[Ovmsdev] Simple Auth for api
Chris van der Meijden
chris at arachnon.de
Sun Mar 16 04:15:17 HKT 2025
Mark,
sorry, for now I'm too busy with all the home automation stuff. I just
needed a quick and dirty solution.
If I would write the AuthSimple.pm as you suggested, I would need to
find out how to access Config::IniFiles first and then would implement
it not only for one user, but for, lets say, four users. For the case
that there are several vehicles using OVMS in the family.
Too time consuming at the moment for me. Allthough, if you are more
familiar with the perl code, it should be fairly easy to achief, I
think.
Regards
Chris
Am Freitag, dem 14.03.2025 um 07:48 +0800 schrieb Mark Webb-Johnson:
> Chris,
> If you’d like to provide a simple contribution to the project it
> would be:
> * AuthSimple.pm
> - Use the Config::IniFiles config file we already have, with a new
> section to store the userid, password, etc.
> For users wanting to run their own server, but only having one user,
> that would be useful.
> > On 14 Mar 2025, at 12:38 AM, Chris van der Meijden via OvmsDev
> > <ovmsdev at lists.openvehicles.com> wrote:
> > OK, it was not that hard ...
> > In the AuthNone.pm I changed the sub Authenticate to
> > sub Authenticate
> > my ($user,$password) = @_;
> > if ($user eq "xxx" && $password eq "yyy") {
> > return '*';
> > } else {
> > return '';
> > and activated AuthNone in the ovms_sever.conf
> > Am Donnerstag, dem 13.03.2025 um 11:34 +0100 schrieb Chris van der
> > Meijden via OvmsDev:
> > > I'm trying to connect our e-UP to EVCC using the http api.
> > > This fails, because I don't have a Drupal server installed. I
> > > only found AuhDrupal and AuthNone as modules for the the server.
> > > I don't want to install a Drupal instance for only one user, so
> > > I'm now trying to write a AuthSimple module for only one user
> > > with the username and password included in the code (I know,
> > > unsecure), so that the authentication for that user goes through
> > > and I get the variables I need for EVCC.
> > > Before I reinvent the wheel, does a code snippet perhaps exists,
> > > that does the trick?
> > > Regards
> > > Chris
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250315/848e9290/attachment.htm>
