[Ovmsdev] Inserting a Single OBD Request into the Poller
Mon May 26 12:28:45 HKT 2025
Notice that I did it 2 different ways.
When the car goes into on state it tries a non blocking request.
If the user requests the vin from the cli and the vin hasn't populated.. it
tries a blocking request.
It uses common code to decode the VIN.
//.ichEl
On Mon, 26 May 2025, 12:15 Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> Look at ioniq 5 for that specific example!
> On Mon, 26 May 2025, 04:09 solterra--- via OvmsDev, <
> ovmsdev at lists.openvehicles.com> wrote:
>> Could someone point me to an example of the correct way to insert a
>> single OBD request into the poller?
>> As an example, I’d like to request the VIN—but I only need to do this
>> once, not on a recurring basis. I was previously using PollSingleRequest,
>> but it no longer seems to be working as expected.
>> Thank you in advance for your help!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250526/328a8718/attachment.htm>
