trigger ?D (200190) cellular: mux-tx #3: AT+CPSI? D (200210) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-76,0,31-31 D (200210) cellular: mux-rx-line #3 (2/0): OK OVMS# module trigger ? Usage: module trigger twdt twdt Trigger task watchdog timeout OVMS# D (201190) cellular: mux-tx #3: AT+COPS? D (201210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (201210) cellular: mux-rx-line #3 (2/0): OK OVMS# module trigger ? ? Usage: module check|factory|fault|leaks|memory|reset|sleep|summary|tasks|trigger check Check heap integrity factory MODULE FACTORY framework fault Abort fault the module leaks Show module memory changes memory Show module memory usage reset Reset module sleep Enter sleep mode summary Show module summary tasks Show module task usage trigger Trigger framework OVMS# module ?ยด fauD (229190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ OVMS# module ?fauD (229210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (229210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (229210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (229210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:00:07+04" D (229210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (229210) cellular: mux-rx-line #3 (2/0): OK OVMS# module ?fauD (230190) cellular: mux-tx #3: AT+CPSI? D (230200) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-79,0,28-28 D (230210) cellular: mux-rx-line #3 (2/0): OK OVMS# module ?fau faD (231190) cellular: mux-tx #3: AT+COPS? D (231200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (231200) cellular: mux-rx-line #3 (2/0): OK OVMS# module fa factory fault OVMS# module fault location status Currently at 0.000000,0.000000 (without GPS lock) There is 1 location defined No active locations OVMS# D (259190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (259210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (259210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (259210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (259210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:00:37+04" D (259210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (259210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (260190) cellular: mux-tx #3: AT+CPSI? D (260210) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-78,0,29-29 D (260210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (261190) cellular: mux-tx #3: AT+COPS? D (261200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (261210) cellular: mux-rx-line #3 (2/0): OK OVMS# cellular status MODEM Status Model: SIM7600 Network Registration: RegisteredRoaming Provider: vodafone.de Hologram Signal: -75 dBm Mode: GSM,Online State: NetMode Mux: Status up PPP: Connected on channel: #2 GPS: Connected on channel: #1 OVMS# D (289190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (289210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (289210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (289210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (289210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:01:07+04" D (289210) cellular: mux-rx-line #3 (11/6): +CSQ: 19,99 D (289210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (290190) cellular: mux-tx #3: AT+CPSI? D (290200) cellular: mux-rx-line #3 (60/0): +CPSI: GSM,Online,262-02,0x011a,17601,3 EGSM 900,-74,0,33-33 D (290210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (291190) cellular: mux-tx #3: AT+COPS? D (291200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (291200) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-nmea Logging level for gsm-nmea set to verbose OVMS# I (302210) housekeeping: 2025-03-29 18:01:20 CET (RAM: 8b=101996-104604 32b=12128 SPI=3274060-3278676) OVMS# D (305170) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99 D (305170) cellular: Signal Quality is: 22 (-69 dBm) OVMS# D (319190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (319210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (319210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (319210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (319210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:01:37+04" D (319210) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (319210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (320190) cellular: mux-tx #3: AT+CPSI? D (320210) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-69,0,38-38 D (320210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (321190) cellular: mux-tx #3: AT+COPS? D (321210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (321210) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-nmeal con lis log log (readable writeable) file.enable: yes file.keepdays: 7 file.maxsize: 1024 file.path: /sd/logs/log level: info level.canlog-monitor: verbose level.cellular: verbose level.esp32wifi: warn level.events: debug level.gsm-mux: warn level.gsm-nmea: warn level.gsm-ppp: info level.location: verbose level.netmanager: verbose level.ovms-duktape: info level.ovms-server-v2: info level.pushover: warn level.script: debug level.simcom: warn level.time: warn level.v-vweup: debug level.vehicle: debug level.vehicle-isotp: info level.vehicle-poll: verbose level.webcommand: info level.webserver: warn level.websocket: warn poller.timers: yes OVMS# con lis loglog level verbose gsm-nmeacon lis log OVMS# con set lD (349190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (349210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (349210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (349210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (349210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:02:07+04" D (349210) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (349210) cellular: mux-rx-line #3 (2/0): OK OVMS# con set log D (350190) cellular: mux-tx #3: AT+CPSI? D (350200) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-69,0,38-38 D (350210) cellular: mux-rx-line #3 (2/0): OK OVMS# con set log le level level.canlog-monitor level.cellular level.esp32wifi level.events level.gsm-mux level.gsm-nmea level.gsm-ppp level.location level.netmanager level.ovms-duktape level.ovms-server-v2 level.pushover level.script level.simcom level.time level.v-vweup level.vehicle level.vehicle-isotp level.vehicle-poll ... OVMS# con set log levelD (351190) cellular: mux-tx #3: AT+COPS? D (351200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (351210) cellular: mux-rx-line #3 (2/0): OK OVMS# con set log level.gs level.gsm-mux level.gsm-nmea level.gsm-ppp OVMS# con set log level.gsm- level.gsm-mux level.gsm-nmea level.gsm-ppp OVMS# con set log level.gsm-nmea verbot se Parameter has been set. OVMS# D (358350) events: Signal(config.changed) I (358370) command: CloseLogfile: file logging stopped I (358380) command: OpenLogfile: now logging to file '/sd/logs/log' OVMS# OVMS# cellular status MODEM Status Model: SIM7600 Network Registration: RegisteredRoaming Provider: vodafone.de Hologram Signal: -69 dBm Mode: GSM,Online State: NetMode Mux: Status up PPP: Connected on channel: #2 GPS: Connected on channel: #1 OVMS# location D (379190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (379210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (379210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (379210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 OVMS# location D (379210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:02:37+04" D (379210) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (379210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (380190) cellular: mux-tx #3: AT+CPSI? D (380210) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-68,0,39-39 D (380210) cellular: mux-rx-line #3 (2/0): OK OVMS# me li D (381190) cellular: mux-tx #3: AT+COPS? D (381200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (381210) cellular: mux-rx-line #3 (2/0): OK OVMS# me li v.p. v.p.acceleration v.p.altitude v.p.direction v.p.gpshdop v.p.gpslock v.p.gpsmode v.p.gpsspeed v.p.gpssq v.p.gpstime v.p.latitude v.p.location v.p.longitude v.p.odometer v.p.satcount v.p.speed v.p.trip v.p.valet.distance v.p.valet.latitude v.p.valet.longitude OVMS# OVMS# D (409190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (409210) cellular: mux-rx-line #3 (10/84): +CREG: 1,5 D (409210) cellular: mux-rx-line #3 (11/69): +CGREG: 1,5 D (409210) cellular: mux-rx-line #3 (11/54): +CEREG: 1,4 D (409210) cellular: mux-rx-line #3 (29/21): +CCLK: "25/03/29,18:03:07+04" D (409210) cellular: mux-rx-line #3 (11/6): +CSQ: 22,99 D (409210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (410190) cellular: mux-tx #3: AT+CPSI? D (410200) cellular: mux-rx-line #3 (59/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-68,0,39-39 D (410210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (411190) cellular: mux-tx #3: AT+COPS? D (411200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 D (411200) cellular: mux-rx-line #3 (2/0): OK OVMS# power cellular off Power mode of cellular is now off OVMS# D (423400) events: Signal(power.cellular.off) I (423410) cellular: State: Enter PoweringOff state V (423410) cellular: Stopping PPP I (423410) gsm-ppp: Shutting down (hard)... I (423410) gsm-ppp: StatusCallBack: User Interrupt I (423410) gsm-ppp: PPP is shutdown D (423410) events: Signal(system.modem.down) V (423410) cellular: Stopping NMEA D (423410) cellular: mux-tx #1: AT+CGPSNMEA=0 I (423410) netmanager: MODEM down (with WIFI client down): network connectivity has been lost D (423420) events: Signal(network.modem.down) D (423420) events: Signal(network.down) D (423420) events: Signal(network.interface.change) D (423430) cellular: mux-tx #1: AT+CGPSINFOCFG=0 D (423530) cellular: mux-tx #1: AT+CGPS=0 I (423530) gsm-nmea: Shutdown (direct) D (423530) events: Signal(system.modem.gpsstop) I (423530) Simcom: Power Off - 3000 ms D (423530) events: Signal(system.modem.stop) D (423530) events: Signal(egpio.output.3.low) D (423540) events: Signal(egpio.output.0.high) D (423560) netmanager: MongooseTask stopping D (423560) events: Signal(network.mgr.stop) I (423560) ssh: Stopping SSH Server OVMS# D (426530) events: Signal(egpio.output.0.low) OVMS# D (443190) cellular: State timeout PoweringOff => CheckPowerOff I (443190) cellular: State: Enter CheckPowerOff state OVMS# D (446190) cellular: tx-cmd: AT OVMS# D (449190) cellular: tx-cmd: AT OVMS# D (452190) cellular: tx-cmd: AT OVMS# D (455190) cellular: tx-cmd: AT OVMS# D (458190) cellular: tx-cmd: AT D (458190) cellular: State timeout CheckPowerOff => PoweredOff I (458190) cellular: State: Enter PoweredOff state V (458190) cellular: Stopping MUX D (458190) events: Signal(system.modem.poweredoff) OVMS# con lis auto auto (readable writeable) dbc: no egpio: no ext12v: no init: yes modem: yes obd2ecu: ota: no scripting: yes server.v2: no server.v3: no vehicle.type: NONE wifi.mode: off wifi.ssid.ap: Test1 wifi.ssid.client: OVMS# con lis auto cel mo modem module OVMS# con lis modem modem (readable writeable) apn: hologram apn.password: apn.user: enable.gps: yes enable.gpstime: yes enable.net: yes enable.sms: yes pincode: OVMS# con power ^c cellular l on Power mode of cellular is now on OVMS# D (523600) events: Signal(power.cellular.on) I (523610) cellular: Set modem driver to 'auto' I (523610) cellular: State: Enter PowerOffOn state V (523610) cellular: Stopping PPP I (523610) gsm-ppp: Shutting down (hard)... I (523610) gsm-ppp: StatusCallBack: User Interrupt I (523610) gsm-ppp: PPP is shutdown D (523610) events: Signal(system.modem.down) I (523610) cellular-modem-auto: Power Cycle I (523610) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (523610) events: Signal(system.modem.stop) D (523620) events: Signal(egpio.output.0.high) OVMS# D (526110) events: Signal(egpio.output.0.low) OVMS# D (531110) events: Signal(egpio.output.0.high) D (531310) events: Signal(egpio.output.0.low) D (531310) cellular: State timeout PowerOffOn => PoweringOn I (531310) cellular: State: Enter PoweringOn state I (531310) cellular-modem-auto: Power Cycle I (531310) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms D (531310) events: Signal(system.modem.poweringon) D (531310) events: Signal(egpio.output.0.high) OVMS# D (533810) events: Signal(egpio.output.0.low) OVMS# D (538810) events: Signal(egpio.output.0.high) D (539010) events: Signal(egpio.output.0.low) D (539010) cellular: tx-cmd: AT D (539010) cellular: tx-cmd: AT D (539010) cellular: tx-cmd: AT D (539010) cellular: tx-cmd: AT OVMS# I (540980) cellular: State: Enter Identify state OVMS# D (541190) cellular: tx-cmd: AT+CGMM I (541200) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600 D (541200) cellular: Remove old 'auto' modem driver I (541200) cellular: Set modem driver to 'SIM7600' I (541200) cellular: State: Enter PoweredOn state D (541200) events: Signal(system.modem.installed) D (541200) events: Signal(system.modem.poweredon) OVMS# D (551190) cellular: tx-cmd: AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (551220) cellular: mux-rx-line #0 (2/120): OK D (551220) cellular: mux-rx-line #0 (124/0): AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0 D (551230) cellular: mux-rx-line #0 (12/20): +CPIN: READY D (551230) cellular: mux-rx-line #0 (10/6): +CSQ: 22,0 D (551230) cellular: Signal Quality is: 22 (-69 dBm) D (551230) cellular: mux-rx-line #0 (2/0): OK OVMS# D (553190) cellular: tx-cmd: AT+CGMR;+ICCID D (553200) cellular: mux-rx-line #0 (26/37): +CGMR: LE20B03SIM7600M21-A D (553200) cellular: mux-rx-line #0 (27/6): +ICCID: 8944500408175816389 D (553200) cellular: mux-rx-line #0 (2/0): OK OVMS# D (561190) cellular: tx-cmd: AT+CMUX=0;+CATR=6 D (561200) cellular: mux-rx-line #0 (2/0): OK I (561200) cellular: State: Enter MuxStart state V (561200) cellular: Starting MUX D (561200) events: Signal(system.modem.muxstart) OVMS# D (562190) cellular: State transition MuxStart => NetWait I (562190) cellular: State: Enter NetWait state V (562190) cellular: Starting NMEA I (562190) gsm-nmea: Startup D (562190) cellular: mux-tx #1: AT+CGPS=0 D (562190) events: Signal(system.modem.netwait) OVMS# D (564190) cellular: mux-tx #1: AT+CGPSNMEA=258 D (564210) cellular: mux-tx #1: AT+CGPSINFOCFG=5,258 D (564230) cellular: mux-tx #1: AT+CGPS=1,1 D (564230) events: Signal(system.modem.gpsstart) D (564230) cellular: mux-rx-line #1 (2/0): OK D (564230) cellular: mux-rx-line #1 (2/0): OK D (564230) cellular: mux-rx-line #1 (2/0): OK D (564240) cellular: mux-rx-line #1 (2/0): OK OVMS# D (572190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (572210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 I (572210) cellular: Network Registration status: RegisteredRoaming D (572210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,2 D (572210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (572210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:05:50+04" D (572210) cellular: mux-rx-line #3 (10/6): +CSQ: 22,0 D (572210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (573190) cellular: mux-tx #3: AT+CPSI? D (573190) cellular: State transition NetWait => NetStart I (573190) cellular: State: Enter NetStart state D (573190) events: Signal(system.modem.netstart) D (573200) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-70,0,0-0 D (573210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (574190) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1 D (574250) cellular: mux-rx-line #2 (14/0): CONNECT 115200 I (574250) cellular: PPP Connection is ready to start OVMS# D (575190) cellular: State transition NetStart => NetMode I (575190) cellular: State: Enter NetMode state V (575190) cellular: Starting PPP I (575190) gsm-ppp: Initialising... D (575190) events: Signal(system.modem.netmode) OVMS# W (576290) cellular: UART frame error OVMS# D (578110) cellular: mux-rx-line #3 (9/0): +CGREG: 5 OVMS# D (578430) cellular: mux-rx-line #3 (26/0): +CTZV: 4,25/03/29,17:05:57 I (578610) gsm-ppp: StatusCallBack: None I (578610) gsm-ppp: status_cb: Connected I (578610) gsm-ppp: our_ipaddr = 10.170.195.13 I (578620) gsm-ppp: his_ipaddr = 10.64.64.64 I (578620) gsm-ppp: netmask = 255.255.255.255 I (578620) gsm-ppp: DNS#0 = 8.8.8.8 I (578620) gsm-ppp: DNS#1 = 8.8.4.4 I (578620) gsm-ppp: our6_ipaddr = :: D (578620) events: Signal(network.interface.up) D (578620) events: Signal(system.modem.gotip) D (578620) netmanager: Saved DNS#0 8.8.8.8 D (578620) netmanager: Saved DNS#1 8.8.4.4 D (578620) netmanager: Saved DNS#2 0.0.0.0 I (578620) netmanager: Set DNS#2 0.0.0.0 I (578620) netmanager: MODEM up (with WIFI client down): starting network with MODEM D (578620) events: Signal(network.modem.up) D (578630) events: Signal(network.up) D (578630) events: Signal(network.interface.change) D (578640) netmanager: MongooseTask starting D (578640) events: Signal(network.mgr.init) I (578660) ssh: Launching SSH Server OVMS# D (580350) cellular: mux-rx-line #3 (10/0): +CSQ: 22,4 OVMS# D (583350) cellular: mux-rx-line #3 (11/0): +CSQ: 22,99 OVMS# D (586350) cellular: mux-rx-line #3 (11/0): +CSQ: 20,99 D (586350) cellular: Signal Quality is: 20 (-73 dBm) D (586410) cellular: mux-rx-line #3 (10/0): +CSQ: 20,4 OVMS# D (588360) cellular: mux-rx-line #3 (10/0): +CSQ: 21,4 D (588360) cellular: Signal Quality is: 21 (-71 dBm) OVMS# D (590360) cellular: mux-rx-line #3 (10/0): +CSQ: 21,0 OVMS# I (602210) housekeeping: 2025-03-29 18:06:20 CET (RAM: 8b=100888-103468 32b=12128 SPI=3274036-3278592) OVMS# D (605190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (605210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (605210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (605210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,4 D (605210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:06:23+04" D (605210) cellular: mux-rx-line #3 (10/6): +CSQ: 21,0 D (605210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (606190) cellular: mux-tx #3: AT+CPSI? D (606200) cellular: mux-rx-line #3 (57/0): +CPSI: GSM,Online,262-02,0x011a,9302,2 EGSM 900,-73,0,0-0 D (606210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (607190) cellular: mux-tx #3: AT+COPS? D (607200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",0 I (607210) cellular: Network Provider is: vodafone.de Hologram D (607210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (622380) cellular: mux-rx-line #3 (10/0): +CSQ: 21,7 D (622380) cellular: mux-rx-line #3 (10/0): +CSQ: 21,0 OVMS# D (626390) cellular: mux-rx-line #3 (10/0): +CSQ: 21,4 OVMS# D (631400) cellular: mux-rx-line #3 (10/0): +CSQ: 20,4 D (631400) cellular: Signal Quality is: 20 (-73 dBm) OVMS# D (635190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (635210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (635210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (635210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (635210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:06:53+04" D (635210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (635210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (636190) cellular: mux-tx #3: AT+CPSI? D (636330) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-119,-1046,-739,11 I (636330) cellular: Network Mode: LTE,Online D (636330) cellular: mux-rx-line #3 (2/0): OK OVMS# D (637190) cellular: mux-tx #3: AT+COPS? D (637210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (637210) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-D (665190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ D (665210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (665210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (665210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (665210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:07:23+04" D (665210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (665210) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-muD (666190) cellular: mux-tx #3: AT+CPSI? D (666210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-128,-1040,-710,10 D (666210) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-muD (667190) cellular: mux-tx #3: AT+COPS? D (667210) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (667210) cellular: mux-rx-line #3 (2/0): OK OVMS# log level verbose gsm-mux Logging level for gsm-mux set to verbose OVMS# V (669230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (669230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (674230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (674230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (679230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (679230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (684230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (684230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (689230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (689230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (694230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (694230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (695190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (695210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (695210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (695210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (695210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (695210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:07:53+04" D (695210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (695210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (696190) cellular: mux-tx #3: AT+CPSI? V (696210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (696210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-122,-1041,-727,11 V (696210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (696210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (697190) cellular: mux-tx #3: AT+COPS? V (697200) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (697200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (697210) cellular: mux-rx-line #3 (2/0): OK OVMS# V (699230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (699230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (704230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (704230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (709230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (709230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (714230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (714230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (719230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (719230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (724230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (724230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (725190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (725210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (725210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (725210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (725210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (725210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:08:23+04" D (725210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (725210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (726190) cellular: mux-tx #3: AT+CPSI? V (726210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (726210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-139,-1046,-710,10 V (726210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (726210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (727190) cellular: mux-tx #3: AT+COPS? V (727200) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (727200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (727210) cellular: mux-rx-line #3 (2/0): OK OVMS# V (729230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (729230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (734230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (734230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (739230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (739230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (744230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (744230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (749230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (749230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (754230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (754230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (755190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (755210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (755210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (755210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (755210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (755210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:08:53+04" D (755210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (755210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (756190) cellular: mux-tx #3: AT+CPSI? V (756210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (756210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-114,-1044,-733,11 V (756210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (756210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (757190) cellular: mux-tx #3: AT+COPS? V (757200) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (757200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (757210) cellular: mux-rx-line #3 (2/0): OK OVMS# V (759230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (759230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (764230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (764230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (769230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (769230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (774230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (774230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (779230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (779230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (784230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (784230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (785190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (785210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (785210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (785210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (785210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (785210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:09:23+04" D (785210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (785210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (786190) cellular: mux-tx #3: AT+CPSI? V (786210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (786210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-143,-1040,-697,11 V (786210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (786210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (787190) cellular: mux-tx #3: AT+COPS? V (787200) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (787200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (787210) cellular: mux-rx-line #3 (2/0): OK OVMS# V (789230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (789230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (799230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (799230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (804230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (804230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (809230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (809230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# V (814230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (814230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82) OVMS# D (815190) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ V (815210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=75, LEN=103) D (815210) cellular: mux-rx-line #3 (10/83): +CREG: 1,5 D (815210) cellular: mux-rx-line #3 (11/68): +CGREG: 1,5 D (815210) cellular: mux-rx-line #3 (11/53): +CEREG: 1,5 D (815210) cellular: mux-rx-line #3 (29/20): +CCLK: "25/03/29,18:09:53+04" D (815210) cellular: mux-rx-line #3 (10/6): +CSQ: 20,4 D (815210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (816190) cellular: mux-tx #3: AT+CPSI? V (816210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c2, LEN=94) D (816210) cellular: mux-rx-line #3 (84/0): +CPSI: LTE,Online,262-02,0xB092,13250581,155,EUTRAN-BAND1,100,5,5,-117,-1048,-728,11 V (816210) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=0f, LEN=12) D (816210) cellular: mux-rx-line #3 (2/0): OK OVMS# D (817190) cellular: mux-tx #3: AT+COPS? V (817200) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=87, LEN=51) D (817200) cellular: mux-rx-line #3 (35/6): +COPS: 0,0,"vodafone.de Hologram",7 D (817210) cellular: mux-rx-line #3 (2/0): OK OVMS# V (819230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78) V (819230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
