[Ovmsdev] esp-idf update fixing spi_flash mutex priority inheritance bug
Wed Jan 28 00:36:49 HKT 2026
Everyone,
TL;DR: update your local esp-idf clone from our esp-idf repository
before doing the next firmware build.
While testing the Mongoose API lock I found out the Mongoose task
priority would still occasionally get raised to 22 = wifi task priority.
In combination with the Mongoose task essentially being 100% busy while
outside the locked poll call, this lead to blocking all other tasks from
Mongoose, which caused at least one of the crash effects observed
(watchdog timeout from our events task). Adding a priority fix to our
netmanager eliminated quite a lot of these crashes.
I then investigated this, as I thought that priority bug was originally
coming from the buggy POSIX mutex implementation we fixed in July 2020
(→ http://lists.openvehicles.com/pipermail/ovmsdev/2020-July/006971.html).
It turned out I was wrong, the actual culprit is a bug in the esp-idf
spi_flash component: each access to the SPI flash memory needs to be
running at maximum priority. The spi_flash methods did this by
temporarily changing the current task priority, and reverting to the
previous priority without taking into account that the task may have had
an inherited priority from an aquired mutex lock. Thus the priority
inherited from e.g. the Wifi task would stick.
That was especially present and reproducable when opening the web UI's
Config→Firmware page, as that page handler reads the OTA status, which
in turn reads the current boot configuration from flash. It also
affected the AutoFlash task during firmware updates, and there may be
more paths, basically running any "ota" command via a network channel.
As config reads & writes also use SPI flash, these also could produce
the bug for any task trying to lock some mutex also being requested by a
higher priority task.
This SPI flash bug has been found by other esp-idf users, and has
finally been fixed, but only for esp-idf 4.3 & higher:
* https://github.com/espressif/esp-idf/issues/5116
* https://github.com/espressif/esp-idf/issues/7580
I have now backported the fix to our version, and haven't had a single
unplanned priority change since.
Positive side effect: I see no event queue overflows & almost no effect
on the overall performance during an OTA flash process now.
This is though probably not the only cause of remaining watchdog
timeouts -- crash reports will tell.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260127/2eb6b61a/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260127/2eb6b61a/attachment.sig>
