[Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Sun Jul 13 16:31:14 HKT 2025
Mark, everyone,
as we don't make any progress on the CAN issues (affecting only few
users), and "main" users struggle with bugs that have long been fixed in
"edge", I'd say we release 3.3.005 now.
Am 12.04.25 um 09:37 schrieb Michael Balzer via OvmsDev:
> Chris,
> as you changed two parameters at once, you cannot currently tell which
> helped.
> I suggest keeping the improved 12V level and returning to the old CAN
> timing to see if that makes a difference.
> Reviewing your report & findings, I'd say your issue was caused by the
> 12V dips.
> Am 11.04.25 um 20:01 schrieb Chris Box:
>> On 2025-04-06 11:03, Michael Balzer via OvmsDev wrote:
>>> Did the changed CAN timing to better follow the SAE recommendations
>>> actually have any benefits?
>> I haven't experienced any Leaf errors using the SAE timing over the
>> past month. As a result my intention is to continue with this new
>> timing, although I can't prove the timing is the reason for the lack
>> of issues. I also improved 12 volt levels.
>> If you're looking for hard data, please advise what I should do to
>> gather that data. It's not particularly clear to me, because I
>> understand that "normal" can bus statistics for the Leaf include some
>> expected errors.
>> Thanks
>> Chris
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250713/71a248cd/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250713/71a248cd/attachment.sig>
