[Ovmsdev] Firmware size approaching 4 MB limit
Wed Feb 25 11:09:56 HKT 2026
Craig,
Thanks for discovering this. It is nasty.
Error 258 is 0x102 and that is ESP_ERR_INVALID_ARG (not ESP_ERR_NOT_SUPPORTED).
I find it esp_ota_begin (components/app_update/esp_ota_ops.c):
    if (!is_ota_partition(partition)) {
        return ESP_ERR_INVALID_ARG;
and that is:
static bool is_ota_partition(const esp_partition_t *p)
    return (p != NULL
            && p->type == ESP_PARTITION_TYPE_APP
            && p->subtype >= ESP_PARTITION_SUBTYPE_APP_OTA_0
            && p->subtype < ESP_PARTITION_SUBTYPE_APP_OTA_MAX);
It seems we can’t target the factory partition with those ota operations. I guess the problem is the whole ota rollback thing (where if it can’t boot into an ota partition, it falls back to the previous one).
It is not too onerous to workaround, though. We can simply change to use esp_partition_erase_range and esp_partition_write when targeting the factory. I will try to implement it that way tonight.
> On 25 Feb 2026, at 7:34 AM, Craig Leres <leres at xse.com> wrote:
> On 2/24/26 04:40, Mark Webb-Johnson via OvmsDev wrote:
>> OK, I have just committed this. The two new commands are:
>>  * ota partitions list
>>  * ota partitions upgrade [-noconfirm]
>> Rollback is via:
>>  * wget http://api.openvehicles.com/firmware/ota/v3.1/main/
>>    partitions.bin <http://api.openvehicles.com/firmware/ota/v3.1/main/
>>    partitions.bin>
>>  * esptool.py -p <path-to-usb> write_flash 0x8000 partitions.bin General approach to manual upgrade:
>> 1. Upgrade to firmware supporting this feature (3.3.005-711-g4feca695
>>    or later)
>> 2. Copy running ota firmware to factory
>> 3. Set to boot from flash and reboot
>> 4. Use ‘ota partitions upgrade’ to upgrade
>> 5. Reboot
>> Items still to be addressed:
>>  * Documentation (including rollback procedure).
>>  * Modify partitions.csv to use this new format (when ready for
>>    production).
>>  * Web interface (in particular concept of factory vs ota), if
>>    necessary (haven’t checked this).
>>  * OTA flash builds. We will need a way to support 6MB builds for those
>>    that can use them. I suggest to change GetOVMSProduct() to return
>>    v3.5 for these modules that are running this new 6MB capable
>>    partition table. Then on server we can build a production release
>>    final 4MB firmware including this support, and then use v3.5 tree to
>>    build future 6MB only builds. The ‘ota flash’ system would
>>    automatically support that and give people time to upgrade (as well
>>    as new users with 4MB partition modules for many months).
>>  * Investigate any simple way to make this a simple one-command
>>    (current ota->factory, boot factory, reboot, partitions upgrade,
>>    reboot).
>> For the moment, please try this out and let me know if you find any problems. We can then decide on the items still to be addressed.
> I took a run at this with my dev module:
>    OVMS# ota
>    Hardware:          OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
>    Firmware:          3.3.005-711-g4feca695-dirty/ota_1/main (build idf v3.3.4-854-g9063c8662 Feb 24 2026 15:08:43)
>    Partition type:    v3-f12 (factory, ota1, ota2)
>    Partition table:   0x8000
>    Running partition: ota_1
>    Boot partition:    ota_1
>    Factory image:     3.3.005-20-g60be058e
>    OTA_O image:       3.3.005-700-g0a804e40-dirty
>    OTA_1 image:       3.3.005-711-g4feca695-dirty
>    OVMS# ota copy ota_1 factory
>    OTA copy ota_1 (08454144) -> factory (00010000) size 4194304
>    Error: ESP32 error #258 starting OTA operation
>    OVMS#
> I couldn't find 258 so I internet searched it and learned that it is ESP_ERR_NOT_SUPPORTED (from components/esp32/include/esp_err.h, might be worth displaying in hex given that's how it's defined).
> I checked and my esp-idf is up to date.
> 		Craig
> sea 12 % pwd
> /home/sea/u0/leres/esp/esp-idf
> sea 13 % git log | head
> commit 9063c8662ca5d67b5490c1503bd4377b380feed3
> Author: Michael Balzer <balzer at expeedo.de>
> Date:   Tue Jan 27 17:34:34 2026 +0100
>    Fix mutex priority inheritance bug in spi_flash component:
>      backport of esp-idf commit aea2fe08162e1ba86ad0189178c1f1cf29238bbd,
>      see https://github.com/espressif/esp-idf/issues/5116
>      and https://github.com/espressif/esp-idf/issues/7580
> commit 75bdad1e05dbbfe2ef79e8398749ff6aaa7deb92
> sea 17 % pwd
> /home/sea/u0/leres/src/OVMS.V3
> sea 18 % git log | head
> commit 4feca695d922f26b5f3864fe43c6855b8f223675
> Author: Mark Webb-Johnson <mark at webb-johnson.net>
> Date:   Tue Feb 24 20:21:30 2026 +0800
>    Support for ota 0+1 partition table format, and 6MB firmware
> commit 1241912b48628e89947e1600f86365b4b174c6c8
> Merge: 92f93554 141bad50
> Author: Michael Balzer <dexter at dexters-web.de>
> Date:   Sun Feb 22 15:57:13 2026 +0100
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260225/eeffdbb6/attachment.htm>
