[Ovmsdev] Urgent server issue: Apple push notification API deprecated
Mon May 19 20:20:38 HKT 2025
Michael,
Yes, seems I missed this. My other projects use either AWS SNS or EXPO so abstract this out.
It appears that a simple short-term solution is to switch to Net::APNS::Simple (which says it uses the Apple HTTP/2 interface). It is blocking, but we could wrap it in a fork_call just like the GCM implementation does.
It is late here now, but I can have a look at it tomorrow (unless anyone else can have a go at it earlier).
> On May 19, 2025, at 7:13 PM, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> A user just reported he no longer gets any iOS notifications, seems to have begun ~2-3 days ago.
> The log shows:
> 2025-05-19 12:50:32.140969 +0200 info main: - - - msg apns processing queue for gateway.push.apple.com
> 2025-05-19 12:50:32.571275 +0200 error main: - - - connection to apns FAILED: EOF during handshake
> 2025-05-19 12:50:32.571384 +0200 error main: - - - msg apns processing ABORT for gateway.push.apple.com: connection closed
> I've found this forum entry:
> https://developer.apple.com/forums/thread/784585?answerId=839840022#839840022
> So it seems Apple has finally adopted the Google way of deprecating established services without need.
> Mark, I assume this affects your server as well, if not now then in the near future. Probably the iOS App doesn't need an update, but I haven't checked that.
> Is anyone able to help with updating the server to the new APNS API? I don't have any iOS devices, so testing is difficult for me.
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250519/63c4451e/attachment.htm>
