[Ovmsdev] Firmware size approaching 4 MB limit
Craig Leres
leres at xse.com
Wed Feb 25 07:34:48 HKT 2026
On 2/24/26 04:40, Mark Webb-Johnson via OvmsDev wrote:
> OK, I have just committed this. The two new commands are:
> * ota partitions list
> * ota partitions upgrade [-noconfirm]
> Rollback is via:
> * wget http://api.openvehicles.com/firmware/ota/v3.1/main/
> partitions.bin <http://api.openvehicles.com/firmware/ota/v3.1/main/
> partitions.bin>
> * esptool.py -p <path-to-usb> write_flash 0x8000 partitions.bin
> General approach to manual upgrade:
> 1. Upgrade to firmware supporting this feature (3.3.005-711-g4feca695
> or later)
> 2. Copy running ota firmware to factory
> 3. Set to boot from flash and reboot
> 4. Use âota partitions upgradeâ to upgrade
> 5. Reboot
> Items still to be addressed:
> * Documentation (including rollback procedure).
> * Modify partitions.csv to use this new format (when ready for
> production).
> * Web interface (in particular concept of factory vs ota), if
> necessary (havenât checked this).
> * OTA flash builds. We will need a way to support 6MB builds for those
> that can use them. I suggest to change GetOVMSProduct() to return
> v3.5 for these modules that are running this new 6MB capable
> partition table. Then on server we can build a production release
> final 4MB firmware including this support, and then use v3.5 tree to
> build future 6MB only builds. The âota flashâ system would
> automatically support that and give people time to upgrade (as well
> as new users with 4MB partition modules for many months).
> * Investigate any simple way to make this a simple one-command
> (current ota->factory, boot factory, reboot, partitions upgrade,
> reboot).
> For the moment, please try this out and let me know if you find any
> problems. We can then decide on the items still to be addressed.
I took a run at this with my dev module:
OVMS# ota
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Firmware: 3.3.005-711-g4feca695-dirty/ota_1/main (build
idf v3.3.4-854-g9063c8662 Feb 24 2026 15:08:43)
Partition type: v3-f12 (factory, ota1, ota2)
Partition table: 0x8000
Running partition: ota_1
Boot partition: ota_1
Factory image: 3.3.005-20-g60be058e
OTA_O image: 3.3.005-700-g0a804e40-dirty
OTA_1 image: 3.3.005-711-g4feca695-dirty
OVMS# ota copy ota_1 factory
OTA copy ota_1 (08454144) -> factory (00010000) size 4194304
Error: ESP32 error #258 starting OTA operation
OVMS#
I couldn't find 258 so I internet searched it and learned that it is
ESP_ERR_NOT_SUPPORTED (from components/esp32/include/esp_err.h, might be
worth displaying in hex given that's how it's defined).
I checked and my esp-idf is up to date.
Craig
sea 12 % pwd
/home/sea/u0/leres/esp/esp-idf
sea 13 % git log | head
commit 9063c8662ca5d67b5490c1503bd4377b380feed3
Author: Michael Balzer <balzer at expeedo.de>
Date: Tue Jan 27 17:34:34 2026 +0100
Fix mutex priority inheritance bug in spi_flash component:
backport of esp-idf commit aea2fe08162e1ba86ad0189178c1f1cf29238bbd,
see https://github.com/espressif/esp-idf/issues/5116
and https://github.com/espressif/esp-idf/issues/7580
commit 75bdad1e05dbbfe2ef79e8398749ff6aaa7deb92
sea 17 % pwd
/home/sea/u0/leres/src/OVMS.V3
sea 18 % git log | head
commit 4feca695d922f26b5f3864fe43c6855b8f223675
Author: Mark Webb-Johnson <mark at webb-johnson.net>
Date: Tue Feb 24 20:21:30 2026 +0800
Support for ota 0+1 partition table format, and 6MB firmware
commit 1241912b48628e89947e1600f86365b4b174c6c8
Merge: 92f93554 141bad50
Author: Michael Balzer <dexter at dexters-web.de>
Date: Sun Feb 22 15:57:13 2026 +0100
