[Ovmsdev] Another incident
Chris Box
chris8086 at ee.eclipse1.net
Sat Mar 29 02:15:30 HKT 2025
On 2025-03-22 02:26, Michael Geddes wrote:
> How are we going with this investigation?
Good question. I've been quiet while I progressed the 12v theory.
Currently the code only tracks average 12v, so I implemented code to
also record the lowest 12v observed. This value is then reported as an
MQTT metric, and also log entries are created every time it reaches a
new low.
I observed this for a couple of weeks, and saw 12v dropping below 11.8
while the average was still up at 12.6 or more:
With normal OVMS only the green line's metrics are reported. The yellow
one is what I've added.
I then replaced the conventional lead acid with a new AGM, to benefit
from its low internal resistance.
The difference can be seen clearly. The change happened on 12th March.
Since I've been using the AGM I haven't experienced a dashboard error.
It's early days of course; time will tell.
Since the tracking of lowest 12v seems to be useful, I plan to create a
PR for this part.
Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250328/3a37ac71/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250328/3a37ac71/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250328/3a37ac71/attachment-0003.png>
