[Ovmsdev] Public OVMS Servers
Carsten Schmiemann carsten.schmiemann at pfalz-mail.de
Mon Sep 22 08:59:20 HKT 2025
1. Title: Turboserv
2. Location: Mutterstadt, Germany
3. Intended geographic coverage: Globally available
4. Access policy: unrestricted public access for OVMS use only
5. Access domain name: https://turboserv.0-c.de
6. User Registration URL: https://turboserv.0-c.de/register
7. V2 offered?: yes
7.1 V2 Type: Custom, compatible with latest master of OVMS Firmware
7.2 V2 Version: master head
7.3 V2 standard service port (if offered): tcp/6867
7.4 V2 SSL server port (if offered): tcp/6870
7.5 V2 HTTP API standard service port: not available
7.6 V2 HTTPS API standard service port: https/443
7.7 V2 is WebSocket available on HTTP/HTTPS API service port?: No
8. V3 offered?: yes
8.1 V3 Type: FlashMQ
8.2 V3 Version: 1.23.0
8.3 V3 MQTT authentication: Per vehicle username+password, for external access additional username+password
8.4 V3 MQTT standard service port: tcp/1883
8.5 V3 MQTT SSL service port: tcp/8883
8.6 V3 MQTT websocket standard service port: not available
8.7 V3 MQTT websocket SSL service port: not available
9. Notifications supported?: Yes
9.1 APNS (Apple IOS) supported?: Yes
9.2 GCM (Android firebase) supported?: Yes
9.3 MAIL (eMail) supported?: Yes
9.4 EXPO supported?: No
10. Notes/comments:
- Rewritten Server + WebGUI and API in Python. API is not compatible with official V3 Server, the documentation of the OpenAPI is available at
https://turboserv.0-c.de/docs and https://turboserv.0-c.de/redoc after login.
- NTFY.sh (Public and self hosted Instance) Notification Support
- Easy to use WebGUI
- Optional Trip Tracking (V3 only)
- Protomaps Support
- Key metrics highlighted and all transmitted metrics visible in WebGUI (V2 and V3) for easy debugging
- Remote console support for V2 and V3
- Improved security, V3 vehicle credentials can only readwrite to its own vehicle topic, User created API Keys=MQTT Credentials for accessing all vehicle topics
--> Will be fully open sourced a the end of 2025, after fixing some bugs and documentation
Am 22.09.2025 um 02:24 schrieb Mark Webb-Johnson via OvmsDev <ovmsdev at lists.openvehicles.com>:
I’m trying to compile a full list of public OVMS servers, and in particular their capabilities.
Here is what I would like to collect:
  1.  Title
  2.  Location
  4.  Access policy
  7.  V2 offered?
     *   V2 Type
     *   V2 Version
     *   V2 standard service port (if offered)
     *   V2 SSL server port (if offered)
     *   V2 HTTP API standard service port
     *   V2 HTTPS API standard service port
     *   V2 is WebSocket available on HTTP/HTTPS API service port?
  8.  V3 offered?
     *   V3 Type
     *   V3 Version
     *   V3 MQTT authentication
     *   V3 MQTT standard service port
     *   V3 MQTT SSL service port
     *   V3 MQTT websocket standard service port
     *   V3 MQTT websocket SSL service port
     *   APNS (Apple IOS) supported?
     *   GCM (Android firebase) supported?
     *   MAIL (eMail) supported?
     *   EXPO supported?
  10. Notes/comments
Grateful if you could reply to this eMail with details of any public OVMS servers that you operate, use, or know-of. Obviously best if the operators could reply directly as they know the capabilities best.
As an example, for api.openvehicles.com<http://api.openvehicles.com/> here are the corresponding details:
  1.  Title: Open Vehicles
  2.  Location: Hong Kong
  5.  Access domain name: api.openvehicles.com<http://api.openvehicles.com/>
  6.  User Registration URL: https://www.openvehicles.com/
  7.  V2 offered?: yes
     *   V2 Type: https://github.com/openvehicles/Open-Vehicle-Server/tree/master/v3/server
     *   V2 Version:  master head, unmodified (currently 3.0.001-74-gb19aaac)
     *   V2 standard service port (if offered): tcp/6867
     *   V2 SSL server port (if offered): tcp/6870
     *   V2 HTTP API standard service port: tcp/6868
     *   V2 HTTPS API standard service port: tcp/6869
     *   V2 is WebSocket available on HTTP/HTTPS API service port?: yes
  8.  V3 offered?: yes
     *   V3 Type: mosquitto
     *   V3 Version: 1.6
     *   V3 MQTT authentication: same username+password as #6
     *   V3 MQTT standard service port: tcp/1883
     *   V3 MQTT SSL service port: tcp/8883
     *   V3 MQTT websocket standard service port: not available
     *   V3 MQTT websocket SSL service port: tcp/8083
     *   APNS (Apple IOS) supported?: Yes
     *   GCM (Android firebase) supported?: Yes
     *   MAIL (eMail) supported?: Yes
     *   EXPO supported?: Yes
  10. Notes/comments: none
Thanks, and Regards,
Mark
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250922/e6512c8d/attachment-0001.htm>
