[Ovmsdev] Another incident
Sat Mar 22 16:44:29 HKT 2025
Michael,
are you aware of these new findings by Richard Taylor?
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/980#issuecomment-2715403436
Am 22.03.25 um 03:26 schrieb Michael Geddes via OvmsDev:
> How are we going with this investigation?
> I've been following along mostly and have been periodically going over
> the poller code trying to work out if there are any points where there
> could be timing issues with long-held mutexes (or even deadlocks). I
> did push up some small tweaks recently but there was no aha! moment.
> I have been working on some changes that would move forward on the
> idea of building a vehicle implementation from duktape scripts... and
> I had been getting some points where ovms went berserk, kicked out the
> ssh session and stopped responding on ssh http but then eventually
> came back (without a reset) after some minutes. The script was simply
> adding a new PollSeriesEntry which then uses the dbc decoder (with
> improvements) to decode to metrics, noting that the script is setup
> only and that there are no call-backs into the duktape engine/task.
> Anyway, those patches mentioned above seem to have resolved that issue
> with the hangups which is why I made the p/r.
> BTW I have been running my Ioniq5 with the latest of the timing
> patches for a while now.
> Because of the correlation of the bus issues with the poller changes,
> I am still concerned that the poller changes are contributing to the
> problem (even if not directly causing it), so would be happy to chase
> down any leads people might have.
> //.ichael
> On Sat, 22 Feb 2025 at 02:52, Chris Box via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
>> Check your DTCs with leafspy, if it shows a bunch of DTCs
>> including a B2604 BCM Shift PN diag, then likely low 12v, try
>> a 24 hr charge or replace it.
> I did indeed have B2604-00, along with nineteen others. Most of
> these mention CAN errors, and it seems plausible that low 12v
> could be a common cause.
> Do you think this rules out a poor OVMS OBDII connection? I'm
> thinking if I have high resistance in that connector, then OVMS
> will experience low voltage but the rest of the car modules will
> have good voltage.
> However I see codes that suggest communication errors between
> Nissan modules:
> C118C-01 ABS Brake: Malfunction is detected in VCM system. Control
> module communication issue.
> B2064-00 BCM Shift PN Diag CAN: Park-Neutral position switch
> signal discrepancy
> C1A70-01 BRAKE: Malfunction is detected in ABS actuator control
> unit system
> U1266-02 MULTI AV: Malfunction is detected between the AV control
> unit and TCU
> U0428-00 AVM: Invalid data received from steering angle sensor module
> So I'm thinking perhaps the whole car briefly had low voltage.
> To try to fix this, I cleaned the 12v battery terminals and
> performed a long charge. After clearing the codes, I have only two
> codes that reappear.
> P317E-00 EV/HEV HV Battery System EVC-249 (perhaps caused by #1061
> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/1061>)
> U1A06-15 TCU Communication incorrect calibration (probably because
> I've removed its antenna)
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250322/e9e59fd1/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250322/e9e59fd1/attachment.sig>
