[Ovmsdev] Leaf AZE1 Can1 stuck after poll 7BB group 61
Tue Mar 25 20:25:46 HKT 2025
Sorry, you're of course right, guess I didn't get enough sleep last
night… 9_9
Am 25.03.25 um 13:09 schrieb Michael Geddes:
> That's to make sure a minimum width so that packages shorter than
> expected dont have issues with the functions accessing it beyond the
> buffer.
> Oversize will just adapt anyway.
> On Tue, 25 Mar 2025, 17:49 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> I see you already checked the poll handlers don't write to the
> buffer, so that's a possible & better option.
> But why do you limit the reserve() call? Clearly, the
> MAX_POLL_DATA_LEN isn't sufficient for the new poll, Wayne wants
> to add. Doing rxbuf.reserve(length + job.mlremain) should be
> perfectly OK, as it adapts to any reply size? After all, it's just
> a reservation, append will need to reallocate if it's too small. I
> think the module can get rid off MAX_POLL_DATA_LEN altogether when
> using the string memory directly.
> Am 25.03.25 um 09:54 schrieb Michael Geddes via OvmsDev:
>> Why don't we just std:max() the reserve() on the string and cast
>> c_str() to uint8_t * !? That way we know the array access
>> in the code won't fumble into uncharted space and we get rid of
>> the unchecked copy into the static memory space?
>> //.ichael
>> On Tue, 25 Mar 2025 at 16:38, Michael Balzer via OvmsDev
>> Wayne,
>> uh, yes, that's a typical buffer overflow pattern there,
>> unguarded
>> copying of a string contents to a fixed size buffer:
>> > static uint8_t buf[MAX_POLL_DATA_LEN];
>> > memcpy(buf, rxbuf.c_str(), rxbuf.size());
>> Not sure why/if the handlers need an uint8_t array in the
>> first place,
>> but a quick first fix should be to adjust MAX_POLL_DATA_LEN:
>> > #define MAX_POLL_DATA_LEN 196
>> Add some spare room to the 329 bytes needed, just in case.
>> Am 25.03.25 um 09:31 schrieb Wayne Love:
>> > Hi Micheal,
>> > Your comment...
>> >> Regarding Leaf CAN problems there ist a running
>> investigation here:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/980
>> > Is dead on the money.
>> > Polling group 61 returns an abnormally large response, 329
>> bytes.
>> > This causes a buffer overrun in
>> > OvmsVehicleNissanLeaf::IncomingPollReply with an unguarded
>> memcpy that
>> > causes the module to crash. Once the module crashes, I get
>> the exact
>> > symptoms in issue 980.
>> > Appreciate your help with this.
>> > Thanks
>> > Wayne
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
>> Fon 02330 9104094 * Handy 0176 20698926
> Michael Balzer *Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250325/9cfa79f3/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250325/9cfa79f3/attachment.sig>
