[Ovmsdev] New to OVMS development
    Info
    info at zeitnitz.eu
    Fri Jan 24 18:38:59 HKT 2025
Hi Michael and Mark,
thanks for your welcome.
Will contact Thomas wrt the Smart EQ features.
Concerning TCPIP: I had only a brief look at the options the 7670 offers
and to use the tcpip stack on the modem looks rather simple via
AT+NETOPEN. But I still need to see, what the implications are for the
rest of the OVMS firmware. Likely there are plenty of side effects ;-)
Best regards
   Christian
Am 24.01.2025 um 00:49 schrieb Mark Webb-Johnson via OvmsDev:
> Christian,
> Welcome aboard.
> Congratulations getting it working on the Lilygo. I like their
> products (particularly those with the little OLED displays).
> Regarding the cellular code, when you say TCP/IP (not PPP) do you mean
> that you are using the TCP/IP stack on the modem, and not the IP stack
> on the ESP32? Using AT+CIPSTART? That is how we used to do it in OVMS
> v2, but that was because the PIC processor had no IP stack and
> resources were very tight. I am not sure that nowadays that is the
> correct approach. What about protocols like mDNS, our web server, etc?
> All would have to treat Wifi differently to Cellular.
>> On 24 Jan 2025, at 3:44 AM, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Signed PGP part
>> Christian, welcome :-)
>> no idea if we need PPP for additional error detection, as we cannot
>> use hardware flow control between the ESP32 and the modem on the OVMS
>> board, or if direct TCP/IP would actually perform better due to less
>> packet overhead. Mark can better comment on this.
>> Nevertheless, the addition of support for the SIMCOM 7670 certainly
>> would be valuable, and support for a different hardware base is also
>> quite interesting.
>> Regarding additions to the Smart EQ adapter, please submit these as
>> separate pull requests -- I assume they can be merged right away
>> without taking your low level mods into account.
>> If not yet done, consider contacting the Smart maintainer Thomas
>> Heuer (@Dimitrie78 on github, also present here on the list) to
>> coordinate your efforts.
>> Am 23.01.25 um 12:29 schrieb Info Zeitnitz via OvmsDev:
>>> Hi everyone,
>>> my name is Christian and I started some time ago to adapt the OVMS
>>> firmware to my hardware.
>>> The hardware is a Lilygo T-Call A7670E V1.0 board (ESP32 Wrover-E,
>>> 4G modem Simcom 7670E, 4MB Flash, 8MB PSRAM) mounted on a custom PCB
>>> providing power, two CAN bus transceivers  and 1 MCP2515. No
>>> extension chip is implemented.
>>> I use this to connect to my Smart EQ, which actually needs only a
>>> single CAN bus.
>>> I got the firmware going, including the 4G modem and its running
>>> reasonably stable, even though the Lilygo board has only 4MB of
>>> Flash (had to disable OTA and some other components). It works with
>>> both server versions.
>>> This firmware is based on the Version 3.3-004 tagged in the Github
>>> repo. I had to modify the code to get it working without the
>>> extension and with the Simcom 7670 module. In addition I added some
>>> changes from the master branch, especially for the Smart EQ.
>>> I would be willing to share some of the mods I did to the code and
>>> contribute to the further development.
>>> Especially the cellular code, which is still utilizing PPP, could
>>> benefit from an update to TCP/IP. I actually had quite a hard time
>>> to get the modem going with PPP, since the Simcom 7670 does not
>>> understand all the used AT-commands.
>>> So, I hope for a productive collaboration.
>>> Best regards
>>> Christian
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250124/d8ba2f2a/attachment.htm>
