Sun Jan 26 23:16:44 HKT 2025
Simon,
you need to decode the backtrace yourself, as you have local code
additions we do not have. Use the a2l script (in support).
Am 26.01.25 um 14:52 schrieb Simon Ehlen via OvmsDev:
> Hi,
> it is of course possible that it is due to something else. But that
> was the only code change I flashed.
> According to the log, it dies at this point:
> I (2369) v-ffe: Ford Focus Electric vehicle module
> I (2369) cellular-modem-auto: Power Cycle 2000ms
> I (2379) mcp2515: can2: SetPowerMode on
> D (2439) mcp2515: can2: Set register (0x2b val 0x00->0x00)
> D (2449) mcp2515: can2:  - read register (0x2b : 0x00)
> D (2449) mcp2515: can2: Set register (0x60 val 0x00->0x64)
> D (2459) mcp2515: can2:  - read register (0x60 : 0x64)
> D (2459) mcp2515: can2: Set register (0x0c val 0x00->0x0c)
> D (2469) mcp2515: can2:  - read register (0x0c : 0x0c)
> D (2469) mcp2515: can2: Change op mode to 0x60
> D (2489) mcp2515: can2:  read CANSTAT register (0x0e : 0x60)
> E (2489) can: can2: intr=1 rxpkt=1 txpkt=0 errflags=0x23401c01 rxerr=0
> txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0
> errreset=0
> Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception
> was unhandled.
> Core 1 register dump:
> PC      : 0x4008a830  PS      : 0x00060a30  A0      : 0x801aaa31
> A1      : 0x3ffc4ab0
> A2      : 0x00120000  A3      : 0x3ffc4af0  A4      : 0x00000024
> A5      : 0x00120000
> A6      : 0x000007e4  A7      : 0x000007ec  A8      : 0x00000000
> A9      : 0x3ffc4a80
> A10     : 0x00000000  A11     : 0x40084a7c  A12     : 0x00000003
> A13     : 0x00000008
> A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x00000010
> EXCCAUSE: 0x0000001d
> EXCVADDR: 0x00120000  LBEG    : 0x4008a82c  LEND    : 0x4008a848
> LCOUNT  : 0x00000001
> ELF file SHA256: 5e6a07d4d02b1a79
> Backtrace: 0x4008a830:0x3ffc4ab0 0x401aaa2e:0x3ffc4ac0
> 0x401aab8a:0x3ffc4ae0 0x401aada5:0x3ffc4b40 0x401ab1f7:0x3ffc4b90
> 0x401ab22e:0x3ffc4c00 0x401a3c07:0x3ffc4c20 0x401a453a:0x3ffc4c50
> 0x401a4618:0x3ffc4ca0 0x4011a697:0x3ffc4d20 0x4011a256:0x3ffc4d90
> 0x40119382:0x3ffc4dd0 0x4011979d:0x3ffc4e00 0x40119b8c:0x3ffc4e60
> 0x40119c11:0x3ffc4ea0
> It then boots to a command prompt
> E (1378) housekeeping: Auto init inhibited: too many early crashes (5)
> Does that tell you anything?
> Cheers,
> Simon
> Am 26.01.2025 um 14:05 schrieb Michael Balzer via OvmsDev:
>> Simon,
>> you need to connect via USB to set the boot partition if you cannot
>> access the module.
>> But… there is no way a wrong MCP2515 timing could cause this. I'd
>> look for other potential causes.
>> Am 26.01.25 um 13:58 schrieb Simon Ehlen via OvmsDev:
>>> Hi Michael,
>>> I tried your first suggestion, but after this change the OVMS no
>>> longer boots at all.
>>> cnf1=0xc3; cnf2=0xaa; cnf3=0x85;
>>> What is the easiest way to select the firmware on the second
>>> partition? Is there a way via the SD card or do I have to connect
>>> the OVMS with USB?
>>> Cheers,
>>> Simon
>>> Am 26.01.2025 um 12:51 schrieb Michael Balzer via OvmsDev:
>>>> Simon,
>>>> Am 25.01.25 um 21:00 schrieb Simon Ehlen via OvmsDev:
>>>>> Are adjustments/improvements also necessary at 125KBPS for CAN2/3?
>>>> I've had a look at SAE J2284-1 for the 125 kbit timing, and it
>>>> seems for this speed, the esp-idf, the mcp_can lib and our current
>>>> driver are outside the spec.
>>>> SAE recommends a sync jump width of 3 for low (nq=8) and 4 for
>>>> higher resolutions, and single sampling at 62.5% (range 58.3…69.2%).
>>>> The esp-idf driver would use a SJW of 3 (would better be 4 as
>>>> nq=20) and single sampling at 80% (very late). The Arduino lib uses
>>>> SJW=2 (too low) and triple sampling at 75% (late).
>>>> Our current driver uses a SJW of 1 (much too low) and triple
>>>> sampling at 56.25% (too early):
>>>>     case CAN_SPEED_125KBPS:
>>>>       cnf1=0x03; cnf2=0xf0; cnf3=0x86;
>>>>       // BRP=3, PRSEG=1, PS1=7, PS2=7, SJW=1, BTLMODE=1, SAM=1,
>>>> SOF=1, WAKFIL=0 → Sample 3x at 9/16 = 56,25%
>>>> (Note: the current comment in the source is incorrect, the tq
>>>> values need each to be read as +1)
>>>> Possible SAE solutions for the MCP2515:
>>>> a)
>>>>       // SAE J2284-1:
>>>>       // BRP=3, PRSEG=3, PS1=6, PS2=6, SJW=4, BTLMODE=1, SAM=0,
>>>> SOF=1, WAKFIL=0 → Sample point at 10/16 = 62.5%
>>>> b)
>>>>       // SAE J2284-1:
>>>>       // BRP=3, PRSEG=3, PS1=7, PS2=5, SJW=4, BTLMODE=1, SAM=0,
>>>> SOF=1, WAKFIL=0 → Sample point at 11/16 = 68.8%
>>>>       cnf1=0xc3; cnf2=0xb2; cnf3=0x84;
>>>> Please try.
>>>> Btw, if anyone would like to experiment: the Microchip timing
>>>> calculator needs to be set to 16 MHz (that's our MCP2515 clock),
>>>> and you need to add 0x80 to the cnf3 byte generated (that's the SOF
>>>> flag, cannot be set in the UI).
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250126/b90b7095/attachment.sig>
