[Ovmsdev] ESP32CAN - CAN bus interferences
Info info at zeitnitz.eu
Fri Jun 13 21:50:43 HKT 2025
Hi Michael,
answers below:
Am 13.06.2025 um 15:18 schrieb Michael Balzer via OvmsDev:
> Christian,
> can you please put this in context with the discussed & implemented
> transceiver shutdown suppression?
The SN65HVD233 has, according to the manual, no shutdown mode.
The so-called low-power mode is described as: a low-current, listen only
standby mode.
So, only the write amplifier is disabled, which requires most of the power.
The mentioned TCAN330 actually has a shutdown pin, put that is separate
from the listen only mode.
Will have a look at the discussion and comment.
> E.g. in thread: Firmware release 3.3.005 / CAN SAE timing
> CAN controller listen mode will be of very limited use, as most
> vehicles need to be able to at least poll.
> Do the GPIO transients actually make it to the bus?
Yes, in case of the ESP32CAN TX pin, a transient is going straight to
the bus and effects the CANL and CANH level. There is nothing preventing
this except for the listen-only mode (RS pin set to high).
> Does disabling the transceiver shutdown help in your case?
Not sure, what you mean by this. As said above the SN65HVD233 has no
shutdown mode.
> Please also share your findings in the mentioned Github discussion
> (issue 980), that's the most complete thread on this issue currently,
> and possibly Richard can do some tests as well.
Ok, will do.
> Changing the transceiver is something Mark needs to comment on.
> Am 13.06.25 um 14:39 schrieb Info via OvmsDev:
>> Dear all,
>> I recently experienced some interferences between my OVMS module
>> (Lilygo based) and the CAN bus of the car. The car was complaining
>> once in while about problems with certain components.
>> I first thought it might be related to my hardware. Checking some
>> discussions, I realized, that, at least for the Smart EQ, this seems
>> to be a common problem, independent of the used hardware.
>> I traced this down to a crashing firmware (edge version), which leads
>> to a disturbance of CAN1 (ESP32CAN).
>> Actually I emulated a car (Smart EQ) with an Arduino and two CAN
>> interfaces and recorded the bus errors and transmission problems. For
>> this I crashed the firmware intentionally once a minute. The
>> efficiency of occurring errors is pretty high, but not each crash
>> leads to transmission problems.
>> It actually does not help to disable the write access to the bus,
>> since this is only implemented in software. The hardware listen-only
>> mode of the CAN transceiver SN65HVD233 is not implemented yet (see
>> below).
>> In conclusion, CAN1 is inherently sensitive to  to a crashing
>> firmware due to the undefined GPIO transients on the ESP32CAN TX pin.
>> What helps, is to switch the transceiver into the listen-only mode
>> (RS pin high). In this case two pins have to conspire to achieve a
>> dominant state on the bus.
>> The MCP2515 based bus is not effected by crashes.
>> I propose to implement the hardware based listen-only mode in case,
>> that the write access is disabled anyway. I implemented this now for
>> the ESP32CAN as well as for the MCP2515 code.
>> See
>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3-Lilygo-Support/tree/add-canbus-hw-listenonly
>> This branch includes only the changes wrt to the switching of the
>> listen-only mode. I will issue a corresponding pull request.
>> In the code for the cars, the can bus mode has to be specified:
>> if (write_is_enabled) RegisterCanBus(busno,CAN_MODE_ACTIVE, speed);
>> else  RegisterCanBus(busno,CAN_MODE_LISTEN, speed);
>> In case the config changes:
>> if (write_is_enabled) SetCanbusMode(busno,CAN_MODE_ACTIVE);
>> else  SetCanbusMode(busno,CAN_MODE_LISTEN);
>> As an example, I implemented this for vehicle_smarteq in the above repo.
>> Another measure of security would be to shift for newer hardware to a
>> different CAN transceiver chip. I use now the TI TCAN330, which is
>> pin and functionally compatible with the SN65HVD233, but has a
>> feature called DOT (Dominant Time Out), which will return the bus to
>> a recessive state after a few msecs, in case the dominant state is
>> applied for a too long time.
>> Best regards
>>   Christian
