[Ovmsdev] Firmware size approaching 4 MB limit
Fri Feb 27 04:57:43 HKT 2026
Am 26.02.26 um 21:51 schrieb Michael Balzer via OvmsDev:
> Mark,
> Am 26.02.26 um 01:47 schrieb Mark Webb-Johnson:
>> My only concern is renaming the existing store to store-old (or
>> something like that) while it is mounted. But that will be necessary
>> to ensure that the new store is accessible directly after reboot.
> That could be avoided: `OvmsConfig::mount()` could try mounting
> "store-v35" (or whatever the new name is) first, then fall back to
> "store".
> Same scheme can be applied to `module_perform_factoryreset()`.
> That way "store" doesn't need to be relabeled at all, the system
> automatically uses the new partition if available.
Btw, we also don't need a store rollback command then, as "store"
remains intact until step #3 does the final update of the partition table.
Step #3 would then also rename "store-v35" to "store", to recover
compatibility with older firmware builds.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260226/e40fcc80/attachment.sig>
