Sun Jan 26 19:51:35 HKT 2025
Simon,
Am 25.01.25 um 21:00 schrieb Simon Ehlen via OvmsDev:
> Are adjustments/improvements also necessary at 125KBPS for CAN2/3?
I've had a look at SAE J2284-1 for the 125 kbit timing, and it seems for
this speed, the esp-idf, the mcp_can lib and our current driver are
outside the spec.
SAE recommends a sync jump width of 3 for low (nq=8) and 4 for higher
resolutions, and single sampling at 62.5% (range 58.3…69.2%).
The esp-idf driver would use a SJW of 3 (would better be 4 as nq=20) and
single sampling at 80% (very late). The Arduino lib uses SJW=2 (too low)
and triple sampling at 75% (late).
Our current driver uses a SJW of 1 (much too low) and triple sampling at
56.25% (too early):
case CAN_SPEED_125KBPS:
cnf1=0x03; cnf2=0xf0; cnf3=0x86;
// BRP=3, PRSEG=1, PS1=7, PS2=7, SJW=1, BTLMODE=1, SAM=1, SOF=1,
WAKFIL=0 → Sample 3x at 9/16 = 56,25%
(Note: the current comment in the source is incorrect, the tq values
need each to be read as +1)
Possible SAE solutions for the MCP2515:
a)
// SAE J2284-1:
// BRP=3, PRSEG=3, PS1=6, PS2=6, SJW=4, BTLMODE=1, SAM=0, SOF=1,
WAKFIL=0 → Sample point at 10/16 = 62.5%
cnf1=0xc3; cnf2=0xaa; cnf3=0x85;
b)
// SAE J2284-1:
// BRP=3, PRSEG=3, PS1=7, PS2=5, SJW=4, BTLMODE=1, SAM=0, SOF=1,
WAKFIL=0 → Sample point at 11/16 = 68.8%
cnf1=0xc3; cnf2=0xb2; cnf3=0x84;
Please try.
Btw, if anyone would like to experiment: the Microchip timing calculator
needs to be set to 16 MHz (that's our MCP2515 clock), and you need to
add 0x80 to the cnf3 byte generated (that's the SOF flag, cannot be set
in the UI).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250126/0f7e27eb/attachment.sig>
