    Sun Jan 26 21:05:50 HKT 2025
Simon,
you need to connect via USB to set the boot partition if you cannot
access the module.
But… there is no way a wrong MCP2515 timing could cause this. I'd look
for other potential causes.
Am 26.01.25 um 13:58 schrieb Simon Ehlen via OvmsDev:
> Hi Michael,
> I tried your first suggestion, but after this change the OVMS no
> longer boots at all.
> cnf1=0xc3; cnf2=0xaa; cnf3=0x85;
> What is the easiest way to select the firmware on the second
> partition? Is there a way via the SD card or do I have to connect the
> OVMS with USB?
> Cheers,
> Simon
> Am 26.01.2025 um 12:51 schrieb Michael Balzer via OvmsDev:
>> Simon,
>> Am 25.01.25 um 21:00 schrieb Simon Ehlen via OvmsDev:
>>> Are adjustments/improvements also necessary at 125KBPS for CAN2/3?
>> I've had a look at SAE J2284-1 for the 125 kbit timing, and it seems
>> for this speed, the esp-idf, the mcp_can lib and our current driver
>> are outside the spec.
>> SAE recommends a sync jump width of 3 for low (nq=8) and 4 for higher
>> resolutions, and single sampling at 62.5% (range 58.3…69.2%).
>> The esp-idf driver would use a SJW of 3 (would better be 4 as nq=20)
>> and single sampling at 80% (very late). The Arduino lib uses SJW=2
>> (too low) and triple sampling at 75% (late).
>> Our current driver uses a SJW of 1 (much too low) and triple sampling
>> at 56.25% (too early):
>>     case CAN_SPEED_125KBPS:
>>       cnf1=0x03; cnf2=0xf0; cnf3=0x86;
>>       // BRP=3, PRSEG=1, PS1=7, PS2=7, SJW=1, BTLMODE=1, SAM=1,
>> SOF=1, WAKFIL=0 → Sample 3x at 9/16 = 56,25%
>> (Note: the current comment in the source is incorrect, the tq values
>> need each to be read as +1)
>> Possible SAE solutions for the MCP2515:
>> a)
>>       // SAE J2284-1:
>>       // BRP=3, PRSEG=3, PS1=6, PS2=6, SJW=4, BTLMODE=1, SAM=0,
>> SOF=1, WAKFIL=0 → Sample point at 10/16 = 62.5%
>> b)
>>       // SAE J2284-1:
>>       // BRP=3, PRSEG=3, PS1=7, PS2=5, SJW=4, BTLMODE=1, SAM=0,
>> SOF=1, WAKFIL=0 → Sample point at 11/16 = 68.8%
>>       cnf1=0xc3; cnf2=0xb2; cnf3=0x84;
>> Please try.
>> Btw, if anyone would like to experiment: the Microchip timing
>> calculator needs to be set to 16 MHz (that's our MCP2515 clock), and
>> you need to add 0x80 to the cnf3 byte generated (that's the SOF flag,
>> cannot be set in the UI).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250126/58120f2b/attachment-0001.sig>
