[Ovmsdev] Leaf AZE1 Can1 stuck after poll 7BB group 61
Tue Mar 25 18:12:19 HKT 2025
I think to prevent the buffer being too small, this should rather be
std::min()?
Am 25.03.25 um 10:49 schrieb Michael Balzer via OvmsDev:
> I see you already checked the poll handlers don't write to the buffer,
> so that's a possible & better option.
> But why do you limit the reserve() call? Clearly, the
> MAX_POLL_DATA_LEN isn't sufficient for the new poll, Wayne wants to
> add. Doing rxbuf.reserve(length + job.mlremain) should be perfectly
> OK, as it adapts to any reply size? After all, it's just a
> reservation, append will need to reallocate if it's too small. I think
> the module can get rid off MAX_POLL_DATA_LEN altogether when using the
> string memory directly.
> Am 25.03.25 um 09:54 schrieb Michael Geddes via OvmsDev:
>> Why don't we just std:max() the  reserve() on the string and cast
>> c_str() to uint8_t * !?  That way we know the array access
>> in the code won't fumble into uncharted space and we get rid of the
>> unchecked copy into the static memory space?
>> //.ichael
>> On Tue, 25 Mar 2025 at 16:38, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>>     Wayne,
>>     uh, yes, that's a typical buffer overflow pattern there, unguarded
>>     copying of a string contents to a fixed size buffer:
>>     >   static uint8_t buf[MAX_POLL_DATA_LEN];
>>     >   memcpy(buf, rxbuf.c_str(), rxbuf.size());
>>     Not sure why/if the handlers need an uint8_t array in the first
>>     place,
>>     but a quick first fix should be to adjust MAX_POLL_DATA_LEN:
>>     > #define MAX_POLL_DATA_LEN         196
>>     Add some spare room to the 329 bytes needed, just in case.
>>     Regards,
>>     Michael
>>     Am 25.03.25 um 09:31 schrieb Wayne Love:
>>     > Hi Micheal,
>>     > Your comment...
>>     >> Regarding Leaf CAN problems there ist a running investigation
>>     here:
>>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/980
>>     > Is dead on the money.
>>     > Polling group 61 returns an abnormally large response, 329 bytes.
>>     > This causes a buffer overrun in
>>     > OvmsVehicleNissanLeaf::IncomingPollReply with an unguarded
>>     memcpy that
>>     > causes the module to crash.  Once the module crashes, I get the
>>     exact
>>     > symptoms in issue 980.
>>     > Appreciate your help with this.
>>     > Thanks
>>     > Wayne
>>     Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>     Fon 02330 9104094 * Handy 0176 20698926
>>     _______________________________________________
>>     OvmsDev mailing list
>>     OvmsDev at lists.openvehicles.com
>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250325/dc25ad71/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250325/dc25ad71/attachment.sig>
