[Ovmsdev] Leaf AZE1 Can1 stuck after poll 7BB group 61
Mon Mar 24 20:23:47 HKT 2025
Wayne,
payload cannot cause bus errors.
> 2025-03-23 13:48:10.648 AEDT E (11528) esp32can: can1 stuck bus-off
> error state (errflags=0x00040cab) detected - resetting bus
OVMS# can can1 explain 0x00040cab
Bus error flags 0x00040cab:
  | IR.2 Error-warning state
  | SR.3 TX done | SR.2 TX buffer free
  | ECC Stuff error in RX, segment data length code
If not by false timing, stuff errors can be caused by noise on the bus,
some component flooding the bus with transmissions, or by hardware
issues with the cabling.
Regarding Leaf CAN problems there ist a running investigation here:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/980
Adding the termination resistor would have been my next guess, but
Richard already tried that, didn't help.
Are you absolutely sure the issue only (!) and reproducably (!) exists
with that additional SOH poll entry?
Assuming that's the case: could it be this is a bus overload caused by
the Leaf module itself when requesting all response frames without delay?
> OvmsVehicleNissanLeaf::OvmsVehicleNissanLeaf()
>> *PollSetResponseSeparationTime(0);*
The framework default is 25 ms, so you could try commenting out that call.
Am 24.03.25 um 07:48 schrieb Wayne Love:
> Hi Michael,
> Adding your patch did not make noticeable difference.
> I noted that Leafspy pads the poll request with 0x00, whereas ovms
> pads with 0x55.  I've also modified vehicle_poller_isotp.cpp to pad
> with 0x00 but again this made no difference.
> Thanks
> Wayne
>> On Mar 23, 2025, at 9:23 PM, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Wayne,
>> do you currently apply my CAN timing patch? If not, please try that
>> first.
>> Also, a general question to all Leaf developers: did anyone yet test
>> fixing that random bytes write in
>> `OvmsVehicleNissanLeaf::CommandWakeup()`?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250324/0a28e7dc/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250324/0a28e7dc/attachment-0001.sig>
