Return-Path: <ovmsdev-bounces@lists.teslaclub.hk>
Received: from network-box.com ([unix socket])
	 by nbmailhq5 (Cyrus v2.3.16-Fedora-RPM-2.3.16-6_5.nb5.0.2) with LMTPA;
	 Tue, 12 Nov 2013 10:56:20 +0800
X-Sieve: CMU Sieve 2.3
Received: from nbmailhk1.network-box.com (unknown [10.8.18.9])
	by network-box.com (Postfix) with ESMTP id 908FB2100198
	for <mark.johnson@network-box.com>; Tue, 12 Nov 2013 10:56:20 +0800 (HKT)
Received: from nbmailscanhq1.network-box.com (unknown [10.12.18.180])
	by nbmailhk1.network-box.com (Postfix) with ESMTP id 75D2C780EA
	for <mark@webb-johnson.net>; Tue, 12 Nov 2013 10:56:20 +0800 (HKT)
Received: (qmail 14725 invoked from network); 12 Nov 2013 02:56:17 -0000
X-NetworkBox-HamSign: 0101;OUT;nbmailscanhq1;82cf1f3ff2e50a83bcb201fc3d743859;
Received: from unknown (HELO markhk2.network-box.com) (10.12.18.80)
  by 10.12.18.180 with SMTP; 12 Nov 2013 02:56:16 -0000
Received: from [127.0.0.1] (markhk2 [127.0.0.1])
	by markhk2.network-box.com (Postfix) with ESMTP id AEDCE80052;
	Tue, 12 Nov 2013 10:56:16 +0800 (HKT)
X-Original-To: ovmsdev@lists.teslaclub.hk
Delivered-To: ovmsdev@lists.teslaclub.hk
	by markhk2.network-box.com (Postfix) with ESMTP id A6A5480052
	for <ovmsdev@lists.teslaclub.hk>; Tue, 12 Nov 2013 10:56:15 +0800 (HKT)
Received: (qmail 14661 invoked from network); 12 Nov 2013 02:56:15 -0000
X-NetworkBox-HamSign: 0101; OUT; nbmailscanhq1;
	29cce9ac4b01677513d17401e7b377be;
Received: from unknown (HELO nbitphk1.network-box.com) (10.254.50.14)
	by 10.12.18.180 with SMTP; 12 Nov 2013 02:56:15 -0000
Received: (qmail 18501 invoked from network); 12 Nov 2013 02:56:15 -0000
Received: from unknown (HELO ?10.8.2.100?) (10.8.2.100)
	by 10.8.2.62 with SMTP; 12 Nov 2013 02:56:15 -0000
Message-Id: <E3E7DA6F-8994-4C52-ADC1-877B281A580A@webb-johnson.net>
Mime-Version: 1.0 (Mac OS X Mail 7.0 \(1812\))
Date: Tue, 12 Nov 2013 10:56:15 +0800
References: <CEA51450.38D15%tom@idleloop.com>
	<59BE8415-F816-4BD9-9EAD-FCD64C0CCAF1@webb-johnson.net>
	<CAJCxhvTA3SrXSKUETBTMvsFYyHU68AP7dvkh76i0t9EjpYrRfg@mail.gmail.com>
	<D4833358-80BF-417A-B24C-8FE54DE851C1@me.com>
	<CAJCxhvTNch3pWKrrBWYWW=eXgxZqbTXB9MhEimE5H=gg7hkuOA@mail.gmail.com>
To: OVMS Developers <ovmsdev@lists.teslaclub.hk>
In-Reply-To:
X-Mailer: Apple Mail (2.1812)
X-NetworkBox-BounceSign-nbhqhk: 0101;16021;67f4b49d
X-Scanned-By-nbmailscanhq1: Virus scan performed by network-box
X-Scanned-By-nbmailscanhq1: Scanner file id is
	nbmailscanhq1-1384224975.440-14656-000
X-Scanned-By-nbmailscanhq1: No known viruses found in message
	(received+scanned in 0.04/0.05 secs)
X-Scanned-By-nbmailscanhq1: Spam-Check-Result: No,
	hits=0 required=7 tests= autolearn=no version=2.0
X-Spam-Status: No
Subject: Re: [Ovmsdev] Inaccurate car_parktime / car_time
X-BeenThere: ovmsdev@lists.teslaclub.hk
X-Mailman-Version: 2.1.11
Precedence: list
Reply-To: OVMS Developers <ovmsdev@lists.teslaclub.hk>
List-Id: OVMS Developers <ovmsdev.lists.teslaclub.hk>
List-Unsubscribe: <http://lists.teslaclub.hk/mailman/options/ovmsdev>,
	<mailto:ovmsdev-request@lists.teslaclub.hk?subject=unsubscribe>
List-Archive: <http://lists.teslaclub.hk/pipermail/ovmsdev>
List-Post: <mailto:ovmsdev@lists.teslaclub.hk>
List-Help: <mailto:ovmsdev-request@lists.teslaclub.hk?subject=help>
List-Subscribe: <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>,
	<mailto:ovmsdev-request@lists.teslaclub.hk?subject=subscribe>
Content-Type: multipart/mixed; boundary="===============0377878180137418127=="
Sender: ovmsdev-bounces@lists.teslaclub.hk
Errors-To: ovmsdev-bounces@lists.teslaclub.hk
 nbmailscanhq1-1384224976.808-14689-000
 (received+scanned in 0.08/0.26 secs)
--===============0377878180137418127==
Content-Type: multipart/alternative;
 boundary="Apple-Mail=_4F9D3CC2-7F14-44BE-96E3-01C1B6CC2C98"
--Apple-Mail=_4F9D3CC2-7F14-44BE-96E3-01C1B6CC2C98
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
	charset=windows-1252
Surely any adjustment issue is solved by changing the parktime any time =
the cartime is changed?
For example, the module is plugged in so car_time starts at 0. A minute =
later, the car is parked, and car_parktime =3D car_time =3D 60. The =
car_time keeps ticking forward. Then, a few minutes later (at car_time =
300), a GSM lock is obtained and the real date/time obtained. That is =
1384223961, an offset of +1384223661 from car_time. So, car_parktime is =
adjusted +1384223661 (to be 1384223721) and car_time is adjusted =
+1384223661 (to be 1384223961). Before the adjustment, the car was =
parked 300-60 =3D 240 seconds ago. After the adjustment, the car was =
parked 1384223961-1384223721 =3D 240 seconds ago.
While we could drop the 1 second accuracy and only update car_time once =
a minute, I don't think it is that hard to make it work properly to 1 =
second accuracy. At the moment, GSM status is only polled when the GSM =
carrier is obtained (READY state), and it would mean quite a few changes =
to also poll GSM status when no carrier lock is present (there are a lot =
of states surrounding that).
One nice side-effect of having a good per-second accuracy car_time is =
the ability to time-stamp messages nicely (e.g.; sms, historical =
records, etc). Another is charging timers (ACC, etc).
Regarding the sanity checking, I'm not sure how this solves the problem =
of two cell towers giving wildly different readings. How do we know =
which one is correct? Say one says it is 2013, and the other 2011 - =
which one is correct? If we 'lock' to the first one (and disregard the =
second correction), what if the first one was 2011? This problem is =
solvable if we use the GPS clock, but that may be more work than is =
really necessary.
On 11 Nov, 2013, at 6:46 pm, Matt Beard OVMS <smvo@mxf.org.uk> wrote:
>=20
> Why so complicated? Firstly I don't think my proposed solution is =
particularly complicated. Secondly what happens if the GSM clock jumps - =
for example if you are parked close to two GSM cells, one with the =
"correct" time and one with a different time (perhaps simply running =
with time since cell rebooted) - you are likely to get some pretty =
skewed times in OVMS. Also, perhaps more likely, if you are in an area =
of poor GSM signal and so the SIM908 is reporting time based on up-time =
for several hours, then the weather changes or something else allows the =
module to suddenly pick up the correct time - what happens to the "time =
parked"?
>=20
> Matt
>=20
>=20
>=20
> On 11 November 2013 10:38, Michael Jochum <mikeljo@me.com> wrote:
> Hi,
>=20
> why so complicated?
> Remember the time/date from GSM when car gets parked.
> Every 60 sec. get the new Time/date from the GSM Module.
> Little math and you have the Parking time.
> If you need smaller time frames use a ticker with an offset. The =
offset is calculated with the difference between the GSM time an the =
time from the ticker.
>=20
> Bye
>=20
>=20
> Am 11.11.2013 um 09:50 schrieb Matt Beard OVMS <smvo@mxf.org.uk>:
>=20
>> Can I suggest that the update from the SIM908 time has a sanity check =
such that a time well outside the expected range is taken as a new =
starting time for the updates. This will prevent an error that I have =
seen on some charging posts where the clock gets updated during a charge =
(I suspect after a reboot the first time a genuine time is received, =
which could be several minutes after the reboot and after your charge =
starts) this can give very strange times in the charger log. So, I would =
suggest a system similar to the following:
>>=20
>> 1) First time through, record the SIM908 time in epoch seconds, and =
the corresponding car_time
>> 2) Next time through (60 seconds later) get the SIM908 time in epoch =
seconds and subtract the stored value
>> 3) If the difference is between 30 and 120, change car_time to =
stored_car_time + diff
>> 4) Store current SIM908 time in epoch seconds, and the newly =
corrected car_time
>> 5) goto 2
>>=20
>> There is an issue with this in that the time can jump backwards a =
number of seconds - which may break some code at some point!
>>=20
>> A solution to this would be to update car_time if it moves forward, =
but if it moves backwards do this by setting a "stall count" that =
prevents the car_time being updated for that number of 1 second =
intervals. This could safely be a byte as step 2 above ensures we can =
never move backwards more than 30 seconds.
>>=20
>> Matt Beard
>>=20
>>=20
>>=20
>> On 11 November 2013 01:33, Mark Webb-Johnson <mark@webb-johnson.net> =
wrote:
>>=20
>> Tom, Michael,
>>=20
>> GPS time is extremely accurate, but once satellite coverage is lost, =
so is the time.
>>=20
>> GSM time is dependent on the carrier keeping their times accurate in =
their cell towers. In the past this was a problem, but not so much =
nowadays. However, if the GSM connectivity is lost, the clock in the =
SIM908 module we use keeps running - and that is a huge advantage over =
GPS. You can see this in my example, earlier in this email thread - the =
clock is shown as 10/10/10 00:02:51 even in a module without a SIM card =
or GSM antenna attached. I think the SIMCOM chip we use will be pretty =
accurate.
>>=20
>> Reflecting on this, I actually think the following approach would be =
'good enough':
>>=20
>> Use the LED interrupt to keep a track of 104.8576ms ticks per =
interrupt, and increment car_time appropriately.
>>=20
>> Use net.c polling to get the time from the GSM module. Convert it to =
epoch seconds (hopefully not too hard, if we can find a simple algorithm =
for it). If car_time and that differs, then adjust car_time to match but =
ALSO adjust car_parktime by the same amount. This would be done once =
every 60 seconds when GSM is online.
>>=20
>> Use a net_fnbits bit to control whether the above is done or not. =
Remove all car_time code from vehicle modules that turn this on.
>>=20
>> The only tricky bit would be the epoch seconds function. We would =
need to convert a GSM date/time (like =9310/10/10,00:02:51+00=94) into =
UTC number of seconds since January 1st 1970. Or, maybe microchip C =
includes a gmtime() function? I haven't had a chance to check...
>>=20
>>=20
>> On 11 Nov, 2013, at 2:47 am, Tom Saxton <tom@idleloop.com> wrote:
>>=20
>>> I had the same thought, but GPS doesn=92t work when the car is in a =
garage, an important case for a parking timer. Cell coverage seems to be =
much more penetrating than GPS.
>>>=20
>>>    Tom
>>>=20
>>> From: Michael Jochum <mikeljo@me.com>
>>> Date: Sunday, November 10, 2013 at 10:30 AM
>>>=20
>>> Hi,
>>>=20
>>> what do you think about the GPS Clock?
>>>=20
>>> Bye
>>>=20
>>>=20
>>> Am 10.11.2013 um 14:01 schrieb Mark Webb-Johnson =
<mark@webb-johnson.net>:
>>>=20
>>>> Our approach at the moment is very kludgy and not at all accurate.
>>>>=20
>>>> For the cars without internal support for a timer, we increment =
car_time on a ticker() call, which is approximately once per second, but =
not in delay loops. It is really just intended to give a very =
approximate 1 second ticker, not a clock-accurate timer.
>>>>=20
>>>> In the PIC, we have four hardware-level timers. Currently:
>>>>  - Timer 0: Used to drive the main event loop
>>>>  - Timer 1: Interrupt-driven, and used for LED blinking
>>>>  - Timer 2: Used for short delays
>>>>  - Timer 3: Unused
>>>>=20
>>>> I suspect that a better approach would be the Timer 1 we currently =
have. That runs off the FOSC/4 (20Mhz/4 =3D 5MHz) and uses a 1:8 =
pre-scaler, so the internal timer works at 625,000 ticks per second. =
With a 16 bit value, it will overflow (interrupt) 9.53674 times per =
second. By my calculations, that means each =91tick=92 is approximately =
104.8576ms. It would be fairly trivial to keep a counter there, and =
drive car_time from that. I am just not sure how accurate that =
oscillator is (particularly as temperature changes) - but I suspect that =
it would be good enough for what we need.
>>>>=20
>>>> Alternatively, or additionally, the GSM modem has a clock which can =
be polled by AT+CCLK. It would not be hard to do that in the net.c code =
(probably where we normally poll for status once a minute) and adjust =
car_time as necessary there. For example, changing net.c:
>>>>=20
>>>>> rom char NET_CREG_CIPSTATUS[] =3D "AT+CREG?;+CIPSTATUS;+CSQ\r";
>>>>=20
>>>>=20
>>>> to:
>>>>=20
>>>>> rom char NET_CREG_CIPSTATUS[] =3D =
"AT+CREG?;+CSQ;+CCLK?;+CIPSTATUS\r";
>>>>=20
>>>>=20
>>>> Produces:
>>>>=20
>>>>> +CREG: 1,0
>>>>> +CSQ: 0,0
>>>>> +CCLK: =9310/10/10,00:02:51+00=94
>>>>> ERROR
>>>>=20
>>>>=20
>>>> (for my disconnected state).
>>>>=20
>>>> The fact that the time is wrong is irrelevant. All we=92d need it =
to do is look at the GSM module time and look for drift against =
car_time. We would need to protect against large changes (as the module =
gets a GSM connection, there may be a very large jump as the timezone =
and other things get set correctly).
>>>>=20
>>>> The only other =91trick=92 here is that this function would need to =
be controlled by a vehicle feature bit - some cars don=92t need it.
>>>>=20
>>>> The coding should not be too hard, but the testing might take some =
work.
>>>>=20
>>>> Regards, Mark.
>>>>=20
>>>> On 7 Nov, 2013, at 10:17 pm, H=E5kon Markussen =
<hakon.markussen@gmail.com> wrote:
>>>>=20
>>>>> Hi,
>>>>>=20
>>>>> The car_time is incremented in the state_ticker1 (approx once =
every second).
>>>>> However I've noticed that this is extremely inacurate=20
>>>>>=20
>>>>> Today I started a stopwatch when parking the car, and compared it =
to the car_parktime in the iOS app:
>>>>>  - Stopwatch: 8:00 (eight hours)
>>>>>  - car_parktime: 6:01 (six hours and one minute
>>>>> A difference of 1 hour and 59 minutes during 8 hours!
>>>>>=20
>>>>> I wonder if this could be done in an other way?=20
>>>>> E.g. by pulling the time from the GPS?
>>>>>=20
>>>>> Best regards.
>>>>> H=E5kon Markussen
>>>>> OvmsDev mailing list
>>>>> OvmsDev@lists.teslaclub.hk
>>>>=20
>>>=20
>>> _______________________________________________ OvmsDev mailing list =
OvmsDev@lists.teslaclub.hk =
>>=20
>>=20
>>=20
>>=20
>=20
>=20
>=20
>=20
Content-Type: text/html;
<html><head><meta http-equiv=3D"Content-Type" content=3D"text/html =
charset=3Dwindows-1252"></head><body style=3D"word-wrap: break-word; =
-webkit-nbsp-mode: space; -webkit-line-break: =
after-white-space;"><div><br></div>Surely any adjustment issue is solved =
by changing the parktime any time the cartime is =
changed?<div><br></div><div>For example, the module is plugged in so =
car_time starts at 0. A minute later, the car is parked, and =
car_parktime =3D car_time =3D 60. The car_time keeps ticking forward. =
Then, a few minutes later (at car_time 300), a GSM lock is obtained and =
the real date/time obtained. That is&nbsp;1384223961, an offset of =
+1384223661 from car_time. So, car_parktime is adjusted +1384223661 (to =
be&nbsp;1384223721) and car_time is adjusted +1384223661 (to =
be&nbsp;1384223961). Before the adjustment, the car was parked 300-60 =3D =
parked&nbsp;1384223961-1384223721 =3D 240 seconds =
ago.</div><div><br></div><div>While we could drop the 1 second accuracy =
and only update car_time once a minute, I don't think it is that hard to =
make it work properly to 1 second accuracy. At the moment, GSM status is =
only polled when the GSM carrier is obtained (READY state), and it would =
mean quite a few changes to also poll GSM status when no carrier lock is =
present (there are a lot of states surrounding =
that).</div><div><br></div><div>One nice side-effect of having a good =
per-second accuracy car_time is the ability to time-stamp messages =
nicely (e.g.; sms, historical records, etc). Another is charging timers =
(ACC, etc).</div><div><br></div><div>Regarding the sanity checking, I'm =
not sure how this solves the problem of two cell towers giving wildly =
different readings. How do we know which one is correct? Say one says it =
is 2013, and the other 2011 - which one is correct? If we 'lock' to the =
first one (and disregard the second correction), what if the first one =
was 2011? This problem is solvable if we use the GPS clock, but that may =
be more work than is really necessary.</div><div><br></div><div>Regards, =
Mark.</div><div><br><div><div>On 11 Nov, 2013, at 6:46 pm, Matt Beard =
OVMS &lt;<a href=3D"mailto:smvo@mxf.org.uk">smvo@mxf.org.uk</a>&gt; =
wrote:</div><br class=3D"Apple-interchange-newline"><blockquote =
type=3D"cite"><div dir=3D"ltr"><div><br>Why so complicated? Firstly I =
don't think my proposed solution is particularly complicated. Secondly =
what happens if the GSM clock jumps - for example if you are parked =
close to two GSM cells, one with the "correct" time and one with a =
different time (perhaps simply running with time since cell rebooted) - =
you are likely to get some pretty skewed times in OVMS. Also, perhaps =
more likely, if you are in an area of poor GSM signal and so the SIM908 =
is reporting time based on up-time for several hours, then the weather =
changes or something else allows the module to suddenly pick up the =
correct time - what happens to the "time parked"?<br>
<br></div>Matt<br><br></div><div class=3D"gmail_extra"><br><br><div =
class=3D"gmail_quote">On 11 November 2013 10:38, Michael Jochum <span =
dir=3D"ltr">&lt;<a href=3D"mailto:mikeljo@me.com" =
target=3D"_blank">mikeljo@me.com</a>&gt;</span> wrote:<br>
<blockquote class=3D"gmail_quote" style=3D"margin:0 0 0 =
.8ex;border-left:1px #ccc solid;padding-left:1ex"><div =
style=3D"word-wrap:break-word">Hi,<div><br></div><div>why so =
complicated?</div><div>Remember the time/date from GSM when car gets =
parked.</div>
<div>Every 60 sec. get the new Time/date from the GSM =
Module.</div><div>Little math and you have the Parking =
time.</div><div>If you need smaller time frames use a ticker with an =
offset. The offset is calculated with the difference between the GSM =
time an the time from the ticker.</div>
<div><br></div><div>Bye</div><div>Michael</div><div><br></div><div><br><di=
v><div>Am 11.11.2013 um 09:50 schrieb Matt Beard OVMS &lt;<a =
href=3D"mailto:smvo@mxf.org.uk" =
target=3D"_blank">smvo@mxf.org.uk</a>&gt;:</div><div><div class=3D"h5">
<br><blockquote type=3D"cite"><div =
dir=3D"ltr"><div><div><div><div><div><div><div><div>Can I suggest that =
the update from the SIM908 time has a sanity check such that a time well =
outside the expected range is taken as a new starting time for the =
updates. This will prevent an error that I have seen on some charging =
posts where the clock gets updated during a charge (I suspect after a =
reboot the first time a genuine time is received, which could be several =
minutes after the reboot and after your charge starts) this can give =
very strange times in the charger log. So, I would suggest a system =
similar to the following:<br>
<br></div>1) First time through, record the SIM908 time in epoch =
seconds, and the corresponding car_time<br></div>2) Next time through =
(60 seconds later) get the SIM908 time in epoch seconds and subtract the =
stored value<br>
</div>3) If the difference is between 30 and 120, change car_time to =
stored_car_time + diff<br></div>4) Store current SIM908 time in epoch =
seconds, and the newly corrected car_time<br></div>5) goto =
2<br><br></div>There is an issue with this in that the time can jump =
backwards a number of seconds - which may break some code at some =
point!<br>
<br></div>A solution to this would be to update car_time if it moves =
forward, but if it moves backwards do this by setting a "stall count" =
that prevents the car_time being updated for that number of 1 second =
never move backwards more than 30 seconds.<br>
<br></div>Matt Beard<br><br></div><div class=3D"gmail_extra"><br><br><div =
class=3D"gmail_quote">On 11 November 2013 01:33, Mark Webb-Johnson <span =
dir=3D"ltr">&lt;<a href=3D"mailto:mark@webb-johnson.net" =
target=3D"_blank">mark@webb-johnson.net</a>&gt;</span> wrote:<br>
style=3D"word-wrap:break-word"><div><br></div>Tom, =
Michael,<div><br></div><div>GPS time is extremely accurate, but once =
satellite coverage is lost, so is the time.</div>
<div><br></div><div>GSM time is dependent on the carrier keeping their =
times accurate in their cell towers. In the past this was a problem, but =
not so much nowadays. However, if the GSM connectivity is lost, the =
clock in the SIM908 module we use keeps running - and that is a huge =
advantage over GPS. You can see this in my example, earlier in this =
email thread - the clock is shown as 10/10/10 00:02:51 even in a module =
without a SIM card or GSM antenna attached. I think the SIMCOM chip we =
use will be pretty accurate.</div>
<div><br></div><div>Reflecting on this, I actually think the following =
approach would be 'good enough':</div><div><br></div><div><ol><li>Use =
the LED interrupt to keep a track of&nbsp;104.8576ms ticks per =
interrupt, and increment car_time appropriately.<br>
<br></li><li>Use net.c polling to get the time from the GSM module. =
Convert it to epoch seconds (hopefully not too hard, if we can find a =
simple algorithm for it). If car_time and that differs, then adjust =
car_time to match but ALSO adjust car_parktime by the same amount. This =
would be done once every 60 seconds when GSM is online.<br>
<br></li><li>Use a&nbsp;net_fnbits bit to control whether the above is =
done or not. Remove all car_time code from vehicle modules that turn =
this on.</li></ol></div><div><br></div><div>The only tricky bit would be =
the epoch seconds function. We would need to convert a GSM date/time =
(like&nbsp;=9310/10/10,00:02:51+00=94) into UTC number of seconds since =
January 1st 1970. Or, maybe microchip C includes a gmtime() function? I =
haven't had a chance to check...</div>
<div><br></div><div>Regards, Mark.</div><div><br><div><div>On 11 Nov, =
2013, at 2:47 am, Tom Saxton &lt;<a href=3D"mailto:tom@idleloop.com" =
target=3D"_blank">tom@idleloop.com</a>&gt; wrote:</div><br><blockquote =
type=3D"cite">
<div =
style=3D"word-wrap:break-word;font-size:14px;font-family:Calibri,sans-seri=
f"><div>I had the same thought, but GPS doesn=92t work when the car is =
in a garage, an important case for a parking timer. Cell coverage seems =
to be much more penetrating than GPS.</div>
<div><br></div><div>&nbsp; &nbsp;Tom</div><div><br></div><span><div =
style=3D"font-family:Calibri;font-size:11pt;text-align:left;border-width:1=
pt medium medium;border-style:solid none none;padding:3pt 0in =
0in;border-top-color:rgb(181,196,223)">
<span style=3D"font-weight:bold">From: </span> Michael Jochum &lt;<a =
target=3D"_blank">mikeljo@me.com</a>&gt;<br><span =
style=3D"font-weight:bold">Reply-To: </span> OVMS Developers &lt;<a =
href=3D"mailto:ovmsdev@lists.teslaclub.hk" =
target=3D"_blank">ovmsdev@lists.teslaclub.hk</a>&gt;<br>
<span style=3D"font-weight:bold">Date: </span> Sunday, November 10, 2013 =
at 10:30 AM<br><span style=3D"font-weight:bold">To: </span> OVMS =
Developers &lt;<a href=3D"mailto:ovmsdev@lists.teslaclub.hk" =
<span style=3D"font-weight:bold">Subject: </span> Re: [Ovmsdev] =
Inaccurate car_parktime / car_time<br></div><div><br></div><div><div =
style=3D"word-wrap:break-word">Hi,<div><br></div><div>what do you think =
about the GPS Clock?</div>
v><div>Am 10.11.2013 um 14:01 schrieb Mark Webb-Johnson &lt;<a =
target=3D"_blank">mark@webb-johnson.net</a>&gt;:</div>
<br><blockquote type=3D"cite"><div style=3D"word-wrap:break-word">Our =
approach at the moment is very kludgy and not at all =
accurate.<div><br></div><div>For the cars without internal support for a =
timer, we increment car_time on a ticker() call, which is approximately =
once per second, but not in delay loops. It is really just intended to =
give a very approximate 1 second ticker, not a clock-accurate =
timer.</div>
<div><br></div><div>In the PIC, we have four hardware-level timers. =
Currently:</div><div>&nbsp;- Timer 0: Used to drive the main event =
loop</div><div>&nbsp;- Timer 1: Interrupt-driven, and used for LED =
blinking</div><div>&nbsp;- Timer 2: Used for short delays</div>
<div>&nbsp;- Timer 3: Unused</div><div><br></div><div>I suspect that a =
better approach would be the Timer 1 we currently have. That runs off =
the FOSC/4 (20Mhz/4 =3D 5MHz) and uses a 1:8 pre-scaler, so the internal =
timer works at&nbsp;625,000 ticks per second. With a 16 bit value, it =
will overflow (interrupt)&nbsp;9.53674 times per second. By my =
calculations, that means each =91tick=92 is approximately 104.8576ms. It =
would be fairly trivial to keep a counter there, and drive car_time from =
that. I am just not sure how accurate that oscillator is (particularly =
as temperature changes) - but I suspect that it would be good enough for =
what we need.</div>
<div><br></div><div>Alternatively, or additionally, the GSM modem has a =
clock which can be polled by AT+CCLK. It would not be hard to do that in =
the net.c code (probably where we normally poll for status once a =
minute) and adjust car_time as necessary there. For example, changing =
net.c:</div>
<div><br></div><div><blockquote style=3D"margin:0 0 0 =
40px;border:none;padding:0px" type=3D"cite">rom char =
"AT+CREG?;+CIPSTATUS;+CSQ\r";</blockquote></div><div><br></div><div>to:</d=
iv><div><br>
"AT+CREG?;+CSQ;+CCLK?;+CIPSTATUS\r";</blockquote></div><div><br></div><div=
>Produces:</div><div>
40px;border:none;padding:0px" type=3D"cite"><div>+CREG: =
1,0</div><div>+CSQ: 0,0</div><div>+CCLK: =
=9310/10/10,00:02:51+00=94</div><div>ERROR</div></blockquote></div><div><b=
r></div>
<div>
(for my disconnected state).</div><div><br></div><div>The fact that the =
time is wrong is irrelevant. All we=92d need it to do is look at the GSM =
module time and look for drift against car_time. We would need to =
protect against large changes (as the module gets a GSM connection, =
there may be a very large jump as the timezone and other things get set =
correctly).</div>
<div><br></div><div>The only other =91trick=92 here is that this =
function would need to be controlled by a vehicle feature bit - some =
cars don=92t need it.</div><div><br></div><div>The coding should not be =
too hard, but the testing might take some work.</div>
<div><br></div><div>Regards, Mark.</div><div><br><div><div>On 7 Nov, =
2013, at 10:17 pm, H=E5kon Markussen &lt;<a =
href=3D"mailto:hakon.markussen@gmail.com" =
target=3D"_blank">hakon.markussen@gmail.com</a>&gt; =
wrote:</div><br><blockquote type=3D"cite">
<div =
dir=3D"ltr"><div><div><div><div><div><div><div><div>Hi,<br><br></div>The =
car_time is incremented in the state_ticker1 (approx once every =
second).<br></div>However I've noticed that this is extremely inacurate =
<br>
<br>
</div>Today I started a stopwatch when parking the car, and compared it =
to the car_parktime in the iOS app:<br></div>&nbsp;- Stopwatch: 8:00 =
(eight hours)<br></div>&nbsp;- car_parktime: 6:01 (six hours and one =
minute<br></div>A difference of 1 hour and 59 minutes during 8 =
hours!<br>
<br>I wonder if this could be done in an other way? <br>E.g. by pulling =
the time from the GPS?<br><br></div>Best regards.<br></div>H=E5kon =
Markussen<br></div>
_______________________________________________<br>OvmsDev mailing =
list<br><a href=3D"mailto:OvmsDev@lists.teslaclub.hk" =
target=3D"_blank">OvmsDev@lists.teslaclub.hk</a><br><a =
href=3D"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev" =
target=3D"_blank">http://lists.teslaclub.hk/mailman/listinfo/ovmsdev</a><b=
r>
</blockquote></div><br></div></div>_______________________________________=
________<br>OvmsDev mailing list<br><a =
r>
</blockquote></div><br></div></div></div>_________________________________=
______________
<a href=3D"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev" =
</span></div>
r>
</blockquote></div><br></div></div><br>___________________________________=
____________<br>
r>
<br></blockquote></div><br></div>
r>
</blockquote></div></div></div><br></div></div><br>_______________________=
<a =
href=3D"mailto:OvmsDev@lists.teslaclub.hk">OvmsDev@lists.teslaclub.hk</a><=
br>
r>
list<br><a =
br>http://lists.teslaclub.hk/mailman/listinfo/ovmsdev<br></blockquote></di=
v><br></div></body></html>=
--Apple-Mail=_4F9D3CC2-7F14-44BE-96E3-01C1B6CC2C98--
Content-Type: text/plain; charset="us-ascii"
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
--===============0377878180137418127==--
