[Ovmsdev] Firmware size approaching 4 MB limit
Thu Feb 26 00:18:36 HKT 2026
Mark,
I don't think the recursive copy operation is an issue. We already do a
similar, but much more memory hungry operation with the config backup &
restore operations (zip/unzip).
The config backup doesn't add all directories, but includes "usr" meant
for anything not fitting our standard /store layout:
   backup_dir[] =
     { "ovms_config", false },
     { "events", true },
     { "scripts", true },
     { "obd2ecu", true },
     { "dbc", true },
     { "plugin", true },
     { "tls", true },
     { "trustedca", true },
     { "usr", true },
     { NULL, false }
We could say that's also what we copy over to the new store, anything
else is left to the user, if you think that's necessary.
But I doubt anyone has been using multi level custom directory
structures on /store, due to the limited space and the frequent
corruption issues we had with /store that would have turned out
impractical very soon. Could be an option now, as I didn't hear about
any corruption since introducing the config transaction scheme, but
that's still new and only on edge, but I'd still recommend using /sd for
that kind of storage.
Am 25.02.26 um 14:13 schrieb Mark Webb-Johnson:
> Craig, Michael,
> I have fixed the (a) partition type in ‘ota’ after upgrade, and (b)
> copy to factory. Both commits pushed.
> I also experimented with store.
>   * I can modify the partition table, rename old store to xstore, and
>     create a new store at 0xe10000 same size 1MB, copy over the store
>     partition. Reboot and all comes up fine (with repositioned store
>     accessible).
>   * If I do the same, but set new store size to 0x1f0000, then the
>     store can’t be mounted (corrupt, presumably). I guess the
>     wear-leveling thing, or maybe internal fat filesystem metadata is
>     messing things up.
> So it seems that either we leave store at 1MB (move it to the end of
> flash and make the code partitions as big as we can), or we resize it
> to the 0x1f0000 and handle the complexities of first modifying the
> partition table for the new store, then mounting two fat file systems,
> recursively copying over the files, and then adjusting the partition
> tables again. The recursive copy worries me (memory consumption and if
> deeply nested then all those directory handles open at the same time -
> one for each level).
> Thoughts?
>> On Feb 25, 2026, at 3:59 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> @Craig: nice find!
>> Am 25.02.26 um 02:58 schrieb Mark Webb-Johnson:
>>> Michael,
>>>> AFAICT "ota partitions upgrade" currently does not verify the
>>>> system has booted from "factory" before allowing the operation -- I
>>>> think that should be added as a safety measure.
>>> I thought it did that check. Maybe not working?
>> No, you're right, should be OK that way. But as Craig's result shows,
>> I still should test it ;-)
>>> Here are the three partition table options:
>>>     Original (f12):
>>>     Label 	Type 	Subtype 	Offset (Hex) 	Size (Hex) 	Next (Hex)
>>>     Offset (Dec) 	Size (Dec)
>>>     bootloader 	bootloader 	bootloader 	0x0000 	0x8000 	8000 	0 	32768
>>>     partition_table 	partition_table 	partition_table 	0x8000
>>>     0x1000 	9000 	32768 	4096
>>>     nvs 	data 	nvs 	0x9000 	0x4000 	D000 	36864 	16384
>>>     otadata 	data 	ota 	0xD000 	0x2000 	F000 	53248 	8192
>>>     phy_init 	data 	phy 	0xF000 	0x1000 	10000 	61440 	4096
>>>     factory 	app 	factory 	0x10000 	0x400000 	410000 	65536 	4194304
>>>     ota_0 	app 	ota_0 	0x410000 	0x400000 	810000 	4259840 	4194304
>>>     ota_1 	app 	ota_1 	0x810000 	0x400000 	C10000 	8454144 	4194304
>>>     store 	data 	fat 	0xC10000 	0x100000 	D10000 	12648448 	1048576
>>>     *unused*
>>>     	0xD10000 	0x2F0000 	1000000 	13697024 	3080192
>>>     Current (12):
>>>     ota_0 	app 	ota_0 	0x10000 	0x600000 	610000 	65536 	6291456
>>>     ota_1 	app 	ota_1 	0x610000 	0x600000 	C10000 	6356992 	6291456
>>>     *unused*
>>>     Suggested (12, 7MB code, more store):
>>>     ota_0 	app 	ota_0 	0x10000 	0x700000 	710000 	65536 	7340032
>>>     ota_1 	app 	ota_1 	0x710000 	0x700000 	E10000 	7405568 	7340032
>>>     store 	data 	fat 	0xE10000 	0x1F0000 	1000000 	14745600 	2031616
>>> It would make sense to resize store *now* if we are going to do it,
>>> but I am wary of requiring a factory reset. Also need to double
>>> check that the unused space at the end is truly unused. I am
>>> assuming the boot loader is in the first 32KB, but haven’t actually
>>> checked.
>>> Looking at the third (resize store) arrangement, it would be moving
>>> 0xC10000-0xD0FFFF to 0xE10000-0xFFFFFF, which doesn’t seem to
>>> overlap. I wonder what simply copy that partition over (without
>>> reformatting flash) would do? Either corrupt the filesystem, ignore
>>> the extra space, or magically have the new space available to FAT? I
>>> suspect corruption. So, there is another (more complex) alternative:
>>>  1. Create a 2nd fat store partition (0xE10000-0xFFFFFF)
>>>  2. Format and mount that as FAT
>>>  3. Copy files from old to new
>>>  4. Unmount and drop the old store
>>>  5. Finish the rest of the partition upgrade
>>> I suspect #3 would be the most complex step.
>>> Or the store move and resize could be done first as a separate step.
>>> Thoughts? Much more complex and risky...
>> There's the fatresize tool, didn't check the code, but given we can
>> simply create the new partition cleanly and copy the files there, we
>> should go that way.
>> I second the store resize should be the first upgrade step:
>> Unmounting /store while running may be risky, that was never needed
>> and up to now only occurrs during shutdown as a final step.
>> I suggest we just relable the old "store" partition and do a reboot
>> instead. esp_vfs_fat_spiflash_mount() searches for the partition by
>> name, so the system should automatically mount & use the new "store"
>> on boot.
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260225/3f9c5b7b/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260225/3f9c5b7b/attachment-0001.sig>
