[Ovmsdev] Firmware size approaching 4 MB limit
Sun Jan 11 17:34:09 HKT 2026
On the migration tool for changing the partition table from a running
application, we're (of course) not the first having that issue.
If we're about to go that way, here is an implementation of the process:
* Explanation: https://johnmu.com/2024-esp32-partition-update/
* Source: https://github.com/softplus/Esp32Repartition
It's written for the Arduino IDE with the PlatformIO lib to create a UI,
but the core function is straight forward and should be adaptable for us.
The implementation allows for direct manipulations of the partition
table, i.e. doesn't need a prepared table blob to flash.
Using a prepared blob should be even more simple, basically just a
matter of `spi_flash_erase_range()` & `spi_flash_write()` (→
https://github.com/softplus/Esp32Repartition/blob/main/src/part_mgr.cpp#L297).
We probably don't even need `getPartitionTableAddr()`, as our table is
fixed at 0x8000.
The code needed is small. When using a blob, the table in theory uses a
full flash sector of 4096 bytes, but probably doesn't fill the whole sector.
Am 08.12.25 um 07:01 schrieb Mark Webb-Johnson via OvmsDev:
> Michael, Carsten,
> I think that if targeting things to cull, we would need to be balance
> size vs importance. For example, the RE tools mentioned is just 10KB
> total size. By comparison TPMS is 9KB, and web server is 538KB.
> We learned with OVMS v2 that the biggest culprits in the long-run are
> always the vehicle modules. The core system stays pretty stable, but
> the space required for *all* vehicle modules grows with the number of
> vehicles supported.
> I don’t think we can simply switch to 32MB flash, as that would
> abandon the existing users. We would also need to source a standard
> certified 32MB module (which I don’t think Espressif offer themselves).
> Looking at the partition table:
> # OVMS 16MB flash ESP32 Partition Table
> # Name, Type, SubType, Offset, Size
> nvs, data, nvs, 0x9000, 0x4000
> otadata, data, ota, 0xd000, 0x2000
> phy_init, data, phy, 0xf000, 0x1000
> factory, app, factory, 0x10000, 4M
> ota_0, app, ota_0, , 4M
> ota_1, app, ota_1, , 4M
> store, data, fat, , 1M
> Assuming we could (and that is a big assumption given our older SDK)
> change that at runtime, then a possible migration path could be:
> 1. Have our code support both old and new partition table formats,
> and refuse to update to old format if firmware > 4MB. Get that
> code out into the hands of users.
> 2. Provide a migration tool for partition table:
> 1. Copy running code to factory (from ota_0 or ota_1, whichever
> is current).
> 2. Reboot
> 3. Change partition table (most likely replacing the entire table
> with a binary blob of the new format)
> 1. factory 4MB -> ota_0 same offset, 6MB size
> 2. ota_0 -> ota_1 6MB offset, 6MB size
> 4. Change boot to ota_0.
> 5. Reboot
> 3. Liase with factory so new modules use new partition format (and
> ship with firmware that supports it).
> 4. Wait a reasonable time for users to update before releasing any
> firmware > 4MB.
> That would work more similarly to other more modern ESP frameworks
> which don’t bother with ‘factory’. It would allow us another 50%
> expansion. But it does run the risk of bricking (requiring espflash to
> recover) during the process.
> But longer-term, the solution to me seems to be to allow the vehicle
> module code to overlay - so only the single vehicle you choose is
> loaded. And (absent any dynamic linking of modular code in freertos),
> the only straightforward way of doing that I know of is migrating
> vehicle support to Javascript (which comes along with a host of other
> advantages - most notably not having to be a C++ embedded developer to
> add/refine vehicle support).
>> On 7 Dec 2025, at 4:39 PM, Carsten Schmiemann via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Hi Michael,
>> It was to be expected that we would eventually run out of flash
>> storage. That’s why I would immediately question whether we should
>> detach ourselves from components that aren’t really being used. We
>> could even start a survey or something like that.
>> For example, the RE tools — the idea behind them is great, but
>> without documentation they’re not easy to use, and every time I tried
>> to work with them, it just resulted in crashes.
>> Then there’s the question of who actually uses Telnet, SSH, the
>> Duktape framework, the DBC parser, OBD2ECU, or CANopen (yes, the
>> Twizy integration is the only one that uses it).
>> All great ideas, but in the end, how many users really make use of them?
>> The fewer active components we have to maintain, the ‘easier’ it
>> would also be to port the code to a more current ESP-IDF version —
>> and that would bring significant benefits such as improved networking
>> features, including firewall capabilities and a much more stable
>> switching between LTE and Wi-Fi. I’ve looked at llanges attempts and
>> it’s extremely tough.
>> As an example, in my own custom firmware builds, I don’t enable the
>> components (and of course not all vehicles, so not 100 percent
>> representative) mentioned above. This requires small modifications in
>> the code because, for example, the ESP logger is missing but
>> referenced in another file, etc. But my firmware file is only about
>> 2.8 MB.
>> Just my 2 cents
>> Carsten
>>> Am 07.12.2025 um 08:57 schrieb Michael Balzer via OvmsDev
>>> <ovmsdev at lists.openvehicles.com>:
>>> FYI: use `make size-components` to create a report on all component
>>> sizes (`make size-files` for source file level).
>>> Unsurprisingly the webserver is on top, even with all assets
>>> precompressed already.
>>> *_Top 10 components:_*
>>> Per-archive contributions to ELF file:
>>> Archive File DRAM .data & .bss IRAM Flash code &
>>> rodata Total
>>> libovms_webserver.a 0 255 0 134342
>>> 399846 534443
>>> libstdc++.a 149 5640 0 141045
>>> 72513 219347
>>> libmain.a 15 2104 0 139216
>>> 40086 181421
>>> libduktape.a 0 0 0 141641
>>> 20367 162008
>>> libvehicle_renaulttwizy. 0 29 0 86517
>>> 75357 161903
>>> libc-psram-workaround.a 1854 66 18391 118283
>>> 10943 149537
>>> liblwip.a 17 3873 0 118366
>>> 16722 138978
>>> libnet80211.a 938 9042 10475 92339
>>> 21900 134694
>>> libmbedtls.a 100 560 76 107079
>>> 26785 134600
>>> libvehicle_vweup.a 8 8 0 60846
>>> 43432 104294
>>> *_Vehicles:_*
>>> rodata Total
>>> 75357 161903
>>> 43432 104294
>>> libvehicle_mgev.a 156 26 0 47756
>>> 33998 81936
>>> libvehicle_smarteq.a 82 15 0 59267
>>> 19527 78891
>>> libvehicle_smarted.a 0 9 0 48481
>>> 28801 77291
>>> libvehicle_renaultzoe_ph 4 10 0 44622
>>> 29564 74200
>>> libvehicle.a 0 68 0 57735
>>> 12062 69865
>>> libvehicle_bmwi3.a 0 2 0 33370
>>> 14357 47729
>>> libvehicle_minise.a 9432 2 0 35360
>>> 2210 47004
>>> libvehicle_hyundai_ioniq 176 7 0 32921
>>> 13425 46529
>>> libvehicle_nissanleaf.a 0 3 0 35491
>>> 8941 44435
>>> libvehicle_kiasoulev.a 240 9 0 32508
>>> 5473 38230
>>> libvehicle_kianiroev.a 108 7 0 24070
>>> 4006 28191
>>> libvehicle_mitsubishi.a 0 5 0 21645
>>> 3893 25543
>>> libvehicle_boltev.a 0 5 0 15999
>>> 7864 23868
>>> libvehicle_niu_gtevo.a 4 12 0 18248
>>> 3733 21997
>>> libvehicle_maxus_edelive 156 3 0 10713
>>> 7477 18349
>>> libvehicle_renaultzoe.a 0 6 0 14828
>>> 2859 17693
>>> libvehicle_maxus_euniq56 156 3 0 8363
>>> 6840 15362
>>> libvehicle_voltampera.a 0 5 0 13221
>>> 1932 15158
>>> libvehicle_hyundai_ioniq 0 3 0 11081
>>> 3191 14275
>>> libvehicle_teslaroadster 0 6 0 10367
>>> 2238 12611
>>> libvehicle_thinkcity.a 0 3 0 6114
>>> 3449 9566
>>> libvehicle_jaguaripace.a 0 8 0 5445
>>> 3941 9394
>>> libvehicle_fiatedoblo.a 0 2 0 4262
>>> 2126 6390
>>> libvehicle_teslamodels.a 0 2 0 5361
>>> 948 6311
>>> libvehicle_toyotarav4ev. 0 2 0 5023
>>> 1255 6280
>>> libvehicle_maxus_t90.a 0 3 0 2567
>>> 2204 4774
>>> libvehicle_byd_atto3.a 0 2 0 3503
>>> 947 4452
>>> libvehicle_energica.a 0 1 0 3319
>>> 880 4200
>>> libvehicle_demo.a 0 2 0 3205
>>> 795 4002
>>> libvehicle_maxus_euniq6. 0 2 0 2470
>>> 1182 3654
>>> libvehicle_fiat500.a 0 2 0 2838
>>> 732 3572
>>> libvehicle_zombie_vcu.a 0 4 0 1882
>>> 1259 3145
>>> libvehicle_mercedesb250e 0 2 0 2113
>>> 955 3070
>>> libvehicle_zeva.a 0 2 0 2209
>>> 688 2899
>>> libvehicle_dbc.a 0 2 0 1278
>>> 1395 2675
>>> libvehicle_cadillac_c2_c 0 7 0 1293
>>> 1105 2405
>>> libvehicle_maple60s.a 0 2 0 1416
>>> 698 2116
>>> libvehicle_chevrolet_c6_ 0 2 0 1053
>>> 1049 2104
>>> libvehicle_obdii.a 0 2 0 957
>>> 1007 1966
>>> libvehicle_teslamodel3.a 0 2 0 458
>>> 713 1173
>>> libvehicle_none.a 0 2 0 418
>>> 684 1104
>>> libvehicle_track.a 0 2 0 416
>>> 680 1098
>>> Am 06.12.25 um 10:33 schrieb Michael Balzer via OvmsDev:
>>>> Everyone,
>>>> with the latest vehicle additions, the firmware size has now grown
>>>> to 4,015,328 bytes in build 3.3.005-485-gc4664881.
>>>> Our flash partitioning scheme is currently designed to provide
>>>> three firmware partitions (factory, ota_0 & ota_1) of 4MB =
>>>> 4,194,304 bytes each.
>>>> So we've now got 178,976 bytes = ~4% left.
>>>> Options beyond the 4 MB limit:
>>>> a) split features, e.g. vehicle support, into two or more builds
>>>> b) repartition into two firmware partitions of 6 MB each, reusing
>>>> the factory partition for OTA
>>>> c) switch to an ESP32 WROOM module with 32 MB flash (possible?)
>>>> We've got some time left, new vehicles normally don't need that
>>>> much space, I just wanted to raise awareness.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260111/8dac5e68/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260111/8dac5e68/attachment-0001.sig>
