[Ovmsdev] Firmware size approaching 4 MB limit
Thu Feb 26 08:47:11 HKT 2026
Michael,
I think you are correct. The safest way of doing this is to split as you suggest:
For #1, I think it is done now and should be ok.
For #2, I will work on that. I can provide both an upgrade and a downgrade option. My only concern is renaming the existing store to store-old (or something like that) while it is mounted. But that will be necessary to ensure that the new store is accessible directly after reboot.
Then #3 will need just a small tweak on the partition sizes to complete it.
Trying to do it all in one command may be too complex.
I will firstly update the typedef enum ovms_flashpartition_t so that you/we can know what state we are in. Suggest to just change it to unknown, v30 (existing arrangement), v34 (store resized and moved), v35 (flash partitions resized and factory removed).
I think I can provide a rollback if store partition is not as expected following reboot. I suggest:
ota partition upgrade store
ota partition downgrade store
ota partition upgrade factory
I’m not sure how long #2 will take me. Perhaps over the weekend, depending on the success of the recursive filesystem copy.
In the meantime, I suggest people don’t play with this too much as I’m only going to handle v30<->v34->v35 formats. Anything else will have to be manually done with esptools.
> On 26 Feb 2026, at 2:07 AM, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> Signed PGP part
> Thinking about the web UI:
> I intend to add a fourth tab "Partitioning" to Config→Firmware that checks the current partitioning scheme and guides through the upgrade process, so this can be done with just a couple of clicks (+ reboots).
> The UI will provide info & links on each step, what to do if something fails.
> So the process will now become this?
> Copy running ota image to "factory", reboot into "factory"
> Upgrade store partition, reboot
> Upgrade OTA partitions, reboot
> If step 2 fails, can we provide a fallback, i.e. re-enabling the old store partition, so the user can retry after another reboot?
> Am 25.02.26 um 17:18 schrieb Michael Balzer via OvmsDev:
>> Mark,
>> I don't think the recursive copy operation is an issue. We already do a similar, but much more memory hungry operation with the config backup & restore operations (zip/unzip).
>> The config backup doesn't add all directories, but includes "usr" meant for anything not fitting our standard /store layout:
>>   backup_dir[] =
>>     { "ovms_config", false },
>>     { "events", true },
>>     { "scripts", true },
>>     { "obd2ecu", true },
>>     { "dbc", true },
>>     { "plugin", true },
>>     { "tls", true },
>>     { "trustedca", true },
>>     { "usr", true },
>>     { NULL, false }
>> We could say that's also what we copy over to the new store, anything else is left to the user, if you think that's necessary.
>> But I doubt anyone has been using multi level custom directory structures on /store, due to the limited space and the frequent corruption issues we had with /store that would have turned out impractical very soon. Could be an option now, as I didn't hear about any corruption since introducing the config transaction scheme, but that's still new and only on edge, but I'd still recommend using /sd for that kind of storage.
>> Am 25.02.26 um 14:13 schrieb Mark Webb-Johnson:
>>> Craig, Michael,
>>> I have fixed the (a) partition type in ‘ota’ after upgrade, and (b) copy to factory. Both commits pushed.
>>> I also experimented with store.
>>> I can modify the partition table, rename old store to xstore, and create a new store at 0xe10000 same size 1MB, copy over the store partition. Reboot and all comes up fine (with repositioned store accessible).
>>> If I do the same, but set new store size to 0x1f0000, then the store can’t be mounted (corrupt, presumably). I guess the wear-leveling thing, or maybe internal fat filesystem metadata is messing things up.
>>> So it seems that either we leave store at 1MB (move it to the end of flash and make the code partitions as big as we can), or we resize it to the 0x1f0000 and handle the complexities of first modifying the partition table for the new store, then mounting two fat file systems, recursively copying over the files, and then adjusting the partition tables again. The recursive copy worries me (memory consumption and if deeply nested then all those directory handles open at the same time - one for each level).
>>> Thoughts?
>>>> On Feb 25, 2026, at 3:59 PM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>>> @Craig: nice find!
>>>> Am 25.02.26 um 02:58 schrieb Mark Webb-Johnson:
>>>>> Michael,
>>>>>> AFAICT "ota partitions upgrade" currently does not verify the system has booted from "factory" before allowing the operation -- I think that should be added as a safety measure.
>>>>> I thought it did that check. Maybe not working?
>>>> No, you're right, should be OK that way. But as Craig's result shows, I still should test it ;-)
>>>>> Here are the three partition table options:
>>>>> Original (f12):
>>>>> Label	Type	Subtype	Offset (Hex)	Size (Hex)	Next (Hex)	Offset (Dec)	Size (Dec)
>>>>> bootloader	bootloader	bootloader	0x0000	0x8000	8000	0	32768
>>>>> partition_table	partition_table	partition_table	0x8000	0x1000	9000	32768	4096
>>>>> nvs	data	nvs	0x9000	0x4000	D000	36864	16384
>>>>> otadata	data	ota	0xD000	0x2000	F000	53248	8192
>>>>> phy_init	data	phy	0xF000	0x1000	10000	61440	4096
>>>>> factory	app	factory	0x10000	0x400000	410000	65536	4194304
>>>>> ota_0	app	ota_0	0x410000	0x400000	810000	4259840	4194304
>>>>> ota_1	app	ota_1	0x810000	0x400000	C10000	8454144	4194304
>>>>> store	data	fat	0xC10000	0x100000	D10000	12648448	1048576
>>>>> *unused*
>>>>> 0xD10000	0x2F0000	1000000	13697024	3080192
>>>>> Current (12):
>>>>> ota_0	app	ota_0	0x10000	0x600000	610000	65536	6291456
>>>>> ota_1	app	ota_1	0x610000	0x600000	C10000	6356992	6291456
>>>>> *unused*
>>>>> Suggested (12, 7MB code, more store):
>>>>> ota_0	app	ota_0	0x10000	0x700000	710000	65536	7340032
>>>>> ota_1	app	ota_1	0x710000	0x700000	E10000	7405568	7340032
>>>>> store	data	fat	0xE10000	0x1F0000	1000000	14745600	2031616
>>>>> It would make sense to resize store *now* if we are going to do it, but I am wary of requiring a factory reset. Also need to double check that the unused space at the end is truly unused. I am assuming the boot loader is in the first 32KB, but haven’t actually checked.
>>>>> Looking at the third (resize store) arrangement, it would be moving 0xC10000-0xD0FFFF to 0xE10000-0xFFFFFF, which doesn’t seem to overlap. I wonder what simply copy that partition over (without reformatting flash) would do? Either corrupt the filesystem, ignore the extra space, or magically have the new space available to FAT? I suspect corruption. So, there is another (more complex) alternative:
>>>>> Create a 2nd fat store partition (0xE10000-0xFFFFFF)
>>>>> Format and mount that as FAT
>>>>> Copy files from old to new
>>>>> Unmount and drop the old store
>>>>> Finish the rest of the partition upgrade
>>>>> I suspect #3 would be the most complex step.
>>>>> Or the store move and resize could be done first as a separate step.
>>>>> Thoughts? Much more complex and risky...
>>>> There's the fatresize tool, didn't check the code, but given we can simply create the new partition cleanly and copy the files there, we should go that way.
>>>> I second the store resize should be the first upgrade step:
>>>> Unmounting /store while running may be risky, that was never needed and up to now only occurrs during shutdown as a final step.
>>>> I suggest we just relable the old "store" partition and do a reboot instead. esp_vfs_fat_spiflash_mount() searches for the partition by name, so the system should automatically mount & use the new "store" on boot.
>>>> Regards,
>>>> Michael
>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260226/9df679a2/attachment-0001.htm>
