[Ovmsdev] Firmware size approaching 4 MB limit
Mon Feb 23 00:27:30 HKT 2026
Awesome :-)
We need to update the user manual's firmware rescue guide
(https://docs.openvehicles.com/en/latest/userguide/factory.html#flash-factory-firmware-via-usb)
accordingly, so in case anything goes wrong, users can help themselves
or get local help.
The 4KB RAM overhead shouldn't be an issue I think, but we could add a
free memory check and recommend switching to the "NONE" vehicle while
performing the operation, if memory is too tight.
> P.S. OVMS v2 had to fit in 96KB of flash ;-)
…and 3328 bytes of RAM in total… so much for the "overhead" ;-)
Am 22.02.26 um 16:00 schrieb Mark Webb-Johnson:
> I’ve made some progress with this:
> OVMS# ota status nocheck
> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
> Firmware: 3.3.005-704-g6a1fed98-dirty/factory/edge (build idf
> v3.3.4-854-g9063c8662-dirty Feb 22 2026 22:28:00)
> Partition type: v3-f12 (factory, ota1, ota2)
> Partition table: 0x8000
> Running partition: factory
> Boot partition: factory
> Factory image: 3.3.005-704-g6a1fed98-dirty
> OTA_O image: 3.3.005-662-g1f318f04
> OTA_1 image: 3.3.005-643-gdbec4a13
> OVMS# ota partitions list
> Partition table:
> Label Type Subtype Address Size
> nvs data nvs 0x00009000 16 KB
> otadata data ota 0x0000d000 8 KB
> phy_init data phy 0x0000f000 4 KB
> factory app factory 0x00010000 4 MB
> ota_0 app ota_0 0x00410000 4 MB
> ota_1 app ota_1 0x00810000 4 MB
> store data fat 0x00c10000 1 MB
> Digest: cfe36765a6bfe1b802a2abd4ec9f6851 pass
> ## Before upgrade, user needs to copy current OTA to FACTORY, set
> boot partition to FACTORY, then reboot
> ## The upgrade process checks this and will refuse to upgrade
> unless that is the case
> OVMS# ota partitions upgrade
> 0x00009000 Skipping over data/nvs partition
> 0x0000d000 Skipping over data/ota partition
> 0x0000f000 Skipping over data/phy partition
> 0x00010000 Converted factory partition to 6MB OTA 0
> 0x00610000 Converted OTA 0 partition to 6MB OTA 1
> 0x00c10000 Moved data/fat partition up one position
> Recalculated MD5 checksum
> Clearing trailing old MD5 checksum record
> Erasing old partition table (4096 bytes at 0x00008000)...
> Writing new partition table (4096 bytes at 0x00008000)...
> Partition table upgraded successfully - reboot required
> Partition table:
> ota_0 app ota_0 0x00010000 6 MB
> ota_1 app ota_1 0x00610000 6 MB
> Digest: a0d94b1efa7f6d8852b44150db218e8d pass
> This is mostly implemented in a new ovms_partitions.{h,cpp} in
> ovms_ota component, with only minor extensions to ovms_ota itself. I
> have removed the ‘factory’ commands from ovms_ota if the new partition
> layout is detected at boot.
> One big ‘gotcha’ I found was that we need to
> set CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORT=
> and CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=y in our
> sdkconfig - otherwise the partition table cannot be re-flashed.
> The partition table must also be held in internal (not external SPI)
> RAM - which is about a 4KB overhead just for these checks.
> The usual app-flash still works (and now targets the first OTA at
> 0x0010000, rather than factory), so this approach seems feasible and
> workable now. Once we are happy with this, and have a production
> firmware supporting this layout, I can also provide a new
> partitions.bin to the factory for new units to ship with.
> I have a few minor enhancements to make: (a) add a ‘yes/no’ (like
> factory reset), (b) an option to load partition table in
> internal/external ram (internal only at the moment), and (c) some
> minor tidy-ups. I suggest then to just check it in with this basic
> manual functionality that can be experimented with. Absent any
> comments / suggestions, I should be able to commit this early in the
> coming week.
>> On Jan 21, 2026, at 11:12 AM, Mark Webb-Johnson
>> <mark at webb-johnson.net> wrote:
>> Michael,
>> The links are very helpful.
>> I have some time, and inclination to handle this (now that my new
>> home build host is up and running and a make of OVMS from clean, with
>> 32 cores and a fast SSD, is under 25 seconds).
>> real0m24.642s
>> user5m50.376s
>> sys0m38.276s
>> We’ve already got the ‘ota copy’ command, so I will start with trying
>> to work on manipulation of the partition table and improving the ‘ota
>> status’ command to show partition table format and sizes.
>>> On 11 Jan 2026, at 5:34 PM, Michael Balzer via OvmsDev
>>> <ovmsdev at lists.openvehicles.com> wrote:
>>> Signed PGP part
>>> On the migration tool for changing the partition table from a
>>> running application, we're (of course) not the first having that issue.
>>> If we're about to go that way, here is an implementation of the process:
>>> * Explanation:https://johnmu.com/2024-esp32-partition-update/
>>> * Source:https://github.com/softplus/Esp32Repartition
>>> It's written for the Arduino IDE with the PlatformIO lib to create a
>>> UI, but the core function is straight forward and should be
>>> adaptable for us.
>>> The implementation allows for direct manipulations of the partition
>>> table, i.e. doesn't need a prepared table blob to flash.
>>> Using a prepared blob should be even more simple, basically just a
>>> matter of `spi_flash_erase_range()` & `spi_flash_write()`
>>> (→https://github.com/softplus/Esp32Repartition/blob/main/src/part_mgr.cpp#L297).
>>> We probably don't even need `getPartitionTableAddr()`, as our table
>>> is fixed at 0x8000.
>>> The code needed is small. When using a blob, the table in theory
>>> uses a full flash sector of 4096 bytes, but probably doesn't fill
>>> the whole sector.
>>> Am 08.12.25 um 07:01 schrieb Mark Webb-Johnson via OvmsDev:
>>>> Michael, Carsten,
>>>> I think that if targeting things to cull, we would need to be
>>>> balance size vs importance. For example, the RE tools mentioned is
>>>> just 10KB total size. By comparison TPMS is 9KB, and web server is
>>>> 538KB.
>>>> We learned with OVMS v2 that the biggest culprits in the long-run
>>>> are always the vehicle modules. The core system stays pretty
>>>> stable, but the space required for *all* vehicle modules grows with
>>>> the number of vehicles supported.
>>>> I don’t think we can simply switch to 32MB flash, as that would
>>>> abandon the existing users. We would also need to source a standard
>>>> certified 32MB module (which I don’t think Espressif offer themselves).
>>>> Looking at the partition table:
>>>> # OVMS 16MB flash ESP32 Partition Table
>>>> # Name, Type, SubType, Offset, Size
>>>> nvs, data, nvs, 0x9000, 0x4000
>>>> otadata, data, ota, 0xd000, 0x2000
>>>> phy_init, data, phy, 0xf000, 0x1000
>>>> factory, app, factory, 0x10000, 4M
>>>> ota_0, app, ota_0, , 4M
>>>> ota_1, app, ota_1, , 4M
>>>> store, data, fat, , 1M
>>>> Assuming we could (and that is a big assumption given our older
>>>> SDK) change that at runtime, then a possible migration path could be:
>>>> 1. Have our code support both old and new partition table formats,
>>>> and refuse to update to old format if firmware > 4MB. Get that
>>>> code out into the hands of users.
>>>> 2. Provide a migration tool for partition table:
>>>> 1. Copy running code to factory (from ota_0 or ota_1,
>>>> whichever is current).
>>>> 2. Reboot
>>>> 3. Change partition table (most likely replacing the entire
>>>> table with a binary blob of the new format)
>>>> 1. factory 4MB -> ota_0 same offset, 6MB size
>>>> 2. ota_0 -> ota_1 6MB offset, 6MB size
>>>> 4. Change boot to ota_0.
>>>> 5. Reboot
>>>> 3. Liase with factory so new modules use new partition format (and
>>>> ship with firmware that supports it).
>>>> 4. Wait a reasonable time for users to update before releasing any
>>>> firmware > 4MB.
>>>> That would work more similarly to other more modern ESP frameworks
>>>> which don’t bother with ‘factory’. It would allow us another 50%
>>>> expansion. But it does run the risk of bricking (requiring espflash
>>>> to recover) during the process.
>>>> But longer-term, the solution to me seems to be to allow the
>>>> vehicle module code to overlay - so only the single vehicle you
>>>> choose is loaded. And (absent any dynamic linking of modular code
>>>> in freertos), the only straightforward way of doing that I know of
>>>> is migrating vehicle support to Javascript (which comes along with
>>>> a host of other advantages - most notably not having to be a C++
>>>> embedded developer to add/refine vehicle support).
>>>> Regards, Mark.
>>>>> On 7 Dec 2025, at 4:39 PM, Carsten Schmiemann via
>>>>> OvmsDev<ovmsdev at lists.openvehicles.com>wrote:
>>>>> Hi Michael,
>>>>> It was to be expected that we would eventually run out of flash
>>>>> storage. That’s why I would immediately question whether we should
>>>>> detach ourselves from components that aren’t really being used. We
>>>>> could even start a survey or something like that.
>>>>> For example, the RE tools — the idea behind them is great, but
>>>>> without documentation they’re not easy to use, and every time I
>>>>> tried to work with them, it just resulted in crashes.
>>>>> Then there’s the question of who actually uses Telnet, SSH, the
>>>>> Duktape framework, the DBC parser, OBD2ECU, or CANopen (yes, the
>>>>> Twizy integration is the only one that uses it).
>>>>> All great ideas, but in the end, how many users really make use of
>>>>> them?
>>>>> The fewer active components we have to maintain, the ‘easier’ it
>>>>> would also be to port the code to a more current ESP-IDF version —
>>>>> and that would bring significant benefits such as improved
>>>>> networking features, including firewall capabilities and a much
>>>>> more stable switching between LTE and Wi-Fi. I’ve looked at
>>>>> llanges attempts and it’s extremely tough.
>>>>> As an example, in my own custom firmware builds, I don’t enable
>>>>> the components (and of course not all vehicles, so not 100 percent
>>>>> representative) mentioned above. This requires small modifications
>>>>> in the code because, for example, the ESP logger is missing but
>>>>> referenced in another file, etc. But my firmware file is only
>>>>> about 2.8 MB.
>>>>> Just my 2 cents
>>>>> Carsten
>>>>>> Am 07.12.2025 um 08:57 schrieb Michael Balzer via
>>>>>> OvmsDev<ovmsdev at lists.openvehicles.com>:
>>>>>> FYI: use `make size-components` to create a report on all
>>>>>> component sizes (`make size-files` for source file level).
>>>>>> Unsurprisingly the webserver is on top, even with all assets
>>>>>> precompressed already.
>>>>>> *_Top 10 components:_*
>>>>>> Per-archive contributions to ELF file:
>>>>>> Archive File DRAM .data & .bss IRAM Flash code & rodata Total
>>>>>> libovms_webserver.a 0 255 0 134342 399846
>>>>>> 534443
>>>>>> libstdc++.a 149 5640 0 141045 72513 219347
>>>>>> libmain.a 15 2104 0 139216 40086 181421
>>>>>> libduktape.a 0 0 0 141641 20367 162008
>>>>>> libvehicle_renaulttwizy. 0 29 0 86517
>>>>>> 75357 161903
>>>>>> libc-psram-workaround.a 1854 66 18391 118283
>>>>>> 10943 149537
>>>>>> liblwip.a 17 3873 0 118366 16722 138978
>>>>>> libnet80211.a 938 9042 10475 92339 21900 134694
>>>>>> libmbedtls.a 100 560 76 107079 26785 134600
>>>>>> libvehicle_vweup.a 8 8 0 60846 43432 104294
>>>>>> *_Vehicles:_*
>>>>>> 75357 161903
>>>>>> libvehicle_mgev.a 156 26 0 47756 33998 81936
>>>>>> libvehicle_smarteq.a 82 15 0 59267 19527 78891
>>>>>> libvehicle_smarted.a 0 9 0 48481 28801 77291
>>>>>> libvehicle_renaultzoe_ph 4 10 0 44622
>>>>>> 29564 74200
>>>>>> libvehicle.a 0 68 0 57735 12062 69865
>>>>>> libvehicle_bmwi3.a 0 2 0 33370 14357 47729
>>>>>> libvehicle_minise.a 9432 2 0 35360 2210
>>>>>> 47004
>>>>>> libvehicle_hyundai_ioniq 176 7 0 32921
>>>>>> 13425 46529
>>>>>> libvehicle_nissanleaf.a 0 3 0 35491
>>>>>> 8941 44435
>>>>>> libvehicle_kiasoulev.a 240 9 0 32508 5473 38230
>>>>>> libvehicle_kianiroev.a 108 7 0 24070 4006 28191
>>>>>> libvehicle_mitsubishi.a 0 5 0 21645
>>>>>> 3893 25543
>>>>>> libvehicle_boltev.a 0 5 0 15999 7864
>>>>>> 23868
>>>>>> libvehicle_niu_gtevo.a 4 12 0 18248 3733 21997
>>>>>> libvehicle_maxus_edelive 156 3 0 10713
>>>>>> 7477 18349
>>>>>> libvehicle_renaultzoe.a 0 6 0 14828
>>>>>> 2859 17693
>>>>>> libvehicle_maxus_euniq56 156 3 0 8363
>>>>>> 6840 15362
>>>>>> libvehicle_voltampera.a 0 5 0 13221
>>>>>> 1932 15158
>>>>>> libvehicle_hyundai_ioniq 0 3 0 11081
>>>>>> 3191 14275
>>>>>> libvehicle_teslaroadster 0 6 0 10367
>>>>>> 2238 12611
>>>>>> libvehicle_thinkcity.a 0 3 0 6114 3449 9566
>>>>>> libvehicle_jaguaripace.a 0 8 0 5445
>>>>>> 3941 9394
>>>>>> libvehicle_fiatedoblo.a 0 2 0 4262
>>>>>> 2126 6390
>>>>>> libvehicle_teslamodels.a 0 2 0 5361
>>>>>> 948 6311
>>>>>> libvehicle_toyotarav4ev. 0 2 0 5023
>>>>>> 1255 6280
>>>>>> libvehicle_maxus_t90.a 0 3 0 2567 2204 4774
>>>>>> libvehicle_byd_atto3.a 0 2 0 3503 947 4452
>>>>>> libvehicle_energica.a 0 1 0 3319 880
>>>>>> 4200
>>>>>> libvehicle_demo.a 0 2 0 3205 795 4002
>>>>>> libvehicle_maxus_euniq6. 0 2 0 2470
>>>>>> 1182 3654
>>>>>> libvehicle_fiat500.a 0 2 0 2838 732 3572
>>>>>> libvehicle_zombie_vcu.a 0 4 0 1882
>>>>>> 1259 3145
>>>>>> libvehicle_mercedesb250e 0 2 0 2113
>>>>>> 955 3070
>>>>>> libvehicle_zeva.a 0 2 0 2209 688 2899
>>>>>> libvehicle_dbc.a 0 2 0 1278 1395 2675
>>>>>> libvehicle_cadillac_c2_c 0 7 0 1293
>>>>>> 1105 2405
>>>>>> libvehicle_maple60s.a 0 2 0 1416 698
>>>>>> 2116
>>>>>> libvehicle_chevrolet_c6_ 0 2 0 1053
>>>>>> 1049 2104
>>>>>> libvehicle_obdii.a 0 2 0 957 1007 1966
>>>>>> libvehicle_teslamodel3.a 0 2 0 458
>>>>>> 713 1173
>>>>>> libvehicle_none.a 0 2 0 418 684 1104
>>>>>> libvehicle_track.a 0 2 0 416 680 1098
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 06.12.25 um 10:33 schrieb Michael Balzer via OvmsDev:
>>>>>>> Everyone,
>>>>>>> with the latest vehicle additions, the firmware size has now
>>>>>>> grown to 4,015,328 bytes in build 3.3.005-485-gc4664881.
>>>>>>> Our flash partitioning scheme is currently designed to provide
>>>>>>> three firmware partitions (factory, ota_0 & ota_1) of 4MB =
>>>>>>> 4,194,304 bytes each.
>>>>>>> So we've now got 178,976 bytes = ~4% left.
>>>>>>> Options beyond the 4 MB limit:
>>>>>>> a) split features, e.g. vehicle support, into two or more builds
>>>>>>> b) repartition into two firmware partitions of 6 MB each,
>>>>>>> reusing the factory partition for OTA
>>>>>>> c) switch to an ESP32 WROOM module with 32 MB flash (possible?)
>>>>>>> We've got some time left, new vehicles normally don't need that
>>>>>>> much space, I just wanted to raise awareness.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260222/cf06ec49/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260222/cf06ec49/attachment-0001.sig>
