[Ovmsdev] OVMS VW e-UP T26 connector
Mon Jan 19 16:59:53 HKT 2026
I think there is no standard male counterpart for the T26 connector.
The connector is used for other devices as well it seems, I'm pretty
confident it's VW OE part no. 7L6 972 726 A, which is also used for the
VW RNS-510 navigation system:
https://kufatec.com/en/repair-kit-connector-26-pin-7l6-972-726-plug-housing-for-vw-audi-seat-skoda-rns-510/38171-1
This connector appears to be only meant for cables to be plugged into a
custom shaped casing hole of a device, exposing a 2x13 board pin header,
with the casing providing the mounting side for the white lock lever.
So we will need to use some standard 2x13 male ribbon connector,
combined with something to suitably secure the connection (there is no
movement stress on the cable under the seat, doesn't need to be strong).
IIRC the T26 plug is also thicker than a standard ribbon connector.
Chris, did you find an extra wide boxed 2x13 connector fitting the T26
plug without cutting the box?
If not we should probably better use an unboxed variant.
Also, was that standard 2.54mm or 2mm pitch on the connector?
Am 27.11.25 um 09:38 schrieb Mark Webb-Johnson via OvmsDev:
> I agree that tapping wires is not a good solution for general users.
> Something more reversal much more appropriate.
> Anyway, if someone can get me pinouts, a link to the connector, and
> cable lengths, I can get talk to the factory.
> Regarding the antenna, I am a little concerned because our
> certifications are limited on antenna types. In particular I remember
> some clauses in there regarding not using ‘combined’ antennas (as they
> void the RF testing we did), but also limitations regarding distance
> between the antenna and driver/passenger head (which we came close to
> in the Tesla Roadster rear-window antenna placement).
> Regards, Mark
>> On 26 Nov 2025, at 4:50 PM, Chris van der Meijden via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> That seems the best approach to me too for a prefabricated cable.
>> I hope somebody can provide the exact lengths for the cables,
>> otherwise it is going to be guesing by rough meassuring the distances
>> in the car.
>> Am Mittwoch, dem 26.11.2025 um 09:20 +0100 schrieb Michael Balzer via
>> OvmsDev:
>>> My 2 cents:
>>> I think tapping into wires (variant 2 / footwell panel) isn't
>>> something we should suggest / encourage users to do.
>>> A regular user is perfectly capable of unmounting the passenger seat
>>> and plugging in prefabricated connectors. That also is easily
>>> reversible, and using the original antennas for the OVMS is really
>>> neat as well.
>>> So I'd vote for variant 1 (combined with OBD), with a long cable to
>>> mount the OVMS module in the front left near the OBD connector (i.e.
>>> not replacing the OCU under the passenger seat), and the kit for
>>> that could/should include the Fakra antenna plug/adapter with
>>> antenna cables of the appropriate length to connect to the module in
>>> the front.
>>> @Mark: for clarification, this image shows a very short T26
>>> connection meant to place the OVMS under the passenger seat near the
>>> T26 connector, replacing the OCU:
>>> This does not apply when mounting the module in the front near the
>>> OBD port.
>>> Taking +12V from the OBD port, the T26 connection cable then only
>>> needs to connect GND and CAN-L, CAN-H of the T26 connector:
>>> This image shows the vehicle side of the T26 connector, i.e. the
>>> OVMS cable needs to be plugged into that.
>>> It would be nice if the OVMS plug could also be secured by using the
>>> white lock lever shown, that's what Chris intends by using some
>>> original T26 part for this. Maybe there are compatible connectors
>>> available, but other ways to secure the connection would also be OK.
>>> Can't help with the cable lengths needed for a proper installation,
>>> I still haven't done that connection other than by a flying CAT5
>>> cable for re-engineering…
>>> Am 26.11.25 um 08:15 schrieb Chris van der Meijden via OvmsDev:
>>>> Hi Mark,
>>>> as I started the e-Up OVMS project years ago my first approach was
>>>> the T26 cable. The reason for that more complicated cable was that
>>>> with the direct connection to CAN3, I was able to get write access
>>>> for i.e. climate control.
>>>> My way to do so was replacing the VW TCU under the passenger seat
>>>> and connect to the VW T26 connector there (hence the name T26).
>>>> As the project developed the direct ODB access was added by other
>>>> very capable developers to gain more data from the car. So we ended
>>>> up with 4 cables. T26 alone, ODB alone, ODB + T26 under the
>>>> passenger seat, ODB + T26 at the passenger footwell panel.
>>>> T26 alone and ODB alone have only historical value, so there needs
>>>> to be a decission, if you want to make the hybrid cable for under
>>>> the passenger seat or at the passenger footwell panel.
>>>> The advantage of the "under the seat" cable is, that you can use
>>>> the GPS and GSM antenna of the car. Disavantage is, the you have to
>>>> struggle with the seat. The "footwell" cable is much easier to
>>>> install, but OVMS will need extra antennas for GPS and GSM.
>>>> I would suggest, that the decission about what cable to make should
>>>> be discussed here briefly first.
>>>> Then someone will probably be able to provide the length of the cable.
>>>> Information on the connector, wire type and pinouts are in the
>>>> documentation. The connector is a workaround as we were not able to
>>>> find the original female T26 plug. But perhaps things has changed
>>>> and somebody has more information on that now.
>>>> Hope this is of some help.
>>>> Regards
>>>> Chris
>>>> Am Mittwoch, dem 26.11.2025 um 10:49 +0800 schrieb Mark
>>>>> We’ve had some enquiries regarding making a standard OVMS cable
>>>>> T26 for VW eUP, Skoda E IV, and Seat MII electric.
>>>>> From my understanding, the cable is variant 1 described here:
>>>>> https://docs.openvehicles.com/en/latest/components/vehicle_vweup/docs/index.html
>>>>> https://docs.openvehicles.com/en/latest/components/vehicle_vweup/docs/index_t26.html
>>>>> If there anybody here knowledgeable about this, that could help
>>>>> specify the cable exactly? Things like:
>>>>> 1. Exact T26 connector
>>>>> 2. Length of each cable segment
>>>>> 3. Cable wire type
>>>>> 4. Pinouts
>>>>> Preferable somebody who has already done it and can document
>>>>> exactly what they have.
>>>>> Also presumably this requires unplugging the existing OCU, and
>>>>> what is the impact of that?
>>>>> Regards, Mark.
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260119/2ae03f10/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260119/2ae03f10/attachment-0001.sig>
