[Ovmsdev] ESP32CAN - CAN bus interferences
Info
info at zeitnitz.eu
Fri Jun 13 20:39:13 HKT 2025
Dear all,
I recently experienced some interferences between my OVMS module (Lilygo
based) and the CAN bus of the car. The car was complaining once in while
about problems with certain components.
I first thought it might be related to my hardware. Checking some
discussions, I realized, that, at least for the Smart EQ, this seems to
be a common problem, independent of the used hardware.
I traced this down to a crashing firmware (edge version), which leads to
a disturbance of CAN1 (ESP32CAN).
Actually I emulated a car (Smart EQ) with an Arduino and two CAN
interfaces and recorded the bus errors and transmission problems. For
this I crashed the firmware intentionally once a minute. The efficiency
of occurring errors is pretty high, but not each crash leads to
It actually does not help to disable the write access to the bus, since
this is only implemented in software. The hardware listen-only mode of
the CAN transceiver SN65HVD233 is not implemented yet (see below).
In conclusion, CAN1 is inherently sensitive to to a crashing firmware
due to the undefined GPIO transients on the ESP32CAN TX pin.
What helps, is to switch the transceiver into the listen-only mode (RS
pin high). In this case two pins have to conspire to achieve a dominant
state on the bus.
The MCP2515 based bus is not effected by crashes.
I propose to implement the hardware based listen-only mode in case, that
the write access is disabled anyway. I implemented this now for the
ESP32CAN as well as for the MCP2515 code.
See
https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3-Lilygo-Support/tree/add-canbus-hw-listenonly
This branch includes only the changes wrt to the switching of the
listen-only mode. I will issue a corresponding pull request.
In the code for the cars, the can bus mode has to be specified:
if (write_is_enabled) RegisterCanBus(busno,CAN_MODE_ACTIVE, speed);
else RegisterCanBus(busno,CAN_MODE_LISTEN, speed);
In case the config changes:
if (write_is_enabled) SetCanbusMode(busno,CAN_MODE_ACTIVE);
else SetCanbusMode(busno,CAN_MODE_LISTEN);
As an example, I implemented this for vehicle_smarteq in the above repo.
Another measure of security would be to shift for newer hardware to a
different CAN transceiver chip. I use now the TI TCAN330, which is pin
and functionally compatible with the SN65HVD233, but has a feature
called DOT (Dominant Time Out), which will return the bus to a recessive
state after a few msecs, in case the dominant state is applied for a too
long time.
Best regards
Christian
