=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.01 13:33:39 =~=~=~=~=~=~=~=~=~=~=~= OVMS# wifi wifi wifi mode apclient OVMS Netgear_Guest2 wifi I (65389854) ovms-server-v2: Send MP-0 S95.0,M,1,0,done,standard,159,148,24,0,0,410,7,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0 I (65389864) ovms-server-v2: Send MP-0 D78,128,5,25,24,25,7775,539363,0,65389,24,2,1,1,13.02,0,12.6,0,25,0,0 I (65389864) ovms-server-v2: Send MP-0 L38.958851,-121.111031,314,381,1,1,0,7775,0,0.398,0,0 I (65389864) ovms-server-v2: Send MP-0 F3.2.014/ota_1/eap (build idf v3.3.2-881-g22d636b Aug 4 2020 16:26:20),5YJRE1A16A1000834,22,1,TR2N,Netgear_Guest2 OVMS# wifi wifi mode client gregnet 40:b0:76:32:ea:72 Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)... OVMS# I (65392534) esp32wifi: Stopping WIFI station I (65392534) netmanager: WIFI client stop I (65392534) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64) I (65392534) netmanager: Set DNS#0 9.9.9.9 I (65392534) netmanager: Set DNS#1 8.8.8.8 I (65392534) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority I (65392534) wifi:state: run -> init (0) I (65392544) wifi:pm stop, total sleep time: 627018803 us / 667166463 us I (65392544) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1 I (65392544) ovms-server-v2: Status: Disconnected W (65392554) netmanager: CleanupConnections: can't get AP station list I (65392554) wifi:flush txq I (65392554) wifi:stop sw txq I (65392554) wifi:lmac stop hw txq I (65392564) time: Network was reconfigured: restarting SNTP client I (65392574) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65392574) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65392594) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE I (65392624) netmanager: WIFI access point is down I (65392624) esp32wifi: AP stopped I (65393074) wifi:mode : sta (30:ae:a4:43:92:88) OVMS#  I (65395254) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65395384) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  I (65396084) wifi:state: init -> auth (b0) I (65396094) wifi:state: auth -> assoc (0) I (65396104) wifi:state: assoc -> run (10) OVMS#  I (65400944) housekeeping: 2020-09-01 13:33:59 PDT (RAM: 8b=82676-83308 32b=9576) OVMS#  I (65401854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B I (65401854) ovms-server-v2: Status: Connecting... OVMS#  I (65402454) ovms-server-v2: Connection successful I (65402454) ovms-server-v2: Status: Logging in... I (65402454) ovms-server-v2: Sending server login: MP-C 0 3tU3AjUBWDjTegrKhFv8SQ rvrEFsVvIpc1WcPcnFTuAA== ROADSTER834B OVMS#  W (65402854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65402854) esp32wifi: StartConnect: error 0xffffffff starting scan I (65402974) ovms-server-v2: Got server response: MP-S 0 +8G+EBcHanqxI+T5lvipOU p23wI7eWAhPkK6DU97Iu7A== I (65402974) ovms-server-v2: Server token is +8G+EBcHanqxI+T5lvipOU and digest is p23wI7eWAhPkK6DU97Iu7A== I (65402974) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (65402974) ovms-server-v2: Shared secret key is +8G+EBcHanqxI+T5lvipOU3tU3AjUBWDjTegrKhFv8SQ (44 bytes) I (65402974) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (65402984) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS#  I (65404214) wifi:state: run -> init (fc0) I (65404214) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65404224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65404234) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT OVMS# wifi I (65414914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65415034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65415034) wifi:state: init -> auth (b0) I (65415044) wifi:state: auth -> assoc (0) I (65415044) wifi:state: assoc -> run (10) OVMS# wifi Power: on Mode: Client mode STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# W (65422854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65422854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65423144) wifi:state: run -> init (fc0) I (65423154) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65423154) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  wifi wifi mode client gregnet 40:b0:76:32:ea:72 I (65434914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69 I (65435034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65435034) wifi:state: init -> auth (b0) I (65435034) wifi:state: auth -> assoc (0) I (65435044) wifi:state: assoc -> run (10) OVMS# wifi mode client gregnet 40:b0:76:32:ea:72 Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)... OVMS# I (65437934) wifi:state: run -> init (0) I (65437934) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65437944) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE OVMS#  I (65452544) event: station ip lost I (65452554) esp32wifi: STA lost IP from SSID 'gregnet' AP 00:00:00:00:00:00 OVMS#  wifi mode client gregnet 40:b0:76:32:ea:72 wifi Power: on Mode: Client mode STA SSID: gregnet (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# wifi wifi mode client gregnet 40:b0:76:32:ea:72 Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)... OVMS# wifi mode client gregnet 40:b0:76:32:ea:72 wifi Power: on Mode: Client mode STA SSID: gregnet (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# wifi wifi mode client gregnet 40:b0:76:32:ea:72 wifi wifi mode client gregnet 40:b0:76:32:ea:72 wifi wifi mode client gregnet 40:b0:76:32:ea:72 wifi wifi wifi mode apclient OVMS Netgear_Guest2 Starting WIFI as Access Point and Client... OVMS# I (65544274) esp32wifi: Stopping WIFI station I (65544284) wifi:flush txq I (65544284) wifi:stop sw txq I (65544284) wifi:lmac stop hw txq I (65544804) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (65544804) wifi:Total power save buffer number: 8 I (65544854) netmanager: WIFI access point is up I (65544854) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1 OVMS#  I (65547284) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65547414) wifi:ap channel adjust o:1,1 n:6,2 I (65547414) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1 OVMS#  I (65548114) wifi:state: init -> auth (b0) I (65548144) wifi:state: auth -> assoc (0) I (65548144) wifi:state: assoc -> run (10) I (65548194) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72 I (65548194) wifi:security type: 3, phy: bgn, rssi: -67 I (65548194) wifi:pm start, type: 1 I (65548204) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2 I (65548354) wifi:AP's beacon interval = 102400 us, DTIM period = 3 OVMS#  I (65549944) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (65549964) netmanager: WIFI client got IP I (65549964) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (65549994) netmanager: WIFI client has good signal quality (-86.7 dBm); connect I (65549994) netmanager: Interface priority is st21 (10.30.1.105/255.255.255.0 gateway 10.30.1.1) I (65549994) netmanager: Set DNS#0 9.9.9.9 I (65549994) netmanager: Set DNS#1 8.8.8.8 I (65549994) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority I (65550034) time: Network was reconfigured: restarting SNTP client I (65550034) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65550034) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65550044) ovms-server-v2: Status: Disconnected OVMS#  wifi mode apclient OVMS Netgear_Guest2 wifi Power: on Mode: Access-Point + Client mode STA SSID: Netgear_Guest2 (-68.2 dBm) [fixed] MAC: 30:ae:a4:43:92:88 IP: 10.30.1.105/255.255.255.0 GW: 10.30.1.1 AP: 40:b0:76:32:ea:72 AP SSID: OVMS MAC: 30:ae:a4:43:92:89 IP: 192.168.4.1 AP Stations: 0 OVMS# I (65609854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B I (65609854) ovms-server-v2: Status: Connecting... OVMS#  I (65610484) ovms-server-v2: Connection successful I (65610484) ovms-server-v2: Status: Logging in... I (65610484) ovms-server-v2: Sending server login: MP-C 0 ETTIk8+djSnT2pvZkaoXqP noJBBLMTQuDoIULvoK4vaA== ROADSTER834B OVMS#  I (65610794) ovms-server-v2: Got server response: MP-S 0 ICVwbgzYKsBHB76n8Dhvh0 cDdLQRD5nBdzLGNKZtymRA== I (65610794) ovms-server-v2: Server token is ICVwbgzYKsBHB76n8Dhvh0 and digest is cDdLQRD5nBdzLGNKZtymRA== I (65610804) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (65610804) ovms-server-v2: Shared secret key is ICVwbgzYKsBHB76n8Dhvh0ETTIk8+djSnT2pvZkaoXqP (44 bytes) I (65610804) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (65610824) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS#  wifi wifi mode apclient OVMS Netgear_Guest2 wifi wifi mode client gregnet 40:b0:76:32:ea:72 Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)... OVMS# I (65626034) esp32wifi: Stopping WIFI station I (65626034) netmanager: WIFI client stop I (65626034) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64) I (65626034) netmanager: Set DNS#0 9.9.9.9 I (65626034) netmanager: Set DNS#1 8.8.8.8 I (65626034) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority I (65626044) wifi:state: run -> init (0) I (65626044) wifi:pm stop, total sleep time: 71417171 us / 77847939 us I (65626044) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1 I (65626054) ovms-server-v2: Status: Disconnected W (65626064) netmanager: CleanupConnections: can't get AP station list I (65626064) wifi:flush txq I (65626064) wifi:stop sw txq I (65626064) wifi:lmac stop hw txq I (65626074) time: Network was reconfigured: restarting SNTP client I (65626074) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65626074) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65626094) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE I (65626124) netmanager: WIFI access point is down I (65626124) esp32wifi: AP stopped I (65626574) wifi:mode : sta (30:ae:a4:43:92:88) OVMS#  I (65628764) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65628884) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  I (65629594) wifi:state: init -> auth (b0) I (65629604) wifi:state: auth -> assoc (0) I (65629614) wifi:state: assoc -> run (10) OVMS#  W (65635854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65635854) esp32wifi: StartConnect: error 0xffffffff starting scan I (65635854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B I (65635854) ovms-server-v2: Status: Connecting... OVMS#  I (65636384) ovms-server-v2: Connection successful I (65636384) ovms-server-v2: Status: Logging in... I (65636384) ovms-server-v2: Sending server login: MP-C 0 fP1CbH+MJWKj2XaEcw8rDr d4NYQ2/bqw445o92cdIQGQ== ROADSTER834B OVMS#  I (65636904) ovms-server-v2: Got server response: MP-S 0 yEAMezBVOYp1Im8YoKC6lP L5PXJRAw90Ue1YaTrisN0A== I (65636904) ovms-server-v2: Server token is yEAMezBVOYp1Im8YoKC6lP and digest is L5PXJRAw90Ue1YaTrisN0A== I (65636904) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (65636904) ovms-server-v2: Shared secret key is yEAMezBVOYp1Im8YoKC6lPfP1CbH+MJWKj2XaEcw8rDr (44 bytes) I (65636904) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (65636914) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS#  I (65637674) wifi:state: run -> init (fc0) I (65637684) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65637684) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65637694) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT OVMS#  I (65647914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65648034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65648034) wifi:state: init -> auth (b0) I (65648054) wifi:state: auth -> assoc (0) I (65648074) wifi:state: assoc -> run (10) OVMS#  W (65655854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65655854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65656434) wifi:state: run -> init (fc0) I (65656434) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65656434) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  I (65667914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67 I (65668034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65668034) wifi:state: init -> auth (b0) I (65668044) wifi:state: auth -> assoc (0) I (65668054) wifi:state: assoc -> run (10) OVMS#  W (65675854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65675854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65676074) wifi:state: run -> init (fc0) I (65676074) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65676074) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  I (65686054) event: station ip lost I (65686064) esp32wifi: STA lost IP from SSID 'Netgear_Guest2' AP 00:00:00:00:00:00 OVMS#  I (65687914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69 I (65688034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65688034) wifi:state: init -> auth (b0) I (65688044) wifi:state: auth -> assoc (0) I (65688054) wifi:state: assoc -> run (10) OVMS# wi W (65695854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65695854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS# wi I (65696154) wifi:state: run -> init (fc0) I (65696164) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65696164) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS# wi Power: on Mode: Client mode STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# I (65700934) housekeeping: 2020-09-01 13:38:59 PDT (RAM: 8b=82204-83048 32b=9576) OVMS#  I (65707914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69 I (65708034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65708034) wifi:state: init -> auth (b0) I (65708034) wifi:state: auth -> assoc (0) I (65708044) wifi:state: assoc -> run (10) OVMS#  W (65715854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65715854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65716224) wifi:state: run -> init (fc0) I (65716224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65716224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  wi Power: on Mode: Client mode STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# I (65727914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69 I (65728034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65728034) wifi:state: init -> auth (b0) I (65728034) wifi:state: auth -> assoc (0) I (65728054) wifi:state: assoc -> run (10) OVMS#  W (65735854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65735854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65736084) wifi:state: run -> init (fc0) I (65736094) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65736094) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  I (65747914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68 I (65748034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65748034) wifi:state: init -> auth (b0) I (65748034) wifi:state: auth -> assoc (0) I (65748054) wifi:state: assoc -> run (10) OVMS#  W (65755854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65755854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS#  I (65756134) wifi:state: run -> init (fc0) I (65756134) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65756134) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS#  wi Power: on Mode: Client mode STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed] MAC: 00:00:00:00:00:00 IP: 0.0.0.0/0.0.0.0 GW: 0.0.0.0 AP: 00:00:00:00:00:00 OVMS# wi wi wi wifi mode client gregnet 40:b0:76:32:ea:72 I (65767914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69 I (65768034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65768034) wifi:state: init -> auth (b0) I (65768064) wifi:state: auth -> assoc (0) I (65768074) wifi:state: assoc -> run (10) OVMS# wifi mode client gregnet 40:b0:76:32:ea:72 wifi wifi mode apclient OVMS Netgear_Guest2 W (65775854) wifi:sta_scan: STA is connecting, scan are not allowed! E (65775854) esp32wifi: StartConnect: error 0xffffffff starting scan OVMS# wifi mode apclient OVMS Netgear_Guest2 I (65776184) wifi:state: run -> init (fc0) I (65776184) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 I (65776184) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1 OVMS# wifi mode apclient OVMS Netgear_Guest2 Starting WIFI as Access Point and Client... OVMS# I (65783094) esp32wifi: Stopping WIFI station I (65783104) wifi:flush txq I (65783104) wifi:stop sw txq I (65783104) wifi:lmac stop hw txq I (65783624) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89) I (65783634) wifi:Total power save buffer number: 8 I (65783674) netmanager: WIFI access point is up I (65783674) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1 OVMS#  I (65786114) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67 I (65786234) wifi:ap channel adjust o:1,1 n:6,2 I (65786234) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1 OVMS#  I (65786944) wifi:state: init -> auth (b0) I (65786954) wifi:state: auth -> assoc (0) I (65786964) wifi:state: assoc -> run (10) I (65787004) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72 I (65787004) wifi:security type: 3, phy: bgn, rssi: -67 I (65787004) wifi:pm start, type: 1 I (65787014) wifi:AP's beacon interval = 102400 us, DTIM period = 3 I (65787024) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2 I (65787044) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 I (65787064) netmanager: WIFI client got IP I (65787064) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1 OVMS#  I (65788854) netmanager: WIFI client has good signal quality (-86.3 dBm); connect I (65788864) netmanager: Interface priority is st24 (10.30.1.105/255.255.255.0 gateway 10.30.1.1) I (65788864) netmanager: Set DNS#0 9.9.9.9 I (65788864) netmanager: Set DNS#1 8.8.8.8 I (65788864) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority I (65788904) time: Network was reconfigured: restarting SNTP client I (65788904) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65788904) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds I (65789034) ovms-server-v2: Status: Disconnected OVMS#  wifi mode apclient OVMS Netgear_Guest2 wi Power: on Mode: Access-Point + Client mode STA SSID: Netgear_Guest2 (-68.1 dBm) [fixed] MAC: 30:ae:a4:43:92:88 IP: 10.30.1.105/255.255.255.0 GW: 10.30.1.1 AP: 40:b0:76:32:ea:72 AP SSID: OVMS MAC: 30:ae:a4:43:92:89 IP: 192.168.4.1 AP Stations: 0 OVMS#
