I (3978624) gsm-ppp: StatusCallBack: None I (3978624) gsm-ppp: status_cb: Connected I (3978624) gsm-ppp: our_ipaddr = 10.170.146.142 I (3978624) gsm-ppp: his_ipaddr = 10.64.64.64 I (3978624) gsm-ppp: netmask = 255.255.255.255 I (3978624) gsm-ppp: our6_ipaddr = :: I (3978624) netmanager: Set DNS#0 9.9.9.9 I (3978624) netmanager: Set DNS#1 8.8.8.8 I (3978634) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (3978634) time: Starting SNTP client I (3978644) ovms-mdns: Launching MDNS service I (3978644) ovms-server-v2: Network is up, so attempt network connection I (3978644) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (3978654) ovms-server-v2: Status: Connecting... I (3979764) ovms-server-v2: Connection successful I (3979764) ovms-server-v2: Status: Logging in... I (3979764) ovms-server-v2: Sending server login: MP-C 0 0pL/VZ4GY1zQHbjz+5L9AC MPnqdVPoyCwFqixbYSa4jw== ROADSTER_834 I (3980434) ovms-server-v2: Got server response: MP-S 0 VeFTVbQuj979f5qxubVbwR KyUX/FqGLuFdtxdb8Fbcwg== I (3980434) ovms-server-v2: Server token is VeFTVbQuj979f5qxubVbwR and digest is KyUX/FqGLuFdtxdb8Fbcwg== I (3980434) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (3980434) ovms-server-v2: Shared secret key is VeFTVbQuj979f5qxubVbwR0pL/VZ4GY1zQHbjz+5L9AC (44 bytes) I (3980434) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (3980444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (3980444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,3980,0,0,0,0,0.274725,0,0,0,0,0 I (3980444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR, I (3980574) ovms-server-v2: Incoming Msg: MP-0 Z0 I (4067744) wifi: station: 40:4e:36:8a:44:c0 leave, AID = 1 I (4067744) wifi: n:1 0, o:1 0, ap:1 1, sta:1 0, prof:1 I (4067744) esp32wifi: AP station disconnected: id: 1, MAC: 40:4e:36:8a:44:c0 W (4216444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (4216444) gsm-ppp: Shutting down (soft)... I (4216444) time: Stopping SNTP client I (4216444) gsm-nmea: Shutdown (direct) I (4216454) gsm-mux: Stop MUX I (4216454) simcom: Power Cycle I (4216584) ovms-server-v2: Network is down, so disconnect network connection E (4216584) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4217454) simcom: State: Enter PoweringOn state I (4217454) simcom: Power Cycle I (4225444) simcom: State timeout, transition to 2 I (4225444) simcom: State: Enter PoweringOn state I (4225444) simcom: Power Cycle I (4227964) gsm-ppp: StatusCallBack: User Interrupt I (4227964) gsm-ppp: PPP connection has been closed I (4231104) simcom: State: Enter PoweredOn state I (4250464) simcom: State: Enter MuxStart state I (4250464) gsm-mux: Start MUX I (4250464) gsm-mux: Channel #0 is open I (4250474) gsm-mux: Channel #1 is open I (4250484) gsm-mux: Channel #2 is open I (4250494) gsm-mux: Channel #3 is open I (4250504) gsm-mux: Channel #4 is open I (4251444) simcom: State: Enter NetWait state I (4255444) simcom: State: Enter NetStart state I (4256584) simcom: PPP Connection is ready to start I (4257444) simcom: State: Enter NetMode state I (4257444) gsm-ppp: Initialising... I (4260434) gsm-ppp: StatusCallBack: None I (4260434) gsm-ppp: status_cb: Connected I (4260434) gsm-ppp: our_ipaddr = 10.170.146.142 I (4260434) gsm-ppp: his_ipaddr = 10.64.64.64 I (4260434) gsm-ppp: netmask = 255.255.255.255 I (4260434) gsm-ppp: our6_ipaddr = :: I (4260434) netmanager: Set DNS#0 9.9.9.9 I (4260434) netmanager: Set DNS#1 8.8.8.8 I (4260434) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (4260434) time: Starting SNTP client I (4260444) ovms-mdns: Launching MDNS service I (4260444) ovms-server-v2: Network is up, so attempt network connection I (4260444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4260444) ovms-server-v2: Status: Connecting... I (4261554) ovms-server-v2: Connection successful I (4261554) ovms-server-v2: Status: Logging in... I (4261554) ovms-server-v2: Sending server login: MP-C 0 N9vhIXnqZCKt2grTHGhDkN wOKX/Wxkt1/tT1vsclptLA== ROADSTER_834 I (4262254) ovms-server-v2: Got server response: MP-S 0 5GmR06bElLbahSU7gTkyS5 6Ty0I08CA46bQVUr+V0KxQ== I (4262254) ovms-server-v2: Server token is 5GmR06bElLbahSU7gTkyS5 and digest is 6Ty0I08CA46bQVUr+V0KxQ== I (4262264) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (4262274) ovms-server-v2: Shared secret key is 5GmR06bElLbahSU7gTkyS5N9vhIXnqZCKt2grTHGhDkN (44 bytes) I (4262274) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (4262284) ovms-server-v2: Incoming Msg: MP-0 Z0 I (4581444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (4581444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,4581,0,0,0,0,0.269231,0,0,0,0,0 I (4581444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,10,1,TR,T-Mobile Hologram W (4588444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (4588444) gsm-ppp: Shutting down (soft)... I (4588444) time: Stopping SNTP client I (4588444) gsm-nmea: Shutdown (direct) I (4588454) gsm-mux: Stop MUX I (4588454) simcom: Power Cycle I (4588534) ovms-server-v2: Network is down, so disconnect network connection E (4588534) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4589454) simcom: State: Enter PoweringOn state I (4589454) simcom: Power Cycle I (4597444) simcom: State timeout, transition to 2 I (4597444) simcom: State: Enter PoweringOn state I (4597444) simcom: Power Cycle I (4599964) gsm-ppp: StatusCallBack: User Interrupt I (4599964) gsm-ppp: PPP connection has been closed I (4603104) simcom: State: Enter PoweredOn state I (4622444) simcom: State: Enter MuxStart state I (4622444) gsm-mux: Start MUX I (4622454) gsm-mux: Channel #0 is open I (4622464) gsm-mux: Channel #1 is open I (4622464) gsm-mux: Channel #2 is open I (4622474) gsm-mux: Channel #3 is open I (4622484) gsm-mux: Channel #4 is open I (4623444) simcom: State: Enter NetWait state I (4627444) simcom: State: Enter NetStart state I (4628604) simcom: PPP Connection is ready to start I (4629444) simcom: State: Enter NetMode state I (4629444) gsm-ppp: Initialising... I (4632574) gsm-ppp: StatusCallBack: None I (4632574) gsm-ppp: status_cb: Connected I (4632574) gsm-ppp: our_ipaddr = 10.170.146.142 I (4632574) gsm-ppp: his_ipaddr = 10.64.64.64 I (4632574) gsm-ppp: netmask = 255.255.255.255 I (4632574) gsm-ppp: our6_ipaddr = :: I (4632574) netmanager: Set DNS#0 9.9.9.9 I (4632574) netmanager: Set DNS#1 8.8.8.8 I (4632574) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (4632574) time: Starting SNTP client I (4632584) ovms-mdns: Launching MDNS service I (4632584) ovms-server-v2: Network is up, so attempt network connection I (4632584) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4632584) ovms-server-v2: Status: Connecting... I (4633684) ovms-server-v2: Connection successful I (4633694) ovms-server-v2: Status: Logging in... I (4633694) ovms-server-v2: Sending server login: MP-C 0 7GOEHSkomgOni01U/OVOSh torSkG45005EErB81yP6sA== ROADSTER_834 E (4663444) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4663444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4663444) ovms-server-v2: Status: Connecting... E (4663454) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 W (4673214) ovms-server-v2: Connection failed I (4692444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4692444) ovms-server-v2: Status: Connecting... W (4702214) ovms-server-v2: Connection failed E (4702214) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4721444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4721444) ovms-server-v2: Status: Connecting... W (4731214) ovms-server-v2: Connection failed E (4731214) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4750444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4750444) ovms-server-v2: Status: Connecting... W (4760214) ovms-server-v2: Connection failed E (4760214) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4779444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4779444) ovms-server-v2: Status: Connecting... W (4789224) ovms-server-v2: Connection failed E (4789224) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (4808444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4808444) ovms-server-v2: Status: Connecting... W (4818224) ovms-server-v2: Connection failed E (4818224) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 W (4826444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (4826444) gsm-ppp: Shutting down (soft)... I (4826444) time: Stopping SNTP client I (4826444) gsm-nmea: Shutdown (direct) I (4826454) gsm-mux: Stop MUX I (4826454) simcom: Power Cycle I (4827454) simcom: State: Enter PoweringOn state I (4827454) simcom: Power Cycle I (4835444) simcom: State timeout, transition to 2 I (4835444) simcom: State: Enter PoweringOn state I (4835444) simcom: Power Cycle I (4838444) gsm-ppp: StatusCallBack: User Interrupt I (4838444) gsm-ppp: PPP connection has been closed I (4841064) simcom: State: Enter PoweredOn state I (4860444) simcom: State: Enter MuxStart state I (4860444) gsm-mux: Start MUX I (4860454) gsm-mux: Channel #0 is open I (4860464) gsm-mux: Channel #1 is open I (4860464) gsm-mux: Channel #2 is open I (4860474) gsm-mux: Channel #3 is open I (4860474) gsm-mux: Channel #4 is open I (4861444) simcom: State: Enter NetWait state I (4865444) simcom: State: Enter NetStart state I (4866594) simcom: PPP Connection is ready to start I (4867444) simcom: State: Enter NetMode state I (4867444) gsm-ppp: Initialising... I (4870564) gsm-ppp: StatusCallBack: None I (4870564) gsm-ppp: status_cb: Connected I (4870564) gsm-ppp: our_ipaddr = 10.170.146.142 I (4870564) gsm-ppp: his_ipaddr = 10.64.64.64 I (4870564) gsm-ppp: netmask = 255.255.255.255 I (4870564) gsm-ppp: our6_ipaddr = :: I (4870564) netmanager: Set DNS#0 9.9.9.9 I (4870564) netmanager: Set DNS#1 8.8.8.8 I (4870564) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (4870574) time: Starting SNTP client I (4870584) ovms-mdns: Launching MDNS service I (4870584) ovms-server-v2: Network is up, so attempt network connection I (4870584) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (4870584) ovms-server-v2: Status: Connecting... I (4871804) ovms-server-v2: Connection successful I (4871804) ovms-server-v2: Status: Logging in... I (4871814) ovms-server-v2: Sending server login: MP-C 0 N1g6zy99i4y+n49r2zmAA1 It+mxVvkHk+8GLgcJXIKiQ== ROADSTER_834 I (4872514) ovms-server-v2: Got server response: MP-S 0 4jHHbd/P2D3o42lgEiXXtc Q41htFsP5Xk5lfUaG8lIgA== I (4872514) ovms-server-v2: Server token is 4jHHbd/P2D3o42lgEiXXtc and digest is Q41htFsP5Xk5lfUaG8lIgA== I (4872524) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (4872524) ovms-server-v2: Shared secret key is 4jHHbd/P2D3o42lgEiXXtcN1g6zy99i4y+n49r2zmAA1 (44 bytes) I (4872524) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (4872534) ovms-server-v2: Incoming Msg: MP-0 Z0 W (5168444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (5168444) gsm-ppp: Shutting down (soft)... I (5168444) time: Stopping SNTP client I (5168444) gsm-nmea: Shutdown (direct) I (5168454) gsm-mux: Stop MUX I (5168454) simcom: Power Cycle I (5168534) ovms-server-v2: Network is down, so disconnect network connection E (5168534) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5169454) simcom: State: Enter PoweringOn state I (5169454) simcom: Power Cycle I (5177444) simcom: State timeout, transition to 2 I (5177444) simcom: State: Enter PoweringOn state I (5177444) simcom: Power Cycle I (5179964) gsm-ppp: StatusCallBack: User Interrupt I (5179964) gsm-ppp: PPP connection has been closed I (5183064) simcom: State: Enter PoweredOn state I (5202464) simcom: State: Enter MuxStart state I (5202464) gsm-mux: Start MUX I (5202474) gsm-mux: Channel #0 is open I (5202484) gsm-mux: Channel #1 is open I (5202494) gsm-mux: Channel #2 is open I (5202494) gsm-mux: Channel #3 is open I (5202504) gsm-mux: Channel #4 is open I (5203444) simcom: State: Enter NetWait state I (5207444) simcom: State: Enter NetStart state I (5208514) simcom: PPP Connection is ready to start I (5209444) simcom: State: Enter NetMode state I (5209444) gsm-ppp: Initialising... I (5212544) gsm-ppp: StatusCallBack: None I (5212544) gsm-ppp: status_cb: Connected I (5212544) gsm-ppp: our_ipaddr = 10.170.146.142 I (5212544) gsm-ppp: his_ipaddr = 10.64.64.64 I (5212544) gsm-ppp: netmask = 255.255.255.255 I (5212544) gsm-ppp: our6_ipaddr = :: I (5212544) netmanager: Set DNS#0 9.9.9.9 I (5212544) netmanager: Set DNS#1 8.8.8.8 I (5212544) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (5212544) time: Starting SNTP client I (5212554) ovms-mdns: Launching MDNS service I (5212554) ovms-server-v2: Network is up, so attempt network connection I (5212554) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5212554) ovms-server-v2: Status: Connecting... I (5213734) ovms-server-v2: Connection successful I (5213744) ovms-server-v2: Status: Logging in... I (5213744) ovms-server-v2: Sending server login: MP-C 0 MDFN9qGZEWSj5Rsao0LVsZ il2/B/jt7FXn7Qyom+kP8w== ROADSTER_834 E (5243444) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5243444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5243444) ovms-server-v2: Status: Connecting... E (5243494) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 W (5253254) ovms-server-v2: Connection failed I (5272444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5272444) ovms-server-v2: Status: Connecting... W (5282254) ovms-server-v2: Connection failed E (5282254) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5301444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5301444) ovms-server-v2: Status: Connecting... W (5311254) ovms-server-v2: Connection failed E (5311254) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5330444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5330444) ovms-server-v2: Status: Connecting... W (5340254) ovms-server-v2: Connection failed E (5340254) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5359444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5359444) ovms-server-v2: Status: Connecting... W (5369254) ovms-server-v2: Connection failed E (5369254) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5388444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5388444) ovms-server-v2: Status: Connecting... W (5398254) ovms-server-v2: Connection failed E (5398254) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 W (5406444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (5406444) gsm-ppp: Shutting down (soft)... I (5406444) time: Stopping SNTP client I (5406444) gsm-nmea: Shutdown (direct) I (5406454) gsm-mux: Stop MUX I (5406454) simcom: Power Cycle I (5407454) simcom: State: Enter PoweringOn state I (5407454) simcom: Power Cycle I (5415444) simcom: State timeout, transition to 2 I (5415444) simcom: State: Enter PoweringOn state I (5415444) simcom: Power Cycle I (5418444) gsm-ppp: StatusCallBack: User Interrupt I (5418444) gsm-ppp: PPP connection has been closed I (5422054) simcom: State: Enter PoweredOn state I (5441444) simcom: State: Enter MuxStart state I (5441444) gsm-mux: Start MUX I (5441454) gsm-mux: Channel #0 is open I (5441454) gsm-mux: Channel #1 is open I (5441464) gsm-mux: Channel #2 is open I (5441474) gsm-mux: Channel #3 is open I (5441474) gsm-mux: Channel #4 is open I (5442444) simcom: State: Enter NetWait state I (5446444) simcom: State: Enter NetStart state I (5447584) simcom: PPP Connection is ready to start I (5448444) simcom: State: Enter NetMode state I (5448444) gsm-ppp: Initialising... I (5451704) gsm-ppp: StatusCallBack: None I (5451704) gsm-ppp: status_cb: Connected I (5451704) gsm-ppp: our_ipaddr = 10.170.146.142 I (5451704) gsm-ppp: his_ipaddr = 10.64.64.64 I (5451704) gsm-ppp: netmask = 255.255.255.255 I (5451704) gsm-ppp: our6_ipaddr = :: I (5451704) netmanager: Set DNS#0 9.9.9.9 I (5451704) netmanager: Set DNS#1 8.8.8.8 I (5451714) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (5451714) time: Starting SNTP client I (5451714) ovms-mdns: Launching MDNS service I (5451714) ovms-server-v2: Network is up, so attempt network connection I (5451714) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5451714) ovms-server-v2: Status: Connecting... I (5452944) ovms-server-v2: Connection successful I (5452944) ovms-server-v2: Status: Logging in... I (5452944) ovms-server-v2: Sending server login: MP-C 0 hrVKMZxxUPBEde3zOZUsJe iaORjfQ376YAEFAqTgb/pw== ROADSTER_834 I (5453644) ovms-server-v2: Got server response: MP-S 0 ekXdgkqxxPg0NO2D9KWskb RaiiWaHSHhMU53FxVZnNgQ== I (5453654) ovms-server-v2: Server token is ekXdgkqxxPg0NO2D9KWskb and digest is RaiiWaHSHhMU53FxVZnNgQ== I (5453654) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (5453654) ovms-server-v2: Shared secret key is ekXdgkqxxPg0NO2D9KWskbhrVKMZxxUPBEde3zOZUsJe (44 bytes) I (5453654) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (5453664) ovms-server-v2: Incoming Msg: MP-0 Z0 I (5454444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (5454444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,5454,0,0,0,0,0.263736,0,0,0,0,0 I (5454444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,8,1,TR, W (5689444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (5689444) gsm-ppp: Shutting down (soft)... I (5689444) time: Stopping SNTP client I (5689454) gsm-nmea: Shutdown (direct) I (5689454) gsm-mux: Stop MUX I (5689454) simcom: Power Cycle I (5689664) ovms-server-v2: Network is down, so disconnect network connection E (5689664) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (5690454) simcom: State: Enter PoweringOn state I (5690454) simcom: Power Cycle I (5691454) simcom: State: Enter PoweredOn state I (5700964) gsm-ppp: StatusCallBack: User Interrupt I (5700964) gsm-ppp: PPP connection has been closed I (5721444) simcom: State timeout, transition to 2 I (5721444) simcom: State: Enter PoweringOn state I (5721444) simcom: Power Cycle I (5728004) simcom: State: Enter PoweredOn state I (5747444) simcom: State: Enter MuxStart state I (5747444) gsm-mux: Start MUX I (5747454) gsm-mux: Channel #0 is open I (5747454) gsm-mux: Channel #1 is open I (5747464) gsm-mux: Channel #2 is open I (5747474) gsm-mux: Channel #3 is open I (5747474) gsm-mux: Channel #4 is open I (5748444) simcom: State: Enter NetWait state I (5752444) simcom: State: Enter NetStart state I (5753584) simcom: PPP Connection is ready to start I (5754444) simcom: State: Enter NetMode state I (5754444) gsm-ppp: Initialising... I (5757754) gsm-ppp: StatusCallBack: None I (5757754) gsm-ppp: status_cb: Connected I (5757754) gsm-ppp: our_ipaddr = 10.170.146.142 I (5757754) gsm-ppp: his_ipaddr = 10.64.64.64 I (5757754) gsm-ppp: netmask = 255.255.255.255 I (5757754) gsm-ppp: our6_ipaddr = :: I (5757754) netmanager: Set DNS#0 9.9.9.9 I (5757754) netmanager: Set DNS#1 8.8.8.8 I (5757764) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (5757764) time: Starting SNTP client I (5757774) ovms-mdns: Launching MDNS service I (5757774) ovms-server-v2: Network is up, so attempt network connection I (5757774) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (5757774) ovms-server-v2: Status: Connecting... I (5758914) ovms-server-v2: Connection successful I (5758914) ovms-server-v2: Status: Logging in... I (5758914) ovms-server-v2: Sending server login: MP-C 0 j9ogaenXyrIJXumxk6flnT r2jNikXUXDZpEpVdUCNs7Q== ROADSTER_834 I (5759614) ovms-server-v2: Got server response: MP-S 0 RUmhG2mnRg2SwMkh7CP3ag qIUSSnStgAhdJhIajetmwg== I (5759614) ovms-server-v2: Server token is RUmhG2mnRg2SwMkh7CP3ag and digest is qIUSSnStgAhdJhIajetmwg== I (5759624) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (5759624) ovms-server-v2: Shared secret key is RUmhG2mnRg2SwMkh7CP3agj9ogaenXyrIJXumxk6flnT (44 bytes) I (5759624) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (5759654) ovms-server-v2: Incoming Msg: MP-0 Z0 I (6055444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (6055444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,6055,0,0,0,0,0.269231,0,0,0,0,0 I (6055444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,10,1,TR,T-Mobile Hologram W (6505444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (6505444) gsm-ppp: Shutting down (soft)... I (6505444) time: Stopping SNTP client I (6505454) gsm-nmea: Shutdown (direct) I (6505454) gsm-mux: Stop MUX I (6505454) simcom: Power Cycle I (6505664) ovms-server-v2: Network is down, so disconnect network connection E (6505664) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (6506454) simcom: State: Enter PoweringOn state I (6506454) simcom: Power Cycle I (6514444) simcom: State timeout, transition to 2 I (6514444) simcom: State: Enter PoweringOn state I (6514444) simcom: Power Cycle I (6516964) gsm-ppp: StatusCallBack: User Interrupt I (6516964) gsm-ppp: PPP connection has been closed I (6520964) simcom: State: Enter PoweredOn state I (6540474) simcom: State: Enter MuxStart state I (6540474) gsm-mux: Start MUX I (6540484) gsm-mux: Channel #0 is open I (6540484) gsm-mux: Channel #1 is open I (6540494) gsm-mux: Channel #2 is open I (6540504) gsm-mux: Channel #3 is open I (6540514) gsm-mux: Channel #4 is open I (6541444) simcom: State: Enter NetWait state I (6545444) simcom: State: Enter NetStart state I (6546584) simcom: PPP Connection is ready to start I (6547444) simcom: State: Enter NetMode state I (6547444) gsm-ppp: Initialising... I (6550594) gsm-ppp: StatusCallBack: None I (6550594) gsm-ppp: status_cb: Connected I (6550594) gsm-ppp: our_ipaddr = 10.170.146.142 I (6550594) gsm-ppp: his_ipaddr = 10.64.64.64 I (6550594) gsm-ppp: netmask = 255.255.255.255 I (6550594) gsm-ppp: our6_ipaddr = :: I (6550594) netmanager: Set DNS#0 9.9.9.9 I (6550594) netmanager: Set DNS#1 8.8.8.8 I (6550594) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (6550594) time: Starting SNTP client I (6550604) ovms-mdns: Launching MDNS service I (6550604) ovms-server-v2: Network is up, so attempt network connection I (6550604) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (6550604) ovms-server-v2: Status: Connecting... I (6551724) ovms-server-v2: Connection successful I (6551734) ovms-server-v2: Status: Logging in... I (6551734) ovms-server-v2: Sending server login: MP-C 0 zc1SI9qDUrbv+gnR7P/2Ca F6Djra4++6jXEIRY+FYQzQ== ROADSTER_834 I (6552424) ovms-server-v2: Got server response: MP-S 0 f9AFpIg5kvGKbkluxqDzMe nq6m31pj7Xp3jVjHX2qqtg== I (6552424) ovms-server-v2: Server token is f9AFpIg5kvGKbkluxqDzMe and digest is nq6m31pj7Xp3jVjHX2qqtg== I (6552434) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (6552434) ovms-server-v2: Shared secret key is f9AFpIg5kvGKbkluxqDzMezc1SI9qDUrbv+gnR7P/2Ca (44 bytes) I (6552434) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (6552444) ovms-server-v2: Incoming Msg: MP-0 Z0 I (6656444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (6656444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,6656,0,0,0,0,0.263736,0,0,0,0,0 I (6656444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,8,1,TR,T-Mobile Hologram W (6758444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (6758444) gsm-ppp: Shutting down (soft)... I (6758444) time: Stopping SNTP client I (6758454) gsm-nmea: Shutdown (direct) I (6758454) gsm-mux: Stop MUX I (6758454) simcom: Power Cycle I (6758464) ovms-server-v2: Network is down, so disconnect network connection E (6758464) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (6759454) simcom: State: Enter PoweringOn state I (6759454) simcom: Power Cycle I (6767444) simcom: State timeout, transition to 2 I (6767444) simcom: State: Enter PoweringOn state I (6767444) simcom: Power Cycle I (6769964) gsm-ppp: StatusCallBack: User Interrupt I (6769964) gsm-ppp: PPP connection has been closed I (6773944) simcom: State: Enter PoweredOn state I (6793484) simcom: State: Enter MuxStart state I (6793484) gsm-mux: Start MUX I (6793494) gsm-mux: Channel #0 is open I (6793504) gsm-mux: Channel #1 is open I (6793504) gsm-mux: Channel #2 is open I (6793514) gsm-mux: Channel #3 is open I (6793524) gsm-mux: Channel #4 is open I (6794444) simcom: State: Enter NetWait state I (6798444) simcom: State: Enter NetStart state I (6799514) simcom: PPP Connection is ready to start I (6800444) simcom: State: Enter NetMode state I (6800444) gsm-ppp: Initialising... I (6803604) gsm-ppp: StatusCallBack: None I (6803604) gsm-ppp: status_cb: Connected I (6803604) gsm-ppp: our_ipaddr = 10.170.146.142 I (6803604) gsm-ppp: his_ipaddr = 10.64.64.64 I (6803604) gsm-ppp: netmask = 255.255.255.255 I (6803604) gsm-ppp: our6_ipaddr = :: I (6803604) netmanager: Set DNS#0 9.9.9.9 I (6803604) netmanager: Set DNS#1 8.8.8.8 I (6803604) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (6803604) time: Starting SNTP client I (6803604) ovms-mdns: Launching MDNS service I (6803604) ovms-server-v2: Network is up, so attempt network connection I (6803604) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (6803604) ovms-server-v2: Status: Connecting... I (6804744) ovms-server-v2: Connection successful I (6804744) ovms-server-v2: Status: Logging in... I (6804744) ovms-server-v2: Sending server login: MP-C 0 pL7wGIL5lg7GNuBxHKEqX2 stg70/M85qht+NFY0jMpcw== ROADSTER_834 I (6805464) ovms-server-v2: Got server response: MP-S 0 tRmJqJEVsOn4RE84+p6cj6 d86ExfhUS18E4cqlc7xd2Q== I (6805464) ovms-server-v2: Server token is tRmJqJEVsOn4RE84+p6cj6 and digest is d86ExfhUS18E4cqlc7xd2Q== I (6805474) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (6805474) ovms-server-v2: Shared secret key is tRmJqJEVsOn4RE84+p6cj6pL7wGIL5lg7GNuBxHKEqX2 (44 bytes) I (6805474) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (6805504) ovms-server-v2: Incoming Msg: MP-0 Z0 I (7257444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (7257444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,7257,0,0,0,0,0.263736,0,0,0,0,0 I (7257444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR,T-Mobile Hologram W (7311444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (7311444) gsm-ppp: Shutting down (soft)... I (7311444) time: Stopping SNTP client I (7311454) gsm-nmea: Shutdown (direct) I (7311454) gsm-mux: Stop MUX I (7311454) simcom: Power Cycle I (7311514) ovms-server-v2: Network is down, so disconnect network connection E (7311514) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (7312454) simcom: State: Enter PoweringOn state I (7312454) simcom: Power Cycle I (7320444) simcom: State timeout, transition to 2 I (7320444) simcom: State: Enter PoweringOn state I (7320444) simcom: Power Cycle I (7322974) gsm-ppp: StatusCallBack: User Interrupt I (7322974) gsm-ppp: PPP connection has been closed I (7326924) simcom: State: Enter PoweredOn state I (7346464) simcom: State: Enter MuxStart state I (7346464) gsm-mux: Start MUX I (7346474) gsm-mux: Channel #0 is open I (7346484) gsm-mux: Channel #1 is open I (7346484) gsm-mux: Channel #2 is open I (7346494) gsm-mux: Channel #3 is open I (7346504) gsm-mux: Channel #4 is open I (7347444) simcom: State: Enter NetWait state I (7351444) simcom: State: Enter NetStart state I (7352464) simcom: PPP Connection is ready to start I (7353444) simcom: State: Enter NetMode state I (7353444) gsm-ppp: Initialising... I (7356594) gsm-ppp: StatusCallBack: None I (7356594) gsm-ppp: status_cb: Connected I (7356594) gsm-ppp: our_ipaddr = 10.170.146.142 I (7356594) gsm-ppp: his_ipaddr = 10.64.64.64 I (7356594) gsm-ppp: netmask = 255.255.255.255 I (7356594) gsm-ppp: our6_ipaddr = :: I (7356594) netmanager: Set DNS#0 9.9.9.9 I (7356594) netmanager: Set DNS#1 8.8.8.8 I (7356604) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (7356604) time: Starting SNTP client I (7356614) ovms-mdns: Launching MDNS service I (7356614) ovms-server-v2: Network is up, so attempt network connection I (7356624) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (7356624) ovms-server-v2: Status: Connecting... I (7357854) ovms-server-v2: Connection successful I (7357854) ovms-server-v2: Status: Logging in... I (7357854) ovms-server-v2: Sending server login: MP-C 0 yI1cHS18zLM7NIQZExmAnv H/X8DZjvTA4UIkEX6zjGJg== ROADSTER_834 I (7358624) ovms-server-v2: Got server response: MP-S 0 DTWuUqrztKfrVo3LSUkdC4 v/zce+pSAZeoE6yfazbc9g== I (7358624) ovms-server-v2: Server token is DTWuUqrztKfrVo3LSUkdC4 and digest is v/zce+pSAZeoE6yfazbc9g== I (7358624) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (7358624) ovms-server-v2: Shared secret key is DTWuUqrztKfrVo3LSUkdC4yI1cHS18zLM7NIQZExmAnv (44 bytes) I (7358624) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (7358654) ovms-server-v2: Incoming Msg: MP-0 Z0 W (7654444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (7654444) gsm-ppp: Shutting down (soft)... I (7654444) time: Stopping SNTP client I (7654444) gsm-nmea: Shutdown (direct) I (7654454) gsm-mux: Stop MUX I (7654454) simcom: Power Cycle I (7654654) ovms-server-v2: Network is down, so disconnect network connection E (7654654) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (7655454) simcom: State: Enter PoweringOn state I (7655454) simcom: Power Cycle I (7663444) simcom: State timeout, transition to 2 I (7663444) simcom: State: Enter PoweringOn state I (7663444) simcom: Power Cycle I (7665944) gsm-ppp: StatusCallBack: User Interrupt I (7665944) gsm-ppp: PPP connection has been closed I (7669904) simcom: State: Enter PoweredOn state I (7695884) simcom: State: Enter MuxStart state I (7695884) gsm-mux: Start MUX I (7815444) simcom: State timeout, transition to 2 I (7815444) simcom: State: Enter PoweringOn state I (7815444) simcom: Power Cycle I (7815464) simcom: State: Enter PoweredOn state I (7825444) simcom: State timeout, transition to 2 I (7825444) simcom: State: Enter PoweringOn state I (7825444) simcom: Power Cycle I (7831904) simcom: State: Enter PoweredOn state I (7851464) simcom: State: Enter MuxStart state I (7851464) gsm-mux: Start MUX I (7851474) gsm-mux: Channel #0 is open I (7851484) gsm-mux: Channel #1 is open I (7851484) gsm-mux: Channel #2 is open I (7851494) gsm-mux: Channel #3 is open I (7851504) gsm-mux: Channel #4 is open I (7852444) simcom: State: Enter NetWait state I (7856444) simcom: State: Enter NetStart state I (7857594) simcom: PPP Connection is ready to start I (7858444) simcom: State: Enter NetMode state I (7858444) gsm-ppp: Initialising... I (7861674) gsm-ppp: StatusCallBack: None I (7861674) gsm-ppp: status_cb: Connected I (7861674) gsm-ppp: our_ipaddr = 10.170.146.142 I (7861674) gsm-ppp: his_ipaddr = 10.64.64.64 I (7861674) gsm-ppp: netmask = 255.255.255.255 I (7861674) gsm-ppp: our6_ipaddr = :: I (7861674) netmanager: Set DNS#0 9.9.9.9 I (7861674) netmanager: Set DNS#1 8.8.8.8 I (7861674) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (7861674) time: Starting SNTP client I (7861674) ovms-mdns: Launching MDNS service I (7861674) ovms-server-v2: Network is up, so attempt network connection I (7861674) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (7861674) ovms-server-v2: Status: Connecting... I (7862814) ovms-server-v2: Connection successful I (7862814) ovms-server-v2: Status: Logging in... I (7862814) ovms-server-v2: Sending server login: MP-C 0 dLB1jodbbovuwWqz22H+iu iZb/7VFXkm8W7jQzArOs9Q== ROADSTER_834 I (7863554) ovms-server-v2: Got server response: MP-S 0 kZMEDKjlyMjmuCFfjaLIaj eq/c1HyHbYcaeuJ8Ac94/A== I (7863564) ovms-server-v2: Server token is kZMEDKjlyMjmuCFfjaLIaj and digest is eq/c1HyHbYcaeuJ8Ac94/A== I (7863564) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (7863564) ovms-server-v2: Shared secret key is kZMEDKjlyMjmuCFfjaLIajdLB1jodbbovuwWqz22H+iu (44 bytes) I (7863564) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (7863574) ovms-server-v2: Incoming Msg: MP-0 Z0 I (7864444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (7864444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,7864,0,0,0,0,0.263736,0,0,0,0,0 I (7864444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,10,1,TR,T-Mobile Hologram W (8069444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (8069444) gsm-ppp: Shutting down (soft)... I (8069444) time: Stopping SNTP client I (8069444) gsm-nmea: Shutdown (direct) I (8069454) gsm-mux: Stop MUX I (8069454) simcom: Power Cycle I (8069574) ovms-server-v2: Network is down, so disconnect network connection E (8069574) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (8070454) simcom: State: Enter PoweringOn state I (8070454) simcom: Power Cycle I (8078444) simcom: State timeout, transition to 2 I (8078444) simcom: State: Enter PoweringOn state I (8078444) simcom: Power Cycle I (8080964) gsm-ppp: StatusCallBack: User Interrupt I (8080964) gsm-ppp: PPP connection has been closed I (8084874) simcom: State: Enter PoweredOn state I (8104464) simcom: State: Enter MuxStart state I (8104464) gsm-mux: Start MUX I (8104474) gsm-mux: Channel #0 is open I (8104474) gsm-mux: Channel #1 is open I (8104484) gsm-mux: Channel #2 is open I (8104494) gsm-mux: Channel #3 is open I (8104504) gsm-mux: Channel #4 is open I (8105444) simcom: State: Enter NetWait state I (8109444) simcom: State: Enter NetStart state I (8110534) simcom: PPP Connection is ready to start I (8111444) simcom: State: Enter NetMode state I (8111444) gsm-ppp: Initialising... I (8114534) gsm-ppp: StatusCallBack: None I (8114534) gsm-ppp: status_cb: Connected I (8114534) gsm-ppp: our_ipaddr = 10.170.146.142 I (8114534) gsm-ppp: his_ipaddr = 10.64.64.64 I (8114534) gsm-ppp: netmask = 255.255.255.255 I (8114534) gsm-ppp: our6_ipaddr = :: I (8114534) netmanager: Set DNS#0 9.9.9.9 I (8114534) netmanager: Set DNS#1 8.8.8.8 I (8114534) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (8114534) time: Starting SNTP client I (8114544) ovms-mdns: Launching MDNS service I (8114544) ovms-server-v2: Network is up, so attempt network connection I (8114544) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (8114544) ovms-server-v2: Status: Connecting... I (8115694) ovms-server-v2: Connection successful I (8115694) ovms-server-v2: Status: Logging in... I (8115694) ovms-server-v2: Sending server login: MP-C 0 85vy4pdVE8jwhUhVlo20q+ NuDYOhcMNCUmyqrhcbf5OA== ROADSTER_834 I (8116414) ovms-server-v2: Got server response: MP-S 0 uGQ4795ANm8fzfVIS3C25w c1DdQzcBABt7/E8ap+tZYg== I (8116414) ovms-server-v2: Server token is uGQ4795ANm8fzfVIS3C25w and digest is c1DdQzcBABt7/E8ap+tZYg== I (8116414) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (8116414) ovms-server-v2: Shared secret key is uGQ4795ANm8fzfVIS3C25w85vy4pdVE8jwhUhVlo20q+ (44 bytes) I (8116414) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (8116424) ovms-server-v2: Incoming Msg: MP-0 Z0 W (8382444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (8382444) gsm-ppp: Shutting down (soft)... I (8382444) time: Stopping SNTP client I (8382454) gsm-nmea: Shutdown (direct) I (8382454) gsm-mux: Stop MUX I (8382454) simcom: Power Cycle I (8382674) ovms-server-v2: Network is down, so disconnect network connection E (8382674) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (8383454) simcom: State: Enter PoweringOn state I (8383454) simcom: Power Cycle I (8391444) simcom: State timeout, transition to 2 I (8391444) simcom: State: Enter PoweringOn state I (8391444) simcom: Power Cycle I (8393964) gsm-ppp: StatusCallBack: User Interrupt I (8393964) gsm-ppp: PPP connection has been closed I (8397864) simcom: State: Enter PoweredOn state I (8417444) simcom: State: Enter MuxStart state I (8417444) gsm-mux: Start MUX I (8417454) gsm-mux: Channel #0 is open I (8417454) gsm-mux: Channel #1 is open I (8417464) gsm-mux: Channel #2 is open I (8417474) gsm-mux: Channel #3 is open I (8417474) gsm-mux: Channel #4 is open I (8418444) simcom: State: Enter NetWait state I (8422444) simcom: State: Enter NetStart state I (8423564) simcom: PPP Connection is ready to start I (8424444) simcom: State: Enter NetMode state I (8424444) gsm-ppp: Initialising... I (8427744) gsm-ppp: StatusCallBack: None I (8427744) gsm-ppp: status_cb: Connected I (8427744) gsm-ppp: our_ipaddr = 10.170.146.142 I (8427744) gsm-ppp: his_ipaddr = 10.64.64.64 I (8427744) gsm-ppp: netmask = 255.255.255.255 I (8427754) gsm-ppp: our6_ipaddr = :: I (8427754) netmanager: Set DNS#0 9.9.9.9 I (8427754) netmanager: Set DNS#1 8.8.8.8 I (8427754) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (8427754) time: Starting SNTP client I (8427764) ovms-mdns: Launching MDNS service I (8427764) ovms-server-v2: Network is up, so attempt network connection I (8427764) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (8427764) ovms-server-v2: Status: Connecting... I (8429024) ovms-server-v2: Connection successful I (8429024) ovms-server-v2: Status: Logging in... I (8429024) ovms-server-v2: Sending server login: MP-C 0 beYT0B+nh3Zl07cCJdDPcX v1vfgyg4lJHtJy1hUIg1aQ== ROADSTER_834 I (8429734) ovms-server-v2: Got server response: MP-S 0 nneAeSVac49drsI2R0Kj56 hY70SzgiJWz8Iij3Rg0BpQ== I (8429734) ovms-server-v2: Server token is nneAeSVac49drsI2R0Kj56 and digest is hY70SzgiJWz8Iij3Rg0BpQ== I (8429744) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (8429744) ovms-server-v2: Shared secret key is nneAeSVac49drsI2R0Kj56beYT0B+nh3Zl07cCJdDPcX (44 bytes) I (8429744) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (8429754) ovms-server-v2: Incoming Msg: MP-0 Z0 I (8465444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (8465444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,8465,0,0,0,0,0.263736,0,0,0,0,0 I (8465444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,8,1,TR,T-Mobile Hologram W (8635444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (8635444) gsm-ppp: Shutting down (soft)... I (8635444) time: Stopping SNTP client I (8635454) gsm-nmea: Shutdown (direct) I (8635454) gsm-mux: Stop MUX I (8635454) simcom: Power Cycle I (8635504) ovms-server-v2: Network is down, so disconnect network connection E (8635504) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (8636454) simcom: State: Enter PoweringOn state I (8636454) simcom: Power Cycle I (8644444) simcom: State timeout, transition to 2 I (8644444) simcom: State: Enter PoweringOn state I (8644444) simcom: Power Cycle I (8646954) gsm-ppp: StatusCallBack: User Interrupt I (8646954) gsm-ppp: PPP connection has been closed I (8650854) simcom: State: Enter PoweredOn state I (8670454) simcom: State: Enter MuxStart state I (8670454) gsm-mux: Start MUX I (8670464) gsm-mux: Channel #0 is open I (8670474) gsm-mux: Channel #1 is open I (8670484) gsm-mux: Channel #2 is open I (8670494) gsm-mux: Channel #3 is open I (8670504) gsm-mux: Channel #4 is open I (8671444) simcom: State: Enter NetWait state I (8675444) simcom: State: Enter NetStart state I (8704444) simcom: State timeout, transition to 7 I (8704444) simcom: State: Enter NetLoss state I (8704444) gsm-ppp: Shutting down (hard)... I (8704444) gsm-ppp: StatusCallBack: User Interrupt I (8704444) gsm-ppp: PPP connection has been closed I (8714444) simcom: State timeout, transition to 5 I (8714444) simcom: State: Enter NetWait state I (8718444) simcom: State: Enter NetStart state I (8747444) simcom: State timeout, transition to 7 I (8747444) simcom: State: Enter NetLoss state I (8747444) gsm-ppp: Shutting down (hard)... I (8747444) gsm-ppp: StatusCallBack: User Interrupt I (8747444) gsm-ppp: PPP connection has been closed I (8757444) simcom: State timeout, transition to 5 I (8757444) simcom: State: Enter NetWait state I (8761444) simcom: State: Enter NetStart state I (8790444) simcom: State timeout, transition to 7 I (8790444) simcom: State: Enter NetLoss state I (8790444) gsm-ppp: Shutting down (hard)... I (8790444) gsm-ppp: StatusCallBack: User Interrupt I (8790444) gsm-ppp: PPP connection has been closed I (8800444) simcom: State timeout, transition to 5 I (8800444) simcom: State: Enter NetWait state I (8804444) simcom: State: Enter NetStart state I (8833444) simcom: State timeout, transition to 7 I (8833444) simcom: State: Enter NetLoss state I (8833444) gsm-ppp: Shutting down (hard)... I (8833444) gsm-ppp: StatusCallBack: User Interrupt I (8833444) gsm-ppp: PPP connection has been closed I (8843444) simcom: State timeout, transition to 5 I (8843444) simcom: State: Enter NetWait state I (8847444) simcom: State: Enter NetStart state W (8851444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (8851444) gsm-ppp: Shutting down (soft)... I (8851444) gsm-ppp: StatusCallBack: User Interrupt I (8851444) gsm-ppp: PPP connection has been closed I (8851444) gsm-nmea: Shutdown (direct) I (8851444) gsm-mux: Stop MUX I (8851454) simcom: Power Cycle I (8852454) simcom: State: Enter PoweringOn state I (8852454) simcom: Power Cycle I (8854124) simcom: State: Enter PoweredOn state I (8883444) simcom: State timeout, transition to 2 I (8883444) simcom: State: Enter PoweringOn state I (8883444) simcom: Power Cycle I (8889844) simcom: State: Enter PoweredOn state I (8909464) simcom: State: Enter MuxStart state I (8909464) gsm-mux: Start MUX I (8909474) gsm-mux: Channel #0 is open I (8909484) gsm-mux: Channel #1 is open I (8909484) gsm-mux: Channel #2 is open I (8909494) gsm-mux: Channel #3 is open I (8909504) gsm-mux: Channel #4 is open I (8910444) simcom: State: Enter NetWait state I (8914444) simcom: State: Enter NetStart state I (8915504) simcom: PPP Connection is ready to start I (8916444) simcom: State: Enter NetMode state I (8916444) gsm-ppp: Initialising... I (8919584) gsm-ppp: StatusCallBack: None I (8919584) gsm-ppp: status_cb: Connected I (8919584) gsm-ppp: our_ipaddr = 10.170.146.142 I (8919584) gsm-ppp: his_ipaddr = 10.64.64.64 I (8919584) gsm-ppp: netmask = 255.255.255.255 I (8919584) gsm-ppp: our6_ipaddr = :: I (8919584) netmanager: Set DNS#0 9.9.9.9 I (8919584) netmanager: Set DNS#1 8.8.8.8 I (8919584) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (8919584) time: Starting SNTP client I (8919584) ovms-mdns: Launching MDNS service I (8919584) ovms-server-v2: Network is up, so attempt network connection I (8919584) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (8919584) ovms-server-v2: Status: Connecting... I (8920754) ovms-server-v2: Connection successful I (8920754) ovms-server-v2: Status: Logging in... I (8920754) ovms-server-v2: Sending server login: MP-C 0 Aoo+sJGDq3DSdgLPWcuVQc nEUIfw1vAKQP3I+S9bSntw== ROADSTER_834 I (8921474) ovms-server-v2: Got server response: MP-S 0 UN5lCR7Czt7r1BboI9Drt/ ebtjmjelM53qFW7SNZe/RA== I (8921474) ovms-server-v2: Server token is UN5lCR7Czt7r1BboI9Drt/ and digest is ebtjmjelM53qFW7SNZe/RA== I (8921484) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (8921494) ovms-server-v2: Shared secret key is UN5lCR7Czt7r1BboI9Drt/Aoo+sJGDq3DSdgLPWcuVQc (44 bytes) I (8921494) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (8921504) ovms-server-v2: Incoming Msg: MP-0 Z0 I (9066444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (9066444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,9066,0,0,0,0,0.263736,0,0,0,0,0 I (9066444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR,T-Mobile Hologram W (9157444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (9157444) gsm-ppp: Shutting down (soft)... I (9157444) time: Stopping SNTP client I (9157444) gsm-nmea: Shutdown (direct) I (9157454) gsm-mux: Stop MUX I (9157454) simcom: Power Cycle I (9157504) ovms-server-v2: Network is down, so disconnect network connection E (9157504) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (9158454) simcom: State: Enter PoweringOn state I (9158454) simcom: Power Cycle I (9166444) simcom: State timeout, transition to 2 I (9166444) simcom: State: Enter PoweringOn state I (9166444) simcom: Power Cycle I (9168964) gsm-ppp: StatusCallBack: User Interrupt I (9168964) gsm-ppp: PPP connection has been closed I (9172784) simcom: State: Enter PoweredOn state I (9192464) simcom: State: Enter MuxStart state I (9192464) gsm-mux: Start MUX I (9192474) gsm-mux: Channel #0 is open I (9192474) gsm-mux: Channel #1 is open I (9192484) gsm-mux: Channel #2 is open I (9192494) gsm-mux: Channel #3 is open I (9192504) gsm-mux: Channel #4 is open I (9193444) simcom: State: Enter NetWait state I (9197444) simcom: State: Enter NetStart state I (9226444) simcom: State timeout, transition to 7 I (9226444) simcom: State: Enter NetLoss state I (9226444) gsm-ppp: Shutting down (hard)... I (9226444) gsm-ppp: StatusCallBack: User Interrupt I (9226444) gsm-ppp: PPP connection has been closed I (9236444) simcom: State timeout, transition to 5 I (9236444) simcom: State: Enter NetWait state I (9240444) simcom: State: Enter NetStart state I (9269444) simcom: State timeout, transition to 7 I (9269444) simcom: State: Enter NetLoss state I (9269444) gsm-ppp: Shutting down (hard)... I (9269444) gsm-ppp: StatusCallBack: User Interrupt I (9269444) gsm-ppp: PPP connection has been closed I (9279444) simcom: State timeout, transition to 5 I (9279444) simcom: State: Enter NetWait state I (9283444) simcom: State: Enter NetStart state I (9312444) simcom: State timeout, transition to 7 I (9312444) simcom: State: Enter NetLoss state I (9312444) gsm-ppp: Shutting down (hard)... I (9312444) gsm-ppp: StatusCallBack: User Interrupt I (9312444) gsm-ppp: PPP connection has been closed I (9322444) simcom: State timeout, transition to 5 I (9322444) simcom: State: Enter NetWait state I (9326444) simcom: State: Enter NetStart state I (9355444) simcom: State timeout, transition to 7 I (9355444) simcom: State: Enter NetLoss state I (9355444) gsm-ppp: Shutting down (hard)... I (9355444) gsm-ppp: StatusCallBack: User Interrupt I (9355444) gsm-ppp: PPP connection has been closed I (9365444) simcom: State timeout, transition to 5 I (9365444) simcom: State: Enter NetWait state I (9369444) simcom: State: Enter NetStart state W (9373444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (9373444) gsm-ppp: Shutting down (soft)... I (9373444) gsm-ppp: StatusCallBack: User Interrupt I (9373444) gsm-ppp: PPP connection has been closed I (9373444) gsm-nmea: Shutdown (direct) I (9373444) gsm-mux: Stop MUX I (9373444) simcom: Power Cycle I (9374454) simcom: State: Enter PoweringOn state I (9374454) simcom: Power Cycle I (9382444) simcom: State timeout, transition to 2 I (9382444) simcom: State: Enter PoweringOn state I (9382444) simcom: Power Cycle I (9388764) simcom: State: Enter PoweredOn state I (9408464) simcom: State: Enter MuxStart state I (9408464) gsm-mux: Start MUX I (9408474) gsm-mux: Channel #0 is open I (9408484) gsm-mux: Channel #1 is open I (9408484) gsm-mux: Channel #2 is open I (9408494) gsm-mux: Channel #3 is open I (9408504) gsm-mux: Channel #4 is open I (9409444) simcom: State: Enter NetWait state I (9413444) simcom: State: Enter NetStart state I (9414474) simcom: PPP Connection is ready to start I (9415444) simcom: State: Enter NetMode state I (9415444) gsm-ppp: Initialising... I (9418674) gsm-ppp: StatusCallBack: None I (9418674) gsm-ppp: status_cb: Connected I (9418674) gsm-ppp: our_ipaddr = 10.170.146.142 I (9418674) gsm-ppp: his_ipaddr = 10.64.64.64 I (9418674) gsm-ppp: netmask = 255.255.255.255 I (9418674) gsm-ppp: our6_ipaddr = :: I (9418674) netmanager: Set DNS#0 9.9.9.9 I (9418674) netmanager: Set DNS#1 8.8.8.8 I (9418674) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (9418674) time: Starting SNTP client I (9418694) ovms-mdns: Launching MDNS service I (9418694) ovms-server-v2: Network is up, so attempt network connection I (9418694) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (9418694) ovms-server-v2: Status: Connecting... I (9419834) ovms-server-v2: Connection successful I (9419834) ovms-server-v2: Status: Logging in... I (9419834) ovms-server-v2: Sending server login: MP-C 0 nwtSPP+1YeGubElVDWQRbk 4bLC3OevM1n0PICtDc1vlQ== ROADSTER_834 I (9420554) ovms-server-v2: Got server response: MP-S 0 HUiVWE18tdUJ3lbZ/yfz0b g+qY0m9axgOX3qcotuU3KA== I (9420554) ovms-server-v2: Server token is HUiVWE18tdUJ3lbZ/yfz0b and digest is g+qY0m9axgOX3qcotuU3KA== I (9420564) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (9420564) ovms-server-v2: Shared secret key is HUiVWE18tdUJ3lbZ/yfz0bnwtSPP+1YeGubElVDWQRbk (44 bytes) I (9420564) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (9420574) ovms-server-v2: Incoming Msg: MP-0 Z0 W (9626444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (9626444) gsm-ppp: Shutting down (soft)... I (9626444) time: Stopping SNTP client I (9626454) gsm-nmea: Shutdown (direct) I (9626454) gsm-mux: Stop MUX I (9626454) simcom: Power Cycle I (9626574) ovms-server-v2: Network is down, so disconnect network connection E (9626574) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (9627454) simcom: State: Enter PoweringOn state I (9627454) simcom: Power Cycle I (9635444) simcom: State timeout, transition to 2 I (9635444) simcom: State: Enter PoweringOn state I (9635444) simcom: Power Cycle I (9637954) gsm-ppp: StatusCallBack: User Interrupt I (9637954) gsm-ppp: PPP connection has been closed I (9641774) simcom: State: Enter PoweredOn state I (9661464) simcom: State: Enter MuxStart state I (9661464) gsm-mux: Start MUX I (9661474) gsm-mux: Channel #0 is open I (9661474) gsm-mux: Channel #1 is open I (9661484) gsm-mux: Channel #2 is open I (9661484) gsm-mux: Channel #3 is open I (9661494) gsm-mux: Channel #4 is open I (9662444) simcom: State: Enter NetWait state I (9666444) simcom: State: Enter NetStart state I (9667564) simcom: PPP Connection is ready to start I (9668444) simcom: State: Enter NetMode state I (9668444) gsm-ppp: Initialising... I (9671594) gsm-ppp: StatusCallBack: None I (9671594) gsm-ppp: status_cb: Connected I (9671594) gsm-ppp: our_ipaddr = 10.170.146.142 I (9671594) gsm-ppp: his_ipaddr = 10.64.64.64 I (9671594) gsm-ppp: netmask = 255.255.255.255 I (9671594) gsm-ppp: our6_ipaddr = :: I (9671594) netmanager: Set DNS#0 9.9.9.9 I (9671594) netmanager: Set DNS#1 8.8.8.8 I (9671594) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (9671594) time: Starting SNTP client I (9671614) ovms-mdns: Launching MDNS service I (9671614) ovms-server-v2: Network is up, so attempt network connection I (9671614) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (9671614) ovms-server-v2: Status: Connecting... I (9672764) ovms-server-v2: Connection successful I (9672764) ovms-server-v2: Status: Logging in... I (9672774) ovms-server-v2: Sending server login: MP-C 0 L9Wd7ouevpVp17fzAkuWYn H/WdmVaqz1RChoZODi9l2w== ROADSTER_834 I (9673484) ovms-server-v2: Got server response: MP-S 0 2ZzO1A30VB0DOYA3WgeLkv AbtkUDk0CLfcBALA2EERRg== I (9673484) ovms-server-v2: Server token is 2ZzO1A30VB0DOYA3WgeLkv and digest is AbtkUDk0CLfcBALA2EERRg== I (9673494) ovms-server-v2: Status: Server auth ok. Now priming crypto. I (9673494) ovms-server-v2: Shared secret key is 2ZzO1A30VB0DOYA3WgeLkvL9Wd7ouevpVp17fzAkuWYn (44 bytes) I (9673494) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (9673504) ovms-server-v2: Incoming Msg: MP-0 Z0 I (9674444) ovms-server-v2: Send MP-0 S66,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (9674444) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,9674,0,0,0,0,0.263736,0,0,0,0,0 I (9674444) ovms-server-v2: Send MP-0 F3.0.991-43-g0d28cb9/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 17 2018 14:20:07,,9,1,TR, W (9948444) simcom: 3 minutes since last MUX rx frame - assume MUX has failed I (9948444) gsm-ppp: Shutting down (soft)... I (9948444) time: Stopping SNTP client I (9948444) gsm-nmea: Shutdown (direct) I (9948454) gsm-mux: Stop MUX I (9948454) simcom: Power Cycle I (9948504) ovms-server-v2: Network is down, so disconnect network connection E (9948504) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (9949454) simcom: State: Enter PoweringOn state I (9949454) simcom: Power Cycle I (9957444) simcom: State timeout, transition to 2 I (9957444) simcom: State: Enter PoweringOn state I (9957444) simcom: Power Cycle I (9959964) gsm-ppp: StatusCallBack: User Interrupt I (9959964) gsm-ppp: PPP connection has been closed I (9963754) simcom: State: Enter PoweredOn state I (9983464) simcom: State: Enter MuxStart state I (9983464) gsm-mux: Start MUX I (9983474) gsm-mux: Channel #0 is open I (9983474) gsm-mux: Channel #1 is open I (9983484) gsm-mux: Channel #2 is open I (9983494) gsm-mux: Channel #3 is open I (9983504) gsm-mux: Channel #4 is open I (9984444) simcom: State: Enter NetWait state I (9988444) simcom: State: Enter NetStart state I (9989584) simcom: PPP Connection is ready to start I (9990444) simcom: State: Enter NetMode state I (9990444) gsm-ppp: Initialising... I (9993474) gsm-ppp: StatusCallBack: None I (9993474) gsm-ppp: status_cb: Connected I (9993474) gsm-ppp: our_ipaddr = 10.170.146.142 I (9993474) gsm-ppp: his_ipaddr = 10.64.64.64 I (9993474) gsm-ppp: netmask = 255.255.255.255 I (9993474) gsm-ppp: our6_ipaddr = :: I (9993474) netmanager: Set DNS#0 9.9.9.9 I (9993474) netmanager: Set DNS#1 8.8.8.8 I (9993474) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 gateway 10.64.64.64) I (9993474) time: Starting SNTP client I (9993474) ovms-mdns: Launching MDNS service I (9993474) ovms-server-v2: Network is up, so attempt network connection I (9993474) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (9993474) ovms-server-v2: Status: Connecting... W (10011674) ovms-server-v2: Connection failed E (10011674) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10031444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10031444) ovms-server-v2: Status: Connecting... W (10041174) ovms-server-v2: Connection failed E (10041174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10060444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10060444) ovms-server-v2: Status: Connecting... W (10070174) ovms-server-v2: Connection failed E (10070174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10089444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10089444) ovms-server-v2: Status: Connecting... W (10099174) ovms-server-v2: Connection failed E (10099174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10118444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10118444) ovms-server-v2: Status: Connecting... W (10128174) ovms-server-v2: Connection failed E (10128174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10147444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10147444) ovms-server-v2: Status: Connecting... W (10157174) ovms-server-v2: Connection failed E (10157174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10176444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10176444) ovms-server-v2: Status: Connecting... OVMS > network Interface#3: pp3 (ifup=1 linkup=1) IPv4: 10.170.146.142/255.255.255.255 gateway 10.64.64.64 Interface#2: ap2 (ifup=1 linkup=1) IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1 Interface#1: st1 (ifup=0 linkup=1) IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 9.9.9.9 8.8.8.8 Default Interface: ap2 (192.168.4.1/255.255.255.0 gateway 192.168.4.1) W (10186174) ovms-server-v2: Connection failed E (10186174) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 I (10205444) ovms-server-v2: Connection is tmc.openvehicles.com:6867 ROADSTER_834/Gdbkt2017server I (10205444) ovms-server-v2: Status: Connecting... W (10215184) ovms-server-v2: Connection failed E (10215184) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2 OVMS >
