[Ovmsdev] SDCard speeds.
Sun Mar 23 18:13:29 HKT 2025
I think the actual max speed of the SPI host is 20 MHz, I never got
anything higher to work. 20 MHz is my current config and works fine with
all SD cards I tested.
Joshua Jung reported an issue with SD cards, that was resolved by a
hardware replacement (I assume he meant replacing the module):
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/1107
So there may be a hardware issue with some modules.
Am 23.03.25 um 04:52 schrieb Michael Geddes via OvmsDev:
> I while ago I was talking about issues with my SDCard, and I've just
> had a friend have some similar issues. Both these issues were fixed
> with setting the max frequency to 15MHz
> config set sdcard maxfreq.khz 15000
> This does end up making things a bit slower, but at least it works.
> The reported max of my card is 25Mhz. I'm concerned that the default
> is misbehaving. Is this a software issue? or is it a hardware issue?
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250323/8ed5f9d8/attachment.sig>
