[Ovmsdev] OVMS VW e-UP T26 connector
Mon Jan 19 17:45:48 HKT 2026
Chris, I think you've got me wrong: the connector I found is the cable
side, i.e. the one we need to adapt to, not the one we could use.
In the forum you wrote & show you actually also bought one of these to
see if your modified ribbon connector will fit to it.
I assume cutting off the ribbon connector box as you did cannot be part
of a manufacturing process, so I think we'll need to use an unboxed
variant -- Mark, maybe you or your manufacturer has a better idea?
Am 19.01.26 um 10:25 schrieb Chris van der Meijden via OvmsDev:
> Here some more details an my cable:
> https://www.goingelectric.de/forum/viewtopic.php?p=1197786#p1197786
> Am Montag, dem 19.01.2026 um 10:22 +0100 schrieb Chris van der Meijden
> via OvmsDev:
>> Hi Michael,
>> the connector you found looks good.
>> I used a 26-pin PC IDC cable and cut the box. The pitch is 2,54 mm.
>> https://www.goingelectric.de/forum/viewtopic.php?p=1186816#p1186816
>> It fits perfectly in the t26 socket, but sits loose. I fixated it
>> with an elastic band.
>> This works for almost 6 years now in the car, so I never bothered to
>> look for a better solution.
>> For DIY it is cheap and works well. For a more professional,
>> sellable, cable the VW connector seems to be worth a try I think.
>> Regards
>> Chris
>> Am Montag, dem 19.01.2026 um 09:59 +0100 schrieb Michael Balzer via
>> OvmsDev:
>>> I think there is no standard male counterpart for the T26 connector.
>>> The connector is used for other devices as well it seems, I'm pretty
>>> confident it's VW OE part no. 7L6 972 726 A, which is also used for
>>> the VW RNS-510 navigation system:
>>> →https://kufatec.com/en/repair-kit-connector-26-pin-7l6-972-726-plug-housing-for-vw-audi-seat-skoda-rns-510/38171-1
>>> This connector appears to be only meant for cables to be plugged
>>> into a custom shaped casing hole of a device, exposing a 2x13 board
>>> pin header, with the casing providing the mounting side for the
>>> white lock lever.
>>> So we will need to use some standard 2x13 male ribbon connector,
>>> combined with something to suitably secure the connection (there is
>>> no movement stress on the cable under the seat, doesn't need to be
>>> strong).
>>> IIRC the T26 plug is also thicker than a standard ribbon connector.
>>> Chris, did you find an extra wide boxed 2x13 connector fitting the
>>> T26 plug without cutting the box?
>>> If not we should probably better use an unboxed variant.
>>> Also, was that standard 2.54mm or 2mm pitch on the connector?
>>> Am 27.11.25 um 09:38 schrieb Mark Webb-Johnson via OvmsDev:
>>>> I agree that tapping wires is not a good solution for general
>>>> users. Something more reversal much more appropriate.
>>>> Anyway, if someone can get me pinouts, a link to the connector, and
>>>> cable lengths, I can get talk to the factory.
>>>> Regarding the antenna, I am a little concerned because our
>>>> certifications are limited on antenna types. In particular I
>>>> remember some clauses in there regarding not using ‘combined’
>>>> antennas (as they void the RF testing we did), but also limitations
>>>> regarding distance between the antenna and driver/passenger head
>>>> (which we came close to in the Tesla Roadster rear-window antenna
>>>> placement).
>>>> Regards, Mark
>>>>> On 26 Nov 2025, at 4:50 PM, Chris van der Meijden via OvmsDev
>>>>> <ovmsdev at lists.openvehicles.com> wrote:
>>>>> That seems the best approach to me too for a prefabricated cable.
>>>>> I hope somebody can provide the exact lengths for the cables,
>>>>> otherwise it is going to be guesing by rough meassuring the
>>>>> distances in the car.
>>>>> Am Mittwoch, dem 26.11.2025 um 09:20 +0100 schrieb Michael Balzer
>>>>> via OvmsDev:
>>>>>> My 2 cents:
>>>>>> I think tapping into wires (variant 2 / footwell panel) isn't
>>>>>> something we should suggest / encourage users to do.
>>>>>> A regular user is perfectly capable of unmounting the passenger
>>>>>> seat and plugging in prefabricated connectors. That also is
>>>>>> easily reversible, and using the original antennas for the OVMS
>>>>>> is really neat as well.
>>>>>> So I'd vote for variant 1 (combined with OBD), with a long cable
>>>>>> to mount the OVMS module in the front left near the OBD connector
>>>>>> (i.e. not replacing the OCU under the passenger seat), and the
>>>>>> kit for that could/should include the Fakra antenna plug/adapter
>>>>>> with antenna cables of the appropriate length to connect to the
>>>>>> module in the front.
>>>>>> @Mark: for clarification, this image shows a very short T26
>>>>>> connection meant to place the OVMS under the passenger seat near
>>>>>> the T26 connector, replacing the OCU:
>>>>>> This does not apply when mounting the module in the front near
>>>>>> the OBD port.
>>>>>> Taking +12V from the OBD port, the T26 connection cable then only
>>>>>> needs to connect GND and CAN-L, CAN-H of the T26 connector:
>>>>>> This image shows the vehicle side of the T26 connector, i.e. the
>>>>>> OVMS cable needs to be plugged into that.
>>>>>> It would be nice if the OVMS plug could also be secured by using
>>>>>> the white lock lever shown, that's what Chris intends by using
>>>>>> some original T26 part for this. Maybe there are compatible
>>>>>> connectors available, but other ways to secure the connection
>>>>>> would also be OK.
>>>>>> Can't help with the cable lengths needed for a proper
>>>>>> installation, I still haven't done that connection other than by
>>>>>> a flying CAT5 cable for re-engineering…
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 26.11.25 um 08:15 schrieb Chris van der Meijden via OvmsDev:
>>>>>>> Hi Mark,
>>>>>>> as I started the e-Up OVMS project years ago my first approach
>>>>>>> was the T26 cable. The reason for that more complicated cable
>>>>>>> was that with the direct connection to CAN3, I was able to get
>>>>>>> write access for i.e. climate control.
>>>>>>> My way to do so was replacing the VW TCU under the passenger
>>>>>>> seat and connect to the VW T26 connector there (hence the name
>>>>>>> T26).
>>>>>>> As the project developed the direct ODB access was added by
>>>>>>> other very capable developers to gain more data from the car. So
>>>>>>> we ended up with 4 cables. T26 alone, ODB alone, ODB + T26 under
>>>>>>> the passenger seat, ODB + T26 at the passenger footwell panel.
>>>>>>> T26 alone and ODB alone have only historical value, so there
>>>>>>> needs to be a decission, if you want to make the hybrid cable
>>>>>>> for under the passenger seat or at the passenger footwell panel.
>>>>>>> The advantage of the "under the seat" cable is, that you can use
>>>>>>> the GPS and GSM antenna of the car. Disavantage is, the you have
>>>>>>> to struggle with the seat. The "footwell" cable is much easier
>>>>>>> to install, but OVMS will need extra antennas for GPS and GSM.
>>>>>>> I would suggest, that the decission about what cable to make
>>>>>>> should be discussed here briefly first.
>>>>>>> Then someone will probably be able to provide the length of the
>>>>>>> cable.
>>>>>>> Information on the connector, wire type and pinouts are in the
>>>>>>> documentation. The connector is a workaround as we were not able
>>>>>>> to find the original female T26 plug. But perhaps things has
>>>>>>> changed and somebody has more information on that now.
>>>>>>> Hope this is of some help.
>>>>>>> Regards
>>>>>>> Chris
>>>>>>> Am Mittwoch, dem 26.11.2025 um 10:49 +0800 schrieb Mark
>>>>>>>> We’ve had some enquiries regarding making a standard OVMS cable
>>>>>>>> T26 for VW eUP, Skoda E IV, and Seat MII electric.
>>>>>>>> From my understanding, the cable is variant 1 described here:
>>>>>>>> https://docs.openvehicles.com/en/latest/components/vehicle_vweup/docs/index.html
>>>>>>>> https://docs.openvehicles.com/en/latest/components/vehicle_vweup/docs/index_t26.html
>>>>>>>> If there anybody here knowledgeable about this, that could help
>>>>>>>> specify the cable exactly? Things like:
>>>>>>>> 1. Exact T26 connector
>>>>>>>> 2. Length of each cable segment
>>>>>>>> 3. Cable wire type
>>>>>>>> 4. Pinouts
>>>>>>>> Preferable somebody who has already done it and can document
>>>>>>>> exactly what they have.
>>>>>>>> Also presumably this requires unplugging the existing OCU, and
>>>>>>>> what is the impact of that?
>>>>>>>> Regards, Mark.
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260119/f1c836dc/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260119/f1c836dc/attachment-0001.sig>
