Thu Jan 23 00:24:41 HKT 2025
Chris,
typically "can can1 status" & "can can2 status" will give the statistics
of the buses, and "poller times on" will enable poller timing statistics
to be then shown by "poller times status".
The Leaf uses can2 to query these values:
// VIN [19]
// QC [2]
// L0/L1/L2 [2]
…but only when the car is on, but not in drive mode. So you should check
if you get these values.
It also uses can2 for TCU commands, if the model year is >= 2016.
So you should try commands and see if they work correctly.
Please also check the log for changes in can error occurence & frequency.
Am 22.01.25 um 14:58 schrieb Chris Box via OvmsDev:
> Thank you Derek and Michael.
> I'm running this firmware from today, and have driven the car 8 miles
> so far without issue.
> Happy to run any useful diagnostic commands. In case it helps, the
> poller reports this.
> |OVMS# poller times status |
> |Poller timing is: off |
> |Type | count | Utlztn | Time |
> | | per s | [‰] | [ms] |
> |Poll:PRI Avg| 0.99| 0.632| 0.065 |
> | Peak| | 0.733| 1.325 |
> | Total Avg| 0.99| 0.632| 0.653 |
> Chris
> On 2025-01-21 00:41, Derek Caudwell via OvmsDev wrote:
>> Hi Chris
>> Here are the required changes, as I understand them, to be compiled
>> into a new firmware from this thread:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1102/files
>> Cheers
>> Derek
>> On Tue, 21 Jan 2025 at 10:48, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Chris,
>> there is no prepared branch for these changes, as we still try to
>> determine the best (most compatible) configuration.
>> You need to apply the suggested changes manually to the current
>> master.
>> Am 20.01.25 um 19:56 schrieb Chris Box via OvmsDev:
>>> I'm happy to try some new code on my Leaf. Which code should I
>>> use? The current master, or a different branch? It wasn't clear
>>> to me from the thread below.
>>> Chris
>>> On 2025-01-19 19:47, Derek Caudwell via OvmsDev wrote:
>>> I can't recall testing a later version but I think Chris can
>>> confirm he was on a later version when his Leaf had a
>>> similar problem.
>>> The Leaf is now my wife's daily drive so I won't be able to
>>> take a look at making the suggested changes for a couple of
>>> weeks at least.
>>> On Mon, 20 Jan 2025, 8:31 am Michael Balzer via OvmsDev,
>>> Derek,
>>> Am 03.05.24 um 12:53 schrieb Derek Caudwell via OvmsDev:
>>> When running *firmware **3.3.004-74-gbd4e7196* on my
>>> Nissan Leaf I suspect (but can't be 100% sure as
>>> it's only been 24h without fault) the new poller
>>> caused the car to throw the attached faults from
>>> overloading the can bus whilst driving. The fault
>>> was sufficient to send the car into limp mode and
>>> could not be driven until cleared with LeafSpy.
>>> Build 3.3.004-74 (released 2024-04-30) did not yet
>>> include the poller tracing control, i.e. it did lots of
>>> logging for frames, significantly affecting overall
>>> performance.
>>> Poller tracing control was introduced in
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/7e4046042a99339d0212aac8f874cc8f780e634e
>>> on May 12.
>>> That commit was first included in build
>>> 3.3.004-103-g11fddbf6 released 2024-05-25. Do you
>>> remember testing that build or a later one?
>>> But as I still don't understand how a software queue
>>> overflow could cause a bus crash, I've also checked the
>>> 500 kbit timing for the MCP2515 and found that may have
>>> the same issue as the 125 kbit timing:
>>> Our timing is:
>>> case CAN_SPEED_500KBPS:
>>> cnf1=0x00; cnf2=0xf0; cnf3=0x86;
>>> = PROP=1, PS1=7, PS2=7, SJW=1, Sample 3x @56.3%
>>> Remember, the SAE/CiA recommendation is SJW=2, Sample 1x
>>> @87.5%. That would translate to:
>>> PROP=5, PS1=8, PS2=2, SJW=2, Sample 1x @87.5% =
>>> cnf1=0x40; cnf2=0xbc; cnf3=0x81;
>>> I also checked the Arduino MCP_CAN lib, and that uses:
>>> cnf1=0x40; cnf2=0xe5; cnf3=0x83;
>>> = PROP=6, PS1=5, PS2=4, SJW=2, Sample 3x @75%
>>> So our timing for 500 kbit/s on the MCP buses also isn't
>>> as recommended.
>>> Derek, could you test the SAE/CiA recommendation and the
>>> MCP_CAN config as shown? Or anyone else with a live
>>> can2/can3 bus at 500 kbit?
>>> If these work, the question is which is the more general
>>> setup we should adopt. Apparently the MCP_CAN lib also
>>> does not follow the CiA recommendation, I wonder if the
>>> MCP_CAN config is a compromise for compatibility.
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250122/f2faf45a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250122/f2faf45a/attachment-0001.sig>
