[Ovmsdev] More support for Scripting a Vehicle implementation
Mon Jan 5 00:23:50 HKT 2026
Sounds all reasonable.
Am 04.01.26 um 09:29 schrieb Michael Geddes via OvmsDev:
> I'm well on the way to finishing bms and vector support in scripted
> vehicle implementation via the DBC infrastructure.
> This is the documentation I'm adding into the 'DBC Introduction' page.
> It's kind of the correct place, but it's going to be common to the
> other script support for polling.. so maybe I should link to it in a
> common area.
> //.ichael
>     DBC Signals <#dbc-signals>
> DBC Signal names can be used to store values directly into metrics. Eg
> a signal |v_b_soc| would be sent to the metric |v.b.soc|. If the unit
> name on a signal matches a valid ‘unit code’ or ‘unit label’, then
> this will be passed on too.
> For signal names, |_| will get translated to a |.| for looking up
> metrics (|.| is still a valid character in a DBC ID).
> It is also possible to store into a vector by putting a number at the
> end of the signal id. Eg the signal |v_t_pressure_0| would be sent to
> the first element of the |v.t.pressure| vector.
>     BMS Targets <#bms-targets>
> There are also special BMS (battery management) targets that make sure
> the averages etc are calculated. The format is:
> bms./{type}/./{operation}/[/.//{index}/].
> The /{type}/ is either v for voltage or t for temperature.
> Operation
> Description
> Has Index
> n
> Total number of cell voltage readings
> No
> m
> Readings per module
> No
> r
> Reset stats
> Optional
> c
> Cell value
> Yes
> DBC Examples <#id1>
> Example
> Description
> |bms.t.n|
> Set total number of cell temperature readings to incoming value.
> |bms.t.m|
> Set total number of cells per grouping to incoming value.
> |bms.v.r|
> Reset stats for cell voltages (ignore value)
> |bms.v.r.0|
> Reset stats and set Voltage at index /0/ to incoming value
> |bms.t.c.2|
> Set cell temperature at index /2/ to incoming value.
> |bms.v.c.5|
> Set cell voltage at index /5/ to incoming value.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260104/87371bf4/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260104/87371bf4/attachment-0001.sig>
