;    Project:       Open Vehicle Monitor System
;    Date:          6 May 2012
;    Changes:
;    1.0  Initial release
; Permission is hereby granted, free of charge, to any person obtaining a copy
; of this software and associated documentation files (the "Software"), to deal
; in the Software without restriction, including without limitation the rights
; to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
; copies of the Software, and to permit persons to whom the Software is
; furnished to do so, subject to the following conditions:
; The above copyright notice and this permission notice shall be included in
; all copies or substantial portions of the Software.
; THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
; IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
; FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
; AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
; LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
; OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
; THE SOFTWARE.
#include <stdlib.h>
#include <delays.h>
#include <string.h>
#include "ovms.h"
#include "params.h"
#include "net_msg.h"
// Mitsubishi state variables
#pragma udata overlay vehicle_overlay_data
signed char mi_batttemps[24];           // Temperature buffer, holds first two temps from the 0x6e1 messages (24 of the 64 values)
#pragma udata
// vehicle_mitsubishi_ticker1()
// This function is an entry point from the main() program loop, and
// gives the CAN framework a ticker call approximately once per second
BOOL vehicle_mitsubishi_ticker1(void)
  return FALSE;
// tc_state_ticker10()
// State Model: 10 second ticker
// This function is called approximately once every 10 seconds (since state
// was first entered), and gives the state a timeslice for activity.
BOOL vehicle_mitsubishi_ticker10(void)
// Check for charging state
// car_door1 Bits used: 0-7
// Function net_prep_stat in net_msg.c uses car_doors1bits.ChargePort to determine SMS-printout
// 0x04 Chargeport open, bit 2 set
// 0x08 Pilot signal on, bit 3 set
// 0x10 Vehicle charging, bit 4 set
// 0x0C Chargeport open and pilot signal, bits 2,3 set
// 0x1C Bits 2,3,4 set
  if ((car_linevoltage > 100) && (car_chargecurrent < 1))
    car_chargestate = 4; //Done
    car_doors1 = 0x0C;  // Charge connector connected
  if ((car_linevoltage > 100) && (car_chargecurrent > 1))
    car_chargestate = 1; //Charging
    car_doors1 = 0x1C;
  if (car_linevoltage < 100)  // AC line voltage < 100
    car_doors1 = 0x00;  // charging connector unplugged
  return FALSE;
// can_poll()
// gives the CAN framework an opportunity to poll for data.
BOOL vehicle_mitsubishi_poll0(void)
  unsigned int id = ((unsigned int)RXB0SIDL >>5)
                  + ((unsigned int)RXB0SIDH <<3);
  can_datalength = RXB0DLC & 0x0F; // number of received bytes
  can_databuffer[0] = RXB0D0;
  can_databuffer[1] = RXB0D1;
  can_databuffer[2] = RXB0D2;
  can_databuffer[3] = RXB0D3;
  can_databuffer[4] = RXB0D4;
  can_databuffer[5] = RXB0D5;
  can_databuffer[6] = RXB0D6;
  can_databuffer[7] = RXB0D7;
  RXB0CONbits.RXFUL = 0; // All bytes read, Clear flag
  switch (id)
    case 0x346:
      car_estrange = (unsigned int)can_databuffer[7]; // Range
    break;
    case 0x373:
      // BatCurr & BatVolt
    break;
    case 0x374:
      car_SOC = (char)(((int)can_databuffer[1] - 10) / 2); //SOC
      car_idealrange = ((((unsigned int)car_SOC) * 80) / 100);
    break;
    case 0x389:
      car_linevoltage = (unsigned int)can_databuffer[1];
      car_chargecurrent = ((unsigned int)can_databuffer[6] / 10);
    break;
  return TRUE;
BOOL vehicle_mitsubishi_poll1(void)
  unsigned int id = ((unsigned int)RXB1SIDL >>5)
                  + ((unsigned int)RXB1SIDH <<3);
  unsigned char CANctrl;
  can_datalength = RXB1DLC & 0x0F; // number of received bytes
  can_databuffer[0] = RXB1D0;
  can_databuffer[1] = RXB1D1;
  can_databuffer[2] = RXB1D2;
  can_databuffer[3] = RXB1D3;
  can_databuffer[4] = RXB1D4;
  can_databuffer[5] = RXB1D5;
  can_databuffer[6] = RXB1D6;
  can_databuffer[7] = RXB1D7;
  CANctrl=RXB1CON;              // copy CAN RX1 Control register
  RXB1CONbits.RXFUL = 0;        // All bytes read, Clear flag
  switch (id)
    case 0x285:
      if (can_databuffer[6] == 0x0C) // Car in park
        //car_doors1 |= 0x40;     //  PARK
        car_doors1 &= ~0x80;    // CAR OFF
      if (can_databuffer[6] == 0x0E) // Car not in park
        //car_doors1 &= ~0x40;     //  NOT PARK
        car_doors1 |= 0x80;     // CAR ON
    break;
    case 0x412:
//      if (can_mileskm == 'K') // Speed & Odo
        car_speed = can_databuffer[1];
//      else
//        car_speed = (unsigned char) ((((unsigned long)can_databuffer[1] * 1000)+500)/1609);
        car_odometer = (((can_databuffer[2] << 8) + can_databuffer[3]) << 8) + can_databuffer[4];
    break;
      case 0x6e1:
          // Calculate average battery pack temperature based on 24 of the 64 temperature values
          // Message 0x6e1 carries two temperatures for each of 12 banks, bank number (1..12) in byte 0,
          // temperatures in bytes 2 and 3, offset by 50C
          int idx = can_databuffer[0] - 1;
          if((idx >= 0) && (idx <= 11))
            int i;
            int tbattery = 0;
            idx <<= 2;
            mi_batttemps[idx] = (signed char)(can_databuffer[2] - 50);
            mi_batttemps[idx + 1] = (signed char)(can_databuffer[3] - 50);
            car_tpem = 100;     // Min cell temp
            car_tmotor = 0;     // Max cell temp
            for(i=0; i<24; i++)
                signed char t = mi_batttemps[i];
                tbattery += t;
                if(t < car_tpem) car_tpem = t;
                if(t > car_tmotor) car_tmotor = t;
            car_tbattery = tbattery / 24;
            car_stale_temps = 120; // Reset stale indicator
          break;
  return TRUE;
// vehicle_mitsubishi_initialise()
// gives the CAN framework an opportunity to initialise itself.
BOOL vehicle_mitsubishi_initialise(void)
  char *p;
  int i;
  car_type[0] = 'M'; // Car is type MI - Mitsubishi iMiev
  car_type[1] = 'I';
  car_type[2] = 0;
  car_type[3] = 0;
  car_type[4] = 0;
  // Vehicle specific data initialisation
  car_stale_timer = -1; // Timed charging is not supported for OVMS MI
  car_time = 0;
  // Clear the battery temperatures
  for(i=0; i<12; i++) mi_batttemps[i] = 0;
  CANCON = 0b10010000; // Initialize CAN
  while (!CANSTATbits.OPMODE2); // Wait for Configuration mode
  // We are now in Configuration Mode
  // Filters: low byte bits 7..5 are the low 3 bits of the filter, and bits 4..0 are all zeros
  //          high byte bits 7..0 are the high 8 bits of the filter
  //          So total is 11 bits
  // Buffer 0 (filters 0, 1) for extended PID responses
  RXB0CON = 0b00000000;
//  // Mask0 = 0b11111111000 (0x7F8), filterbit 0,1,2 deactivated
//  //RXM0SIDL = 0b00000000;
//  //RXM0SIDH = 0b11111111;
//  RXM0SIDL = 0b00000000;
//  RXM0SIDH = 0b11111100;
  // Mask0 = 0b11100000000 (0x700), filterbit 0,1,2 deactivated
  RXM0SIDH = 0b11100000;
  // Filter0 0b01100000000 (0x300..0x3F8)
  RXF0SIDL = 0b00000000;
  RXF0SIDH = 0b01100000;
  // Buffer 1 (filters 2, 3, 4 and 5) for direct can bus messages
  RXB1CON  = 0b00000000;	// RX buffer1 uses Mask RXM1 and filters RXF2, RXF3, RXF4, RXF5
   // Mask1 = 0b11111111111 (0x7FF)
  RXM1SIDL = 0b11100000;
  RXM1SIDH = 0b11111111;
  // Filter2 0b01010000101 (0x285)
  RXF2SIDL = 0b10100000;
  RXF2SIDH = 0b01010000;
  // Filter3 0b10000010010 (0x412)
  RXF3SIDL = 0b01000000;
  RXF3SIDH = 0b10000010;
  // Filter4 0b11011100001 (0x6E1)
  // Sample the first of the battery values
  RXF4SIDL = 0b00100000;
  RXF4SIDH = 0b11011100;
  // CAN bus baud rate
  BRGCON1 = 0x01; // SET BAUDRATE to 500 Kbps
  BRGCON2 = 0xD2;
  BRGCON3 = 0x02;
  CIOCON = 0b00100000; // CANTX pin will drive VDD when recessive
  if (sys_features[FEATURE_CANWRITE]>0)
    CANCON = 0b00000000;  // Normal mode
  else
    CANCON = 0b01100000; // Listen only mode, Receive bufer 0
  // Hook in...
  vehicle_fn_poll0 = &vehicle_mitsubishi_poll0;
  vehicle_fn_poll1 = &vehicle_mitsubishi_poll1;
  vehicle_fn_ticker1 = &vehicle_mitsubishi_ticker1;
  vehicle_fn_ticker10 = &vehicle_mitsubishi_ticker10;
  net_fnbits |= NET_FN_INTERNALGPS;   // Require internal GPS
  net_fnbits |= NET_FN_12VMONITOR;    // Require 12v monitor
  return TRUE;
